[GRASS-SVN] r72585 - in grass/trunk/temporal: t.rast.accdetect t.rast.accumulate t.rast.contour t.rast.gapfill t.rast.neighbors t.rast.to.vect
Fri Mar 30 10:21:28 PDT 2018
Author: huhabla
Date: 2018-03-30 10:21:28 -0700 (Fri, 30 Mar 2018)
New Revision: 72585
   grass/trunk/temporal/t.rast.accdetect/t.rast.accdetect.py
   grass/trunk/temporal/t.rast.accumulate/t.rast.accumulate.py
   grass/trunk/temporal/t.rast.contour/t.rast.contour.py
   grass/trunk/temporal/t.rast.gapfill/t.rast.gapfill.py
   grass/trunk/temporal/t.rast.neighbors/t.rast.neighbors.py
   grass/trunk/temporal/t.rast.to.vect/t.rast.to.vect.py
temporal modules: Fixed tgis suffix function spell mistake
Modified: grass/trunk/temporal/t.rast.accdetect/t.rast.accdetect.py
--- grass/trunk/temporal/t.rast.accdetect/t.rast.accdetect.py	2018-03-29 13:20:37 UTC (rev 72584)
+++ grass/trunk/temporal/t.rast.accdetect/t.rast.accdetect.py	2018-03-30 17:21:28 UTC (rev 72585)
@@ -341,7 +341,7 @@
                     suffix = tgis.create_time_suffix(map)
                     indicator_map_name = "{ba}_indicator_{su}".format(ba=base, su=suffix)
                 else:
-                    indicator_map_name = tgis.create_numeric_suffic(base + "_indicator",
+                    indicator_map_name = tgis.create_numeric_suffix(base + "_indicator",
        indi_count, time_suffix)
                 indicator_map_id = dummy.build_id(indicator_map_name, mapset)
                 indicator_map = input_strds.get_new_map_instance(indicator_map_id)
@@ -534,7 +534,7 @@
             occurrence_map_name = "{ba}_{su}".format(ba=base, su=suffix)
         else:
-            occurrence_map_name = tgis.create_numeric_suffic(base, count, tsuffix)
+            occurrence_map_name = tgis.create_numeric_suffix(base, count, tsuffix)
         occurrence_map_id = map.build_id(occurrence_map_name, mapset)
         occurrence_map = input_strds.get_new_map_instance(occurrence_map_id)
Modified: grass/trunk/temporal/t.rast.accumulate/t.rast.accumulate.py
--- grass/trunk/temporal/t.rast.accumulate/t.rast.accumulate.py	2018-03-29 13:20:37 UTC (rev 72584)
+++ grass/trunk/temporal/t.rast.accumulate/t.rast.accumulate.py	2018-03-30 17:21:28 UTC (rev 72585)
@@ -396,7 +396,7 @@
                 output_map_name = "{ba}_{su}".format(ba=base, su=suffix)
             else:
-                output_map_name = tgis.create_numeric_suffic(base, count, time_suffix)
+                output_map_name = tgis.create_numeric_suffix(base, count, time_suffix)
             output_map_id = map.build_id(output_map_name, mapset)
             output_map = input_strds.get_new_map_instance(output_map_id)
Modified: grass/trunk/temporal/t.rast.contour/t.rast.contour.py
--- grass/trunk/temporal/t.rast.contour/t.rast.contour.py	2018-03-29 13:20:37 UTC (rev 72584)
+++ grass/trunk/temporal/t.rast.contour/t.rast.contour.py	2018-03-30 17:21:28 UTC (rev 72585)
@@ -215,7 +215,7 @@
         else:
-            map_name = tgis.create_numeric_suffic(base, count, time_suffix)
+            map_name = tgis.create_numeric_suffix(base, count, time_suffix)
         new_map = tgis.open_new_map_dataset(map_name, None, type="vector",
                                             temporal_extent=map.get_temporal_extent(),
                                             overwrite=overwrite, dbif=dbif)
Modified: grass/trunk/temporal/t.rast.gapfill/t.rast.gapfill.py
--- grass/trunk/temporal/t.rast.gapfill/t.rast.gapfill.py	2018-03-29 13:20:37 UTC (rev 72584)
+++ grass/trunk/temporal/t.rast.gapfill/t.rast.gapfill.py	2018-03-30 17:21:28 UTC (rev 72585)
@@ -121,7 +121,7 @@
             if sp.get_temporal_type() == 'absolute' and tsuffix in ['gran', 'time']:
                 _id = "{ba}@{ma}".format(ba=base, ma=mapset)
             else:
-                map_name = tgis.create_numeric_suffic(base, num + count, tsuffix)
+                map_name = tgis.create_numeric_suffix(base, num + count, tsuffix)
                 _id = "{name}@{ma}".format(name=map_name, ma=mapset)
             _map.set_id(_id)
@@ -182,7 +182,7 @@
                 new_id = "{ba}_{su}@{ma}".format(ba=new_map.get_name(),
                                                  su=suffix, ma=mapset)
             else:
-                map_name = tgis.create_numeric_suffic(new_map.get_name(),
+                map_name = tgis.create_numeric_suffix(new_map.get_name(),
                                                       count, tsuffix)
                 new_id = "{name}@{ma}".format(name=map_name, ma=mapset)
Modified: grass/trunk/temporal/t.rast.neighbors/t.rast.neighbors.py
--- grass/trunk/temporal/t.rast.neighbors/t.rast.neighbors.py	2018-03-29 13:20:37 UTC (rev 72584)
+++ grass/trunk/temporal/t.rast.neighbors/t.rast.neighbors.py	2018-03-30 17:21:28 UTC (rev 72585)
@@ -166,7 +166,7 @@
         else:
         new_map = tgis.open_new_map_dataset(map_name, None, type="raster",
Modified: grass/trunk/temporal/t.rast.to.vect/t.rast.to.vect.py
--- grass/trunk/temporal/t.rast.to.vect/t.rast.to.vect.py	2018-03-29 13:20:37 UTC (rev 72584)
+++ grass/trunk/temporal/t.rast.to.vect/t.rast.to.vect.py	2018-03-30 17:21:28 UTC (rev 72585)
@@ -210,7 +210,7 @@
         else:
