[GRASS-SVN] r72317 - in grass/trunk/lib/python/pygrass: . raster raster/testsuite
Sat Mar 3 04:15:41 PST 2018
Author: marisn
Date: 2018-03-03 04:15:41 -0800 (Sat, 03 Mar 2018)
New Revision: 72317
   grass/trunk/lib/python/pygrass/errors.py
   grass/trunk/lib/python/pygrass/raster/__init__.py
   grass/trunk/lib/python/pygrass/raster/abstract.py
   grass/trunk/lib/python/pygrass/raster/buffer.py
   grass/trunk/lib/python/pygrass/raster/category.py
   grass/trunk/lib/python/pygrass/raster/history.py
   grass/trunk/lib/python/pygrass/raster/segment.py
   grass/trunk/lib/python/pygrass/raster/testsuite/test_category.py
   grass/trunk/lib/python/pygrass/raster/testsuite/test_doctests.py
   grass/trunk/lib/python/pygrass/raster/testsuite/test_history.py
   grass/trunk/lib/python/pygrass/raster/testsuite/test_numpy.py
   grass/trunk/lib/python/pygrass/raster/testsuite/test_raster.py
   grass/trunk/lib/python/pygrass/raster/testsuite/test_raster_img.py
   grass/trunk/lib/python/pygrass/raster/testsuite/test_raster_region.py
pygrass: raster PEP8 cleanup
Modified: grass/trunk/lib/python/pygrass/errors.py
--- grass/trunk/lib/python/pygrass/errors.py	2018-03-03 11:42:02 UTC (rev 72316)
+++ grass/trunk/lib/python/pygrass/errors.py	2018-03-03 12:15:41 UTC (rev 72317)
@@ -14,7 +14,8 @@
         if self.is_open():
             return method(self, *args, **kargs)
         else:
-            get_msgr().warning(_("The map is close!"))
+            msgr = get_msgr()
+            msgr.warning(_("The map is close!"))
     return wrapper
Modified: grass/trunk/lib/python/pygrass/raster/__init__.py
--- grass/trunk/lib/python/pygrass/raster/__init__.py	2018-03-03 11:42:02 UTC (rev 72316)
+++ grass/trunk/lib/python/pygrass/raster/__init__.py	2018-03-03 12:15:41 UTC (rev 72317)
@@ -1,7 +1,6 @@
 # -*- coding: utf-8 -*-
 from __future__ import (nested_scopes, generators, division, absolute_import,
                         with_statement, print_function, unicode_literals)
-import os
 import ctypes
 import numpy as np
@@ -8,8 +7,7 @@
 # import GRASS modules
-from grass.script import fatal, warning
-from grass.script import core as grasscore
+from grass.script import fatal
 import grass.lib.gis as libgis
 import grass.lib.raster as libraster
@@ -35,8 +33,9 @@
 WARN_OVERWRITE = "Raster map <{0}> already exists and will be overwritten"
-test_raster_name="Raster_test_map"
+test_raster_name = "Raster_test_map"
 class RasterRow(RasterAbstractBase):
     """Raster_row_access": Inherits: "Raster_abstract_base" and implements
     the default row access of the Rast library.
@@ -329,7 +328,7 @@
     def __setitem__(self, key, row):
         """Return the row of Raster object, slice allowed."""
         if isinstance(key, slice):
-            #Get the start, stop, and step from the slice
+            # Get the start, stop, and step from the slice
             return [self.put_row(ii, row)
                     for ii in range(*key.indices(len(self)))]
         elif isinstance(key, tuple):
@@ -546,7 +545,7 @@
                 self.hist.read()
                 if self.mode == "rw":
-                    #warning(_(WARN_OVERWRITE.format(self)))
+                    # warning(_(WARN_OVERWRITE.format(self)))
                     # Close the file descriptor and open it as new again
                     libraster.Rast_close(self._fd)
                     self._fd = libraster.Rast_open_new(
@@ -553,7 +552,7 @@
                         self.name, self._gtype)
             # Here we simply overwrite the existing map without content copying
             elif self.mode == "w":
                 self._gtype = RTYPE[self.mtype]['grass type']
                 self.segment.open(self)
                 self._fd = libraster.Rast_open_new(self.name, self._gtype)
@@ -678,7 +677,7 @@
         color_mode = 4
     if array is None:
-        array = np.ndarray((region.rows*region.cols*scale), np.uint8)
+        array = np.ndarray((region.rows * region.cols * scale), np.uint8)
     libraster.Rast_map_to_img_str(rastname, color_mode,
                                   array.ctypes.data_as(ctypes.POINTER(ctypes.c_uint8)))
@@ -709,16 +708,16 @@
 if __name__ == "__main__":
     import doctest
-    from grass.pygrass import utils
     from grass.pygrass.modules import Module
     Module("g.region", n=40, s=0, e=40, w=0, res=10)
-    Module("r.mapcalc", expression="%s = row() + (10 * col())"%(test_raster_name),
-                             overwrite=True)
+    Module("r.mapcalc",
+        expression="%s = row() + (10 * col())" % (test_raster_name),
+        overwrite=True)
     Module("r.support", map=test_raster_name,
-                        title="A test map",
-                        history="Generated by r.mapcalc",
-                        description="This is a test map")
-    cats="""11:A
+        title="A test map",
+        history="Generated by r.mapcalc",
+        description="This is a test map")
+    cats = """11:A
             12:B
             13:C
             14:D
Modified: grass/trunk/lib/python/pygrass/raster/abstract.py
--- grass/trunk/lib/python/pygrass/raster/abstract.py	2018-03-03 11:42:02 UTC (rev 72316)
+++ grass/trunk/lib/python/pygrass/raster/abstract.py	2018-03-03 12:15:41 UTC (rev 72317)
@@ -11,7 +11,7 @@
-from grass.script import fatal, error, gisenv
+from grass.script import fatal, gisenv
@@ -31,9 +31,9 @@
 from grass.pygrass.raster.category import Category
 from grass.pygrass.raster.history import History
-test_raster_name="abstract_test_map"
+test_raster_name = "abstract_test_map"
-## Define global variables to not exceed the 80 columns
+# Define global variables to not exceed the 80 columns
 INDXOUTRANGE = "The index (%d) is out of range, have you open the map?."
 INFO = """{name}@{mapset}
 rows: {rows}
@@ -225,17 +225,17 @@
         self.mapset = mapset
         self._name = name
-        ## Private attribute `_fd` that return the file descriptor of the map
+        # Private attribute `_fd` that return the file descriptor of the map
         self._fd = None
-        ## Private attribute `_rows` that return the number of rows
+        # Private attribute `_rows` that return the number of rows
         # in active window, When the class is instanced is empty and it is set
         # when you open the file, using Rast_window_rows()
         self._rows = None
-        ## Private attribute `_cols` that return the number of rows
+        # Private attribute `_cols` that return the number of rows
         # when you open the file, using Rast_window_cols()
         self._cols = None
-        #self.region = Region()
+        # self.region = Region()
         self.hist = History(self.name, self.mapset)
         self.cats = Category(self.name, self.mapset)
         self.info = Info(self.name, self.mapset)
@@ -259,7 +259,6 @@
     def _set_mtype(self, mtype):
         """Private method to change the Raster type"""
         if mtype.upper() not in ('CELL', 'FCELL', 'DCELL'):
-            #fatal(_("Raser type: {0} not supported".format(mtype) ) )
             str_err = "Raster type: {0} not supported ('CELL','FCELL','DCELL')"
             raise ValueError(_(str_err).format(mtype))
         self._mtype = mtype
@@ -327,8 +326,7 @@
     def __getitem__(self, key):
-            #import pdb; pdb.set_trace()
             return (self.get_row(ii) for ii in range(*key.indices(len(self))))
             x, y = key
@@ -556,11 +554,10 @@
     import doctest
-                             overwrite=True)
+    Module("r.mapcalc", expression="%s = row() + (10 * col())" % (test_raster_name),
+        overwrite=True)
     doctest.testmod()
Modified: grass/trunk/lib/python/pygrass/raster/buffer.py
--- grass/trunk/lib/python/pygrass/raster/buffer.py	2018-03-03 11:42:02 UTC (rev 72316)
+++ grass/trunk/lib/python/pygrass/raster/buffer.py	2018-03-03 12:15:41 UTC (rev 72317)
@@ -30,7 +30,6 @@
     def __new__(cls, shape, mtype='FCELL', buffer=None, offset=0,
                 strides=None, order=None):
         obj = np.ndarray.__new__(cls, shape, RTYPE[mtype]['numpy'],
                                  buffer, offset, strides, order)
         obj.pointer_type = ctypes.POINTER(RTYPE[mtype]['ctypes'])
Modified: grass/trunk/lib/python/pygrass/raster/category.py
--- grass/trunk/lib/python/pygrass/raster/category.py	2018-03-03 11:42:02 UTC (rev 72316)
+++ grass/trunk/lib/python/pygrass/raster/category.py	2018-03-03 12:15:41 UTC (rev 72317)
@@ -8,6 +8,7 @@
 from operator import itemgetter
+from grass.exceptions import ImplementationError
 from grass.pygrass.errors import GrassError
@@ -65,7 +66,6 @@
             raise ValueError(_("Raster type: {0} not supported".format(mtype)))
         self._mtype = mtype
@@ -270,8 +270,8 @@
         """Not implemented yet.
         void Rast_set_cats_fmt()
-        #TODO: add
-        pass
+        # TODO: add
+        raise ImplementationError("set_cats_fmt() is not implemented yet.")
     def read_rules(self, filename, sep=':'):
         """Copy categories from a rules file, default separetor is ':', the
@@ -300,7 +300,6 @@
                     label, min_cat, max_cat = cat
                 else:
                     raise TypeError("Row length is greater than 3")
                 self.append((label, min_cat, max_cat))
     def write_rules(self, filename, sep=':'):
Modified: grass/trunk/lib/python/pygrass/raster/history.py
--- grass/trunk/lib/python/pygrass/raster/history.py	2018-03-03 11:42:02 UTC (rev 72316)
+++ grass/trunk/lib/python/pygrass/raster/history.py	2018-03-03 12:15:41 UTC (rev 72317)
@@ -40,7 +40,7 @@
     def __eq__(self, hist):
         for attr in self.attrs:
-           if getattr(self, attr) != getattr(hist, attr):
+            if getattr(self, attr) != getattr(hist, attr):
                 return False
         return True
@@ -50,8 +50,8 @@
     def __iter__(self):
         return ((attr, getattr(self, attr)) for attr in self.attrs)
-    #libraster.HIST_CREATOR
+    # libraster.HIST_CREATOR
     def _get_creator(self):
         return libraster.Rast_get_history(self.c_hist,
                                           libraster.HIST_CREATOR)
@@ -64,8 +64,8 @@
     creator = property(fget=_get_creator, fset=_set_creator,
                        doc="Set or obtain the creator of map")
-    #libraster.HIST_DATSRC_1
+    # libraster.HIST_DATSRC_1
     def _get_src1(self):
                                           libraster.HIST_DATSRC_1)
@@ -78,8 +78,8 @@
     src1 = property(fget=_get_src1, fset=_set_src1,
                     doc="Set or obtain the first source of map")
-    #libraster.HIST_DATSRC_2
+    # libraster.HIST_DATSRC_2
     def _get_src2(self):
                                           libraster.HIST_DATSRC_2)
@@ -92,8 +92,8 @@
     src2 = property(fget=_get_src2, fset=_set_src2,
                     doc="Set or obtain the second source of map")
-    #libraster.HIST_KEYWORD
+    # libraster.HIST_KEYWORD
     def _get_keyword(self):
                                           libraster.HIST_KEYWRD)
@@ -106,8 +106,8 @@
     keyword = property(fget=_get_keyword, fset=_set_keyword,
                        doc="Set or obtain the keywords of map")
-    #libraster.HIST_MAPID
+    # libraster.HIST_MAPID
     def _get_date(self):
         date_str = libraster.Rast_get_history(self.c_hist,
                                               libraster.HIST_MAPID)
@@ -127,8 +127,8 @@
     date = property(fget=_get_date, fset=_set_date,
                     doc="Set or obtain the date of map")
-    #libraster.HIST_MAPSET
+    # libraster.HIST_MAPSET
     def _get_mapset(self):
                                           libraster.HIST_MAPSET)
@@ -141,8 +141,8 @@
     mapset = property(fget=_get_mapset, fset=_set_mapset,
                       doc="Set or obtain the mapset of map")
-    #libraster.HIST_MAPTYPE
+    # libraster.HIST_MAPTYPE
     def _get_maptype(self):
                                           libraster.HIST_MAPTYPE)
@@ -155,8 +155,8 @@
     maptype = property(fget=_get_maptype, fset=_set_maptype,
                        doc="Set or obtain the type of map")
-    #libraster.HIST_NUM_FIELDS
+    # libraster.HIST_NUM_FIELDS
     # Never used in any raster modules
@@ -170,8 +170,8 @@
     #                                          ctypes.c_char_p(num_fields))
     #    num_fields = property(fget = _get_num_fields, fset = _set_num_fields)
-    #libraster.HIST_TITLE
+    # libraster.HIST_TITLE
     def _get_title(self):
                                           libraster.HIST_TITLE)
Modified: grass/trunk/lib/python/pygrass/raster/segment.py
--- grass/trunk/lib/python/pygrass/raster/segment.py	2018-03-03 11:42:02 UTC (rev 72316)
+++ grass/trunk/lib/python/pygrass/raster/segment.py	2018-03-03 12:15:41 UTC (rev 72317)
@@ -47,7 +47,6 @@
         self.val = RTYPE[mapobj.mtype]['grass def']()
         size = ctypes.sizeof(RTYPE[mapobj.mtype]['ctypes'])
         file_name = libgis.G_tempfile()
         libseg.Segment_open(self.c_seg, file_name,
                             self.rows(), self.cols(),
                             self.srows, self.scols,
Modified: grass/trunk/lib/python/pygrass/raster/testsuite/test_category.py
--- grass/trunk/lib/python/pygrass/raster/testsuite/test_category.py	2018-03-03 11:42:02 UTC (rev 72316)
+++ grass/trunk/lib/python/pygrass/raster/testsuite/test_category.py	2018-03-03 12:15:41 UTC (rev 72317)
@@ -22,13 +22,14 @@
         """Create test raster map and region"""
         cls.use_temp_region()
         cls.runModule("g.region", n=40, s=0, e=40, w=0, res=10)
-        cls.runModule("r.mapcalc", expression="%s = row() + (10.0 * col())"%(cls.name),
-                                   overwrite=True)
+        cls.runModule("r.mapcalc",
+            expression="%s = row() + (10.0 * col())" % (cls.name),
+            overwrite=True)
         cls.runModule("r.support", map=cls.name,
-        cats="""11:A
+        cats = """11:A
                 12:B
                 13:C
                 14:D
@@ -46,12 +47,12 @@
                 44:P"""
         cls.runModule("r.category", rules="-", map=cls.name,
-                                 stdin_=cats, separator=":")
+            stdin_=cats, separator=":")
     @classmethod
     def tearDownClass(cls):
         """Remove the generated vector map, if exist"""
-        cls.runModule("g.remove", flags='f', type='raster',
+        cls.runModule("g.remove", flags='f', type='raster',
                       name=cls.name)
         cls.del_temp_region()
Modified: grass/trunk/lib/python/pygrass/raster/testsuite/test_doctests.py
--- grass/trunk/lib/python/pygrass/raster/testsuite/test_doctests.py	2018-03-03 11:42:02 UTC (rev 72316)
+++ grass/trunk/lib/python/pygrass/raster/testsuite/test_doctests.py	2018-03-03 12:15:41 UTC (rev 72317)
@@ -32,17 +32,16 @@
     grass.gunittest.utils.do_doctest_gettext_workaround()
     # this should be called at some top level
-    Module("r.mapcalc", expression="%s = row() + (10 * col())"%\
-                                   (pgrass.test_raster_name),
-                             overwrite=True)
+        expression="%s = row() + (10 * col())" % (pgrass.test_raster_name),
+        overwrite=True)
     Module("r.support", map=pgrass.test_raster_name,
-    cats="""11:A
+    cats = """11:A
             12:B
             13:C
             14:D
@@ -61,9 +60,9 @@
     Module("r.category", rules="-", map=pgrass.test_raster_name,
-                                   (pgrass.abstract.test_raster_name),
-                             overwrite=True)
+        expression="%s = row() + (10 * col())" % (pgrass.abstract.test_raster_name),
+        overwrite=True)
     tests.addTests(doctest.DocTestSuite(pgrass))
     tests.addTests(doctest.DocTestSuite(pgrass.abstract))
Modified: grass/trunk/lib/python/pygrass/raster/testsuite/test_history.py
--- grass/trunk/lib/python/pygrass/raster/testsuite/test_history.py	2018-03-03 11:42:02 UTC (rev 72316)
+++ grass/trunk/lib/python/pygrass/raster/testsuite/test_history.py	2018-03-03 12:15:41 UTC (rev 72317)
@@ -21,17 +21,18 @@
-        cls.runModule("r.mapcalc", expression="%s = row() + (10 * col())"%(cls.name),
-                                   overwrite=True)
+            expression="%s = row() + (10 * col())" % (cls.name),
+            overwrite=True)
     @classmethod
                       name=cls.name)
@@ -41,13 +42,13 @@
         hist = r.hist
         self.assertEqual(hist.title, "A test map")
-        self.assertEqual(hist.keyword,  "This is a test map")
+        self.assertEqual(hist.keyword, "This is a test map")
         hist1 = History(self.name)
         hist1.read()
         self.assertEqual(hist1.title, "A test map")
-        self.assertEqual(hist1.keyword,  "This is a test map")
+        self.assertEqual(hist1.keyword, "This is a test map")
         self.assertEqual(hist, hist1)
         self.assertEqual(hist.creator, hist1.creator)
@@ -65,7 +66,7 @@
         hist = r.hist
         self.assertEqual(hist.title, "No such title")
-        self.assertEqual(hist.keyword,  "No such description")
+        self.assertEqual(hist.keyword, "No such description")
         self.assertEqual(hist.creator, "Markus")
         self.assertEqual(hist.src1, "No such source 1")
Modified: grass/trunk/lib/python/pygrass/raster/testsuite/test_numpy.py
--- grass/trunk/lib/python/pygrass/raster/testsuite/test_numpy.py	2018-03-03 11:42:02 UTC (rev 72316)
+++ grass/trunk/lib/python/pygrass/raster/testsuite/test_numpy.py	2018-03-03 12:15:41 UTC (rev 72317)
@@ -29,8 +29,9 @@
         cls.runModule("g.region", n=40, s=0, e=60, w=0, res=1)
-        cls.runModule("r.mapcalc", expression="%s = float(row() + (10.0 * col()))"%(cls.name),
-                                   overwrite=True)
+            expression="%s = float(row() + (10.0 * col()))" % (cls.name),
+            overwrite=True)
         cls.numpy_obj = raster2numpy(cls.name)
     @classmethod
Modified: grass/trunk/lib/python/pygrass/raster/testsuite/test_raster.py
--- grass/trunk/lib/python/pygrass/raster/testsuite/test_raster.py	2018-03-03 11:42:02 UTC (rev 72316)
+++ grass/trunk/lib/python/pygrass/raster/testsuite/test_raster.py	2018-03-03 12:15:41 UTC (rev 72317)
@@ -2,7 +2,6 @@
 from grass.exceptions import OpenError
 from grass.gunittest.case import TestCase
 from grass.gunittest.main import test
-from unittest import skip
 from grass.pygrass.raster import RasterRow
@@ -17,7 +16,7 @@
         cls.runModule("r.mapcalc", expression="%s = row() + (10.0 * col())" % (cls.name),
-                                   overwrite=True)
+            overwrite=True)
     @classmethod
Modified: grass/trunk/lib/python/pygrass/raster/testsuite/test_raster_img.py
--- grass/trunk/lib/python/pygrass/raster/testsuite/test_raster_img.py	2018-03-03 11:42:02 UTC (rev 72316)
+++ grass/trunk/lib/python/pygrass/raster/testsuite/test_raster_img.py	2018-03-03 12:15:41 UTC (rev 72317)
@@ -1,25 +1,23 @@
 # -*- coding: utf-8
 import numpy as np
 import unittest
-import ctypes
-from grass.pygrass.raster import RasterRow
 from grass.pygrass.raster import raster2numpy_img
 from grass.pygrass.gis.region import Region
 from grass.script.core import tempfile
-has_PyQt4=False
+has_PyQt4 = False
 try:
     from PyQt4.QtCore import *
     from PyQt4.QtGui import *
-    has_PyQt4=True
+    has_PyQt4 = True
 except:
     pass
 class RasterRowImgTestCase(TestCase):
     name = "RasterRowImgTestCase_map"
@@ -29,8 +27,9 @@
         cls.runModule("g.region", n=60, s=0, e=40, w=0, res=0.1)
-        cls.runModule("r.mapcalc", expression="%s = if(row() >= 10 && row() <= 60, null(), row()  + (10.0 * col()))"%(cls.name),
-                                   overwrite=True)
+            expression="%s = if(row() >= 10 && row() <= 60, null(), row()  + (10.0 * col()))" % (cls.name),
+            overwrite=True)
         cls.runModule("r.colors", map=cls.name, color="elevation")
     @classmethod
@@ -56,7 +55,7 @@
         image = QImage(a.data, region.cols, region.rows,
                        QImage.Format_ARGB32)
-        #image.save("data/a.png")
+        # image.save("data/a.png")
         image.save(tmpfile)
         self.assertFilesEqualMd5(tmpfile, "data/a.png")
@@ -73,7 +72,7 @@
         tmpfile = tmpfile + ".png"
         # With array as argument
-        array = np.ndarray((region.rows*region.cols*4), np.uint8)
+        array = np.ndarray((region.rows * region.cols * 4), np.uint8)
         raster2numpy_img(rastname=self.name, region=region,
                          color="ARGB", array=array)
@@ -80,7 +79,7 @@
         image = QImage(array.data,
                        region.cols, region.rows, QImage.Format_ARGB32)
-        #image.save("data/b.png")
+        # image.save("data/b.png")
         image.save(tmpfile)
         self.assertFilesEqualMd5(tmpfile, "data/b.png")
@@ -97,7 +96,7 @@
@@ -104,7 +103,7 @@
-        #image.save("data/c.png")
+        # image.save("data/c.png")
         image.save(tmpfile)
         self.assertFilesEqualMd5(tmpfile, "data/c.png")
@@ -121,7 +120,7 @@
                          color="RGB", array=array)
@@ -128,7 +127,7 @@
                        region.cols, region.rows, QImage.Format_RGB32)
-        #image.save("data/d.png")
+        # image.save("data/d.png")
         image.save(tmpfile)
         self.assertFilesEqualMd5(tmpfile, "data/d.png")
@@ -149,7 +148,7 @@
-        #image.save("data/e.png")
+        # image.save("data/e.png")
         image.save(tmpfile)
         self.assertFilesEqualMd5(tmpfile, "data/e.png")
@@ -162,7 +161,7 @@
         a = raster2numpy_img(self.name, region)
-        self.assertEqual(len(a), region.rows * region.cols*4)
+        self.assertEqual(len(a), region.rows * region.cols * 4)
     def test_resampling_to_numpy_img_2(self):
@@ -173,7 +172,7 @@
     def test_resampling_to_numpy_img_3(self):
@@ -184,7 +183,7 @@
         a = raster2numpy_img(self.name, region, color="GRAY1")
-        self.assertEqual(len(a), region.rows * region.cols*1)
+        self.assertEqual(len(a), region.rows * region.cols * 1)
     def test_resampling_to_numpy_img_4(self):
@@ -195,7 +194,7 @@
         a = raster2numpy_img(self.name, region, color="GRAY2")
 if __name__ == '__main__':
     test()
Modified: grass/trunk/lib/python/pygrass/raster/testsuite/test_raster_region.py
--- grass/trunk/lib/python/pygrass/raster/testsuite/test_raster_region.py	2018-03-03 11:42:02 UTC (rev 72316)
+++ grass/trunk/lib/python/pygrass/raster/testsuite/test_raster_region.py	2018-03-03 12:15:41 UTC (rev 72317)
@@ -1,12 +1,12 @@
 # -*- coding: utf-8
 class RasterRowRegionTestCase(TestCase):
     name = "RasterRowRegionTestCase_map"
@@ -16,13 +16,13 @@
-                                   overwrite=True)
+        cls.runModule("r.mapcalc", expression="%s = row() + (10.0 * col())" % (cls.name),
+            overwrite=True)
     @classmethod
                       name=cls.name)
@@ -42,8 +42,8 @@
         rast.set_region(region)
         rast.open(mode='r')
-        self.assertItemsEqual(rast[0].tolist(), [22,22,22,22,22,32,32,32,32,32])
-        self.assertItemsEqual(rast[5].tolist(), [23,23,23,23,23,33,33,33,33,33])
+        self.assertItemsEqual(rast[0].tolist(), [22, 22, 22, 22, 22, 32, 32, 32, 32, 32])
+        self.assertItemsEqual(rast[5].tolist(), [23, 23, 23, 23, 23, 33, 33, 33, 33, 33])
         rast.close()
@@ -74,8 +74,8 @@
         [nan, nan, nan, nan, nan, nan, nan, nan]
-        self.assertItemsEqual(rast[2].tolist()[2:6], [11.,21.,31.,41.])
-        self.assertItemsEqual(rast[5].tolist()[2:6], [14.,24.,34.,44.])
+        self.assertItemsEqual(rast[2].tolist()[2:6], [11., 21., 31., 41.])
+        self.assertItemsEqual(rast[5].tolist()[2:6], [14., 24., 34., 44.])
         rast.close()
