[GRASS-SVN] r72433 - grass/trunk/raster/r.sunmask
Tue Mar 20 11:52:28 PDT 2018
Author: mmetz
Date: 2018-03-20 11:52:28 -0700 (Tue, 20 Mar 2018)
New Revision: 72433
   grass/trunk/raster/r.sunmask/g_solposition.c
r.sunmask: use new PROJ 5+ API if available
Modified: grass/trunk/raster/r.sunmask/g_solposition.c
--- grass/trunk/raster/r.sunmask/g_solposition.c	2018-03-20 18:51:34 UTC (rev 72432)
+++ grass/trunk/raster/r.sunmask/g_solposition.c	2018-03-20 18:52:28 UTC (rev 72433)
@@ -56,7 +56,9 @@
     long retval;		/* to capture S_solpos return codes */
     struct Key_Value *in_proj_info, *in_unit_info;	/* projection information of input map */
     struct pj_info iproj;	/* input map proj parameters  */
+#ifndef HAVE_PROJ_H
     struct pj_info oproj;	/* output map proj parameters  */
+#endif
     extern struct Cell_head window;
     int inside;
@@ -113,7 +115,7 @@
 	G_debug(1, "IN coord: longitude: %f, latitude: %f", longitude,
 		latitude);
 	/* see src/include/projects.h, struct PJconsts */
 	/* set output projection to lat/long for solpos */
 	oproj.zone = 0;
 	oproj.meters = 1.;
@@ -120,10 +122,14 @@
 	sprintf(oproj.proj, "ll");
 	if ((oproj.pj = pj_latlong_from_proj(iproj.pj)) == NULL)
 	    G_fatal_error("Unable to set up lat/long projection parameters");
+#endif
 	/* XX do the transform
 	 *               outx        outy    in_info  out_info */
+#ifdef HAVE_PROJ_H
+	if (GPJ_do_proj_ll(&longitude, &latitude, &iproj, PJ_INV) < 0) {
+#else
 	if (pj_do_proj(&longitude, &latitude, &iproj, &oproj) < 0) {
+#endif
 	    G_fatal_error(_("Error in pj_do_proj (projection of input coordinate pair)"));
