[GRASS-SVN] r72398 - grass/branches/releasebranch_7_4/vector/v.select
Mon Mar 19 14:57:46 PDT 2018
Author: neteler
Date: 2018-03-19 14:57:45 -0700 (Mon, 19 Mar 2018)
New Revision: 72398
   grass/branches/releasebranch_7_4/vector/v.select/v.select.html
v.select: make it clear that 'overlap' is 'intersects' in GEOS, not 'overlaps'
Modified: grass/branches/releasebranch_7_4/vector/v.select/v.select.html
--- grass/branches/releasebranch_7_4/vector/v.select/v.select.html	2018-03-19 21:00:28 UTC (rev 72397)
+++ grass/branches/releasebranch_7_4/vector/v.select/v.select.html	2018-03-19 21:57:45 UTC (rev 72398)
@@ -5,7 +5,7 @@
 <p>Supported operators (without GEOS; using GRASS' own algorithm):
 <ul>
-  <li><b>overlap</b> - features partially or completely overlap
+  <li><b>overlap</b> - features partially or completely overlap (GEOS equivalent: intersects)
 </ul>
 Supported operators (internally using
@@ -13,7 +13,7 @@
 <ul>
   <li><b>equals</b> - features are spatially equals</li>
   <li><b>disjoint</b> - features do not spatially intersect</li>
-  <li><b>intersects</b> - features spatially intersect</li>
+  <li><b>intersects</b> - features spatially intersect (equivalent to native 'overlap')</li>
   <li><b>touches</b> - features spatially touches</li>
   <li><b>crosses</b> - features spatially crosses</li>
   <li><b>within</b> - feature A is completely inside feature B</li>
