[GRASS-SVN] r72578 - grass/trunk/raster/r.mode/testsuite
Sun Mar 25 08:30:33 PDT 2018
Author: lucadelu
Date: 2018-03-25 08:30:33 -0700 (Sun, 25 Mar 2018)
New Revision: 72578
   grass/trunk/raster/r.mode/testsuite/testrmode.py
r.mode: fixed tests using nc_basic_spm_grass7 location
Modified: grass/trunk/raster/r.mode/testsuite/testrmode.py
--- grass/trunk/raster/r.mode/testsuite/testrmode.py	2018-03-25 14:51:11 UTC (rev 72577)
+++ grass/trunk/raster/r.mode/testsuite/testrmode.py	2018-03-25 15:30:33 UTC (rev 72578)
@@ -1,8 +1,13 @@
 Purpose:    Tests r.mode and its flags/options.
 Author:     Supreet Singh
+Copyright:  (C) 2018 by Supreet Singh and the GRASS Development Team
+Licence:    This program is free software under the GNU General Public
+            License (>=v2). Read the file COPYING that comes with GRASS
+            for details.
 from grass.gunittest.case import TestCase
@@ -10,13 +15,13 @@
 class Testrmode(TestCase):
     output='rmode'
-    base='facility'
-    cover='soils_Kfactor'
+    base='geology'
+    cover='soils'
     @classmethod
     def setUpClass(cls):
         cls.use_temp_region()
-        cls.runModule('g.region', flags='d')
+        cls.runModule('g.region', raster=cls.base, flags='d')
     @classmethod
     def tearDownClass(cls):
@@ -26,28 +31,22 @@
         self.runModule('g.remove', type='raster', flags='f', name=self.output)
     def test_1(self):
-        facility='facility'
-        self.assertModule('r.mode', base=self.base, cover=self.cover,
-                          output=self.output)
-        self.assertRasterMinMax(map=facility, refmin=1, refmax=1,
-                                msg="facility in degrees must be between "
-                                    "1 and 1")
+        soilsID='soils'
+        self.assertModule('r.mode', base=self.base, cover=self.cover, output=self.output)
+        self.assertRasterMinMax(map=soilsID, refmin=18683, refmax=46555,
+	                        msg="soilsID in degrees must be between 18683 and 46555")
     def test_2(self):
-        slope='slope'
-        self.assertRasterMinMax(map=slope, refmin=0, refmax=38.68939,
-                                msg="slope in degrees must be between 0 and "
-                                    "38.68939")
+        lakes='lakes'
+        self.assertRasterMinMax(map=lakes, refmin=34300, refmax=43600,
+	                        msg="lakes in degrees must be between 34300 and 43600")
     def test_3(self):
         elevation='elevation'
-        self.assertRasterMinMax(map=elevation, refmin=55.57879,
-                                refmax=156.3299, msg="elevation in degrees "
-                                "must be between 55.57879 and 156.3299")
+        self.assertRasterMinMax(map=elevation, refmin=2, refmax=4,
+	                        msg="elevation in degrees must be between NULL and NULL")
 if __name__ == '__main__':
     test()
