[GRASS-SVN] r72945 - grass/trunk/scripts/v.db.addtable
Tue Jul 3 08:10:19 PDT 2018
Author: mmetz
Date: 2018-07-03 08:10:19 -0700 (Tue, 03 Jul 2018)
New Revision: 72945
   grass/trunk/scripts/v.db.addtable/v.db.addtable.py
v.db.addtable: create unique index
Modified: grass/trunk/scripts/v.db.addtable/v.db.addtable.py
--- grass/trunk/scripts/v.db.addtable/v.db.addtable.py	2018-07-03 08:15:08 UTC (rev 72944)
+++ grass/trunk/scripts/v.db.addtable/v.db.addtable.py	2018-07-03 15:10:19 UTC (rev 72945)
@@ -136,6 +136,14 @@
         except CalledModuleError:
             grass.fatal(_("Unable to create table <%s>") % table)
+        if driver != "dbf":
+            sql = "CREATE UNIQUE INDEX IF NOT EXISTS %s_%s ON %s (%s)" % (table, key, table, key)
+            try:
+		grass.run_command('db.execute',
+				  database=database, driver=driver, sql=sql)
+	    except:
+		grass.warning(_("Unable to create index on table <%s>") % table)
     # connect the map to the DB:
     if schema:
         table = '{schema}.{table}'.format(schema=schema, table=table)
