[GRASS-SVN] r72077 - in grass/trunk/vector/v.select: . testsuite
Mon Jan 15 06:29:09 PST 2018
Author: lucadelu
Date: 2018-01-15 06:29:09 -0800 (Mon, 15 Jan 2018)
New Revision: 72077
Added:
   grass/trunk/vector/v.select/testsuite/
   grass/trunk/vector/v.select/testsuite/test_v_select.py
v.select: added tests, thanks to Sunveer Singh during Google Code-in 2017
Added: grass/trunk/vector/v.select/testsuite/test_v_select.py
--- grass/trunk/vector/v.select/testsuite/test_v_select.py	                        (rev 0)
+++ grass/trunk/vector/v.select/testsuite/test_v_select.py	2018-01-15 14:29:09 UTC (rev 72077)
@@ -0,0 +1,66 @@
+Name:       v.select test
+Purpose:    Tests v.select and its flags/options.
+Author:     Sunveer Singh, Google Code-in 2017
+Copyright:  (C) 2017 by Sunveer Singh and the GRASS Development Team
+Licence:    This program is free software under the GNU General Public
+	            License (>=v2). Read the file COPYING that comes with GRASS
+	            for details.
+from grass.gunittest.case import TestCase
+class TestRasterreport(TestCase):
+    binput='bridges'
+    ainput='geology'
+    output='testvselect'
+    overlap="geonames_wake"
+    disjoint="schools_wake"
+    equals="streets_wake"
+    touches="zipcodes_wake"
+    within="geonames_wake"
+    @classmethod
+    def setUpClass(cls):
+        cls.use_temp_region()
+    @classmethod
+    def tearDownClass(cls):
+        cls.del_temp_region()
+    def tearDown(cls):
+        cls.runModule('g.remove', type='vector', flags='f', name=cls.output)
+    def test_opo(self):
+        """Testing operator overlap"""
+        self.assertModule('v.select', ainput=self.ainput, binput=self.binput, output=self.output, operator='overlap')
+        topology = dict(points=1088, lines=0, areas=0)
+	self.assertVectorFitsTopoInfo(self.overlap, topology)
+    def test_opd(self):
+        """Testign operator disjoint """
+        self.assertModule('v.select', ainput=self.ainput, binput=self.binput, output=self.output, operator='disjoint')
+        topology = dict(points=167, lines=0, areas=0)
+	self.assertVectorFitsTopoInfo(self.disjoint, topology)
+    def test_ope(self):
+        """Testing operator equals """
+        self.assertModule('v.select', ainput=self.ainput, binput=self.binput, output=self.output, operator='equals')
+        topology = dict(points=0, lines=49746, areas=0)
+	self.assertVectorFitsTopoInfo(self.equals, topology)
+    def test_opt(self):
+        """Testing operator touches"""
+        self.assertModule('v.select', ainput=self.ainput, binput=self.binput, output=self.output, operator='touches')
+        topology = dict(points=0, lines=0, areas=48)
+	self.assertVectorFitsTopoInfo(self.touches, topology)
+    def test_opw(self):
+        """Testing operator within"""
+        self.assertModule('v.select', ainput=self.ainput, binput=self.binput, output=self.output, operator='within')
+	self.assertVectorFitsTopoInfo(self.within, topology)
+if __name__ == '__main__':
+    from grass.gunittest.main import test
+    test()
