[GRASS-SVN] r72354 - in grass-addons/grass7/imagery: . i.cutlines
Mon Mar 12 04:24:32 PDT 2018
Author: mlennert
Date: 2018-03-12 04:24:32 -0700 (Mon, 12 Mar 2018)
New Revision: 72354
Added:
   grass-addons/grass7/imagery/i.cutlines/
   grass-addons/grass7/imagery/i.cutlines/Makefile
   grass-addons/grass7/imagery/i.cutlines/i.cutlines.html
   grass-addons/grass7/imagery/i.cutlines/i.cutlines.py
   grass-addons/grass7/imagery/i.cutlines/i_cutlines_default.png
i.cutlines: new addon to create semantically meaningful irregular tile borders
Added: grass-addons/grass7/imagery/i.cutlines/Makefile
--- grass-addons/grass7/imagery/i.cutlines/Makefile	                        (rev 0)
+++ grass-addons/grass7/imagery/i.cutlines/Makefile	2018-03-12 11:24:32 UTC (rev 72354)
@@ -0,0 +1,7 @@
+MODULE_TOPDIR = ../..
+PGM = i.cutlines
+include $(MODULE_TOPDIR)/include/Make/Script.make
+default: script
Property changes on: grass-addons/grass7/imagery/i.cutlines/Makefile
___________________________________________________________________
Added: svn:mime-type
## -0,0 +1 ##
+text/x-makefile
\ No newline at end of property
Added: svn:eol-style
## -0,0 +1 ##
+native
Added: grass-addons/grass7/imagery/i.cutlines/i.cutlines.html
--- grass-addons/grass7/imagery/i.cutlines/i.cutlines.html	                        (rev 0)
+++ grass-addons/grass7/imagery/i.cutlines/i.cutlines.html	2018-03-12 11:24:32 UTC (rev 72354)
@@ -0,0 +1,86 @@
+<h2>DESCRIPTION</h2>
+<em>i.cutlines</em> tiles the images into tiles with irregular borders that
+avoid cutting through meaningful objects. This allows tiling an image for
+parallel processing while avoiding border effects.
+<p>
+The approach used in <em>i.cutlines</em> is inspired by Soares et al (2016).
+The module first uses an edge detection algorithm (which the user can chose
+with the <b>edge_detection</b> parameter) to identify edges in the image. It
+then uses <a href="r.cost.html">r.cost</a> and <a href="r.drain">r.drain</a> to
+draw lines through the image, following edges when possible and going straight
+when there are none.
+<p>
+The user can determine the number of lines desired (<b>number_lines</b>) in each
+direction and the relative weight given to edges compared to other pixels
+(<b>edge_weight</b>), weight of other pixels being 1. In order to avoid that all
+lines gather into one single lowest cost path, the module defines a lane for
+each desired line. The parameter <b>lane_border_resistance</b> defines the cost
+to cross that line, i.e. the lower the value, the more likely cutlines will join
+each other. Output can be in the form of raster or vector lines
+(<b>raster_lines</b> and <b>vector_lines</b> parameters) or in the form of
+vector polygon tiles (<b>vector_tiles</b>). For the latter, the user can decide
+a minimum size defined in map units (<b>min_tile_size</b>). Tiles smaller than
+that size will be merged with the neighboring tile they share the longest
+border with.
+<p>
+For edge detection the user can chose between the <a href="i.zc.html">i.zc</a>
+module or the <a href="i.edge.html">i.edge</a> addon. For the former, the user
+can determine the <b>zc_threshold</b> and the <b>zc_width</b> parameters. For
+the latter, the <b>canny_low_threshold</b>, <b>canny_high_threshold</b> and
+<b>canny_sigma</b> parameters. See the manual page of the respective modules
+for details about these parameters which might need tuning to fit to the
+specific image. As these modules read the entire image into RAM,
+<em>i.cutlines</em> allows the user to run split the image into rectangular
+tiles and to process each tile separately. Tiles can be defined with the
+<b>tile_width</b>, <b>tile_height</b> and <b>overlap</b> parameters. If
+<b>processes</b> is higher than one, these tiles will be processed in parallel
+as will the <a href="r.cost.html">r.cost</a> calls for the two directions.
+<p>
+The <b>memory</b> parameter determines the memory used both for the
+<a href="r.cost.html">r.cost</a> runs.
+<h2>NOTES</h2>
+There is currently a parameter name conflict between <a href="i.zc.html">i.zc
+</a> and the GridModule class in pygrass. Until this is resolved tiled edge
+detection is only possible with <a href="i.edge.html">i.edge</a>.
+<h2>EXAMPLE</h2>
+Using default <a href="i.zc.html">i.zc</a> edge detection without tiling,
+default parameters and 10 horizontal and 10 vertical cutlines, creating
+vector polygon output:
+<div class="code"><pre>
+g.region rast=ortho_2001_t792_1m
+i.cutlines ortho_2001_t792_1m number_lines=10 vector_tiles=ortho_tiles
+</pre></div>
+<center>
+	        <img src="i_cutlines_default.png" width="600" height="294" border="1"><br>
+		Irregular vector tiles created for the NC demo data set orthophoto
+</center>
+<h2>REFERENCES</h2>
+Soares, Anderson Reis, Thales Sehn Körting, and Leila Maria Garcia Fonseca. 2016. "Improvements of the Divide and Segment Method for Parallel Image Segmentation." Revista Brasileira de Cartografia 68 (6), http://www.lsie.unb.br/rbc/index.php/rbc/article/view/1602.
+<h2>SEE ALSO</h2>
+<a href="i.zc.html">i.zc</a>,
+<a href="i.edge.html">i.edge</a>,
+<a href="r.tile.html">r.tile</a>,
+<a href="v.mkgrid.html">v.mkgrid</a>,
+<a href="i.segment.html">i.segment</a>
+<h2>AUTHOR</h2>
+Moritz Lennert
+<p><i>Last changed: $Date$</i>
Property changes on: grass-addons/grass7/imagery/i.cutlines/i.cutlines.html
## -0,0 +1 ##
+text/html
Added: svn:keywords
## -0,0 +1 ##
+Author Date Id
## -0,0 +1 ##
+native
Added: grass-addons/grass7/imagery/i.cutlines/i.cutlines.py
--- grass-addons/grass7/imagery/i.cutlines/i.cutlines.py	                        (rev 0)
+++ grass-addons/grass7/imagery/i.cutlines/i.cutlines.py	2018-03-12 11:24:32 UTC (rev 72354)
@@ -0,0 +1,626 @@
+#!/usr/bin/env python
+# MODULE:	i.cutlines
+# AUTHOR(S):	Moritz Lennert, with help of Stefanos Georganos
+# PURPOSE:	Create tiles the borders of which do not cut across semantically
+#               meaningful objects
+# COPYRIGHT:	(C) 1997-2018 by the GRASS Development Team
+#		This program is free software under the GNU General Public
+#		License (>=v2). Read the file COPYING that comes with GRASS
+#		for details.
+#%Module
+#% description: Creates semantically meaningful tile borders
+#% keyword: imagery
+#% keyword: tiling
+#%end
+#%option G_OPT_R_INPUT
+#% description: Raster map to use as input for tiling
+#% required: yes
+#%end
+#%option
+#% key: number_lines
+#% type: integer
+#% description: Number of tile border lines in each direction
+#% required: yes
+#%end
+#%option
+#% key: edge_detection
+#% type: string
+#% description: Edge detection algorithm to use
+#% options: zc,canny
+#% answer: zc
+#% required: yes
+#%end
+#%option
+#% key: edge_weight
+#% type: integer
+#% description: Priority to give to edge pixels over other pixels
+#% required: yes
+#% answer: 5
+#%end
+#%option
+#% key: lane_border_resistance
+#% type: integer
+#% description: Friction of borders of lanes
+#% required: yes
+#% answer: 10000
+#%end
+#%option
+#% key: min_tile_size
+#% type: integer
+#% description: Minimum size of tiles in map units
+#% required: no
+#%end
+#%option G_OPT_V_OUTPUT
+#% key: vector_tiles
+#% label: Name for output vector map with tiles as polygons
+#% required: no
+#% guisection: Output
+#%end
+#% key: vector_lines
+#% label: Name for output vector map with tiles as lines
+#% required: no
+#%end
+#%option G_OPT_R_OUTPUT
+#% key: raster_lines
+#% label: Name for output raster map with tiles as lines
+#% required: no
+#%end
+#%option
+#% key: zc_threshold
+#% type: double
+#% label: Sensitivity of Gaussian filter (i.zc)
+#% answer: 1
+#% required: no
+#% guisection: Zero-crossing
+#%end
+#%option
+#% key: zc_width
+#% type: integer
+#% label: x-y extent of the Gaussian filter (i.zc)
+#% answer: 9
+#% required: no
+#%end
+#%option
+#% key: canny_low_threshold
+#% type: double
+#% label: Low treshold for edges (i.edge)
+#% answer: 3
+#% required: no
+#% guisection: Canny
+#%end
+#%option
+#% key: canny_high_threshold
+#% type: double
+#% label: High treshold for edges (i.edge)
+#% answer: 10
+#% required: no
+#%end
+#%option
+#% key: canny_sigma
+#% type: double
+#% label: Kernel radius (i.edge)
+#% answer: 2
+#% required: no
+#%end
+#%option
+#% key: tile_width
+#% type: integer
+#% description: Width of tiles for tiled edge detection (pixels)
+#% required: no
+#% guisection: Parallel processing
+#%end
+#%option
+#% key: tile_height
+#% type: integer
+#% description: Height of tiles for tiled edge detection (pixels)
+#% required: no
+#%end
+#%option
+#% key: overlap
+#% type: integer
+#% description: Overlap between tiles for tiled edge detection (pixels)
+#% required: no
+#% answer: 1
+#%end
+#%option
+#% key: processes
+#% type: integer
+#% description: Number of parallel processes
+#% answer: 1
+#% required: yes
+#%end
+#%option
+#% key: memory
+#% type: integer
+#% description: RAM memory available (in MB)
+#% answer: 300
+#% required: yes
+#% guisection: Options
+#%end
+#%rules
+#% collective: tile_width, tile_height, overlap
+#% required: vector_tiles, vector_lines, raster_lines
+#%end
+import os
+import atexit
+import grass.script as gscript
+from grass.pygrass.modules.grid.grid import GridModule
+from grass.pygrass.vector import VectorTopo
+from grass.pygrass.vector import geometry as geom
+def cleanup():
+    gscript.message(_("Erasing temporary files..."))
+    for temp_map, maptype in temp_maps:
+        if gscript.find_file(temp_map, element=maptype)['name']:
+            gscript.run_command('g.remove', flags='f', type=maptype,
+                              name=temp_map, quiet=True)
+def main():
+    inputraster = options['input']
+    number_lines = int(options['number_lines'])
+    edge_detection_algorithm = options['edge_detection']
+    edge_weight = int(options['edge_weight'])
+    lane_border_resistance = int(options['lane_border_resistance'])
+    min_tile_size = None
+    if options['min_tile_size']:
+        min_tile_size = float(options['min_tile_size'])
+    tiles = None
+    if options['vector_tiles']:
+        tiles = options['vector_tiles']
+    vector_lines = None
+    if options['vector_lines']:
+        vector_lines = options['vector_lines']
+    raster_lines = None
+    if options['raster_lines']:
+        raster_lines = options['raster_lines']
+    memory = int(options['memory'])
+    tiled = False
+    if options['tile_width']:
+        tiled = True
+        gscript.message(_("Using tiles processing for edge detection"))
+        width = int(options['tile_width'])
+        height = int(options['tile_height'])
+        overlap = int(options['overlap'])
+    processes = int(options['processes'])
+    global temp_maps
+    temp_maps = []
+    r = 'raster'
+    v = 'vector'
+    temp_edge_map = "temp_icutlines_edgemap_%d" % os.getpid()
+    temp_maps.append([temp_edge_map, r])
+    gscript.message(_("Creating edge map"))
+    if edge_detection_algorithm == 'zc':
+        kwargs = {'input' : inputraster,
+                  'output' : temp_edge_map,
+                  'width' : int(options['zc_width']),
+                  'threshold' : float(options['zc_threshold']),
+                  'quiet' : True}
+        if tiled:
+            message = "Currently there is a parameter name conflict between\n"
+            message += "i.zc and GridModule used for tiling.\n"
+            message += "Please use i.edge for edge detection if you want to\n"
+            message += "tile this part."
+            gscript.fatal(message)
+            grd = GridModule('i.zc',
+                             width=width,
+                             height=height,
+                             overlap=overlap,
+                             processes=processes,
+                             split=False,
+                             **kwargs)
+            grd.run()
+        else:
+            gscript.run_command('i.zc',
+                                **kwargs)
+    elif edge_detection_algorithm == 'canny':
+        if not gscript.find_program('i.edge', '--help'):
+                message = _("You need to install the addon i.edge to use ")
+                message += _("the Canny edge detector.\n")
+                message += _(" You can install the addon with 'g.extension i.edge'")
+                  'low_threshold' : float(options['canny_low_threshold']),
+                  'high_threshold' : float(options['canny_high_threshold']),
+                  'sigma' : float(options['canny_sigma']),
+                  'quiet' : True}
+        if tiled:
+            grd = GridModule('i.edge',
+                             width=width,
+                             height=height,
+                             overlap=overlap,
+                             split=False,
+                             **kwargs)
+            grd.run()
+        else:
+            gscript.run_command('i.edge',
+                                **kwargs)
+    else:
+        gscript.fatal("Only zero-crossing and Canny available as edge detection algorithms.")
+    region = gscript.region()
+    gscript.message(_("Finding cutlines in both directions"))
+    # Create the lines in horizonal direction
+    nsstep = float(region.n - region.s - region.nsres) / number_lines
+    hpointsy = [((region.n - i * nsstep) - region.nsres / 2.0) for i in range(0, number_lines+1)]
+    hlanepointsy = [y - nsstep / 2.0 for y in hpointsy]
+    hstartpoints = zip([region.w + 0.2 * region.ewres] * len(hpointsy), hpointsy)
+    hstoppoints = zip([region.e - 0.2 * region.ewres] * len(hpointsy), hpointsy)
+    hlanestartpoints = zip([region.w + 0.2 * region.ewres] * len(hlanepointsy),
+            hlanepointsy)
+    hlanestoppoints = zip([region.e - 0.2 * region.ewres] * len(hlanepointsy),
+            hlanepointsy)
+    hlanemap = 'temp_icutlines_hlanemap_%i' % os.getpid()
+    temp_maps.append([hlanemap, v])
+    temp_maps.append([hlanemap, r])
+    os.environ['GRASS_VERBOSE'] = '0'
+    new = VectorTopo(hlanemap)
+    new.open('w')
+    for line in zip(hlanestartpoints,hlanestoppoints):
+        new.write(geom.Line(line), cat=1)
+    new.close()
+    del os.environ['GRASS_VERBOSE']
+    gscript.run_command('v.to.rast',
+                        input_=hlanemap,
+                        output=hlanemap,
+                        use='val',
+                        type_='line',
+                        overwrite=True,
+                        quiet=True)
+    hbasemap = 'temp_icutlines_hbasemap_%i' % os.getpid()
+    temp_maps.append([hbasemap, r])
+    mapcalc_expression = "%s = " % hbasemap
+    mapcalc_expression += "if(isnull(%s), " % hlanemap
+    mapcalc_expression += "if(%s == 0, " % temp_edge_map
+    mapcalc_expression += "%i, 1), " % edge_weight
+    mapcalc_expression += "%i)" % lane_border_resistance
+    gscript.run_command('r.mapcalc',
+                        expression=mapcalc_expression,
+                        quiet=True,
+                        overwrite=True)
+    hcumcost = 'temp_icutlines_hcumcost_%i' % os.getpid()
+    temp_maps.append([hcumcost, r])
+    hdir = 'temp_icutlines_hdir_%i' % os.getpid()
+    temp_maps.append([hdir, r])
+    # Create the lines in vertical direction
+    ewstep = float(region.e - region.w - region.ewres) / number_lines
+    vpointsx = [((region.e - i * ewstep) - region.ewres / 2.0) for i in range(0, number_lines+1)]
+    vlanepointsx = [x + ewstep / 2.0 for x in vpointsx]
+    vstartpoints = zip(vpointsx, [region.n - 0.2 * region.nsres] * len(vpointsx))
+    vstoppoints = zip(vpointsx, [region.s + 0.2 * region.nsres] * len(vpointsx))
+    vlanestartpoints = zip(vlanepointsx, [region.n - 0.2 * region.nsres] *
+            len(vlanepointsx))
+    vlanestoppoints = zip(vlanepointsx, [region.s + 0.2 * region.nsres] * len(vlanepointsx))
+    vlanemap = 'temp_icutlines_vlanemap_%i' % os.getpid()
+    temp_maps.append([vlanemap, v])
+    temp_maps.append([vlanemap, r])
+    new = VectorTopo(vlanemap)
+    new.open('w')
+    for line in zip(vlanestartpoints,vlanestoppoints):
+    new.close()
+                        input_=vlanemap,
+                        output=vlanemap,
+                        use='val',
+                        type_='line',
+                        overwrite=True,
+                        quiet=True)
+    vbasemap = 'temp_icutlines_vbasemap_%i' % os.getpid()
+    temp_maps.append([vbasemap, r])
+    mapcalc_expression = "%s = " % vbasemap
+    mapcalc_expression += "if(isnull(%s), " % vlanemap
+                        quiet=True,
+                        overwrite=True)
+    vcumcost = 'temp_icutlines_vcumcost_%i' % os.getpid()
+    temp_maps.append([vcumcost, r])
+    vdir = 'temp_icutlines_vdir_%i' % os.getpid()
+    temp_maps.append([vdir, r])
+    if processes > 1:
+        pmemory = memory / 2.0
+        rcv = gscript.start_command('r.cost',
+                                    input_=vbasemap,
+                                    startcoordinates=vstartpoints,
+                                    stopcoordinates=vstoppoints,
+                                    output=vcumcost,
+                                    outdir=vdir,
+                                    memory=pmemory,
+                                    quiet=True,
+                                    overwrite=True)
+        rch = gscript.start_command('r.cost',
+                                    input_=hbasemap,
+                                    startcoordinates=hstartpoints,
+                                    stopcoordinates=hstoppoints,
+                                    output=hcumcost,
+                                    outdir=hdir,
+                                    memory=pmemory,
+                                    quiet=True,
+                                    overwrite=True)
+        rcv.wait()
+        rch.wait()
+    else:
+        gscript.run_command('r.cost',
+                            input_=vbasemap,
+                            output=vcumcost,
+                            outdir=vdir,
+                            memory=memory,
+                            quiet=True,
+                            overwrite=True)
+                            input_=hbasemap,
+                            output=hcumcost,
+                            outdir=hdir,
+                            memory=memory,
+                            quiet=True,
+                            overwrite=True)
+    hlines = 'temp_icutlines_hlines_%i' % os.getpid()
+    temp_maps.append([hlines, r])
+    vlines = 'temp_icutlines_vlines_%i' % os.getpid()
+    temp_maps.append([vlines, r])
+    if processes > 1:
+        rdh = gscript.start_command('r.drain',
+                                    input_=hcumcost,
+                                    direction=hdir,
+                                    startcoordinates=hstoppoints,
+                                    output=hlines,
+                                    flags='d',
+                                    quiet=True,
+                                    overwrite=True)
+        rdv = gscript.start_command('r.drain',
+                                    input_=vcumcost,
+                                    direction=vdir,
+                                    startcoordinates=vstoppoints,
+                                    output=vlines,
+                                    flags='d',
+                                    quiet=True,
+                                    overwrite=True)
+        rdh.wait()
+        rdv.wait()
+    else:
+        gscript.run_command('r.drain',
+                            input_=hcumcost,
+                            direction=hdir,
+                            output=hlines,
+                            flags='d',
+                            quiet=True,
+                            overwrite=True)
+                            input_=vcumcost,
+                            direction=vdir,
+                            output=vlines,
+                            flags='d',
+                            quiet=True,
+                            overwrite=True)
+    # Combine horizonal and vertical lines
+    temp_raster_tile_borders = 'temp_icutlines_raster_tile_borders_%i' % os.getpid()
+    temp_maps.append([temp_raster_tile_borders, r])
+    gscript.run_command('r.patch',
+                        input_=[hlines,vlines],
+                        output=temp_raster_tile_borders,
+                        quiet=True,
+                        overwrite=True)
+    if raster_lines:
+        gscript.run_command('g.copy',
+                            raster=[temp_raster_tile_borders,raster_lines],
+                            quiet=True,
+                            overwrite=True)
+    if vector_lines:
+        temp_vector_tile_borders = 'temp_icutlines_vector_tile_borders_%i' % os.getpid()
+        temp_maps.append([temp_vector_tile_borders, v])
+        gscript.run_command('r.to.vect',
+                            input_=temp_raster_tile_borders,
+                            output=temp_vector_tile_borders,
+                            type_='line',
+                            flags='t',
+                            quiet=True,
+                            overwrite=True)
+                            vector=[temp_vector_tile_borders,vector_lines],
+                            quiet=True,
+                            overwrite=True)
+    if tiles:
+        gscript.message(_("Creating vector polygons"))
+        # Create vector polygons
+        # First we need to shrink the region a bit to make sure that all vector
+        # points / lines fall within the raster
+        gscript.use_temp_region()
+        gscript.run_command('g.region',
+                            s=region.s+region.nsres,
+                            e=region.e-region.ewres,
+                            quiet=True)
+        region_map = 'temp_icutlines_region_map_%i' % os.getpid()
+        temp_maps.append([region_map, v])
+        temp_maps.append([region_map, r])
+        gscript.run_command('v.in.region',
+                            output=region_map,
+                            type_='line',
+                            quiet=True,
+                            overwrite=True)
+        gscript.del_temp_region()
+                            input_=region_map,
+                            use='val',
+                            type_='line',
+                            quiet=True,
+                            overwrite=True)
+        temp_raster_polygons = 'temp_icutlines_raster_polygons_%i' % os.getpid()
+        temp_maps.append([temp_raster_polygons, r])
+                            input_=[temp_raster_tile_borders,region_map],
+                            output=temp_raster_polygons,
+                            quiet=True,
+                            overwrite=True)
+        temp_raster_polygons_thin = 'temp_icutlines_raster_polygons_thin_%i' % os.getpid()
+        temp_maps.append([temp_raster_polygons_thin, r])
+        gscript.run_command('r.thin',
+                            input_=temp_raster_polygons,
+                            output=temp_raster_polygons_thin,
+                            quiet=True,
+                            overwrite=True)
+        # Create a series of temporary map names as we have to go
+        # through several steps until we reach the final map.
+        temp_vector_polygons1 = 'temp_icutlines_vector_polygons1_%i' % os.getpid()
+        temp_maps.append([temp_vector_polygons1, v])
+        temp_vector_polygons2 = 'temp_icutlines_vector_polygons2_%i' % os.getpid()
+        temp_maps.append([temp_vector_polygons2, v])
+        temp_vector_polygons3 = 'temp_icutlines_vector_polygons3_%i' % os.getpid()
+        temp_maps.append([temp_vector_polygons3, v])
+        temp_vector_polygons4 = 'temp_icutlines_vector_polygons4_%i' % os.getpid()
+        temp_maps.append([temp_vector_polygons4, v])
+                            input_=temp_raster_polygons_thin,
+                            output=temp_vector_polygons1,
+                            type_='line',
+                            flags='t',
+                            quiet=True,
+                            overwrite=True)
+        # Erase all category values from the lines
+        gscript.run_command('v.category',
+                            input_=temp_vector_polygons1,
+                            op='del',
+                            cat='-1',
+                            output=temp_vector_polygons2,
+                            quiet=True,
+                            overwrite=True)
+        # Transform lines to boundaries
+        gscript.run_command('v.type',
+                            input_=temp_vector_polygons2,
+                            from_type='line',
+                            to_type='boundary',
+                            output=temp_vector_polygons3,
+                            quiet=True,
+                            overwrite=True)
+        # Add centroids
+        gscript.run_command('v.centroids',
+                            input_=temp_vector_polygons3,
+                            output=temp_vector_polygons4,
+                            quiet=True,
+                            overwrite=True)
+        # If a threshold is given erase polygons that are too small
+        if min_tile_size:
+            gscript.run_command('v.clean',
+                                input_=temp_vector_polygons4,
+                                tool='rmarea',
+                                threshold=min_tile_size,
+                                output=tiles,
+                                quiet=True,
+                                overwrite=True)
+        else:
+                                vect=[temp_vector_polygons4,tiles],
+                                quiet=True,
+                                overwrite=True)
+if __name__ == "__main__":
+    options, flags = gscript.parser()
+    atexit.register(cleanup)
+    main()
Property changes on: grass-addons/grass7/imagery/i.cutlines/i.cutlines.py
Added: svn:executable
## -0,0 +1 ##
## -0,0 +1 ##
+text/x-python
## -0,0 +1 ##
+native
Added: grass-addons/grass7/imagery/i.cutlines/i_cutlines_default.png
(Binary files differ)
Index: grass-addons/grass7/imagery/i.cutlines/i_cutlines_default.png
--- grass-addons/grass7/imagery/i.cutlines/i_cutlines_default.png	2018-03-12 08:47:35 UTC (rev 72353)
+++ grass-addons/grass7/imagery/i.cutlines/i_cutlines_default.png	2018-03-12 11:24:32 UTC (rev 72354)
Property changes on: grass-addons/grass7/imagery/i.cutlines/i_cutlines_default.png
## -0,0 +1 ##
+image/png
