[GRASS-SVN] r72781 - grass-addons/grass7/vector/v.class.mlR
Thu Jun 7 05:38:20 PDT 2018
Author: mlennert
Date: 2018-06-07 05:38:20 -0700 (Thu, 07 Jun 2018)
New Revision: 72781
   grass-addons/grass7/vector/v.class.mlR/v.class.mlR.html
v.class.mlR: add hint about R installation
Modified: grass-addons/grass7/vector/v.class.mlR/v.class.mlR.html
--- grass-addons/grass7/vector/v.class.mlR/v.class.mlR.html	2018-06-06 20:15:00 UTC (rev 72780)
+++ grass-addons/grass7/vector/v.class.mlR/v.class.mlR.html	2018-06-07 12:38:20 UTC (rev 72781)
@@ -102,10 +102,14 @@
 <h2>DEPENDENCIES</h2>
-<p>This module uses R. It tries to install necessary R packages automatically
-if necessary. These include : 'caret', 'kernlab', 'e1071', 'randomForest', and 'rpart'.
-Other packages can be necessary such as 'ggplot2', 'lattice' (for the plots),
-and 'doParallel' (if parallel processing is desired).
+<p>This module uses R. It is the user's responsibility to make sure R is
+installed and can be called from the environment this module is running in.
+See the relevant
+<a href="https://grasswiki.osgeo.org/wiki/R_statistics/Installation">wiki page</a>
+for more information. The module tries to install necessary R packages
+automatically if necessary. These include : 'caret', 'kernlab', 'e1071',
+'randomForest', and 'rpart'. Other packages can be necessary such as 'ggplot2',
+'lattice' (for the plots), and 'doParallel' (if parallel processing is desired).
 <h2>TODO</h2>
