[GRASS-SVN] r72407 - in grass-addons/grass7/imagery/i.sentinel: i.sentinel.download i.sentinel.import
Tue Mar 20 04:52:22 PDT 2018
Author: martinl
Date: 2018-03-20 04:52:22 -0700 (Tue, 20 Mar 2018)
New Revision: 72407
Added:
   grass-addons/grass7/imagery/i.sentinel/i.sentinel.download/i.sentinel.download.html
   grass-addons/grass7/imagery/i.sentinel/i.sentinel.download/i.sentinel.download.py
   grass-addons/grass7/imagery/i.sentinel/i.sentinel.import/i.sentinel.import.html
   grass-addons/grass7/imagery/i.sentinel/i.sentinel.import/i.sentinel.import.py
   grass-addons/grass7/imagery/i.sentinel/i.sentinel.import/v_sentinel_import_band_4_clouds.png
Removed:
   grass-addons/grass7/imagery/i.sentinel/i.sentinel.download/r.sentinel.download.html
   grass-addons/grass7/imagery/i.sentinel/i.sentinel.download/r.sentinel.download.py
   grass-addons/grass7/imagery/i.sentinel/i.sentinel.import/r.sentinel.import.html
   grass-addons/grass7/imagery/i.sentinel/i.sentinel.import/r.sentinel.import.py
   grass-addons/grass7/imagery/i.sentinel/i.sentinel.import/r_sentinel_import_band_4_clouds.png
   grass-addons/grass7/imagery/i.sentinel/i.sentinel.download/Makefile
   grass-addons/grass7/imagery/i.sentinel/i.sentinel.import/Makefile
rename r.sentinel -> i.sentinel (done), see #3522
Modified: grass-addons/grass7/imagery/i.sentinel/i.sentinel.download/Makefile
--- grass-addons/grass7/imagery/i.sentinel/i.sentinel.download/Makefile	2018-03-20 11:48:26 UTC (rev 72406)
+++ grass-addons/grass7/imagery/i.sentinel/i.sentinel.download/Makefile	2018-03-20 11:52:22 UTC (rev 72407)
@@ -1,6 +1,6 @@
 MODULE_TOPDIR = ../..
-PGM = r.sentinel.download
+PGM = i.sentinel.download
 include $(MODULE_TOPDIR)/include/Make/Script.make
Copied: grass-addons/grass7/imagery/i.sentinel/i.sentinel.download/i.sentinel.download.html (from rev 72406, grass-addons/grass7/imagery/i.sentinel/i.sentinel.download/r.sentinel.download.html)
--- grass-addons/grass7/imagery/i.sentinel/i.sentinel.download/i.sentinel.download.html	                        (rev 0)
+++ grass-addons/grass7/imagery/i.sentinel/i.sentinel.download/i.sentinel.download.html	2018-03-20 11:52:22 UTC (rev 72407)
@@ -0,0 +1,141 @@
+<em>i.sentinel.download</em> allows downloading Sentinel products
+from <a href="https://scihub.copernicus.eu/">Copernicus Open Access
+Hub</a>.
+<p>
+To connect Copernicus Open Access Hub a <em>user</em>
+and <em>password</em> are required,
+see <a href="https://scihub.copernicus.eu/dhus/#/self-registration">Register
+new account</a> page for signing up.
+<p><em>i.sentinel.download</em> reads user credentials
+from <b>settings</b> file. The file must contain at least two lines:
+<div class="code"><pre>
+myusername
+mypassword
+</pre></div>
+Optionally on third line custom API URL can be defined. Note that
+empty lines in settings file are silently skipped.
+<h2>NOTES</h2>
+<p>User credentials can be also defined interactively
+when <b>settings=-</b> is given. Note that interactive prompt does not
+work in GUI.
+Insert username: myusername
+Insert password:
+Insert API URL (leave empty for https://scihub.copernicus.eu/dhus):
+</pre></div>
+<p>
+By default Sentinel products are sorted by <i>cloudcoverpercentage</i>
+and <i>ingestiondate</i> (see <b>sort</b> option). By default,
+only products which footprint intersects current computation region
+extent (area of interest, AOI) are filtered. The AOI can be optionally
+defined also by vector <b>map</b>. In addition the spatial relation
+between AOI and the footprint (<b>area_relation</b>) can be set to
+<ul>
+<li><i>Contains</i>: to only return scenes where the AOI is contained
+inside the footprint</li>
+<li><i>IsWithin</i>: to only return scenes where the footprint is
+contained inside the AOI</li>
+<li><i>Intersects</i>: to return all scenes where the footprint
+intersects the AOI (default)</li>
+</ul>
+Filtered products can be reduced by <b>limit</b> option.
+<p>
+Module searches for products in last 60 days, exact date range can be
+defined by <b>start</b> and <b>end</b> options.
+<p>
+Sentinel products can be also filtered by <b>producttype</b> or
+maximum <b>clouds</b> cover percentage.
+<h2>EXAMPLES</h2>
+<h3>List filtered products</h3>
+<p>
+Find S2MSI1C products in last 60 days covering current computation region extent.
+i.sentinel.download -l settings=sentinel.txt
+1 Sentinel product(s) found
+ae1c33ec-aa33-4303-a525-9e6481709614 2017-12-08T10:23:59Z 18% S2MSI1C
+</pre></div>
+Find all S2MSI2Ap products in 2017.
+i.sentinel.download -l settings=sentinel.txt producttype=S2MSI2Ap start=2017-01-01 end=2017-12-31
+7 Sentinel product(s) found
+e5df8b4f-a4c6-47bd-88f3-e16b7540cc7a 2017-05-27T10:20:31Z  2% S2MSI2Ap
+b62afeda-a28d-475c-8220-91e24fc368ff 2017-05-17T10:20:31Z  2% S2MSI2Ap
+9a6bc289-98e9-4489-84eb-1aac95aaa056 2017-08-15T10:20:21Z  3% S2MSI2Ap
+35c72002-78a0-45f8-b39d-66c2d7b4ad87 2017-10-14T10:20:21Z  6% S2MSI2Ap
+c0ae8085-c1bb-4a27-89f2-2138a0866586 2017-07-06T10:20:21Z 12% S2MSI2Ap
+433ebfbc-5144-42f8-97dc-b9f4f1eb7b5a 2017-11-03T10:22:01Z 12% S2MSI2Ap
+fc56a594-d9d8-4e93-8dec-af3a58b24080 2017-09-04T10:20:21Z 19% S2MSI2Ap
+</pre></div>
+Sort products by <b>ingestiondate</b>, limit cloud coverage to 5% per scene.
+i.sentinel.download -l settings=sentinel.txt producttype=S2MSI2Ap start=2017-01-01 end=2017-12-31 sort=ingestiondate order=desc clouds=5
+3 Sentinel product(s) found
+</pre></div>
+Create vector map with <b>footprints</b>.
+i.sentinel.download -l settings=sentinel.txt producttype=S2MSI2Ap start=2017-01-01 end=2017-12-31 footprints=ft
+</pre></div>
+<h3>Download Sentinel products</h3>
+Download first (<b>limit=1</b>) found S2MSI2Ap product into <i>data</i> directory.
+i.sentinel.download settings=sentinel.txt producttype=S2MSI2Ap start=2017-01-01 end=2017-12-31 limit=1 output=data
+</pre></div>
+Such downloaded data can be easily imported into GRASS
+using <em><a href="i.sentinel.import.html">i.sentinel.import</a></em>
+module.
+<h2>REQUIREMENTS</h2>
+<ul>
+  <li><a href="https://pypi.python.org/pypi/sentinelsat">Sentinelsat library</a></li>
+  <li><a href="https://pypi.python.org/pypi/pandas">Pandas library</a></li>
+</ul>
+<h2>SEE ALSO</h2>
+<em>
+<a href="i.sentinel.import.html">i.sentinel.import</a>,
+<a href="v.import.html">v.import</a>
+</em>
+<p>
+See
+also <a href="http://training.gismentors.eu/grass-gis-workshop-jena-2018/units/20.html">GRASS
+GIS Workshop in Jena</a> for usage examples.
+<h2>AUTHOR</h2>
+Martin
+Landa, <a href="http://geomatics.fsv.cvut.cz/research/geoforall/">GeoForAll
+Lab</a>, CTU in Prague, Czech Republic with support
+of <a href="http://opengeolabs.cz/en/home/">OpenGeoLabs</a> company
Copied: grass-addons/grass7/imagery/i.sentinel/i.sentinel.download/i.sentinel.download.py (from rev 72406, grass-addons/grass7/imagery/i.sentinel/i.sentinel.download/r.sentinel.download.py)
--- grass-addons/grass7/imagery/i.sentinel/i.sentinel.download/i.sentinel.download.py	                        (rev 0)
+++ grass-addons/grass7/imagery/i.sentinel/i.sentinel.download/i.sentinel.download.py	2018-03-20 11:52:22 UTC (rev 72407)
@@ -0,0 +1,341 @@
+#!/usr/bin/env python
+# MODULE:      i.sentinel.download
+# AUTHOR(S):   Martin Landa
+# PURPOSE:     Downloads Sentinel data from Copernicus Open Access Hub
+#              using sentinelsat library.
+# COPYRIGHT:   (C) 2018 by Martin Landa, and the GRASS development team
+#              This program is free software under the GNU General Public
+#              License (>=v2). Read the file COPYING that comes with GRASS
+#              for details.
+#%module
+#% description: Downloads Sentinel data from Copernicus Open Access Hub using sentinelsat library.
+#% keyword: raster
+#% keyword: imagery
+#% keyword: sentinel
+#% keyword: download
+#%end
+#%option G_OPT_F_INPUT
+#% key: settings
+#% label: Full path to settings file (user, password)
+#% description: '-' for standard input
+#%end
+#%option G_OPT_M_DIR
+#% key: output
+#% description: Name for output directory where to store downloaded Sentinel data
+#% required: no
+#% guisection: Output
+#%end
+#%option G_OPT_V_OUTPUT
+#% key: footprints
+#% description: Name for output vector map with footprints
+#% required: no
+#%end
+#%option G_OPT_V_MAP
+#% label: Name of input vector map to define Area of Interest (AOI)
+#% description: If not given than current computational extent is used
+#% required: no
+#% guisection: Region
+#%end
+#%option
+#% key: area_relation
+#% type: string
+#% description: Spatial reation of footprint to AOI
+#% options: Intersects,Contains,IsWithin
+#% answer: Intersects
+#% required: no
+#%end
+#%option
+#% key: clouds
+#% type: integer
+#% description: Maximum cloud cover percentage for Sentinel scene
+#% answer: 30
+#% required: no
+#% guisection: Filter
+#%end
+#%option
+#% key: producttype
+#% type: string
+#% description: Sentinel product type to filter
+#% required: no
+#% options: SLC,GRD,OCN,S2MSI1C,S2MSI2Ap
+#% answer: S2MSI1C
+#%end
+#%option
+#% key: start
+#% type: string
+#% description: Start date ('YYYY-MM-DD')
+#%end
+#%option
+#% key: end
+#% type: string
+#% description: End date ('YYYY-MM-DD')
+#%end
+#%option
+#% key: limit
+#% type: integer
+#% description: Limit number of Sentinel products
+#%end
+#%option
+#% key: sort
+#% description: Sort by values in given order
+#% multiple: yes
+#% options: ingestiondate,cloudcoverpercentage,footprint
+#% answer: cloudcoverpercentage,ingestiondate,footprint
+#% guisection: Sort
+#%end
+#%option
+#% key: order
+#% description: Sort order (see sort parameter)
+#% options: asc,desc
+#% answer: asc
+#%end
+#%flag
+#% key: l
+#% description: List filtered products and exist
+#% guisection: Print
+#%end
+#%rules
+#% required: output,-l
+#%end
+import os
+import sys
+import logging
+import zipfile
+from collections import OrderedDict
+import grass.script as gs
+def get_aoi_box(vector=None):
+    args = {}
+    if vector:
+        args['vector'] = vector
+    info = gs.parse_command('g.region', flags='uplg', **args)
+    return 'POLYGON(({nw_lon} {nw_lat}, {ne_lon} {ne_lat}, {se_lon} {se_lat}, {sw_lon} {sw_lat}, {nw_lon} {nw_lat}))'.format(
+        nw_lat=info['nw_lat'], nw_lon=info['nw_long'], ne_lat=info['ne_lat'], ne_lon=info['ne_long'],
+        sw_lat=info['sw_lat'], sw_lon=info['sw_long'], se_lat=info['se_lat'], se_lon=info['se_long']
+class SentinelDownloader(object):
+    def __init__(self, user, password, api_url='https://scihub.copernicus.eu/dhus'):
+        try:
+            from sentinelsat import SentinelAPI
+        except ImportError as e:
+            gs.fatal(_("Module requires sentinelsat library: {}").format(e))
+        try:
+            import pandas
+            gs.fatal(_("Module requires pandas library: {}").format(e))
+        # init logger
+        root = logging.getLogger()
+        root.addHandler(logging.StreamHandler(
+            sys.stderr
+        # connect SciHub via API
+        self._api = SentinelAPI(user, password,
+                                api_url=api_url
+        self._products_df_sorted = None
+    def filter(self, area, area_relation,
+               clouds=None, producttype=None, limit=None,
+               start=None, end=None, sortby=[], asc=True):
+        args = {}
+        if clouds:
+            args['cloudcoverpercentage'] = (0, clouds)
+        if producttype:
+            args['producttype'] = producttype
+        if not start:
+            start = 'NOW-60DAYS'
+        else:
+            start = start.replace('-', '')
+        if not end:
+            end = 'NOW'
+        else:
+            end = end.replace('-', '')
+        products = self._api.query(
+            area=area, area_relation=area_relation,
+            platformname='Sentinel-2',
+            date=(start, end),
+            **args
+        products_df = self._api.to_dataframe(products)
+        if len(products_df) < 1:
+            gs.message(_('No product found'))
+            return
+        # sort and limit to first sorted product
+        if sortby:
+            self._products_df_sorted = products_df.sort_values(
+                sortby,
+                ascending=[asc] * len(sortby)
+        if limit:
+            self._products_df_sorted = self._products_df_sorted.head(int(limit))
+        gs.message(_('{} Sentinel product(s) found').format(len(self._products_df_sorted)))
+    def list(self):
+        if self._products_df_sorted is None:
+            return
+        for idx in range(len(self._products_df_sorted)):
+            print ('{0} {1} {2:2.0f}% {3}'.format(
+                self._products_df_sorted['uuid'][idx],
+                self._products_df_sorted['beginposition'][idx].strftime("%Y-%m-%dT%H:%M:%SZ"),
+                self._products_df_sorted['cloudcoverpercentage'][idx],
+                self._products_df_sorted['producttype'][idx],
+    def download(self, output):
+            return
+        if not os.path.exists(output):
+            os.makedirs(output)
+        gs.message(_('Downloading data into <{}>...').format(output))
+            gs.message('{} -> {}.SAFE'.format(
+                os.path.join(output, self._products_df_sorted['identifier'][idx])
+            # download
+            self._api.download(self._products_df_sorted['uuid'][idx], output)
+            # unzip
+            if os.path.exists(os.path.join(output, self._products_df_sorted['identifier'][idx])):
+                continue
+            filename = self._products_df_sorted['identifier'][idx] + '.zip'
+            with zipfile.ZipFile(os.path.join(output, filename), 'r') as zip_ref:
+                zip_ref.extractall(output)
+    def save_footprints(self, map_name):
+            return
+        try:
+            from osgeo import ogr, osr
+            gs.fatal(_("Option <footprints> requires GDAL library: {}").format(e))
+        gs.message(_("Writing footprints into <{}>...").format(map_name))
+        driver = ogr.GetDriverByName("GPKG")
+        tmp_name = gs.tempfile() + '.gpkg'
+        data_source = driver.CreateDataSource(tmp_name)
+        srs = osr.SpatialReference()
+        srs.ImportFromEPSG(4326)
+        layer = data_source.CreateLayer(str(map_name), srs, ogr.wkbPolygon)
+        # attributes
+        attrs = OrderedDict([
+            ("uuid", ogr.OFTString),
+            ("ingestiondate", ogr.OFTString),
+            ("cloudcoverpercentage", ogr.OFTInteger),
+            ("producttype", ogr.OFTString)
+        for key in attrs.keys():
+            field = ogr.FieldDefn(key, attrs[key])
+            layer.CreateField(field)
+        # features
+            wkt = self._products_df_sorted['footprint'][idx]
+            feature = ogr.Feature(layer.GetLayerDefn())
+            feature.SetGeometry(ogr.CreateGeometryFromWkt(wkt))
+                if key == 'ingestiondate':
+                    value = self._products_df_sorted[key][idx].strftime("%Y-%m-%dT%H:%M:%SZ")
+                else:
+                feature.SetField(key, value)
+            layer.CreateFeature(feature)
+            feature = None
+        data_source = None
+        gs.run_command('v.import', input=tmp_name, output=map_name,
+                       layer=map_name, quiet=True
+def main():
+    user = password = None
+    api_url='https://scihub.copernicus.eu/dhus'
+    if options['settings'] == '-':
+        # stdin
+        import getpass
+        user = raw_input(_('Insert username: '))
+        password = getpass.getpass(_('Insert password: '))
+        url = raw_input(_('Insert API URL (leave empty for {}): ').format(api_url))
+        if url:
+            api_url = url
+    else:
+        try:
+            with open(options['settings'], 'r') as fd:
+                lines = filter(None, (line.rstrip() for line in fd)) # non-blank lines only
+                if len(lines) < 2:
+                    gs.fatal(_("Invalid settings file"))
+                user = lines[0].strip()
+                password = lines[1].strip()
+                if len(lines) > 2:
+                    api_url = lines[2].strip()
+        except IOError as e:
+            gs.fatal(_("Unable to open settings file: {}").format(e))
+    if user is None or password is None:
+        gs.fatal(_("No user or password given"))
+    map_box = get_aoi_box(options['map'])
+    try:
+        downloader = SentinelDownloader(user, password, api_url)
+        downloader.filter(area=map_box,
+                          area_relation=options['area_relation'],
+                          clouds=options['clouds'],
+                          producttype=options['producttype'],
+                          limit=options['limit'],
+                          start=options['start'],
+                          end=options['end'],
+                          sortby=options['sort'].split(','),
+                          asc=options['order'] == 'asc'
+    except StandardError as e:
+        gs.fatal(_('Unable to connect Copernicus Open Access Hub: {}').format(e))
+    if options['footprints']:
+        downloader.save_footprints(options['footprints'])
+    if flags['l']:
+        downloader.list()
+        return
+    downloader.download(options['output'])
+    return 0
+if __name__ == "__main__":
+    options, flags = gs.parser()
+    sys.exit(main())
Deleted: grass-addons/grass7/imagery/i.sentinel/i.sentinel.download/r.sentinel.download.html
--- grass-addons/grass7/imagery/i.sentinel/i.sentinel.download/r.sentinel.download.html	2018-03-20 11:48:26 UTC (rev 72406)
+++ grass-addons/grass7/imagery/i.sentinel/i.sentinel.download/r.sentinel.download.html	2018-03-20 11:52:22 UTC (rev 72407)
@@ -1,141 +0,0 @@
-<em>r.sentinel.download</em> allows downloading Sentinel products
-from <a href="https://scihub.copernicus.eu/">Copernicus Open Access
-Hub</a>.
-<p>
-To connect Copernicus Open Access Hub a <em>user</em>
-and <em>password</em> are required,
-see <a href="https://scihub.copernicus.eu/dhus/#/self-registration">Register
-new account</a> page for signing up.
-<p><em>r.sentinel.download</em> reads user credentials
-from <b>settings</b> file. The file must contain at least two lines:
-<div class="code"><pre>
-myusername
-mypassword
-</pre></div>
-Optionally on third line custom API URL can be defined. Note that
-empty lines in settings file are silently skipped.
-<h2>NOTES</h2>
-<p>User credentials can be also defined interactively
-when <b>settings=-</b> is given. Note that interactive prompt does not
-work in GUI.
-Insert username: myusername
-Insert password:
-Insert API URL (leave empty for https://scihub.copernicus.eu/dhus):
-</pre></div>
-<p>
-By default Sentinel products are sorted by <i>cloudcoverpercentage</i>
-and <i>ingestiondate</i> (see <b>sort</b> option). By default,
-only products which footprint intersects current computation region
-extent (area of interest, AOI) are filtered. The AOI can be optionally
-defined also by vector <b>map</b>. In addition the spatial relation
-between AOI and the footprint (<b>area_relation</b>) can be set to
-<ul>
-<li><i>Contains</i>: to only return scenes where the AOI is contained
-inside the footprint</li>
-<li><i>IsWithin</i>: to only return scenes where the footprint is
-contained inside the AOI</li>
-<li><i>Intersects</i>: to return all scenes where the footprint
-intersects the AOI (default)</li>
-</ul>
-Filtered products can be reduced by <b>limit</b> option.
-<p>
-Module searches for products in last 60 days, exact date range can be
-defined by <b>start</b> and <b>end</b> options.
-<p>
-Sentinel products can be also filtered by <b>producttype</b> or
-maximum <b>clouds</b> cover percentage.
-<h2>EXAMPLES</h2>
-<h3>List filtered products</h3>
-<p>
-Find S2MSI1C products in last 60 days covering current computation region extent.
-r.sentinel.download -l settings=sentinel.txt
-1 Sentinel product(s) found
-ae1c33ec-aa33-4303-a525-9e6481709614 2017-12-08T10:23:59Z 18% S2MSI1C
-</pre></div>
-Find all S2MSI2Ap products in 2017.
-r.sentinel.download -l settings=sentinel.txt producttype=S2MSI2Ap start=2017-01-01 end=2017-12-31
-7 Sentinel product(s) found
-e5df8b4f-a4c6-47bd-88f3-e16b7540cc7a 2017-05-27T10:20:31Z  2% S2MSI2Ap
-b62afeda-a28d-475c-8220-91e24fc368ff 2017-05-17T10:20:31Z  2% S2MSI2Ap
-9a6bc289-98e9-4489-84eb-1aac95aaa056 2017-08-15T10:20:21Z  3% S2MSI2Ap
-35c72002-78a0-45f8-b39d-66c2d7b4ad87 2017-10-14T10:20:21Z  6% S2MSI2Ap
-c0ae8085-c1bb-4a27-89f2-2138a0866586 2017-07-06T10:20:21Z 12% S2MSI2Ap
-433ebfbc-5144-42f8-97dc-b9f4f1eb7b5a 2017-11-03T10:22:01Z 12% S2MSI2Ap
-fc56a594-d9d8-4e93-8dec-af3a58b24080 2017-09-04T10:20:21Z 19% S2MSI2Ap
-</pre></div>
-Sort products by <b>ingestiondate</b>, limit cloud coverage to 5% per scene.
-r.sentinel.download -l settings=sentinel.txt producttype=S2MSI2Ap start=2017-01-01 end=2017-12-31 sort=ingestiondate order=desc clouds=5
-3 Sentinel product(s) found
-</pre></div>
-Create vector map with <b>footprints</b>.
-r.sentinel.download -l settings=sentinel.txt producttype=S2MSI2Ap start=2017-01-01 end=2017-12-31 footprints=ft
-</pre></div>
-<h3>Download Sentinel products</h3>
-Download first (<b>limit=1</b>) found S2MSI2Ap product into <i>data</i> directory.
-r.sentinel.download settings=sentinel.txt producttype=S2MSI2Ap start=2017-01-01 end=2017-12-31 limit=1 output=data
-</pre></div>
-Such downloaded data can be easily imported into GRASS
-using <em><a href="r.sentinel.import.html">r.sentinel.import</a></em>
-module.
-<h2>REQUIREMENTS</h2>
-<ul>
-  <li><a href="https://pypi.python.org/pypi/sentinelsat">Sentinelsat library</a></li>
-  <li><a href="https://pypi.python.org/pypi/pandas">Pandas library</a></li>
-</ul>
-<h2>SEE ALSO</h2>
-<em>
-<a href="r.sentinel.import.html">r.sentinel.import</a>,
-<a href="v.import.html">v.import</a>
-</em>
-<p>
-See
-also <a href="http://training.gismentors.eu/grass-gis-workshop-jena-2018/units/20.html">GRASS
-GIS Workshop in Jena</a> for usage examples.
-<h2>AUTHOR</h2>
-Martin
-Landa, <a href="http://geomatics.fsv.cvut.cz/research/geoforall/">GeoForAll
-Lab</a>, CTU in Prague, Czech Republic with support
-of <a href="http://opengeolabs.cz/en/home/">OpenGeoLabs</a> company
Deleted: grass-addons/grass7/imagery/i.sentinel/i.sentinel.download/r.sentinel.download.py
--- grass-addons/grass7/imagery/i.sentinel/i.sentinel.download/r.sentinel.download.py	2018-03-20 11:48:26 UTC (rev 72406)
+++ grass-addons/grass7/imagery/i.sentinel/i.sentinel.download/r.sentinel.download.py	2018-03-20 11:52:22 UTC (rev 72407)
@@ -1,341 +0,0 @@
-#!/usr/bin/env python
-# MODULE:      r.sentinel.download
-# AUTHOR(S):   Martin Landa
-# PURPOSE:     Downloads Sentinel data from  Copernicus Open Access Hub
-#              using sentinelsat library.
-# COPYRIGHT:   (C) 2018 by Martin Landa, and the GRASS development team
-#              This program is free software under the GNU General Public
-#              License (>=v2). Read the file COPYING that comes with GRASS
-#              for details.
-#%module
-#% description: Downloads Sentinel data from Copernicus Open Access Hub using sentinelsat library.
-#% keyword: raster
-#% keyword: imagery
-#% keyword: sentinel
-#% keyword: download
-#%end
-#%option G_OPT_F_INPUT
-#% key: settings
-#% label: Full path to settings file (user, password)
-#% description: '-' for standard input
-#%end
-#%option G_OPT_M_DIR
-#% key: output
-#% description: Name for output directory where to store downloaded Sentinel data
-#% required: no
-#% guisection: Output
-#%end
-#%option G_OPT_V_OUTPUT
-#% key: footprints
-#% description: Name for output vector map with footprints
-#% required: no
-#%end
-#%option G_OPT_V_MAP
-#% label: Name of input vector map to define Area of Interest (AOI)
-#% description: If not given than current computational extent is used
-#% required: no
-#% guisection: Region
-#%end
-#%option
-#% key: area_relation
-#% type: string
-#% description: Spatial reation of footprint to AOI
-#% options: Intersects,Contains,IsWithin
-#% answer: Intersects
-#% required: no
-#%end
-#%option
-#% key: clouds
-#% type: integer
-#% description: Maximum cloud cover percentage for Sentinel scene
-#% answer: 30
-#% required: no
-#% guisection: Filter
-#%end
-#%option
-#% key: producttype
-#% type: string
-#% description: Sentinel product type to filter
-#% required: no
-#% options: SLC,GRD,OCN,S2MSI1C,S2MSI2Ap
-#% answer: S2MSI1C
-#%end
-#%option
-#% key: start
-#% type: string
-#% description: Start date ('YYYY-MM-DD')
-#%end
-#%option
-#% key: end
-#% type: string
-#% description: End date ('YYYY-MM-DD')
-#%end
-#%option
-#% key: limit
-#% type: integer
-#% description: Limit number of Sentinel products
-#%end
-#%option
-#% key: sort
-#% description: Sort by values in given order
-#% multiple: yes
-#% options: ingestiondate,cloudcoverpercentage,footprint
-#% answer: cloudcoverpercentage,ingestiondate,footprint
-#% guisection: Sort
-#%end
-#%option
-#% key: order
-#% description: Sort order (see sort parameter)
-#% options: asc,desc
-#% answer: asc
-#%end
-#%flag
-#% key: l
-#% description: List filtered products and exist
-#% guisection: Print
-#%end
-#%rules
-#% required: output,-l
-#%end
-import os
-import sys
-import logging
-import zipfile
-from collections import OrderedDict
-import grass.script as gs
-def get_aoi_box(vector=None):
-    args = {}
-    if vector:
-        args['vector'] = vector
-    info = gs.parse_command('g.region', flags='uplg', **args)
-    return 'POLYGON(({nw_lon} {nw_lat}, {ne_lon} {ne_lat}, {se_lon} {se_lat}, {sw_lon} {sw_lat}, {nw_lon} {nw_lat}))'.format(
-        nw_lat=info['nw_lat'], nw_lon=info['nw_long'], ne_lat=info['ne_lat'], ne_lon=info['ne_long'],
-        sw_lat=info['sw_lat'], sw_lon=info['sw_long'], se_lat=info['se_lat'], se_lon=info['se_long']
-class SentinelDownloader(object):
-    def __init__(self, user, password, api_url='https://scihub.copernicus.eu/dhus'):
-        try:
-            from sentinelsat import SentinelAPI
-        except ImportError as e:
-            gs.fatal(_("Module requires sentinelsat library: {}").format(e))
-        try:
-            import pandas
-            gs.fatal(_("Module requires pandas library: {}").format(e))
-        # init logger
-        root = logging.getLogger()
-        root.addHandler(logging.StreamHandler(
-            sys.stderr
-        # connect SciHub via API
-        self._api = SentinelAPI(user, password,
-                                api_url=api_url
-        self._products_df_sorted = None
-    def filter(self, area, area_relation,
-               clouds=None, producttype=None, limit=None,
-               start=None, end=None, sortby=[], asc=True):
-        args = {}
-        if clouds:
-            args['cloudcoverpercentage'] = (0, clouds)
-        if producttype:
-            args['producttype'] = producttype
-        if not start:
-            start = 'NOW-60DAYS'
-        else:
-            start = start.replace('-', '')
-        if not end:
-            end = 'NOW'
-        else:
-            end = end.replace('-', '')
-        products = self._api.query(
-            area=area, area_relation=area_relation,
-            platformname='Sentinel-2',
-            date=(start, end),
-            **args
-        products_df = self._api.to_dataframe(products)
-        if len(products_df) < 1:
-            gs.message(_('No product found'))
-            return
-        # sort and limit to first sorted product
-        if sortby:
-            self._products_df_sorted = products_df.sort_values(
-                sortby,
-                ascending=[asc] * len(sortby)
-        if limit:
-            self._products_df_sorted = self._products_df_sorted.head(int(limit))
-        gs.message(_('{} Sentinel product(s) found').format(len(self._products_df_sorted)))
-    def list(self):
-        if self._products_df_sorted is None:
-            return
-        for idx in range(len(self._products_df_sorted)):
-            print ('{0} {1} {2:2.0f}% {3}'.format(
-                self._products_df_sorted['uuid'][idx],
-                self._products_df_sorted['beginposition'][idx].strftime("%Y-%m-%dT%H:%M:%SZ"),
-                self._products_df_sorted['cloudcoverpercentage'][idx],
-                self._products_df_sorted['producttype'][idx],
-    def download(self, output):
-            return
-        if not os.path.exists(output):
-            os.makedirs(output)
-        gs.message(_('Downloading data into <{}>...').format(output))
-            gs.message('{} -> {}.SAFE'.format(
-                os.path.join(output, self._products_df_sorted['identifier'][idx])
-            # download
-            self._api.download(self._products_df_sorted['uuid'][idx], output)
-            # unzip
-            if os.path.exists(os.path.join(output, self._products_df_sorted['identifier'][idx])):
-                continue
-            filename = self._products_df_sorted['identifier'][idx] + '.zip'
-            with zipfile.ZipFile(os.path.join(output, filename), 'r') as zip_ref:
-                zip_ref.extractall(output)
-    def save_footprints(self, map_name):
-            return
-        try:
-            from osgeo import ogr, osr
-            gs.fatal(_("Option <footprints> requires GDAL library: {}").format(e))
-        gs.message(_("Writing footprints into <{}>...").format(map_name))
-        driver = ogr.GetDriverByName("GPKG")
-        tmp_name = gs.tempfile() + '.gpkg'
-        data_source = driver.CreateDataSource(tmp_name)
-        srs = osr.SpatialReference()
-        srs.ImportFromEPSG(4326)
-        layer = data_source.CreateLayer(str(map_name), srs, ogr.wkbPolygon)
-        # attributes
-        attrs = OrderedDict([
-            ("uuid", ogr.OFTString),
-            ("ingestiondate", ogr.OFTString),
-            ("cloudcoverpercentage", ogr.OFTInteger),
-            ("producttype", ogr.OFTString)
-        for key in attrs.keys():
-            field = ogr.FieldDefn(key, attrs[key])
-            layer.CreateField(field)
-        # features
-            wkt = self._products_df_sorted['footprint'][idx]
-            feature = ogr.Feature(layer.GetLayerDefn())
-            feature.SetGeometry(ogr.CreateGeometryFromWkt(wkt))
-                if key == 'ingestiondate':
-                    value = self._products_df_sorted[key][idx].strftime("%Y-%m-%dT%H:%M:%SZ")
-                else:
-                feature.SetField(key, value)
-            layer.CreateFeature(feature)
-            feature = None
-        data_source = None
-        gs.run_command('v.import', input=tmp_name, output=map_name,
-                       layer=map_name, quiet=True
-def main():
-    user = password = None
-    api_url='https://scihub.copernicus.eu/dhus'
-    if options['settings'] == '-':
-        # stdin
-        import getpass
-        user = raw_input(_('Insert username: '))
-        password = getpass.getpass(_('Insert password: '))
-        url = raw_input(_('Insert API URL (leave empty for {}): ').format(api_url))
-        if url:
-            api_url = url
-    else:
-        try:
-            with open(options['settings'], 'r') as fd:
-                lines = filter(None, (line.rstrip() for line in fd)) # non-blank lines only
-                if len(lines) < 2:
-                    gs.fatal(_("Invalid settings file"))
-                user = lines[0].strip()
-                password = lines[1].strip()
-                if len(lines) > 2:
-                    api_url = lines[2].strip()
-        except IOError as e:
-            gs.fatal(_("Unable to open settings file: {}").format(e))
-    if user is None or password is None:
-        gs.fatal(_("No user or password given"))
-    map_box = get_aoi_box(options['map'])
-    try:
-        downloader = SentinelDownloader(user, password, api_url)
-        downloader.filter(area=map_box,
-                          area_relation=options['area_relation'],
-                          clouds=options['clouds'],
-                          producttype=options['producttype'],
-                          limit=options['limit'],
-                          start=options['start'],
-                          end=options['end'],
-                          sortby=options['sort'].split(','),
-                          asc=options['order'] == 'asc'
-    except StandardError as e:
-        gs.fatal(_('Unable to connect Copernicus Open Access Hub: {}').format(e))
-    if options['footprints']:
-        downloader.save_footprints(options['footprints'])
-    if flags['l']:
-        downloader.list()
-        return
-    downloader.download(options['output'])
-    return 0
-if __name__ == "__main__":
-    options, flags = gs.parser()
-    sys.exit(main())
Modified: grass-addons/grass7/imagery/i.sentinel/i.sentinel.import/Makefile
--- grass-addons/grass7/imagery/i.sentinel/i.sentinel.import/Makefile	2018-03-20 11:48:26 UTC (rev 72406)
+++ grass-addons/grass7/imagery/i.sentinel/i.sentinel.import/Makefile	2018-03-20 11:52:22 UTC (rev 72407)
@@ -1,6 +1,6 @@
-PGM = r.sentinel.import
+PGM = i.sentinel.import
Copied: grass-addons/grass7/imagery/i.sentinel/i.sentinel.import/i.sentinel.import.html (from rev 72406, grass-addons/grass7/imagery/i.sentinel/i.sentinel.import/r.sentinel.import.html)
--- grass-addons/grass7/imagery/i.sentinel/i.sentinel.import/i.sentinel.import.html	                        (rev 0)
+++ grass-addons/grass7/imagery/i.sentinel/i.sentinel.import/i.sentinel.import.html	2018-03-20 11:52:22 UTC (rev 72407)
@@ -0,0 +1,86 @@
+<em>i.sentinel.import</em> module allows importing Sentinel products
+downloaded
+by <em><a href="i.sentinel.download.html">i.sentinel.download</a></em>
+module.
+<p>
+By default <em>i.sentinel.import</em> imports all Sentinel bands found
+in <b>input</b> directory
+by <em><a href="r.import.html">r.import</a></em>. Note that in the
+case that spatial reference system of input data differs from GRASS
+location, the input data are reprojected.
+<p>
+Optionally input data can be linked
+by <em><a href="r.external.html">r.external</a></em> when <b>-l</b> is
+given. Note that linking data requires that input data and GRASS
+location have the same spatial reference system.
+<p>
+Number of imported Sentinel bands can be optionally reduced
+by <b>pattern</b> option.
+<h2>NOTES</h2>
+<p>
+If <b>-c</b> flag is given, than also cloud mask file is imported as
+vector map if available. Name of created vector map is determined from
+input Sentinel product.
+<h2>EXAMPLES</h2>
+At first, print list of raster files to be imported by <b>-p</b>. For
+each file also projection match with current location is printed
+including detected input data EPSG code.
+i.sentinel.import -p input=data
+data/S2B_MSIL1C_20180216T102059_N0206_R065_T32UPB_20180216T140508.SAFE/GRANULE/.../T32UPB_20180216T102059_B04.jp2 1 (EPSG: 32632)
+data/S2B_MSIL1C_20180216T102059_N0206_R065_T32UPB_20180216T140508.SAFE/GRANULE/.../T32UPB_20180216T102059_B07.jp2 1 (EPSG: 32632)
+data/S2B_MSIL1C_20180216T102059_N0206_R065_T32UPB_20180216T140508.SAFE/GRANULE/.../T32UPB_20180216T102059_B11.jp2 1 (EPSG: 32632)
+</pre></div>
+Import all Sentinel bands found in <i>data</i> directory.
+i.sentinel.import input=data
+</pre></div>
+Limit import only to 4th and 8th bands.
+i.sentinel.import input=data pattern='B0[4|8]'
+</pre></div>
+Link data and import also cloud mask file.
+i.sentinel.import -l -c input=data
+</pre></div>
+<center>
+<img src="i_sentinel_import_band_4_clouds.png" width="600" height="356"><br>
+<i>Fig: Band 4 with imported cloud mask</i>
+</center>
+<h2>SEE ALSO</h2>
+<em>
+<a href="i.sentinel.download.html">i.sentinel.download</a>,
+<a href="r.import.html">r.import</a>,
+<a href="r.extenal.html">r.external</a>,
+</em>
+<p>
+See
+<h2>AUTHOR</h2>
+Martin
Copied: grass-addons/grass7/imagery/i.sentinel/i.sentinel.import/i.sentinel.import.py (from rev 72406, grass-addons/grass7/imagery/i.sentinel/i.sentinel.import/r.sentinel.import.py)
--- grass-addons/grass7/imagery/i.sentinel/i.sentinel.import/i.sentinel.import.py	                        (rev 0)
+++ grass-addons/grass7/imagery/i.sentinel/i.sentinel.import/i.sentinel.import.py	2018-03-20 11:52:22 UTC (rev 72407)
@@ -0,0 +1,199 @@
+# MODULE:      i.sentinel.import
+# PURPOSE:     Imports Sentinel data downloaded from Copernicus Open Access Hub
+#              using i.sentinel.download.
+#              for details.
+#%Module
+#% description: Imports Sentinel data downloaded from Copernicus Open Access Hub using i.sentinel.download.
+#% keyword: raster
+#% keyword: import
+#%end
+#% key: input
+#% description: Name for input directory where downloaded Sentinel data lives
+#% required: yes
+#%end
+#%option
+#% key: pattern
+#% description: File name pattern to import
+#%end
+#%flag
+#% key: r
+#% description: Reproject raster data using r.import if needed
+#%end
+#%flag
+#% key: l
+#% description: Link raster data instead of importing
+#%end
+#%flag
+#% key: c
+#% description: Import cloud masks as vector maps
+#%end
+#%flag
+#% key: p
+#% description: Print raster data to be imported and exit
+#%end
+#%rules
+#% exclusive: -l,-r,-p
+#%end
+import os
+import sys
+import re
+from grass.exceptions import CalledModuleError
+class SentinelImporter(object):
+    def __init__(self, input_dir):
+        if not os.path.exists(input_dir):
+            gs.fatal(_('{} not exists').format(input_dir))
+        self.input_dir = input_dir
+    def filter(self, pattern=None):
+        if pattern:
+            filter_p = '.*' + options['pattern'] + '.*.jp2$'
+        else:
+            filter_p = r'.*_B.*.jp2$'
+        self.files = self._filter(filter_p)
+    def _filter(self, filter_p):
+        pattern = re.compile(filter_p)
+        files = []
+        for rec in os.walk(self.input_dir):
+            if not rec[-1]:
+                continue
+            match = filter(pattern.match, rec[-1])
+            if match is None:
+                continue
+            for f in match:
+                files.append(os.path.join(rec[0], f))
+        return files
+    def import_products(self, reproject=False, link=False):
+        args = {}
+        if link:
+            module = 'r.external'
+        else:
+            if reproject:
+                module = 'r.import'
+                args['resample'] = 'bilinear'
+                args['resolution'] = 'value'
+            else:
+                module = 'r.in.gdal'
+        for f in self.files:
+            if link or (not link and not reproject):
+                if not self._check_projection(f):
+                    gs.fatal(_('Projection of dataset does not appear to match current location. '
+                               'Force reprojecting dataset by -r flag.'))
+            self._import_file(f, module, args)
+    def _check_projection(self, filename):
+        try:
+            gs.run_command('r.in.gdal', flags='j',
+                           input=filename, quiet=True)
+        except CalledModuleError as e:
+            return False
+        return True
+    def _raster_resolution(self, filename):
+        try:
+            from osgeo import gdal
+            gs.fatal(_("Flag -r requires GDAL library: {}").format(e))
+        dsn = gdal.Open(filename)
+        trans = dsn.GetGeoTransform()
+        ret = int(trans[1])
+        dsn = None
+        return ret
+    def _raster_epsg(self, filename):
+        try:
+            from osgeo import gdal, osr
+        srs.ImportFromWkt(dsn.GetProjectionRef())
+        ret = srs.GetAuthorityCode(None)
+        dsn = None
+        return ret
+    def _import_file(self, filename, module, args):
+        mapname = os.path.splitext(os.path.basename(filename))[0]
+        gs.message(_('Processing <{}>...').format(mapname))
+        if module == 'r.import':
+            args['resolution_value'] = self._raster_resolution(filename)
+        try:
+            gs.run_command(module, input=filename, output=mapname, **args)
+            pass # error already printed
+    def import_cloud_masks(self):
+        files = self._filter("MSK_CLOUDS_B00.gml")
+        for f in files:
+            safe_dir = os.path.dirname(f).split(os.path.sep)[-4]
+            items = safe_dir.split('_')
+            map_name = '_'.join([items[5],items[2], 'MSK', 'CLOUDS'])
+            try:
+                gs.run_command('v.import', input=f,
+                               flags='o', # same SRS as data
+                               output=map_name,
+                               quiet=True
+    def print_products(self):
+            sys.stdout.write('{} {} (EPSG: {}){}'.format(
+                f,
+                '1' if self._check_projection(f) else '0',
+                self._raster_epsg(f),
+                os.linesep
+def main():
+    importer = SentinelImporter(options['input'])
+    importer.filter(options['pattern'])
+    if flags['p']:
+        importer.print_products()
+        return 0
+    importer.import_products(flags['r'], flags['l'])
+    if flags['c']:
+        importer.import_cloud_masks()
+    return 0
+    sys.exit(main())
Deleted: grass-addons/grass7/imagery/i.sentinel/i.sentinel.import/r.sentinel.import.html
--- grass-addons/grass7/imagery/i.sentinel/i.sentinel.import/r.sentinel.import.html	2018-03-20 11:48:26 UTC (rev 72406)
+++ grass-addons/grass7/imagery/i.sentinel/i.sentinel.import/r.sentinel.import.html	2018-03-20 11:52:22 UTC (rev 72407)
@@ -1,86 +0,0 @@
-<em>r.sentinel.import</em> module allows importing Sentinel products
-downloaded
-by <em><a href="r.sentinel.download.html">r.sentinel.download</a></em>
-module.
-<p>
-By default <em>r.sentinel.import</em> imports all Sentinel bands found
-in <b>input</b> directory
-by <em><a href="r.import.html">r.import</a></em>. Note that in the
-case that spatial reference system of input data differs from GRASS
-location, the input data are reprojected.
-<p>
-Optionally input data can be linked
-by <em><a href="r.external.html">r.external</a></em> when <b>-l</b> is
-given. Note that linking data requires that input data and GRASS
-location have the same spatial reference system.
-<p>
-Number of imported Sentinel bands can be optionally reduced
-by <b>pattern</b> option.
-<h2>NOTES</h2>
-<p>
-If <b>-c</b> flag is given, than also cloud mask file is imported as
-vector map if available. Name of created vector map is determined from
-input Sentinel product.
-<h2>EXAMPLES</h2>
-At first, print list of raster files to be imported by <b>-p</b>. For
-each file also projection match with current location is printed
-including detected input data EPSG code.
-r.sentinel.import -p input=data
-data/S2B_MSIL1C_20180216T102059_N0206_R065_T32UPB_20180216T140508.SAFE/GRANULE/.../T32UPB_20180216T102059_B04.jp2 1 (EPSG: 32632)
-data/S2B_MSIL1C_20180216T102059_N0206_R065_T32UPB_20180216T140508.SAFE/GRANULE/.../T32UPB_20180216T102059_B07.jp2 1 (EPSG: 32632)
-data/S2B_MSIL1C_20180216T102059_N0206_R065_T32UPB_20180216T140508.SAFE/GRANULE/.../T32UPB_20180216T102059_B11.jp2 1 (EPSG: 32632)
-</pre></div>
-Import all Sentinel bands found in <i>data</i> directory.
-r.sentinel.import input=data
-</pre></div>
-Limit import only to 4th and 8th bands.
-r.sentinel.import input=data pattern='B0[4|8]'
-</pre></div>
-Link data and import also cloud mask file.
-r.sentinel.import -l -c input=data
-</pre></div>
-<center>
-<img src="r_sentinel_import_band_4_clouds.png" width="600" height="356"><br>
-<i>Fig: Band 4 with imported cloud mask</i>
-</center>
-<h2>SEE ALSO</h2>
-<em>
-<a href="r.sentinel.download.html">r.sentinel.download</a>,
-<a href="r.import.html">r.import</a>,
-<a href="r.extenal.html">r.external</a>,
-</em>
-<p>
-See
-<h2>AUTHOR</h2>
-Martin
Deleted: grass-addons/grass7/imagery/i.sentinel/i.sentinel.import/r.sentinel.import.py
--- grass-addons/grass7/imagery/i.sentinel/i.sentinel.import/r.sentinel.import.py	2018-03-20 11:48:26 UTC (rev 72406)
+++ grass-addons/grass7/imagery/i.sentinel/i.sentinel.import/r.sentinel.import.py	2018-03-20 11:52:22 UTC (rev 72407)
@@ -1,199 +0,0 @@
-# MODULE:      r.sentinel.import
-# PURPOSE:     Imports Sentinel data downloaded from Copernicus Open Access Hub
-#              using r.sentinel.download.
-#              for details.
-#%Module
-#% description: Imports Sentinel data downloaded from Copernicus Open Access Hub using r.sentinel.download.
-#% keyword: raster
-#% keyword: import
-#%end
-#% key: input
-#% description: Name for input directory where downloaded Sentinel data lives
-#% required: yes
-#%end
-#%option
-#% key: pattern
-#% description: File name pattern to import
-#%end
-#%flag
-#% key: r
-#% description: Reproject raster data using r.import if needed
-#%end
-#%flag
-#% key: l
-#% description: Link raster data instead of importing
-#%end
-#%flag
-#% key: c
-#% description: Import cloud masks as vector maps
-#%end
-#%flag
-#% key: p
-#% description: Print raster data to be imported and exit
-#%end
-#%rules
-#% exclusive: -l,-r,-p
-#%end
-import os
-import sys
-import re
-from grass.exceptions import CalledModuleError
-class SentinelImporter(object):
-    def __init__(self, input_dir):
-        if not os.path.exists(input_dir):
-            gs.fatal(_('{} not exists').format(input_dir))
-        self.input_dir = input_dir
-    def filter(self, pattern=None):
-        if pattern:
-            filter_p = '.*' + options['pattern'] + '.*.jp2$'
-        else:
-            filter_p = r'.*_B.*.jp2$'
-        self.files = self._filter(filter_p)
-    def _filter(self, filter_p):
-        pattern = re.compile(filter_p)
-        files = []
-        for rec in os.walk(self.input_dir):
-            if not rec[-1]:
-                continue
-            match = filter(pattern.match, rec[-1])
-            if match is None:
-                continue
-            for f in match:
-                files.append(os.path.join(rec[0], f))
-        return files
-    def import_products(self, reproject=False, link=False):
-        args = {}
-        if link:
-            module = 'r.external'
-        else:
-            if reproject:
-                module = 'r.import'
-                args['resample'] = 'bilinear'
-                args['resolution'] = 'value'
-            else:
-                module = 'r.in.gdal'
-        for f in self.files:
-            if link or (not link and not reproject):
-                if not self._check_projection(f):
-                    gs.fatal(_('Projection of dataset does not appear to match current location. '
-                               'Force reprojecting dataset by -r flag.'))
-            self._import_file(f, module, args)
-    def _check_projection(self, filename):
-        try:
-            gs.run_command('r.in.gdal', flags='j',
-                           input=filename, quiet=True)
-        except CalledModuleError as e:
-            return False
-        return True
-    def _raster_resolution(self, filename):
-        try:
-            from osgeo import gdal
-            gs.fatal(_("Flag -r requires GDAL library: {}").format(e))
-        dsn = gdal.Open(filename)
-        trans = dsn.GetGeoTransform()
-        ret = int(trans[1])
-        dsn = None
-        return ret
-    def _raster_epsg(self, filename):
-        try:
-            from osgeo import gdal, osr
-        srs.ImportFromWkt(dsn.GetProjectionRef())
-        ret = srs.GetAuthorityCode(None)
-        dsn = None
-        return ret
-    def _import_file(self, filename, module, args):
-        mapname = os.path.splitext(os.path.basename(filename))[0]
-        gs.message(_('Processing <{}>...').format(mapname))
-        if module == 'r.import':
-            args['resolution_value'] = self._raster_resolution(filename)
-        try:
-            gs.run_command(module, input=filename, output=mapname, **args)
-            pass # error already printed
-    def import_cloud_masks(self):
-        files = self._filter("MSK_CLOUDS_B00.gml")
-        for f in files:
-            safe_dir = os.path.dirname(f).split(os.path.sep)[-4]
-            items = safe_dir.split('_')
-            map_name = '_'.join([items[5],items[2], 'MSK', 'CLOUDS'])
-            try:
-                gs.run_command('v.import', input=f,
-                               flags='o', # same SRS as data
-                               output=map_name,
-                               quiet=True
-    def print_products(self):
-            sys.stdout.write('{} {} (EPSG: {}){}'.format(
-                f,
-                '1' if self._check_projection(f) else '0',
-                self._raster_epsg(f),
-                os.linesep
-def main():
-    importer = SentinelImporter(options['input'])
-    importer.filter(options['pattern'])
-    if flags['p']:
-        importer.print_products()
-        return 0
-    importer.import_products(flags['r'], flags['l'])
-    if flags['c']:
-        importer.import_cloud_masks()
-    return 0
-    sys.exit(main())
Deleted: grass-addons/grass7/imagery/i.sentinel/i.sentinel.import/r_sentinel_import_band_4_clouds.png
(Binary files differ)
Copied: grass-addons/grass7/imagery/i.sentinel/i.sentinel.import/v_sentinel_import_band_4_clouds.png (from rev 72406, grass-addons/grass7/imagery/i.sentinel/i.sentinel.import/r_sentinel_import_band_4_clouds.png)
