[GRASS-SVN] r72430 - grass/trunk/raster/r.latlong
Tue Mar 20 11:50:29 PDT 2018
Author: mmetz
Date: 2018-03-20 11:50:29 -0700 (Tue, 20 Mar 2018)
New Revision: 72430
   grass/trunk/raster/r.latlong/main.c
r.latlong: use new PROJ 5+ API if available
Modified: grass/trunk/raster/r.latlong/main.c
--- grass/trunk/raster/r.latlong/main.c	2018-03-20 18:49:55 UTC (rev 72429)
+++ grass/trunk/raster/r.latlong/main.c	2018-03-20 18:50:29 UTC (rev 72430)
@@ -32,7 +32,9 @@
     struct Flag *flag1;
     struct History history;	/*metadata */
     struct pj_info iproj;
+#ifndef HAVE_PROJ_H
     struct pj_info oproj;
+#endif
     struct Key_Value *in_proj_info, *in_unit_info;
@@ -93,8 +95,7 @@
     /*Stolen from r.sun */
     /* Set up parameters for projection to lat/long if necessary */
-    if ((G_projection() != PROJECTION_LL))
+    if ((G_projection() != PROJECTION_LL)) {
 	not_ll = 1;
 	if ((in_proj_info = G_get_projinfo()) == NULL)
@@ -105,7 +106,7 @@
 	    G_fatal_error(_("Unable to get projection key values of current location"));
 	G_free_key_value(in_proj_info);
 	G_free_key_value(in_unit_info);
         /* Set output projection to latlong w/ same ellipsoid */
 	oproj.zone = 0;
 	oproj.meters = 1.;
@@ -112,6 +113,7 @@
 	sprintf(oproj.proj, "ll");
 	if ((oproj.pj = pj_latlong_from_proj(iproj.pj)) == NULL)
 	    G_fatal_error(_("Unable to set up lat/long projection parameters"));
+#endif
     }	/* End of stolen from r.sun */
     outrast1 = Rast_allocate_d_buf();
@@ -129,7 +131,11 @@
 	    latitude = ymax - ((double)row * stepy);
 	    longitude = xmin + ((double)col * stepx);
 	    if (not_ll)
+#ifdef HAVE_PROJ_H
+		if (GPJ_do_proj_ll(&longitude, &latitude, &iproj, PJ_INV) < 0)
+#else
 		if (pj_do_proj(&longitude, &latitude, &iproj, &oproj) < 0)
+#endif
 		    G_fatal_error(_("Error in pj_do_proj"));
             if(flag1->answer)
 	        d = longitude;
