[GRASS-SVN] r72118 - grass/trunk/imagery/i.atcorr
    svn_grass at osgeo.org
    Wed Jan 24 06:05:46 PST 2018
Author: mmetz
Date: 2018-01-24 06:05:46 -0800 (Wed, 24 Jan 2018)
New Revision: 72118
   grass/trunk/imagery/i.atcorr/create_iwave.py
i.atcorr: improvements on create_iwave.py, with help from Stefan Blumentrath
Modified: grass/trunk/imagery/i.atcorr/create_iwave.py
--- grass/trunk/imagery/i.atcorr/create_iwave.py	2018-01-23 15:37:24 UTC (rev 72117)
+++ grass/trunk/imagery/i.atcorr/create_iwave.py	2018-01-24 14:05:46 UTC (rev 72118)
@@ -71,7 +71,7 @@
     # fix nodata or \n
     conv = {}
     for b in range(len(bands)):
-        conv[b+1] = lambda s: float(s or -99)
+        conv[b+1] = lambda s: float(s or 0)
     values = np.loadtxt(csvfile, delimiter=',', skiprows=1, converters = conv)
@@ -85,49 +85,62 @@
     and min, max wl values
     values must be numpy array with 2 columns
-    # These 2 lines select the subarray
-    # remove nodata (-99) lines in values array
-    # where response is nodata?
+    # removing nodata and invalid values
     w = values[:,1] >= 0
-    response = values[w]
+    values_clean = values[w]
-    wavelengths = response[:,0]  # 1st column of input array
-    spectral_response = response[:,1]  # 2nd column
-    assert len(wavelengths) == len(spectral_response), "Number of wavelength slots and spectral responses are not equal!"
+    wavelengths = values_clean[:,0]  # 1st column of input array
+    responses = values_clean[:,1]  # 2nd column
+    assert len(wavelengths) == len(responses), "Number of wavelength slots and spectral responses are not equal!"
-    # interpolating
-    f = interpolate.interp1d(wavelengths, spectral_response)
-    start = wavelengths[0]
+    # spectral responses are written out with .4f in pretty_print()
+    # anything smaller than 0.0001 will become 0.0000 -> discard with ...
+    rthresh = 0.0001
-    # considering last entry for np.arange
-    input_step = wavelengths[-1] - wavelengths[-2]
+    # i.atcorr not only expects steps of 2.5 nm, it also expects
+    # wavelentgh values to be exact multiples of 2.5 nm
+    # in the range 250 - 4000 nm
-    # if wavelength step in input data is 1 nm
-    # print "  > Wavelength step in input data is", input_step, "nm"
-    if input_step == 1:
-        addendum = 0
-        # print "    i No need to modify the stop value for the np.arrange function."
+    # find first response > rthresh
+    nvalues = len(responses)
+    start = 0
+    i = 0
+    while i < nvalues - 1 and responses[i] <= rthresh:
+	i += 1
+    start = wavelengths[i] - step
+    # align to multiple of step
+    nsteps = int(start / step)
+    start = step * nsteps
+    while start < wavelengths[0]:
+	start += step
-    # what if input step != 1 and input step != 2.5?
-    else:
-        addendum = step
-        # print "  ! Wavelength step in input data is nor 1 nm, neither 2.5 nm.",
-        # print "Internally setting the \"stop\" value for the np.arrange()",
-        # print "function so as to not exceed the end value", wavelengths[-1],
-        # print "of the open half ended range."
+    # find last response > rthresh
+    stop = 0
+    i = nvalues - 1
+    while i > 0 and responses[i] <= rthresh:
+	i -= 1
+    stop = wavelengths[i] + step
+    nsteps = np.ceil(stop / step)
+    stop = step * nsteps
+    while stop > wavelengths[nvalues - 1]:
+	stop -= step
-    stop = wavelengths[-1] + addendum
+    assert start < stop, "Empty spectral responses!"
+    # interpolating
+    f = interpolate.interp1d(wavelengths, responses)
     filter_f = f(np.arange(start, stop, step))
     # how many spectral responses?
     expected = np.ceil((stop - start) / step)
-    assert len(filter_f) == expected, "Number of interpolated spectral responses not equal to expected number of interpolations"
+    assert len(filter_f) == expected, "Number of interpolated spectral responses not equal to expected number of interpolations"
     # convert limits from nanometers to micrometers
-    lowerlimit = wavelengths[0]/1000
-    upperlimit = wavelengths[-1]/1000
+    lowerlimit = start/1000
+    upperlimit = stop/1000
     return(filter_f, (lowerlimit, upperlimit))
@@ -158,14 +171,18 @@
         if i%8 is 0:
             if i is not 0:
                 value_wo_leading_zero = ('%.4f' % (filter_f[i-1])).lstrip('0')
-                pstring += value_wo_leading_zero+', '
+                pstring += value_wo_leading_zero
+	    if i > 1 and i < len(filter_f):
+                pstring += ', '
             if i is not 1:
                 # trim the trailing whitespace at the end of line
                 pstring = pstring.rstrip()
-            pstring += "\n\t\t"
+            pstring += "\n        "
         else:
+	    if i < len(filter_f):
+		pstring += ', '
     # trim starting \n and trailing ,
     pstring = pstring.lstrip("\n").rstrip(", ")
     return pstring
@@ -177,10 +194,32 @@
     needs other functions: interpolate_bands, pretty_print
+    # keep in sync with IWave::parse()
+    rthresh = 0.01
+    print
+    print " > Response peaks from interpolation to 2.5 nm steps:"
     # getting necessary data
     # single or multiple bands?
     if len(bands) == 1:
         filter_f, limits = interpolate_band(values)
+	fi = filter_f
+	li = limits
+	# Get wavelength range for spectral response in band
+ 	maxresponse_idx = np.argmax(fi)
+ 	# Get minimum wavelength with spectral response
+ 	c = maxresponse_idx
+ 	while c > 0 and fi[c - 1] > rthresh:
+	    c = c - 1
+ 	min_wavelength = np.ceil(li[0] * 1000 + (2.5 * c))
+ 	# Get maximum wavelength with spectral response
+ 	while c < len(fi) - 1 and fi[c + 1] > rthresh:
+	    c = c + 1
+ 	max_wavelength = np.floor(li[0] * 1000 + (2.5 * c))
+ 	print "   %s (%i nm - %i nm)" % (bands[b], min_wavelength, max_wavelength)
     else:
         filter_f = []
         limits = []
@@ -188,6 +227,20 @@
             fi, li = interpolate_band(values[:,[0,b+1]])
             filter_f.append(fi)
             limits.append(li)
+		c = c - 1
+		c = c + 1
     # writing...
     outfile = open(os.path.join(folder, sensor+"_cpp_template.txt"), 'w')
@@ -228,8 +281,8 @@
         # writing band limits
-            inf = ", ".join(["%.3f" % i[0] for i in limits])
-            sup = ", ".join(["%.3f" % i[1] for i in limits])
+            inf = ", ".join(["%.4f" % i[0] for i in limits])
+            sup = ", ".join(["%.4f" % i[1] for i in limits])
         outfile.write('    static const float wli[%i] = {%s};\n' % (len(bands), inf))
         outfile.write('    static const float wls[%i] = {%s};\n' % (len(bands), sup))
@@ -266,9 +319,39 @@
     # getting data from file
     bands, values = read_input(inputfile)
+    # print spectral ranges from input file
+    # consider only wavelengths with a reasonably large response
+    # around the peak response, keep in sync with IWave::parse()
+    rthresh = 0.01
+    print
+    print " > Response peaks from input file:"
+    for b in range(1, len(bands) + 1):
+	lowl = 0
+	hiwl = 0
+	maxr = 0
+	maxi = 0
+	for i in range(len(values[:,0])):
+	    if maxr < values[i,b]:
+		maxr = values[i,b]
+		maxi = i
+	i = maxi
+	while i >= 0 and values[i,b] > rthresh:
+	    lowl = values[i,0]
+	    i -= 1
+	i = maxi
+	nvalues = len(values[:,0])
+	while i < nvalues and values[i,b] > rthresh:
+	    hiwl = values[i,0]
+	    i += 1
+	print "   %s (%i nm - %i nm)" % (bands[b - 1], lowl, hiwl)
     # writing file in same folder of input file
     write_cpp(bands, values, sensor, os.path.dirname(inputfile))
+    print
     print " > Filter functions exported to %s" % ("sensors_csv/"+sensor+"_cpp_template.txt")
     print " > Please check this file for possible errors before inserting the code into file iwave.cpp"
     print " > Don't forget to add the necessary data to the files iwave.h, geomcond.h, geomcond.cpp, and to i.atcorr.html"
