[GRASS-SVN] r72676 - grass/trunk
Fri May 4 13:36:28 PDT 2018
Author: neteler
Date: 2018-05-04 13:36:28 -0700 (Fri, 04 May 2018)
New Revision: 72676
   grass/trunk/config.guess
   grass/trunk/config.sub
   grass/trunk/configure
config.guess + config.sub: updated from http://git.savannah.gnu.org/cgit/config.git/plain/
Modified: grass/trunk/config.guess
--- grass/trunk/config.guess	2018-05-04 20:23:14 UTC (rev 72675)
+++ grass/trunk/config.guess	2018-05-04 20:36:28 UTC (rev 72676)
@@ -1,8 +1,8 @@
 #! /bin/sh
 # Attempt to guess a canonical system name.
-#   Copyright 1992-2017 Free Software Foundation, Inc.
+#   Copyright 1992-2018 Free Software Foundation, Inc.
-timestamp='2017-11-07'
+timestamp='2018-03-08'
 # This file is free software; you can redistribute it and/or modify it
 # under the terms of the GNU General Public License as published by
@@ -50,7 +50,7 @@
 GNU config.guess ($timestamp)
 Originally written by Per Bothner.
-Copyright 1992-2017 Free Software Foundation, Inc.
+Copyright 1992-2018 Free Software Foundation, Inc.
 This is free software; see the source for copying conditions.  There is NO
 warranty; not even for MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE."
@@ -107,9 +107,9 @@
 dummy=$tmp/dummy ;
 tmpfiles="$dummy.c $dummy.o $dummy.rel $dummy" ;
 case $CC_FOR_BUILD,$HOST_CC,$CC in
- ,,)    echo "int x;" > $dummy.c ;
+ ,,)    echo "int x;" > "$dummy.c" ;
 	for c in cc gcc c89 c99 ; do
-	  if ($c -c -o $dummy.o $dummy.c) >/dev/null 2>&1 ; then
+	  if ($c -c -o "$dummy.o" "$dummy.c") >/dev/null 2>&1 ; then
 	     CC_FOR_BUILD="$c"; break ;
 	  fi ;
 	done ;
@@ -132,14 +132,14 @@
 UNAME_SYSTEM=`(uname -s) 2>/dev/null`  || UNAME_SYSTEM=unknown
 UNAME_VERSION=`(uname -v) 2>/dev/null` || UNAME_VERSION=unknown
-case "${UNAME_SYSTEM}" in
+case "$UNAME_SYSTEM" in
 Linux|GNU|GNU/*)
 	# If the system lacks a compiler, then just pick glibc.
 	# We could probably try harder.
 	LIBC=gnu
-	eval $set_cc_for_build
-	cat <<-EOF > $dummy.c
+	eval "$set_cc_for_build"
+	cat <<-EOF > "$dummy.c"
 	#include <features.h>
 	#if defined(__UCLIBC__)
 	LIBC=uclibc
@@ -149,13 +149,20 @@
 	LIBC=gnu
 	#endif
 	EOF
-	eval `$CC_FOR_BUILD -E $dummy.c 2>/dev/null | grep '^LIBC' | sed 's, ,,g'`
+	eval "`$CC_FOR_BUILD -E "$dummy.c" 2>/dev/null | grep '^LIBC' | sed 's, ,,g'`"
+	# If ldd exists, use it to detect musl libc.
+	if command -v ldd >/dev/null && \
+		ldd --version 2>&1 | grep -q ^musl
+	then
+	    LIBC=musl
+	fi
 esac
 # Note: order is significant - the case branches are not exclusive.
-case "${UNAME_MACHINE}:${UNAME_SYSTEM}:${UNAME_RELEASE}:${UNAME_VERSION}" in
+case "$UNAME_MACHINE:$UNAME_SYSTEM:$UNAME_RELEASE:$UNAME_VERSION" in
     *:NetBSD:*:*)
 	# NetBSD (nbsd) targets should (where applicable) match one or
 	# more of the tuples: *-*-netbsdelf*, *-*-netbsdaout*,
@@ -169,10 +176,10 @@
 	# portion of the name.  We always set it to "unknown".
 	sysctl="sysctl -n hw.machine_arch"
 	UNAME_MACHINE_ARCH=`(uname -p 2>/dev/null || \
-	    /sbin/$sysctl 2>/dev/null || \
-	    /usr/sbin/$sysctl 2>/dev/null || \
+	    "/sbin/$sysctl" 2>/dev/null || \
+	    "/usr/sbin/$sysctl" 2>/dev/null || \
 	    echo unknown)`
-	case "${UNAME_MACHINE_ARCH}" in
+	case "$UNAME_MACHINE_ARCH" in
 	    armeb) machine=armeb-unknown ;;
 	    arm*) machine=arm-unknown ;;
 	    sh3el) machine=shl-unknown ;;
@@ -179,20 +186,20 @@
 	    sh3eb) machine=sh-unknown ;;
 	    sh5el) machine=sh5le-unknown ;;
 	    earmv*)
-		arch=`echo ${UNAME_MACHINE_ARCH} | sed -e 's,^e\(armv[0-9]\).*$,\1,'`
-		endian=`echo ${UNAME_MACHINE_ARCH} | sed -ne 's,^.*\(eb\)$,\1,p'`
-		machine=${arch}${endian}-unknown
+		arch=`echo "$UNAME_MACHINE_ARCH" | sed -e 's,^e\(armv[0-9]\).*$,\1,'`
+		endian=`echo "$UNAME_MACHINE_ARCH" | sed -ne 's,^.*\(eb\)$,\1,p'`
+		machine="${arch}${endian}"-unknown
-	    *) machine=${UNAME_MACHINE_ARCH}-unknown ;;
+	    *) machine="$UNAME_MACHINE_ARCH"-unknown ;;
 	esac
 	# The Operating System including object format, if it has switched
 	# to ELF recently (or will in the future) and ABI.
 	    earm*)
 		os=netbsdelf
 	    arm*|i386|m68k|ns32k|sh3*|sparc|vax)
 		if echo __ELF__ | $CC_FOR_BUILD -E - 2>/dev/null \
 			| grep -q __ELF__
 		then
@@ -208,10 +215,10 @@
 	esac
 	# Determine ABI tags.
 	    earm*)
 		expr='s/^earmv[0-9]/-eabi/;s/eb$//'
-		abi=`echo ${UNAME_MACHINE_ARCH} | sed -e "$expr"`
+		abi=`echo "$UNAME_MACHINE_ARCH" | sed -e "$expr"`
 	esac
 	# The OS release
@@ -219,52 +226,55 @@
 	# thus, need a distinct triplet. However, they do not need
 	# kernel version information, so it can be replaced with a
 	# suitable tag, in the style of linux-gnu.
-	case "${UNAME_VERSION}" in
+	case "$UNAME_VERSION" in
 	    Debian*)
 		release='-gnu'
-		release=`echo ${UNAME_RELEASE} | sed -e 's/[-_].*//' | cut -d. -f1,2`
+		release=`echo "$UNAME_RELEASE" | sed -e 's/[-_].*//' | cut -d. -f1,2`
 	esac
 	# Since CPU_TYPE-MANUFACTURER-KERNEL-OPERATING_SYSTEM:
 	# contains redundant information, the shorter form:
 	# CPU_TYPE-MANUFACTURER-OPERATING_SYSTEM is used.
-	echo "${machine}-${os}${release}${abi}"
+	echo "$machine-${os}${release}${abi}"
 	exit ;;
     *:Bitrig:*:*)
 	UNAME_MACHINE_ARCH=`arch | sed 's/Bitrig.//'`
-	echo ${UNAME_MACHINE_ARCH}-unknown-bitrig${UNAME_RELEASE}
+	echo "$UNAME_MACHINE_ARCH"-unknown-bitrig"$UNAME_RELEASE"
 	exit ;;
     *:OpenBSD:*:*)
 	UNAME_MACHINE_ARCH=`arch | sed 's/OpenBSD.//'`
-	echo ${UNAME_MACHINE_ARCH}-unknown-openbsd${UNAME_RELEASE}
+	echo "$UNAME_MACHINE_ARCH"-unknown-openbsd"$UNAME_RELEASE"
 	exit ;;
     *:LibertyBSD:*:*)
 	UNAME_MACHINE_ARCH=`arch | sed 's/^.*BSD\.//'`
-	echo ${UNAME_MACHINE_ARCH}-unknown-libertybsd${UNAME_RELEASE}
+	echo "$UNAME_MACHINE_ARCH"-unknown-libertybsd"$UNAME_RELEASE"
 	exit ;;
     *:MidnightBSD:*:*)
-	echo ${UNAME_MACHINE}-unknown-midnightbsd${UNAME_RELEASE}
+	echo "$UNAME_MACHINE"-unknown-midnightbsd"$UNAME_RELEASE"
 	exit ;;
     *:ekkoBSD:*:*)
-	echo ${UNAME_MACHINE}-unknown-ekkobsd${UNAME_RELEASE}
+	echo "$UNAME_MACHINE"-unknown-ekkobsd"$UNAME_RELEASE"
 	exit ;;
     *:SolidBSD:*:*)
-	echo ${UNAME_MACHINE}-unknown-solidbsd${UNAME_RELEASE}
+	echo "$UNAME_MACHINE"-unknown-solidbsd"$UNAME_RELEASE"
 	exit ;;
     macppc:MirBSD:*:*)
-	echo powerpc-unknown-mirbsd${UNAME_RELEASE}
+	echo powerpc-unknown-mirbsd"$UNAME_RELEASE"
 	exit ;;
     *:MirBSD:*:*)
-	echo ${UNAME_MACHINE}-unknown-mirbsd${UNAME_RELEASE}
+	echo "$UNAME_MACHINE"-unknown-mirbsd"$UNAME_RELEASE"
 	exit ;;
     *:Sortix:*:*)
-	echo ${UNAME_MACHINE}-unknown-sortix
+	echo "$UNAME_MACHINE"-unknown-sortix
 	exit ;;
     *:Redox:*:*)
-	echo ${UNAME_MACHINE}-unknown-redox
+	echo "$UNAME_MACHINE"-unknown-redox
 	exit ;;
+    mips:OSF1:*.*)
+        echo mips-dec-osf1
+        exit ;;
     alpha:OSF1:*:*)
 	case $UNAME_RELEASE in
 	*4.0)
@@ -316,7 +326,7 @@
 	# A Tn.n version is a released field test version.
 	# A Xn.n version is an unreleased experimental baselevel.
 	# 1.2 uses "1.2" for uname -r.
-	echo ${UNAME_MACHINE}-dec-osf`echo ${UNAME_RELEASE} | sed -e 's/^[PVTX]//' | tr ABCDEFGHIJKLMNOPQRSTUVWXYZ abcdefghijklmnopqrstuvwxyz`
+	echo "$UNAME_MACHINE"-dec-osf"`echo "$UNAME_RELEASE" | sed -e 's/^[PVTX]//' | tr ABCDEFGHIJKLMNOPQRSTUVWXYZ abcdefghijklmnopqrstuvwxyz`"
 	# Reset EXIT trap before exiting to avoid spurious non-zero exit code.
 	exitcode=$?
 	trap '' 0
@@ -325,10 +335,10 @@
 	echo m68k-unknown-sysv4
 	exit ;;
     *:[Aa]miga[Oo][Ss]:*:*)
-	echo ${UNAME_MACHINE}-unknown-amigaos
+	echo "$UNAME_MACHINE"-unknown-amigaos
 	exit ;;
     *:[Mm]orph[Oo][Ss]:*:*)
-	echo ${UNAME_MACHINE}-unknown-morphos
+	echo "$UNAME_MACHINE"-unknown-morphos
 	exit ;;
     *:OS/390:*:*)
 	echo i370-ibm-openedition
@@ -340,7 +350,7 @@
 	echo powerpc-ibm-os400
 	exit ;;
     arm:RISC*:1.[012]*:*|arm:riscix:1.[012]*:*)
-	echo arm-acorn-riscix${UNAME_RELEASE}
+	echo arm-acorn-riscix"$UNAME_RELEASE"
 	exit ;;
     arm*:riscos:*:*|arm*:RISCOS:*:*)
 	echo arm-unknown-riscos
@@ -367,19 +377,19 @@
 	    sparc) echo sparc-icl-nx7; exit ;;
 	esac ;;
     s390x:SunOS:*:*)
-	echo ${UNAME_MACHINE}-ibm-solaris2`echo ${UNAME_RELEASE}|sed -e 's/[^.]*//'`
+	echo "$UNAME_MACHINE"-ibm-solaris2"`echo "$UNAME_RELEASE" | sed -e 's/[^.]*//'`"
 	exit ;;
     sun4H:SunOS:5.*:*)
-	echo sparc-hal-solaris2`echo ${UNAME_RELEASE}|sed -e 's/[^.]*//'`
+	echo sparc-hal-solaris2"`echo "$UNAME_RELEASE"|sed -e 's/[^.]*//'`"
 	exit ;;
     sun4*:SunOS:5.*:* | tadpole*:SunOS:5.*:*)
-	echo sparc-sun-solaris2`echo ${UNAME_RELEASE}|sed -e 's/[^.]*//'`
+	echo sparc-sun-solaris2"`echo "$UNAME_RELEASE" | sed -e 's/[^.]*//'`"
 	exit ;;
     i86pc:AuroraUX:5.*:* | i86xen:AuroraUX:5.*:*)
-	echo i386-pc-auroraux${UNAME_RELEASE}
+	echo i386-pc-auroraux"$UNAME_RELEASE"
 	exit ;;
     i86pc:SunOS:5.*:* | i86xen:SunOS:5.*:*)
 	SUN_ARCH=i386
 	# If there is a compiler, see if it is configured for 64-bit objects.
 	# Note that the Sun cc does not turn __LP64__ into 1 like gcc does.
@@ -392,13 +402,13 @@
 		SUN_ARCH=x86_64
 	    fi
 	fi
-	echo ${SUN_ARCH}-pc-solaris2`echo ${UNAME_RELEASE}|sed -e 's/[^.]*//'`
+	echo "$SUN_ARCH"-pc-solaris2"`echo "$UNAME_RELEASE"|sed -e 's/[^.]*//'`"
 	exit ;;
     sun4*:SunOS:6*:*)
 	# According to config.sub, this is the proper way to canonicalize
 	# SunOS6.  Hard to guess exactly what SunOS6 will be like, but
 	# it's likely to be more like Solaris than SunOS4.
-	echo sparc-sun-solaris3`echo ${UNAME_RELEASE}|sed -e 's/[^.]*//'`
+	echo sparc-sun-solaris3"`echo "$UNAME_RELEASE"|sed -e 's/[^.]*//'`"
 	exit ;;
     sun4*:SunOS:*:*)
 	case "`/usr/bin/arch -k`" in
@@ -407,25 +417,25 @@
 	esac
 	# Japanese Language versions have a version number like `4.1.3-JL'.
-	echo sparc-sun-sunos`echo ${UNAME_RELEASE}|sed -e 's/-/_/'`
+	echo sparc-sun-sunos"`echo "$UNAME_RELEASE"|sed -e 's/-/_/'`"
 	exit ;;
     sun3*:SunOS:*:*)
-	echo m68k-sun-sunos${UNAME_RELEASE}
+	echo m68k-sun-sunos"$UNAME_RELEASE"
 	exit ;;
     sun*:*:4.2BSD:*)
 	UNAME_RELEASE=`(sed 1q /etc/motd | awk '{print substr($5,1,3)}') 2>/dev/null`
-	test "x${UNAME_RELEASE}" = x && UNAME_RELEASE=3
+	test "x$UNAME_RELEASE" = x && UNAME_RELEASE=3
 	case "`/bin/arch`" in
 	    sun3)
 	    sun4)
-		echo sparc-sun-sunos${UNAME_RELEASE}
+		echo sparc-sun-sunos"$UNAME_RELEASE"
 	esac
 	exit ;;
     aushp:SunOS:*:*)
-	echo sparc-auspex-sunos${UNAME_RELEASE}
+	echo sparc-auspex-sunos"$UNAME_RELEASE"
 	exit ;;
     # The situation for MiNT is a little confusing.  The machine name
     # can be virtually everything (everything which is not
@@ -436,44 +446,44 @@
     # MiNT.  But MiNT is downward compatible to TOS, so this should
     # be no problem.
     atarist[e]:*MiNT:*:* | atarist[e]:*mint:*:* | atarist[e]:*TOS:*:*)
-	echo m68k-atari-mint${UNAME_RELEASE}
+	echo m68k-atari-mint"$UNAME_RELEASE"
 	exit ;;
     atari*:*MiNT:*:* | atari*:*mint:*:* | atarist[e]:*TOS:*:*)
 	exit ;;
     *falcon*:*MiNT:*:* | *falcon*:*mint:*:* | *falcon*:*TOS:*:*)
 	exit ;;
     milan*:*MiNT:*:* | milan*:*mint:*:* | *milan*:*TOS:*:*)
-	echo m68k-milan-mint${UNAME_RELEASE}
+	echo m68k-milan-mint"$UNAME_RELEASE"
 	exit ;;
     hades*:*MiNT:*:* | hades*:*mint:*:* | *hades*:*TOS:*:*)
-	echo m68k-hades-mint${UNAME_RELEASE}
+	echo m68k-hades-mint"$UNAME_RELEASE"
 	exit ;;
     *:*MiNT:*:* | *:*mint:*:* | *:*TOS:*:*)
-	echo m68k-unknown-mint${UNAME_RELEASE}
+	echo m68k-unknown-mint"$UNAME_RELEASE"
 	exit ;;
     m68k:machten:*:*)
-	echo m68k-apple-machten${UNAME_RELEASE}
+	echo m68k-apple-machten"$UNAME_RELEASE"
 	exit ;;
     powerpc:machten:*:*)
-	echo powerpc-apple-machten${UNAME_RELEASE}
+	echo powerpc-apple-machten"$UNAME_RELEASE"
 	exit ;;
     RISC*:Mach:*:*)
 	echo mips-dec-mach_bsd4.3
 	exit ;;
     RISC*:ULTRIX:*:*)
-	echo mips-dec-ultrix${UNAME_RELEASE}
+	echo mips-dec-ultrix"$UNAME_RELEASE"
 	exit ;;
     VAX*:ULTRIX*:*:*)
-	echo vax-dec-ultrix${UNAME_RELEASE}
+	echo vax-dec-ultrix"$UNAME_RELEASE"
 	exit ;;
     2020:CLIX:*:* | 2430:CLIX:*:*)
-	echo clipper-intergraph-clix${UNAME_RELEASE}
+	echo clipper-intergraph-clix"$UNAME_RELEASE"
 	exit ;;
     mips:*:*:UMIPS | mips:*:*:RISCos)
-	sed 's/^	//' << EOF >$dummy.c
+	sed 's/^	//' << EOF > "$dummy.c"
 #ifdef __cplusplus
 #include <stdio.h>  /* for printf() prototype */
 	int main (int argc, char *argv[]) {
@@ -494,11 +504,11 @@
 	  exit (-1);
 EOF
-	$CC_FOR_BUILD -o $dummy $dummy.c &&
-	  dummyarg=`echo "${UNAME_RELEASE}" | sed -n 's/\([0-9]*\).*/\1/p'` &&
-	  SYSTEM_NAME=`$dummy $dummyarg` &&
+	$CC_FOR_BUILD -o "$dummy" "$dummy.c" &&
+	  dummyarg=`echo "$UNAME_RELEASE" | sed -n 's/\([0-9]*\).*/\1/p'` &&
+	  SYSTEM_NAME=`"$dummy" "$dummyarg"` &&
 	    { echo "$SYSTEM_NAME"; exit; }
-	echo mips-mips-riscos${UNAME_RELEASE}
+	echo mips-mips-riscos"$UNAME_RELEASE"
 	exit ;;
     Motorola:PowerMAX_OS:*:*)
 	echo powerpc-motorola-powermax
@@ -524,17 +534,17 @@
     AViiON:dgux:*:*)
 	# DG/UX returns AViiON for all architectures
 	UNAME_PROCESSOR=`/usr/bin/uname -p`
-	if [ $UNAME_PROCESSOR = mc88100 ] || [ $UNAME_PROCESSOR = mc88110 ]
+	if [ "$UNAME_PROCESSOR" = mc88100 ] || [ "$UNAME_PROCESSOR" = mc88110 ]
 	then
-	    if [ ${TARGET_BINARY_INTERFACE}x = m88kdguxelfx ] || \
-	       [ ${TARGET_BINARY_INTERFACE}x = x ]
+	    if [ "$TARGET_BINARY_INTERFACE"x = m88kdguxelfx ] || \
+	       [ "$TARGET_BINARY_INTERFACE"x = x ]
 	    then
-		echo m88k-dg-dgux${UNAME_RELEASE}
+		echo m88k-dg-dgux"$UNAME_RELEASE"
 	    else
-		echo m88k-dg-dguxbcs${UNAME_RELEASE}
+		echo m88k-dg-dguxbcs"$UNAME_RELEASE"
 	    fi
 	else
-	    echo i586-dg-dgux${UNAME_RELEASE}
+	    echo i586-dg-dgux"$UNAME_RELEASE"
 	fi
 	exit ;;
     M88*:DolphinOS:*:*)	# DolphinOS (SVR3)
@@ -551,7 +561,7 @@
 	echo m68k-tektronix-bsd
 	exit ;;
     *:IRIX*:*:*)
-	echo mips-sgi-irix`echo ${UNAME_RELEASE}|sed -e 's/-/_/g'`
+	echo mips-sgi-irix"`echo "$UNAME_RELEASE"|sed -e 's/-/_/g'`"
 	exit ;;
     ????????:AIX?:[12].1:2)   # AIX 2.2.1 or AIX 2.1.1 is RT/PC AIX.
 	echo romp-ibm-aix     # uname -m gives an 8 hex-code CPU id
@@ -563,14 +573,14 @@
 	if [ -x /usr/bin/oslevel ] ; then
 		IBM_REV=`/usr/bin/oslevel`
 	else
-		IBM_REV=${UNAME_VERSION}.${UNAME_RELEASE}
+		IBM_REV="$UNAME_VERSION.$UNAME_RELEASE"
 	fi
-	echo ${UNAME_MACHINE}-ibm-aix${IBM_REV}
+	echo "$UNAME_MACHINE"-ibm-aix"$IBM_REV"
 	exit ;;
     *:AIX:2:3)
 	if grep bos325 /usr/include/stdio.h >/dev/null 2>&1; then
 		#include <sys/systemcfg.h>
 		main()
@@ -581,7 +591,7 @@
 			exit(0);
 EOF
-		if $CC_FOR_BUILD -o $dummy $dummy.c && SYSTEM_NAME=`$dummy`
+		if $CC_FOR_BUILD -o "$dummy" "$dummy.c" && SYSTEM_NAME=`"$dummy"`
 		then
 			echo "$SYSTEM_NAME"
 		else
@@ -595,7 +605,7 @@
 	exit ;;
     *:AIX:*:[4567])
 	IBM_CPU_ID=`/usr/sbin/lsdev -C -c processor -S available | sed 1q | awk '{ print $1 }'`
-	if /usr/sbin/lsattr -El ${IBM_CPU_ID} | grep ' POWER' >/dev/null 2>&1; then
+	if /usr/sbin/lsattr -El "$IBM_CPU_ID" | grep ' POWER' >/dev/null 2>&1; then
 		IBM_ARCH=rs6000
 	else
 		IBM_ARCH=powerpc
@@ -604,9 +614,9 @@
 		IBM_REV=`/usr/bin/lslpp -Lqc bos.rte.libc |
 			   awk -F: '{ print $3 }' | sed s/[0-9]*$/0/`
 	else
 	fi
-	echo ${IBM_ARCH}-ibm-aix${IBM_REV}
+	echo "$IBM_ARCH"-ibm-aix"$IBM_REV"
 	exit ;;
     *:AIX:*:*)
 	echo rs6000-ibm-aix
@@ -615,7 +625,7 @@
 	echo romp-ibm-bsd4.4
 	exit ;;
     ibmrt:*BSD:*|romp-ibm:BSD:*)            # covers RT/PC BSD and
-	echo romp-ibm-bsd${UNAME_RELEASE}   # 4.3 with uname added to
+	echo romp-ibm-bsd"$UNAME_RELEASE"   # 4.3 with uname added to
 	exit ;;                             # report: romp-ibm BSD 4.3
     *:BOSX:*:*)
 	echo rs6000-bull-bosx
@@ -630,8 +640,8 @@
 	echo m68k-hp-bsd4.4
 	exit ;;
     9000/[34678]??:HP-UX:*:*)
-	HPUX_REV=`echo ${UNAME_RELEASE}|sed -e 's/[^.]*.[0B]*//'`
-	case "${UNAME_MACHINE}" in
+	HPUX_REV=`echo "$UNAME_RELEASE"|sed -e 's/[^.]*.[0B]*//'`
+	case "$UNAME_MACHINE" in
 	    9000/31?)            HP_ARCH=m68000 ;;
 	    9000/[34]??)         HP_ARCH=m68k ;;
 	    9000/[678][0-9][0-9])
@@ -638,11 +648,11 @@
 		if [ -x /usr/bin/getconf ]; then
 		    sc_cpu_version=`/usr/bin/getconf SC_CPU_VERSION 2>/dev/null`
 		    sc_kernel_bits=`/usr/bin/getconf SC_KERNEL_BITS 2>/dev/null`
-		    case "${sc_cpu_version}" in
+		    case "$sc_cpu_version" in
 		      523) HP_ARCH=hppa1.0 ;; # CPU_PA_RISC1_0
 		      528) HP_ARCH=hppa1.1 ;; # CPU_PA_RISC1_1
 		      532)                      # CPU_PA_RISC2_0
-			case "${sc_kernel_bits}" in
+			case "$sc_kernel_bits" in
 			  32) HP_ARCH=hppa2.0n ;;
 			  64) HP_ARCH=hppa2.0w ;;
 			  '') HP_ARCH=hppa2.0 ;;   # HP-UX 10.20
@@ -649,9 +659,9 @@
 			esac ;;
 		    esac
 		fi
-		if [ "${HP_ARCH}" = "" ]; then
+		if [ "$HP_ARCH" = "" ]; then
 		#define _HPUX_SOURCE
 		#include <stdlib.h>
@@ -684,13 +694,13 @@
 		    exit (0);
 EOF
-		    (CCOPTS="" $CC_FOR_BUILD -o $dummy $dummy.c 2>/dev/null) && HP_ARCH=`$dummy`
+		    (CCOPTS="" $CC_FOR_BUILD -o "$dummy" "$dummy.c" 2>/dev/null) && HP_ARCH=`"$dummy"`
 		    test -z "$HP_ARCH" && HP_ARCH=hppa
 		fi ;;
 	esac
-	if [ ${HP_ARCH} = hppa2.0w ]
+	if [ "$HP_ARCH" = hppa2.0w ]
 	then
 	    # hppa2.0w-hp-hpux* has a 64-bit kernel and a compiler generating
 	    # 32-bit code.  hppa64-hp-hpux* has the same kernel and a compiler
@@ -709,15 +719,15 @@
 		HP_ARCH=hppa64
 	    fi
 	fi
-	echo ${HP_ARCH}-hp-hpux${HPUX_REV}
+	echo "$HP_ARCH"-hp-hpux"$HPUX_REV"
 	exit ;;
     ia64:HP-UX:*:*)
-	echo ia64-hp-hpux${HPUX_REV}
+	echo ia64-hp-hpux"$HPUX_REV"
 	exit ;;
     3050*:HI-UX:*:*)
 	#include <unistd.h>
 	int
 	main ()
@@ -742,7 +752,7 @@
 	  exit (0);
 EOF
-	$CC_FOR_BUILD -o $dummy $dummy.c && SYSTEM_NAME=`$dummy` &&
+	$CC_FOR_BUILD -o "$dummy" "$dummy.c" && SYSTEM_NAME=`"$dummy"` &&
 	echo unknown-hitachi-hiuxwe2
 	exit ;;
@@ -763,9 +773,9 @@
 	exit ;;
     i*86:OSF1:*:*)
 	if [ -x /usr/sbin/sysversion ] ; then
-	    echo ${UNAME_MACHINE}-unknown-osf1mk
+	    echo "$UNAME_MACHINE"-unknown-osf1mk
 	else
 	fi
 	exit ;;
     parisc*:Lites*:*:*)
@@ -790,109 +800,109 @@
 	echo c4-convex-bsd
 	exit ;;
     CRAY*Y-MP:*:*:*)
-	echo ymp-cray-unicos${UNAME_RELEASE} | sed -e 's/\.[^.]*$/.X/'
+	echo ymp-cray-unicos"$UNAME_RELEASE" | sed -e 's/\.[^.]*$/.X/'
 	exit ;;
     CRAY*[A-Z]90:*:*:*)
-	echo ${UNAME_MACHINE}-cray-unicos${UNAME_RELEASE} \
+	echo "$UNAME_MACHINE"-cray-unicos"$UNAME_RELEASE" \
 	| sed -e 's/CRAY.*\([A-Z]90\)/\1/' \
 	      -e y/ABCDEFGHIJKLMNOPQRSTUVWXYZ/abcdefghijklmnopqrstuvwxyz/ \
 	      -e 's/\.[^.]*$/.X/'
 	exit ;;
     CRAY*TS:*:*:*)
-	echo t90-cray-unicos${UNAME_RELEASE} | sed -e 's/\.[^.]*$/.X/'
+	echo t90-cray-unicos"$UNAME_RELEASE" | sed -e 's/\.[^.]*$/.X/'
 	exit ;;
     CRAY*T3E:*:*:*)
-	echo alphaev5-cray-unicosmk${UNAME_RELEASE} | sed -e 's/\.[^.]*$/.X/'
+	echo alphaev5-cray-unicosmk"$UNAME_RELEASE" | sed -e 's/\.[^.]*$/.X/'
 	exit ;;
     CRAY*SV1:*:*:*)
-	echo sv1-cray-unicos${UNAME_RELEASE} | sed -e 's/\.[^.]*$/.X/'
+	echo sv1-cray-unicos"$UNAME_RELEASE" | sed -e 's/\.[^.]*$/.X/'
 	exit ;;
     *:UNICOS/mp:*:*)
-	echo craynv-cray-unicosmp${UNAME_RELEASE} | sed -e 's/\.[^.]*$/.X/'
+	echo craynv-cray-unicosmp"$UNAME_RELEASE" | sed -e 's/\.[^.]*$/.X/'
 	exit ;;
     F30[01]:UNIX_System_V:*:* | F700:UNIX_System_V:*:*)
 	FUJITSU_PROC=`uname -m | tr ABCDEFGHIJKLMNOPQRSTUVWXYZ abcdefghijklmnopqrstuvwxyz`
 	FUJITSU_SYS=`uname -p | tr ABCDEFGHIJKLMNOPQRSTUVWXYZ abcdefghijklmnopqrstuvwxyz | sed -e 's/\///'`
-	FUJITSU_REL=`echo ${UNAME_RELEASE} | sed -e 's/ /_/'`
+	FUJITSU_REL=`echo "$UNAME_RELEASE" | sed -e 's/ /_/'`
 	echo "${FUJITSU_PROC}-fujitsu-${FUJITSU_SYS}${FUJITSU_REL}"
 	exit ;;
     5000:UNIX_System_V:4.*:*)
-	FUJITSU_REL=`echo ${UNAME_RELEASE} | tr ABCDEFGHIJKLMNOPQRSTUVWXYZ abcdefghijklmnopqrstuvwxyz | sed -e 's/ /_/'`
+	FUJITSU_REL=`echo "$UNAME_RELEASE" | tr ABCDEFGHIJKLMNOPQRSTUVWXYZ abcdefghijklmnopqrstuvwxyz | sed -e 's/ /_/'`
 	echo "sparc-fujitsu-${FUJITSU_SYS}${FUJITSU_REL}"
 	exit ;;
     i*86:BSD/386:*:* | i*86:BSD/OS:*:* | *:Ascend\ Embedded/OS:*:*)
-	echo ${UNAME_MACHINE}-pc-bsdi${UNAME_RELEASE}
+	echo "$UNAME_MACHINE"-pc-bsdi"$UNAME_RELEASE"
 	exit ;;
     sparc*:BSD/OS:*:*)
-	echo sparc-unknown-bsdi${UNAME_RELEASE}
+	echo sparc-unknown-bsdi"$UNAME_RELEASE"
 	exit ;;
     *:BSD/OS:*:*)
-	echo ${UNAME_MACHINE}-unknown-bsdi${UNAME_RELEASE}
+	echo "$UNAME_MACHINE"-unknown-bsdi"$UNAME_RELEASE"
 	exit ;;
     *:FreeBSD:*:*)
-	case ${UNAME_PROCESSOR} in
+	case "$UNAME_PROCESSOR" in
 	    amd64)
 		UNAME_PROCESSOR=x86_64 ;;
 	    i386)
 		UNAME_PROCESSOR=i586 ;;
 	esac
-	echo ${UNAME_PROCESSOR}-unknown-freebsd`echo ${UNAME_RELEASE}|sed -e 's/[-(].*//'`
+	echo "$UNAME_PROCESSOR"-unknown-freebsd"`echo "$UNAME_RELEASE"|sed -e 's/[-(].*//'`"
 	exit ;;
     i*:CYGWIN*:*)
-	echo ${UNAME_MACHINE}-pc-cygwin
+	echo "$UNAME_MACHINE"-pc-cygwin
 	exit ;;
     *:MINGW64*:*)
-	echo ${UNAME_MACHINE}-pc-mingw64
+	echo "$UNAME_MACHINE"-pc-mingw64
 	exit ;;
     *:MINGW*:*)
-	echo ${UNAME_MACHINE}-pc-mingw32
+	echo "$UNAME_MACHINE"-pc-mingw32
 	exit ;;
     *:MSYS*:*)
-	echo ${UNAME_MACHINE}-pc-msys
+	echo "$UNAME_MACHINE"-pc-msys
 	exit ;;
     i*:PW*:*)
-	echo ${UNAME_MACHINE}-pc-pw32
+	echo "$UNAME_MACHINE"-pc-pw32
 	exit ;;
     *:Interix*:*)
-	case ${UNAME_MACHINE} in
 	    x86)
-		echo i586-pc-interix${UNAME_RELEASE}
+		echo i586-pc-interix"$UNAME_RELEASE"
 		exit ;;
 	    authenticamd | genuineintel | EM64T)
-		echo x86_64-unknown-interix${UNAME_RELEASE}
+		echo x86_64-unknown-interix"$UNAME_RELEASE"
 		exit ;;
 	    IA64)
-		echo ia64-unknown-interix${UNAME_RELEASE}
+		echo ia64-unknown-interix"$UNAME_RELEASE"
 		exit ;;
 	esac ;;
     i*:UWIN*:*)
-	echo ${UNAME_MACHINE}-pc-uwin
+	echo "$UNAME_MACHINE"-pc-uwin
 	exit ;;
     amd64:CYGWIN*:*:* | x86_64:CYGWIN*:*:*)
 	echo x86_64-unknown-cygwin
 	exit ;;
     prep*:SunOS:5.*:*)
-	echo powerpcle-unknown-solaris2`echo ${UNAME_RELEASE}|sed -e 's/[^.]*//'`
+	echo powerpcle-unknown-solaris2"`echo "$UNAME_RELEASE"|sed -e 's/[^.]*//'`"
 	exit ;;
     *:GNU:*:*)
 	# the GNU system
-	echo `echo ${UNAME_MACHINE}|sed -e 's,[-/].*$,,'`-unknown-${LIBC}`echo ${UNAME_RELEASE}|sed -e 's,/.*$,,'`
+	echo "`echo "$UNAME_MACHINE"|sed -e 's,[-/].*$,,'`-unknown-$LIBC`echo "$UNAME_RELEASE"|sed -e 's,/.*$,,'`"
 	exit ;;
     *:GNU/*:*:*)
 	# other systems with GNU libc and userland
-	echo ${UNAME_MACHINE}-unknown-`echo ${UNAME_SYSTEM} | sed 's,^[^/]*/,,' | tr "[:upper:]" "[:lower:]"``echo ${UNAME_RELEASE}|sed -e 's/[-(].*//'`-${LIBC}
+	echo "$UNAME_MACHINE-unknown-`echo "$UNAME_SYSTEM" | sed 's,^[^/]*/,,' | tr "[:upper:]" "[:lower:]"``echo "$UNAME_RELEASE"|sed -e 's/[-(].*//'`-$LIBC"
 	exit ;;
     i*86:Minix:*:*)
-	echo ${UNAME_MACHINE}-pc-minix
+	echo "$UNAME_MACHINE"-pc-minix
 	exit ;;
     aarch64:Linux:*:*)
-	echo ${UNAME_MACHINE}-unknown-linux-${LIBC}
+	echo "$UNAME_MACHINE"-unknown-linux-"$LIBC"
 	exit ;;
     aarch64_be:Linux:*:*)
 	UNAME_MACHINE=aarch64_be
 	exit ;;
     alpha:Linux:*:*)
 	case `sed -n '/^cpu model/s/^.*: \(.*\)/\1/p' < /proc/cpuinfo` in
@@ -906,63 +916,63 @@
 	esac
 	objdump --private-headers /bin/sh | grep -q ld.so.1
 	if test "$?" = 0 ; then LIBC=gnulibc1 ; fi
 	exit ;;
     arc:Linux:*:* | arceb:Linux:*:*)
 	exit ;;
     arm*:Linux:*:*)
 	if echo __ARM_EABI__ | $CC_FOR_BUILD -E - 2>/dev/null \
 	    | grep -q __ARM_EABI__
 	then
 	else
 	    if echo __ARM_PCS_VFP | $CC_FOR_BUILD -E - 2>/dev/null \
 		| grep -q __ARM_PCS_VFP
 	    then
-		echo ${UNAME_MACHINE}-unknown-linux-${LIBC}eabi
+		echo "$UNAME_MACHINE"-unknown-linux-"$LIBC"eabi
 	    else
-		echo ${UNAME_MACHINE}-unknown-linux-${LIBC}eabihf
+		echo "$UNAME_MACHINE"-unknown-linux-"$LIBC"eabihf
 	    fi
 	fi
 	exit ;;
     avr32*:Linux:*:*)
 	exit ;;
     cris:Linux:*:*)
-	echo ${UNAME_MACHINE}-axis-linux-${LIBC}
+	echo "$UNAME_MACHINE"-axis-linux-"$LIBC"
 	exit ;;
     crisv32:Linux:*:*)
 	exit ;;
     e2k:Linux:*:*)
 	exit ;;
     frv:Linux:*:*)
 	exit ;;
     hexagon:Linux:*:*)
 	exit ;;
     i*86:Linux:*:*)
-	echo ${UNAME_MACHINE}-pc-linux-${LIBC}
+	echo "$UNAME_MACHINE"-pc-linux-"$LIBC"
 	exit ;;
     ia64:Linux:*:*)
 	exit ;;
     k1om:Linux:*:*)
 	exit ;;
     m32r*:Linux:*:*)
 	exit ;;
     m68*:Linux:*:*)
 	exit ;;
     mips:Linux:*:* | mips64:Linux:*:*)
 	#undef CPU
 	#undef ${UNAME_MACHINE}
 	#undef ${UNAME_MACHINE}el
@@ -976,70 +986,70 @@
 	#endif
 	#endif
 EOF
-	eval `$CC_FOR_BUILD -E $dummy.c 2>/dev/null | grep '^CPU'`
-	test x"${CPU}" != x && { echo "${CPU}-unknown-linux-${LIBC}"; exit; }
+	eval "`$CC_FOR_BUILD -E "$dummy.c" 2>/dev/null | grep '^CPU'`"
+	test "x$CPU" != x && { echo "$CPU-unknown-linux-$LIBC"; exit; }
     mips64el:Linux:*:*)
 	exit ;;
     openrisc*:Linux:*:*)
-	echo or1k-unknown-linux-${LIBC}
+	echo or1k-unknown-linux-"$LIBC"
 	exit ;;
     or32:Linux:*:* | or1k*:Linux:*:*)
 	exit ;;
     padre:Linux:*:*)
-	echo sparc-unknown-linux-${LIBC}
+	echo sparc-unknown-linux-"$LIBC"
 	exit ;;
     parisc64:Linux:*:* | hppa64:Linux:*:*)
-	echo hppa64-unknown-linux-${LIBC}
+	echo hppa64-unknown-linux-"$LIBC"
 	exit ;;
     parisc:Linux:*:* | hppa:Linux:*:*)
 	# Look for CPU level
 	case `grep '^cpu[^a-z]*:' /proc/cpuinfo 2>/dev/null | cut -d' ' -f2` in
-	  PA7*) echo hppa1.1-unknown-linux-${LIBC} ;;
-	  PA8*) echo hppa2.0-unknown-linux-${LIBC} ;;
-	  *)    echo hppa-unknown-linux-${LIBC} ;;
+	  PA7*) echo hppa1.1-unknown-linux-"$LIBC" ;;
+	  PA8*) echo hppa2.0-unknown-linux-"$LIBC" ;;
+	  *)    echo hppa-unknown-linux-"$LIBC" ;;
 	esac
 	exit ;;
     ppc64:Linux:*:*)
-	echo powerpc64-unknown-linux-${LIBC}
+	echo powerpc64-unknown-linux-"$LIBC"
 	exit ;;
     ppc:Linux:*:*)
-	echo powerpc-unknown-linux-${LIBC}
+	echo powerpc-unknown-linux-"$LIBC"
 	exit ;;
     ppc64le:Linux:*:*)
-	echo powerpc64le-unknown-linux-${LIBC}
+	echo powerpc64le-unknown-linux-"$LIBC"
 	exit ;;
     ppcle:Linux:*:*)
-	echo powerpcle-unknown-linux-${LIBC}
+	echo powerpcle-unknown-linux-"$LIBC"
 	exit ;;
     riscv32:Linux:*:* | riscv64:Linux:*:*)
 	exit ;;
     s390:Linux:*:* | s390x:Linux:*:*)
-	echo ${UNAME_MACHINE}-ibm-linux-${LIBC}
+	echo "$UNAME_MACHINE"-ibm-linux-"$LIBC"
 	exit ;;
     sh64*:Linux:*:*)
 	exit ;;
     sh*:Linux:*:*)
 	exit ;;
     sparc:Linux:*:* | sparc64:Linux:*:*)
 	exit ;;
     tile*:Linux:*:*)
 	exit ;;
     vax:Linux:*:*)
-	echo ${UNAME_MACHINE}-dec-linux-${LIBC}
+	echo "$UNAME_MACHINE"-dec-linux-"$LIBC"
 	exit ;;
     x86_64:Linux:*:*)
 	exit ;;
     xtensa*:Linux:*:*)
 	exit ;;
     i*86:DYNIX/ptx:4*:*)
 	# ptx 4.0 does uname -s correctly, with DYNIX/ptx in there.
@@ -1053,34 +1063,34 @@
 	# I am not positive that other SVR4 systems won't match this,
 	# I just have to hope.  -- rms.
 	# Use sysv4.2uw... so that sysv4* matches it.
-	echo ${UNAME_MACHINE}-pc-sysv4.2uw${UNAME_VERSION}
+	echo "$UNAME_MACHINE"-pc-sysv4.2uw"$UNAME_VERSION"
 	exit ;;
     i*86:OS/2:*:*)
 	# If we were able to find `uname', then EMX Unix compatibility
 	# is probably installed.
-	echo ${UNAME_MACHINE}-pc-os2-emx
+	echo "$UNAME_MACHINE"-pc-os2-emx
 	exit ;;
     i*86:XTS-300:*:STOP)
-	echo ${UNAME_MACHINE}-unknown-stop
+	echo "$UNAME_MACHINE"-unknown-stop
 	exit ;;
     i*86:atheos:*:*)
-	echo ${UNAME_MACHINE}-unknown-atheos
+	echo "$UNAME_MACHINE"-unknown-atheos
 	exit ;;
     i*86:syllable:*:*)
-	echo ${UNAME_MACHINE}-pc-syllable
+	echo "$UNAME_MACHINE"-pc-syllable
 	exit ;;
     i*86:LynxOS:2.*:* | i*86:LynxOS:3.[01]*:* | i*86:LynxOS:4.[02]*:*)
-	echo i386-unknown-lynxos${UNAME_RELEASE}
+	echo i386-unknown-lynxos"$UNAME_RELEASE"
 	exit ;;
     i*86:*DOS:*:*)
-	echo ${UNAME_MACHINE}-pc-msdosdjgpp
+	echo "$UNAME_MACHINE"-pc-msdosdjgpp
 	exit ;;
     i*86:*:4.*:*)
-	UNAME_REL=`echo ${UNAME_RELEASE} | sed 's/\/MP$//'`
+	UNAME_REL=`echo "$UNAME_RELEASE" | sed 's/\/MP$//'`
 	if grep Novell /usr/include/link.h >/dev/null 2>/dev/null; then
-		echo ${UNAME_MACHINE}-univel-sysv${UNAME_REL}
+		echo "$UNAME_MACHINE"-univel-sysv"$UNAME_REL"
 	else
-		echo ${UNAME_MACHINE}-pc-sysv${UNAME_REL}
+		echo "$UNAME_MACHINE"-pc-sysv"$UNAME_REL"
 	fi
 	exit ;;
     i*86:*:5:[678]*)
@@ -1090,12 +1100,12 @@
 	    *Pentium)	     UNAME_MACHINE=i586 ;;
 	    *Pent*|*Celeron) UNAME_MACHINE=i686 ;;
 	esac
-	echo ${UNAME_MACHINE}-unknown-sysv${UNAME_RELEASE}${UNAME_SYSTEM}${UNAME_VERSION}
+	echo "$UNAME_MACHINE-unknown-sysv${UNAME_RELEASE}${UNAME_SYSTEM}{$UNAME_VERSION}"
 	exit ;;
     i*86:*:3.2:*)
 	if test -f /usr/options/cb.name; then
 		UNAME_REL=`sed -n 's/.*Version //p' </usr/options/cb.name`
-		echo ${UNAME_MACHINE}-pc-isc$UNAME_REL
+		echo "$UNAME_MACHINE"-pc-isc"$UNAME_REL"
 	elif /bin/uname -X 2>/dev/null >/dev/null ; then
 		UNAME_REL=`(/bin/uname -X|grep Release|sed -e 's/.*= //')`
 		(/bin/uname -X|grep i80486 >/dev/null) && UNAME_MACHINE=i486
@@ -1105,9 +1115,9 @@
 			&& UNAME_MACHINE=i686
 		(/bin/uname -X|grep '^Machine.*Pentium Pro' >/dev/null) \
-		echo ${UNAME_MACHINE}-pc-sco$UNAME_REL
+		echo "$UNAME_MACHINE"-pc-sco"$UNAME_REL"
 	else
-		echo ${UNAME_MACHINE}-pc-sysv32
+		echo "$UNAME_MACHINE"-pc-sysv32
 	fi
 	exit ;;
     pc:*:*:*)
@@ -1127,9 +1137,9 @@
 	exit ;;
     i860:*:4.*:*) # i860-SVR4
 	if grep Stardent /usr/include/sys/uadmin.h >/dev/null 2>&1 ; then
-	  echo i860-stardent-sysv${UNAME_RELEASE} # Stardent Vistra i860-SVR4
+	  echo i860-stardent-sysv"$UNAME_RELEASE" # Stardent Vistra i860-SVR4
 	else # Add other i860-SVR4 vendors below as they are discovered.
-	  echo i860-unknown-sysv${UNAME_RELEASE}  # Unknown i860-SVR4
+	  echo i860-unknown-sysv"$UNAME_RELEASE"  # Unknown i860-SVR4
 	fi
 	exit ;;
     mini*:CTIX:SYS*5:*)
@@ -1149,9 +1159,9 @@
 	test -r /etc/.relid \
 	&& OS_REL=.`sed -n 's/[^ ]* [^ ]* \([0-9][0-9]\).*/\1/p' < /etc/.relid`
 	/bin/uname -p 2>/dev/null | grep 86 >/dev/null \
-	  && { echo i486-ncr-sysv4.3${OS_REL}; exit; }
+	  && { echo i486-ncr-sysv4.3"$OS_REL"; exit; }
 	/bin/uname -p 2>/dev/null | /bin/grep entium >/dev/null \
-	  && { echo i586-ncr-sysv4.3${OS_REL}; exit; } ;;
+	  && { echo i586-ncr-sysv4.3"$OS_REL"; exit; } ;;
     3[34]??:*:4.0:* | 3[34]??,*:*:4.0:*)
 	  && { echo i486-ncr-sysv4; exit; } ;;
@@ -1160,28 +1170,28 @@
 	/bin/uname -p 2>/dev/null | /bin/grep pteron >/dev/null \
     m68*:LynxOS:2.*:* | m68*:LynxOS:3.0*:*)
-	echo m68k-unknown-lynxos${UNAME_RELEASE}
+	echo m68k-unknown-lynxos"$UNAME_RELEASE"
 	exit ;;
     mc68030:UNIX_System_V:4.*:*)
 	echo m68k-atari-sysv4
 	exit ;;
     TSUNAMI:LynxOS:2.*:*)
-	echo sparc-unknown-lynxos${UNAME_RELEASE}
+	echo sparc-unknown-lynxos"$UNAME_RELEASE"
 	exit ;;
     rs6000:LynxOS:2.*:*)
-	echo rs6000-unknown-lynxos${UNAME_RELEASE}
+	echo rs6000-unknown-lynxos"$UNAME_RELEASE"
 	exit ;;
     PowerPC:LynxOS:2.*:* | PowerPC:LynxOS:3.[01]*:* | PowerPC:LynxOS:4.[02]*:*)
-	echo powerpc-unknown-lynxos${UNAME_RELEASE}
+	echo powerpc-unknown-lynxos"$UNAME_RELEASE"
 	exit ;;
     SM[BE]S:UNIX_SV:*:*)
-	echo mips-dde-sysv${UNAME_RELEASE}
+	echo mips-dde-sysv"$UNAME_RELEASE"
 	exit ;;
     RM*:ReliantUNIX-*:*:*)
 	echo mips-sni-sysv4
@@ -1192,7 +1202,7 @@
     *:SINIX-*:*:*)
 	if uname -p 2>/dev/null >/dev/null ; then
 		UNAME_MACHINE=`(uname -p) 2>/dev/null`
-		echo ${UNAME_MACHINE}-sni-sysv4
+		echo "$UNAME_MACHINE"-sni-sysv4
 	else
 		echo ns32k-sni-sysv
 	fi
@@ -1212,7 +1222,7 @@
 	exit ;;
     i*86:VOS:*:*)
 	# From Paul.Green at stratus.com.
-	echo ${UNAME_MACHINE}-stratus-vos
+	echo "$UNAME_MACHINE"-stratus-vos
 	exit ;;
     *:VOS:*:*)
@@ -1219,7 +1229,7 @@
 	echo hppa1.1-stratus-vos
 	exit ;;
     mc68*:A/UX:*:*)
-	echo m68k-apple-aux${UNAME_RELEASE}
+	echo m68k-apple-aux"$UNAME_RELEASE"
 	exit ;;
     news*:NEWS-OS:6*:*)
 	echo mips-sony-newsos6
@@ -1226,9 +1236,9 @@
 	exit ;;
     R[34]000:*System_V*:*:* | R4000:UNIX_SYSV:*:* | R*000:UNIX_SV:*:*)
 	if [ -d /usr/nec ]; then
-		echo mips-nec-sysv${UNAME_RELEASE}
+		echo mips-nec-sysv"$UNAME_RELEASE"
 	else
-		echo mips-unknown-sysv${UNAME_RELEASE}
+		echo mips-unknown-sysv"$UNAME_RELEASE"
 	fi
 	exit ;;
     BeBox:BeOS:*:*)	# BeOS running on hardware made by Be, PPC only.
@@ -1247,39 +1257,39 @@
 	echo x86_64-unknown-haiku
 	exit ;;
     SX-4:SUPER-UX:*:*)
-	echo sx4-nec-superux${UNAME_RELEASE}
+	echo sx4-nec-superux"$UNAME_RELEASE"
 	exit ;;
     SX-5:SUPER-UX:*:*)
-	echo sx5-nec-superux${UNAME_RELEASE}
+	echo sx5-nec-superux"$UNAME_RELEASE"
 	exit ;;
     SX-6:SUPER-UX:*:*)
-	echo sx6-nec-superux${UNAME_RELEASE}
+	echo sx6-nec-superux"$UNAME_RELEASE"
 	exit ;;
     SX-7:SUPER-UX:*:*)
-	echo sx7-nec-superux${UNAME_RELEASE}
+	echo sx7-nec-superux"$UNAME_RELEASE"
 	exit ;;
     SX-8:SUPER-UX:*:*)
-	echo sx8-nec-superux${UNAME_RELEASE}
+	echo sx8-nec-superux"$UNAME_RELEASE"
 	exit ;;
     SX-8R:SUPER-UX:*:*)
-	echo sx8r-nec-superux${UNAME_RELEASE}
+	echo sx8r-nec-superux"$UNAME_RELEASE"
 	exit ;;
     SX-ACE:SUPER-UX:*:*)
-	echo sxace-nec-superux${UNAME_RELEASE}
+	echo sxace-nec-superux"$UNAME_RELEASE"
 	exit ;;
     Power*:Rhapsody:*:*)
-	echo powerpc-apple-rhapsody${UNAME_RELEASE}
+	echo powerpc-apple-rhapsody"$UNAME_RELEASE"
 	exit ;;
     *:Rhapsody:*:*)
-	echo ${UNAME_MACHINE}-apple-rhapsody${UNAME_RELEASE}
+	echo "$UNAME_MACHINE"-apple-rhapsody"$UNAME_RELEASE"
 	exit ;;
     *:Darwin:*:*)
 	UNAME_PROCESSOR=`uname -p` || UNAME_PROCESSOR=unknown
 	if test "$UNAME_PROCESSOR" = unknown ; then
 	    UNAME_PROCESSOR=powerpc
 	fi
-	if test `echo "$UNAME_RELEASE" | sed -e 's/\..*//'` -le 10 ; then
+	if test "`echo "$UNAME_RELEASE" | sed -e 's/\..*//'`" -le 10 ; then
 	    if [ "$CC_FOR_BUILD" != no_compiler_found ]; then
 		if (echo '#ifdef __LP64__'; echo IS_64BIT_ARCH; echo '#endif') | \
 		       (CCOPTS="" $CC_FOR_BUILD -E - 2>/dev/null) | \
@@ -1307,7 +1317,7 @@
 	    # that Apple uses in portable devices.
 	fi
-	echo ${UNAME_PROCESSOR}-apple-darwin${UNAME_RELEASE}
+	echo "$UNAME_PROCESSOR"-apple-darwin"$UNAME_RELEASE"
 	exit ;;
     *:procnto*:*:* | *:QNX:[0123456789]*:*)
@@ -1315,22 +1325,25 @@
 		UNAME_PROCESSOR=i386
 		UNAME_MACHINE=pc
 	fi
-	echo ${UNAME_PROCESSOR}-${UNAME_MACHINE}-nto-qnx${UNAME_RELEASE}
+	echo "$UNAME_PROCESSOR"-"$UNAME_MACHINE"-nto-qnx"$UNAME_RELEASE"
 	exit ;;
     *:QNX:*:4*)
 	echo i386-pc-qnx
 	exit ;;
     NEO-*:NONSTOP_KERNEL:*:*)
-	echo neo-tandem-nsk${UNAME_RELEASE}
+	echo neo-tandem-nsk"$UNAME_RELEASE"
 	exit ;;
     NSE-*:NONSTOP_KERNEL:*:*)
-	echo nse-tandem-nsk${UNAME_RELEASE}
+	echo nse-tandem-nsk"$UNAME_RELEASE"
 	exit ;;
     NSR-*:NONSTOP_KERNEL:*:*)
-	echo nsr-tandem-nsk${UNAME_RELEASE}
+	echo nsr-tandem-nsk"$UNAME_RELEASE"
 	exit ;;
+    NSV-*:NONSTOP_KERNEL:*:*)
+	echo nsv-tandem-nsk"$UNAME_RELEASE"
+	exit ;;
     NSX-*:NONSTOP_KERNEL:*:*)
-	echo nsx-tandem-nsk${UNAME_RELEASE}
+	echo nsx-tandem-nsk"$UNAME_RELEASE"
 	exit ;;
     *:NonStop-UX:*:*)
 	echo mips-compaq-nonstopux
@@ -1339,7 +1352,7 @@
 	echo bs2000-siemens-sysv
 	exit ;;
     DS/*:UNIX_System_V:*:*)
-	echo ${UNAME_MACHINE}-${UNAME_SYSTEM}-${UNAME_RELEASE}
+	echo "$UNAME_MACHINE"-"$UNAME_SYSTEM"-"$UNAME_RELEASE"
 	exit ;;
     *:Plan9:*:*)
 	# "uname -m" is not consistent, so use $cputype instead. 386
@@ -1350,7 +1363,7 @@
 	else
 	    UNAME_MACHINE="$cputype"
 	fi
-	echo ${UNAME_MACHINE}-unknown-plan9
+	echo "$UNAME_MACHINE"-unknown-plan9
 	exit ;;
     *:TOPS-10:*:*)
 	echo pdp10-unknown-tops10
@@ -1371,14 +1384,14 @@
 	echo pdp10-unknown-its
 	exit ;;
     SEI:*:*:SEIUX)
-	echo mips-sei-seiux${UNAME_RELEASE}
+	echo mips-sei-seiux"$UNAME_RELEASE"
 	exit ;;
     *:DragonFly:*:*)
-	echo ${UNAME_MACHINE}-unknown-dragonfly`echo ${UNAME_RELEASE}|sed -e 's/[-(].*//'`
+	echo "$UNAME_MACHINE"-unknown-dragonfly"`echo "$UNAME_RELEASE"|sed -e 's/[-(].*//'`"
 	exit ;;
     *:*VMS:*:*)
 	    A*) echo alpha-dec-vms ; exit ;;
 	    I*) echo ia64-dec-vms ; exit ;;
 	    V*) echo vax-dec-vms ; exit ;;
@@ -1387,16 +1400,16 @@
 	echo i386-pc-xenix
 	exit ;;
     i*86:skyos:*:*)
-	echo ${UNAME_MACHINE}-pc-skyos`echo ${UNAME_RELEASE} | sed -e 's/ .*$//'`
+	echo "$UNAME_MACHINE"-pc-skyos"`echo "$UNAME_RELEASE" | sed -e 's/ .*$//'`"
 	exit ;;
     i*86:rdos:*:*)
-	echo ${UNAME_MACHINE}-pc-rdos
+	echo "$UNAME_MACHINE"-pc-rdos
 	exit ;;
     i*86:AROS:*:*)
-	echo ${UNAME_MACHINE}-pc-aros
+	echo "$UNAME_MACHINE"-pc-aros
 	exit ;;
     x86_64:VMkernel:*:*)
-	echo ${UNAME_MACHINE}-unknown-esx
+	echo "$UNAME_MACHINE"-unknown-esx
 	exit ;;
     amd64:Isilon\ OneFS:*:*)
 	echo x86_64-unknown-onefs
@@ -1405,7 +1418,7 @@
 echo "$0: unable to guess system type" >&2
-case "${UNAME_MACHINE}:${UNAME_SYSTEM}" in
+case "$UNAME_MACHINE:$UNAME_SYSTEM" in
     mips:Linux | mips64:Linux)
 	# If we got here on MIPS GNU/Linux, output extra information.
 	cat >&2 <<EOF
@@ -1447,16 +1460,16 @@
 /usr/bin/oslevel       = `(/usr/bin/oslevel) 2>/dev/null`
 /usr/convex/getsysinfo = `(/usr/convex/getsysinfo) 2>/dev/null`
-UNAME_MACHINE = ${UNAME_MACHINE}
-UNAME_RELEASE = ${UNAME_RELEASE}
-UNAME_SYSTEM  = ${UNAME_SYSTEM}
-UNAME_VERSION = ${UNAME_VERSION}
+UNAME_MACHINE = "$UNAME_MACHINE"
+UNAME_RELEASE = "$UNAME_RELEASE"
+UNAME_SYSTEM  = "$UNAME_SYSTEM"
+UNAME_VERSION = "$UNAME_VERSION"
 EOF
 exit 1
 # Local variables:
-# eval: (add-hook 'write-file-functions 'time-stamp)
+# eval: (add-hook 'before-save-hook 'time-stamp)
 # time-stamp-start: "timestamp='"
 # time-stamp-format: "%:y-%02m-%02d"
 # time-stamp-end: "'"
Modified: grass/trunk/config.sub
--- grass/trunk/config.sub	2018-05-04 20:23:14 UTC (rev 72675)
+++ grass/trunk/config.sub	2018-05-04 20:36:28 UTC (rev 72676)
@@ -1,8 +1,8 @@
 #! /bin/sh
 # Configuration validation subroutine script.
-timestamp='2017-11-04'
+timestamp='2018-05-03'
@@ -67,7 +67,7 @@
 version="\
 GNU config.sub ($timestamp)
@@ -94,7 +94,7 @@
     *local*)
        # First pass through any local machine types.
-       echo $1
+       echo "$1"
        exit ;;
@@ -112,26 +112,31 @@
 # Separate what the user gave into CPU-COMPANY and OS or KERNEL-OS (if any).
 # Here we must recognize all the valid KERNEL-OS combinations.
-maybe_os=`echo $1 | sed 's/^\(.*\)-\([^-]*-[^-]*\)$/\2/'`
+maybe_os=`echo "$1" | sed 's/^\(.*\)-\([^-]*-[^-]*\)$/\2/'`
 case $maybe_os in
-  nto-qnx* | linux-gnu* | linux-android* | linux-dietlibc | linux-newlib* | \
-  linux-musl* | linux-uclibc* | uclinux-uclibc* | uclinux-gnu* | kfreebsd*-gnu* | \
-  knetbsd*-gnu* | netbsd*-gnu* | netbsd*-eabi* | \
-  kopensolaris*-gnu* | cloudabi*-eabi* | \
-  storm-chaos* | os2-emx* | rtmk-nova*)
-    os=-$maybe_os
-    basic_machine=`echo $1 | sed 's/^\(.*\)-\([^-]*-[^-]*\)$/\1/'`
-  android-linux)
-    os=-linux-android
-    basic_machine=`echo $1 | sed 's/^\(.*\)-\([^-]*-[^-]*\)$/\1/'`-unknown
-    basic_machine=`echo $1 | sed 's/-[^-]*$//'`
-    if [ $basic_machine != $1 ]
-    then os=`echo $1 | sed 's/.*-/-/'`
-    else os=; fi
+	nto-qnx* | linux-gnu* | linux-android* | linux-dietlibc | linux-newlib* | \
+	linux-musl* | linux-uclibc* | uclinux-uclibc* | uclinux-gnu* | kfreebsd*-gnu* | \
+	knetbsd*-gnu* | netbsd*-gnu* | netbsd*-eabi* | \
+	kopensolaris*-gnu* | cloudabi*-eabi* | \
+	storm-chaos* | os2-emx* | rtmk-nova*)
+	os=-$maybe_os
+	basic_machine=`echo "$1" | sed 's/^\(.*\)-\([^-]*-[^-]*\)$/\1/'`
+    android-linux)
+	os=-linux-android
+	basic_machine=`echo "$1" | sed 's/^\(.*\)-\([^-]*-[^-]*\)$/\1/'`-unknown
+	basic_machine=`echo "$1" | sed 's/-[^-]*$//'`
+	case $1 in
+		os=`echo "$1" | sed 's/.*-/-/'`
+		os=
+	esac
 esac
 ### Let's recognize common machines as not being operating systems so
@@ -178,44 +183,44 @@
 	-sco6)
 		os=-sco5v6
-		basic_machine=`echo $1 | sed -e 's/86-.*/86-pc/'`
+		basic_machine=`echo "$1" | sed -e 's/86-.*/86-pc/'`
 	-sco5)
 		os=-sco3.2v5
 	-sco4)
 		os=-sco3.2v4
 	-sco3.2.[4-9]*)
 		os=`echo $os | sed -e 's/sco3.2./sco3.2v/'`
 	-sco3.2v[4-9]*)
 		# Don't forget version if it is 3.2v4 or newer.
 	-sco5v6*)
 	-sco*)
 		os=-sco3.2v2
 	-udk*)
 	-isc)
 		os=-isc2.2
 	-clix*)
 		basic_machine=clipper-intergraph
 	-isc*)
 	-lynx*178)
 		os=-lynxos178
@@ -227,7 +232,7 @@
 		os=-lynxos
 	-ptx*)
-		basic_machine=`echo $1 | sed -e 's/86-.*/86-sequent/'`
+		basic_machine=`echo "$1" | sed -e 's/86-.*/86-sequent/'`
 	-psos*)
 		os=-psos
@@ -249,12 +254,12 @@
 	| alpha64 | alpha64ev[4-8] | alpha64ev56 | alpha64ev6[78] | alpha64pca5[67] \
 	| am33_2.0 \
 	| arc | arceb \
-	| arm | arm[bl]e | arme[lb] | armv[2-8] | armv[3-8][lb] | armv7[arm] \
+	| arm | arm[bl]e | arme[lb] | armv[2-8] | armv[3-8][lb] | armv6m | armv[78][arm] \
 	| avr | avr32 \
 	| ba \
 	| be32 | be64 \
 	| bfin \
-	| c4x | c8051 | clipper \
+	| c4x | c8051 | clipper | csky \
 	| d10v | d30v | dlx | dsp16xx \
 	| e2k | epiphany \
 	| fido | fr30 | frv | ft32 \
@@ -293,10 +298,11 @@
 	| mt \
 	| msp430 \
 	| nds32 | nds32le | nds32be \
+	| nfp \
 	| nios | nios2 | nios2eb | nios2el \
 	| ns16k | ns32k \
 	| open8 | or1k | or1knd | or32 \
-	| pdp10 | pdp11 | pj | pjl \
+	| pdp10 | pj | pjl \
 	| powerpc | powerpc64 | powerpc64le | powerpcle \
 	| pru \
 	| pyramid \
@@ -333,8 +339,12 @@
 		basic_machine=$basic_machine-unknown
 		os=-none
-	m88110 | m680[12346]0 | m683?2 | m68360 | m5200 | v70 | w65 | z8k)
+	m88110 | m680[12346]0 | m683?2 | m68360 | m5200 | v70 | w65)
+	m9s12z | m68hcs12z | hcs12z | s12z)
+		basic_machine=s12z-unknown
+		os=-none
 	ms1)
 		basic_machine=mt-unknown
@@ -362,7 +372,7 @@
 	# Object if more than one company name word.
-		echo Invalid configuration \`$1\': machine \`$basic_machine\' not recognized 1>&2
+		echo Invalid configuration \`"$1"\': machine \`"$basic_machine"\' not recognized 1>&2
 		exit 1
 	# Recognize the basic CPU types with company name.
@@ -378,7 +388,7 @@
 	| be32-* | be64-* \
 	| bfin-* | bs2000-* \
 	| c[123]* | c30-* | [cjt]90-* | c4x-* \
-	| c8051-* | clipper-* | craynv-* | cydra-* \
+	| c8051-* | clipper-* | craynv-* | csky-* | cydra-* \
 	| d10v-* | d30v-* | dlx-* \
 	| e2k-* | elxsi-* \
 	| f30[01]-* | f700-* | fido-* | fr30-* | frv-* | fx80-* \
@@ -419,6 +429,7 @@
 	| mt-* \
 	| msp430-* \
 	| nds32-* | nds32le-* | nds32be-* \
+	| nfp-* \
 	| nios-* | nios2-* | nios2eb-* | nios2el-* \
 	| none-* | np1-* | ns16k-* | ns32k-* \
 	| open8-* \
@@ -457,7 +468,7 @@
 	# Recognize the various machine names and aliases which stand
 	# for a CPU type and a company and sometimes even an OS.
 	386bsd)
-		basic_machine=i386-unknown
+		basic_machine=i386-pc
 		os=-bsd
 	3b1 | 7300 | 7300-att | att-7300 | pc7300 | safari | unixpc)
@@ -491,7 +502,7 @@
 		basic_machine=x86_64-pc
 	amd64-*)
-		basic_machine=x86_64-`echo $basic_machine | sed 's/^[^-]*-//'`
+		basic_machine=x86_64-`echo "$basic_machine" | sed 's/^[^-]*-//'`
 	amdahl)
 		basic_machine=580-amdahl
@@ -536,7 +547,7 @@
 		os=-linux
 	blackfin-*)
-		basic_machine=bfin-`echo $basic_machine | sed 's/^[^-]*-//'`
+		basic_machine=bfin-`echo "$basic_machine" | sed 's/^[^-]*-//'`
 		os=-linux
 	bluegene*)
@@ -544,13 +555,13 @@
 		os=-cnk
 	c54x-*)
-		basic_machine=tic54x-`echo $basic_machine | sed 's/^[^-]*-//'`
+		basic_machine=tic54x-`echo "$basic_machine" | sed 's/^[^-]*-//'`
 	c55x-*)
-		basic_machine=tic55x-`echo $basic_machine | sed 's/^[^-]*-//'`
+		basic_machine=tic55x-`echo "$basic_machine" | sed 's/^[^-]*-//'`
 	c6x-*)
-		basic_machine=tic6x-`echo $basic_machine | sed 's/^[^-]*-//'`
+		basic_machine=tic6x-`echo "$basic_machine" | sed 's/^[^-]*-//'`
 	c90)
 		basic_machine=c90-cray
@@ -648,7 +659,7 @@
 		os=$os"spe"
 	e500v[12]-*)
-		basic_machine=powerpc-`echo $basic_machine | sed 's/^[^-]*-//'`
+		basic_machine=powerpc-`echo "$basic_machine" | sed 's/^[^-]*-//'`
 		os=$os"spe"
 	ebmon29k)
@@ -740,9 +751,6 @@
 	hp9k8[0-9][0-9] | hp8[0-9][0-9])
 		basic_machine=hppa1.0-hp
-	hppa-next)
-		os=-nextstep3
 	hppaosf)
 		basic_machine=hppa1.1-hp
 		os=-osf
@@ -755,19 +763,19 @@
 		basic_machine=i370-ibm
 	i*86v32)
-		basic_machine=`echo $1 | sed -e 's/86.*/86-pc/'`
+		basic_machine=`echo "$1" | sed -e 's/86.*/86-pc/'`
 		os=-sysv32
 	i*86v4*)
 		os=-sysv4
 	i*86v)
 		os=-sysv
 	i*86sol2)
 		os=-solaris2
 	i386mach)
@@ -774,7 +782,7 @@
 		basic_machine=i386-mach
 		os=-mach
-	i386-vsta | vsta)
+	vsta)
 		os=-vsta
@@ -793,7 +801,7 @@
 		os=-sysv
 	leon-*|leon[3-9]-*)
-		basic_machine=sparc-`echo $basic_machine | sed 's/-.*//'`
+		basic_machine=sparc-`echo "$basic_machine" | sed 's/-.*//'`
 	m68knommu)
 		basic_machine=m68k-unknown
@@ -800,12 +808,9 @@
 		os=-linux
 	m68knommu-*)
-		basic_machine=m68k-`echo $basic_machine | sed 's/^[^-]*-//'`
+		basic_machine=m68k-`echo "$basic_machine" | sed 's/^[^-]*-//'`
 		os=-linux
-	m88k-omron*)
-		basic_machine=m88k-omron
 	magnum | m3230)
 		basic_machine=mips-mips
 		os=-sysv
@@ -837,10 +842,10 @@
 		os=-mint
 	mips3*-*)
-		basic_machine=`echo $basic_machine | sed -e 's/mips3/mips64/'`
+		basic_machine=`echo "$basic_machine" | sed -e 's/mips3/mips64/'`
 	mips3*)
-		basic_machine=`echo $basic_machine | sed -e 's/mips3/mips64/'`-unknown
+		basic_machine=`echo "$basic_machine" | sed -e 's/mips3/mips64/'`-unknown
 	monitor)
 		basic_machine=m68k-rom68k
@@ -859,7 +864,7 @@
 		os=-msdos
 	ms1-*)
-		basic_machine=`echo $basic_machine | sed -e 's/ms1-/mt-/'`
+		basic_machine=`echo "$basic_machine" | sed -e 's/ms1-/mt-/'`
 	msys)
 		basic_machine=i686-pc
@@ -946,6 +951,9 @@
 	nsr-tandem)
 		basic_machine=nsr-tandem
+	nsv-tandem)
+		basic_machine=nsv-tandem
 	nsx-tandem)
 		basic_machine=nsx-tandem
@@ -981,7 +989,7 @@
 		os=-linux
 	parisc-*)
-		basic_machine=hppa-`echo $basic_machine | sed 's/^[^-]*-//'`
+		basic_machine=hppa-`echo "$basic_machine" | sed 's/^[^-]*-//'`
 		os=-linux
 	pbd)
@@ -997,7 +1005,7 @@
 	pc98-*)
-		basic_machine=i386-`echo $basic_machine | sed 's/^[^-]*-//'`
+		basic_machine=i386-`echo "$basic_machine" | sed 's/^[^-]*-//'`
 	pentium | p5 | k5 | k6 | nexgen | viac3)
 		basic_machine=i586-pc
@@ -1012,16 +1020,16 @@
 		basic_machine=i786-pc
 	pentium-* | p5-* | k5-* | k6-* | nexgen-* | viac3-*)
-		basic_machine=i586-`echo $basic_machine | sed 's/^[^-]*-//'`
+		basic_machine=i586-`echo "$basic_machine" | sed 's/^[^-]*-//'`
 	pentiumpro-* | p6-* | 6x86-* | athlon-*)
-		basic_machine=i686-`echo $basic_machine | sed 's/^[^-]*-//'`
+		basic_machine=i686-`echo "$basic_machine" | sed 's/^[^-]*-//'`
 	pentiumii-* | pentium2-* | pentiumiii-* | pentium3-*)
 	pentium4-*)
-		basic_machine=i786-`echo $basic_machine | sed 's/^[^-]*-//'`
+		basic_machine=i786-`echo "$basic_machine" | sed 's/^[^-]*-//'`
 	pn)
 		basic_machine=pn-gould
@@ -1031,23 +1039,23 @@
 	ppc | ppcbe)	basic_machine=powerpc-unknown
 	ppc-* | ppcbe-*)
 	ppcle | powerpclittle)
 		basic_machine=powerpcle-unknown
 	ppcle-* | powerpclittle-*)
-		basic_machine=powerpcle-`echo $basic_machine | sed 's/^[^-]*-//'`
+		basic_machine=powerpcle-`echo "$basic_machine" | sed 's/^[^-]*-//'`
 	ppc64)	basic_machine=powerpc64-unknown
-	ppc64-*) basic_machine=powerpc64-`echo $basic_machine | sed 's/^[^-]*-//'`
+	ppc64-*) basic_machine=powerpc64-`echo "$basic_machine" | sed 's/^[^-]*-//'`
 	ppc64le | powerpc64little)
 		basic_machine=powerpc64le-unknown
 	ppc64le-* | powerpc64little-*)
-		basic_machine=powerpc64le-`echo $basic_machine | sed 's/^[^-]*-//'`
+		basic_machine=powerpc64le-`echo "$basic_machine" | sed 's/^[^-]*-//'`
 	ps2)
 		basic_machine=i386-ibm
@@ -1101,17 +1109,10 @@
 	sequent)
 		basic_machine=i386-sequent
-	sh)
-		basic_machine=sh-hitachi
-		os=-hms
 	sh5el)
 		basic_machine=sh5le-unknown
-	sh64)
-		basic_machine=sh64-unknown
-	sparclite-wrs | simso-wrs)
+	simso-wrs)
 		basic_machine=sparclite-wrs
 		os=-vxworks
@@ -1130,7 +1131,7 @@
 		os=-sysv4
 	strongarm-* | thumb-*)
-		basic_machine=arm-`echo $basic_machine | sed 's/^[^-]*-//'`
+		basic_machine=arm-`echo "$basic_machine" | sed 's/^[^-]*-//'`
 	sun2)
 		basic_machine=m68000-sun
@@ -1244,9 +1245,6 @@
 		basic_machine=a29k-wrs
 		os=-vxworks
-	wasm32)
-		basic_machine=wasm32-unknown
 	w65*)
 		basic_machine=w65-wdc
 		os=-none
@@ -1266,20 +1264,12 @@
 		basic_machine=xps100-honeywell
 	xscale-* | xscalee[bl]-*)
-		basic_machine=`echo $basic_machine | sed 's/^xscale/arm/'`
+		basic_machine=`echo "$basic_machine" | sed 's/^xscale/arm/'`
 	ymp)
 		basic_machine=ymp-cray
 		os=-unicos
-	z8k-*-coff)
-		basic_machine=z8k-unknown
-		os=-sim
-	z80-*-coff)
-		basic_machine=z80-unknown
-		os=-sim
 	none)
 		basic_machine=none-none
 		os=-none
@@ -1308,10 +1298,6 @@
 	vax)
 		basic_machine=vax-dec
-	pdp10)
-		# there are many clones, so DEC is not a safe bet
-		basic_machine=pdp10-unknown
 	pdp11)
 		basic_machine=pdp11-dec
@@ -1321,9 +1307,6 @@
 	sh[1234] | sh[24]a | sh[24]aeb | sh[34]eb | sh[1234]le | sh[23]ele)
 		basic_machine=sh-unknown
-	sparc | sparcv8 | sparcv9 | sparcv9b | sparcv9v)
-		basic_machine=sparc-sun
 	cydra)
 		basic_machine=cydra-cydrome
@@ -1343,7 +1326,7 @@
 		# Make sure to match an already-canonicalized machine name.
 		exit 1
 esac
@@ -1351,10 +1334,10 @@
 # Here we canonicalize certain aliases for manufacturers.
 case $basic_machine in
 	*-digital*)
-		basic_machine=`echo $basic_machine | sed 's/digital.*/dec/'`
+		basic_machine=`echo "$basic_machine" | sed 's/digital.*/dec/'`
 	*-commodore*)
-		basic_machine=`echo $basic_machine | sed 's/commodore.*/cbm/'`
+		basic_machine=`echo "$basic_machine" | sed 's/commodore.*/cbm/'`
@@ -1377,9 +1360,6 @@
 	-solaris)
 		os=-solaris2
-	-svr4*)
-		os=-sysv4
 	-unixware*)
 		os=-sysv4.2uw
@@ -1386,6 +1366,10 @@
 	-gnu/linux*)
 		os=`echo $os | sed -e 's|gnu/linux|linux-gnu|'`
+	# es1800 is here to avoid being matched by es* (a different OS)
+	-es1800*)
+		os=-ose
 	# Now accept the basic system types.
 	# The portable systems comes first.
 	# Each alternative MUST end in a * to match a version number.
@@ -1398,25 +1382,26 @@
 	      | -aos* | -aros* | -cloudabi* | -sortix* \
 	      | -nindy* | -vxsim* | -vxworks* | -ebmon* | -hms* | -mvs* \
 	      | -clix* | -riscos* | -uniplus* | -iris* | -rtu* | -xenix* \
-	      | -hiux* | -386bsd* | -knetbsd* | -mirbsd* | -netbsd* \
+	      | -hiux* | -knetbsd* | -mirbsd* | -netbsd* \
 	      | -bitrig* | -openbsd* | -solidbsd* | -libertybsd* \
 	      | -ekkobsd* | -kfreebsd* | -freebsd* | -riscix* | -lynxos* \
 	      | -bosx* | -nextstep* | -cxux* | -aout* | -elf* | -oabi* \
 	      | -ptx* | -coff* | -ecoff* | -winnt* | -domain* | -vsta* \
-	      | -udi* | -eabi* | -lites* | -ieee* | -go32* | -aux* \
+	      | -udi* | -eabi* | -lites* | -ieee* | -go32* | -aux* | -hcos* \
 	      | -chorusos* | -chorusrdb* | -cegcc* | -glidix* \
 	      | -cygwin* | -msys* | -pe* | -psos* | -moss* | -proelf* | -rtems* \
 	      | -midipix* | -mingw32* | -mingw64* | -linux-gnu* | -linux-android* \
 	      | -linux-newlib* | -linux-musl* | -linux-uclibc* \
 	      | -uxpv* | -beos* | -mpeix* | -udk* | -moxiebox* \
-	      | -interix* | -uwin* | -mks* | -rhapsody* | -darwin* | -opened* \
+	      | -interix* | -uwin* | -mks* | -rhapsody* | -darwin* \
 	      | -openstep* | -oskit* | -conix* | -pw32* | -nonstopux* \
 	      | -storm-chaos* | -tops10* | -tenex* | -tops20* | -its* \
 	      | -os2* | -vos* | -palmos* | -uclinux* | -nucleus* \
-	      | -morphos* | -superux* | -rtmk* | -rtmk-nova* | -windiss* \
+	      | -morphos* | -superux* | -rtmk* | -windiss* \
 	      | -powermax* | -dnix* | -nx6 | -nx7 | -sei* | -dragonfly* \
 	      | -skyos* | -haiku* | -rdos* | -toppers* | -drops* | -es* \
-	      | -onefs* | -tirtos* | -phoenix* | -fuchsia* | -redox*)
+	      | -onefs* | -tirtos* | -phoenix* | -fuchsia* | -redox* | -bme* \
+	      | -midnightbsd*)
 	# Remember, each alternative MUST END IN *, to match a version number.
 	-qnx*)
@@ -1433,12 +1418,12 @@
 	-nto*)
 		os=`echo $os | sed -e 's|nto|nto-qnx|'`
-	-sim | -es1800* | -hms* | -xray | -os68k* | -none* | -v88r* \
-	      | -windows* | -osx | -abug | -netware* | -os9* | -beos* | -haiku* \
+	-sim | -xray | -os68k* | -v88r* \
+	      | -windows* | -osx | -abug | -netware* | -os9* \
 	      | -macos* | -mpw* | -magic* | -mmixware* | -mon960* | -lnews*)
 	-mac*)
-		os=`echo $os | sed -e 's|mac|macos|'`
+		os=`echo "$os" | sed -e 's|mac|macos|'`
 	-linux-dietlibc)
 		os=-linux-dietlibc
@@ -1447,10 +1432,10 @@
 		os=`echo $os | sed -e 's|linux|linux-gnu|'`
 	-sunos5*)
-		os=`echo $os | sed -e 's|sunos5|solaris2|'`
+		os=`echo "$os" | sed -e 's|sunos5|solaris2|'`
 	-sunos6*)
-		os=`echo $os | sed -e 's|sunos6|solaris3|'`
+		os=`echo "$os" | sed -e 's|sunos6|solaris3|'`
 	-opened*)
 		os=-openedition
@@ -1461,12 +1446,6 @@
 	-wince*)
 		os=-wince
-	-osfrose*)
-		os=-osfrose
-	-osf*)
-		os=-osf
 	-utek*)
 		os=-bsd
@@ -1513,7 +1492,7 @@
 	-oss*)
 		os=-sysv3
-	-svr4)
+	-svr4*)
 		os=-sysv4
 	-svr3)
@@ -1528,18 +1507,9 @@
 	-ose*)
 		os=-ose
-	-es1800*)
-		os=-ose
-	-xenix)
-		os=-xenix
 	-*mint | -mint[0-9]* | -*MiNT | -MiNT[0-9]*)
 		os=-mint
-	-aros*)
-		os=-aros
 	-zvmoe)
 		os=-zvmoe
@@ -1546,6 +1516,19 @@
 	-dicos*)
 		os=-dicos
+	-pikeos*)
+		# Until real need of OS specific support for
+		# particular features comes up, bare metal
+		# configurations are quite functional.
+		case $basic_machine in
+		    arm*)
+			os=-eabi
+			os=-elf
+		esac
 	-nacl*)
 	-ios)
@@ -1555,7 +1538,7 @@
 		# Get rid of the `-' at the beginning of $os.
 		os=`echo $os | sed 's/[^-]*-//'`
-		echo Invalid configuration \`$1\': system \`$os\' not recognized 1>&2
+		echo Invalid configuration \`"$1"\': system \`"$os"\' not recognized 1>&2
 		exit 1
 esac
@@ -1651,9 +1634,6 @@
 	*-be)
 		os=-beos
-	*-haiku)
-		os=-haiku
 	*-ibm)
 		os=-aix
@@ -1708,9 +1688,6 @@
 	i370-*)
 		os=-mvs
-	*-next)
-		os=-nextstep3
 	*-gould)
 		os=-sysv
@@ -1820,15 +1797,15 @@
 				vendor=stratus
 		esac
-		basic_machine=`echo $basic_machine | sed "s/unknown/$vendor/"`
+		basic_machine=`echo "$basic_machine" | sed "s/unknown/$vendor/"`
 esac
-echo $basic_machine$os
+echo "$basic_machine$os"
 exit
 # Local variables:
Modified: grass/trunk/configure
--- grass/trunk/configure	2018-05-04 20:23:14 UTC (rev 72675)
+++ grass/trunk/configure	2018-05-04 20:36:28 UTC (rev 72676)
@@ -1593,7 +1593,7 @@
 	    #SHLIB_LD="ld -Bshareable -x"
 	    SHLIB_LD="${CC} -shared"
 	    SHLIB_SUFFIX=".so"
-	    LDFLAGS="-Wl,--export-dynamic"
+	    LDFLAGS="-export-dynamic"
 	    #LD_SEARCH_FLAGS='-rpath ${LIB_RUNTIME_DIR}'
 	    LD_SEARCH_FLAGS='-Wl,-rpath-link,${LIB_RUNTIME_DIR}'
 	    # TODO: add optional pthread support with any combination of:
