[GRASS-SVN] r72683 - in grass-addons/grass7/raster: . r.in.usgs
Fri May 4 20:16:50 PDT 2018
Author: annakrat
Date: 2018-05-04 20:16:50 -0700 (Fri, 04 May 2018)
New Revision: 72683
Added:
   grass-addons/grass7/raster/r.in.usgs/
   grass-addons/grass7/raster/r.in.usgs/Makefile
   grass-addons/grass7/raster/r.in.usgs/r.in.usgs.html
   grass-addons/grass7/raster/r.in.usgs/r.in.usgs.py
   grass-addons/grass7/raster/r.in.usgs/r_in_usgs.png
   grass-addons/grass7/raster/Makefile
r.in.usgs: GSoC 2017 module for automatic downloading USGS DEM, land cover and orthoimagery, author: Zechariah Krautwurst, Anna Petrasova
Modified: grass-addons/grass7/raster/Makefile
--- grass-addons/grass7/raster/Makefile	2018-05-04 21:19:33 UTC (rev 72682)
+++ grass-addons/grass7/raster/Makefile	2018-05-05 03:16:50 UTC (rev 72683)
@@ -57,6 +57,7 @@
 	r.hypso \
 	r.in.arc \
 	r.in.srtm.region \
+	r.in.usgs \
 	r.in.wcs \
 	r.jpdf \
 	r.lake.series \
Added: grass-addons/grass7/raster/r.in.usgs/Makefile
--- grass-addons/grass7/raster/r.in.usgs/Makefile	                        (rev 0)
+++ grass-addons/grass7/raster/r.in.usgs/Makefile	2018-05-05 03:16:50 UTC (rev 72683)
@@ -0,0 +1,7 @@
+MODULE_TOPDIR = ../..
+PGM = r.in.usgs
+include $(MODULE_TOPDIR)/include/Make/Script.make
+default: script
Property changes on: grass-addons/grass7/raster/r.in.usgs/Makefile
___________________________________________________________________
Added: svn:mime-type
## -0,0 +1 ##
+text/x-makefile
\ No newline at end of property
Added: svn:eol-style
## -0,0 +1 ##
+native
Added: grass-addons/grass7/raster/r.in.usgs/r.in.usgs.html
--- grass-addons/grass7/raster/r.in.usgs/r.in.usgs.html	                        (rev 0)
+++ grass-addons/grass7/raster/r.in.usgs/r.in.usgs.html	2018-05-05 03:16:50 UTC (rev 72683)
@@ -0,0 +1,119 @@
+<h2>DESCRIPTION</h2>
+<em>r.in.usgs</em> downloads and patches selected USGS datasets (NED, NLCD, NAIP) to
+the current GRASS computational region and coordinate reference system.
+Associated parameters are automatically passed to
+<a href="https://viewer.nationalmap.gov/tnmaccess/api/index">
+The National Map Access API</a>, downloaded to a user-specified
+local directory, then imported and patched.
+<em>r.in.usgs</em> supports the following datasets:
+<ul>
+<li><b>ned</b>: National Elevation Dataset</li>
+<li><b>nlcd</b>: National Land Cover Dataset</li>
+<li><b>naip</b>: NAIP orthoimagery</li>
+</ul>
+<h2>NOTES</h2>
+<p>
+NED data are available at resolutions of 1 arc-second (about 30 meters),
+1/3 arc-second (about 10 meters), and in limited areas at 1/9 arc-second (about 3 meters).
+<p>
+NLCD data are available for years 2001, 2006, and 2011 (see <b>nlcd_dataset</b> option)
+at 30m resolution and include Land Cover, Percent Developed Imperviousness,
+and Percent Tree Canopy (see <b>nlcd_subset</b> option).
+<p>
+NAIP is available at 1 m resolution.
+<p>
+If the <b>i</b> flag is set, only information about data meeting the input parameters
+is displayed without downloading the data.
+<p>
+By default, downloaded files are kept in the specified <b>output_direcory</b>,
+so that they can be reused in case different computational region is required.
+However, unzipped files and imported rasters before patching are removed.
+If the <b>k</b> flag is set, extracted files from compressed archives are also kept within the
+download directory after the import.
+<p>
+By default, resampling method is chosen based on the nature of the dataset,
+bilinear for NED and nearest for NLCD and NAIP. This can be changed with option
+<b>resampling_method</b>.
+<h2>EXAMPLE</h2>
+We will download NED 1/9 arc-second digital elevation model in the extent of raster 'elevation'.
+First, we just list the files to be downloaded
+ (change output directory depending on the operating system):
+<div class="code"><pre>
+g.region raster=elevation
+r.in.usgs product=ned ned_dataset=ned19sec output_directory=/tmp output_name=ned -i
+</pre></div>
+<pre>
+USGS file(s) to download:
+Total download size:	826.95 MB
+Tile count:	4
+USGS SRS:	wgs84
+USGS tile titles:
+USGS NED ned19_n35x75_w078x75_nc_statewide_2003 1/9 arc-second 2012 15 x 15 minute IMG
+USGS NED ned19_n36x00_w078x75_nc_statewide_2003 1/9 arc-second 2012 15 x 15 minute IMG
+USGS NED ned19_n35x75_w079x00_nc_statewide_2003 1/9 arc-second 2012 15 x 15 minute IMG
+USGS NED ned19_n36x00_w079x00_nc_statewide_2003 1/9 arc-second 2012 15 x 15 minute IMG
+To download USGS data, remove i flag, and rerun r.in.usgs.
+</pre>
+We proceed with the download:
+r.colors map=ned_small color=grey
+</pre></div>
+We change the computational region to a smaller extent and create a new DEM,
+downloaded files will be used.
+g.region n=224649 s=222000 w=633000 e=636000
+r.in.usgs product=ned ned_dataset=ned19sec output_directory=/tmp output_name=ned_small
+</pre></div>
+For a different extent we download NAIP imagery:
+g.region n=224649 s=222000 w=636000 e=639000
+r.in.usgs product=naip output_directory=/tmp output_name=ortho
+</pre></div>
+For a different extent we download NLCD land cover:
+g.region n=224649 s=222000 w=639000 e=642000
+r.in.usgs product=nlcd nlcd_dataset=nlcd2011 nlcd_subset=landcover output_directory=/tmp output_name=nlcd
+</pre></div>
+<div align="center" style="margin: 10px">
+<a href="r_in_usgs.png">
+<img src="r_in_usgs.png" width="600" height="600" alt="NED and ortho" border="0">
+</a><br>
+<i>Figure: Downloaded NED (large and small extent), NAIP orthoimagery, and NLCD land cover</i>
+</div>
+<h2>REFERENCES</h2>
+<em>
+<a href="https://viewer.nationalmap.gov/help/documents/TNMAccessAPIDocumentation/TNMAccessAPIDocumentation.pdf">TNM Access API Guide</a><br>
+<a href="https://nationalmap.gov/elevation.html">National Elevation Dataset</a><br>
+<a href="https://www.mrlc.gov/">National Land Cover Dataset</a>
+</em>
+<h2>SEE ALSO</h2>
+<em>
+<a href="g.region.html">g.region</a>,
+<a href="r.import.html">r.import</a>,
+<a href="r.patch.html">r.patch</a>,
+<a href="r.colors.html">r.colors</a>
+</em>
+<h2>AUTHOR</h2>
+Zechariah Krautwurst, 2017 MGIST Candidate, North Carolina State University<br>
+Anna Petrasova, <a href="https://geospatial.ncsu.edu/geoforall/">NCSU GeoForAll Lab</a><br>
+(Google Summer of Code 2017, mentors: Anna Petrasova, Vaclav Petras)<br>
Property changes on: grass-addons/grass7/raster/r.in.usgs/r.in.usgs.html
## -0,0 +1 ##
+text/html
Added: svn:keywords
## -0,0 +1 ##
+Author Date Id
## -0,0 +1 ##
+native
Added: grass-addons/grass7/raster/r.in.usgs/r.in.usgs.py
--- grass-addons/grass7/raster/r.in.usgs/r.in.usgs.py	                        (rev 0)
+++ grass-addons/grass7/raster/r.in.usgs/r.in.usgs.py	2018-05-05 03:16:50 UTC (rev 72683)
@@ -0,0 +1,656 @@
+#!/usr/bin/env python
+#-*- coding: utf-8 -*-
+#MODULE:     r.in.usgs
+#AUTHOR:     Zechariah Krautwurst, Anna Petrasova
+#MENTORS:    Anna Petrasova
+#            Vaclav Petras
+#PURPOSE:    Download user-requested products through the USGS TNM API.
+#COPYRIGHT:  (C) 2017 Zechariah Krautwurst and the GRASS Development Team
+#            This program is free software under the GNU General Public
+#            License (>=v2). Read the file COPYING that comes with GRASS
+#            for details.
+#%module
+#% description: Download user-requested products through the USGS TNM API
+#% keyword: import
+#% keyword: raster
+#% keyword: USGS
+#% keyword: NED
+#% keyword: NLCD
+#% keyword: NAIP
+#%end
+#%flag
+#% key: i
+#% description: Return USGS data information without downloading files
+#%end
+#%option
+#% key: product
+#% required: yes
+#% options: ned,nlcd,naip
+#% label: USGS data product
+#% description: Available USGS data products to query
+#%end
+#%option G_OPT_R_OUTPUT
+#% key: output_name
+#% required: yes
+#%end
+#%option G_OPT_M_DIR
+#% key: output_directory
+#% required: yes
+#% description: Directory for USGS data download and processing
+#%end
+#%option
+#% key: ned_dataset
+#% required: no
+#% options: ned1sec, ned13sec, ned19sec
+#% answer: ned1sec
+#% label: NED dataset
+#% description: Available NED datasets to query
+#% descriptions: ned1sec;NED 1 arc-second;ned13sec;NED 1/3 arc-second;ned19sec;NED 1/9 arc-second
+#% guisection: NED
+#%end
+#%option
+#% key: nlcd_dataset
+#% required: no
+#% options: nlcd2001, nlcd2006, nlcd2011
+#% answer: nlcd2011
+#% label: NLCD dataset
+#% description: Available NLCD datasets to query
+#% descriptions: nlcd2001;National Land Cover Dataset - 2001;nlcd2006;National Land Cover Dataset - 2006;nlcd2011;National Land Cover Dataset - 2011
+#% guisection: NLCD
+#%end
+#%option
+#% key: nlcd_subset
+#% required: no
+#% options: landcover, impervious, canopy
+#% answer: landcover
+#% label: NLCD subset
+#% description: Available NLCD subsets to query
+#% descriptions: impervious;Percent Developed Imperviousness;canopy;Percent Tree Canopy;landcover;Land Cover
+#%end
+#%option
+#% key: resampling_method
+#% type: string
+#% required: no
+#% multiple: no
+#% options: default,nearest,bilinear,bicubic,lanczos,bilinear_f,bicubic_f,lanczos_f
+#% description: Resampling method to use
+#% descriptions: default;default method based on product;nearest;nearest neighbor;bilinear;bilinear interpolation;bicubic;bicubic interpolation;lanczos;lanczos filter;bilinear_f;bilinear interpolation with fallback;bicubic_f;bicubic interpolation with fallback;lanczos_f;lanczos filter with fallback
+#% answer: default
+#%end
+#%flag
+#% key: k
+#% description: Keep extracted files after GRASS import and patch
+#%end
+#%rules
+#% required: output_name, -i
+#%end
+import sys
+import os
+import zipfile
+import grass.script as gscript
+import urllib
+import urllib2
+import json
+import atexit
+from grass.exceptions import CalledModuleError
+cleanup_list = []
+def main():
+    # Hard-coded parameters needed for USGS datasets
+    usgs_product_dict = {
+        "ned": {
+                'product': 'National Elevation Dataset (NED)',
+                'dataset': {
+                        'ned1sec': (1. / 3600, 30, 100),
+                        'ned13sec': (1. / 3600 / 3, 10, 30),
+                        'ned19sec': (1. / 3600 / 9, 3, 10)
+                'subset': {},
+                'extent': [
+                        '1 x 1 degree',
+                        '15 x 15 minute'
+                'format': 'IMG',
+                'extension': 'img',
+                'zip': True,
+                'srs': 'wgs84',
+                'srs_proj4': "+proj=longlat +ellps=GRS80 +datum=NAD83 +nodefs",
+                'interpolation': 'bilinear',
+                'url_split': '/'
+        "nlcd": {
+                'product': 'National Land Cover Database (NLCD)',
+                'dataset': {
+                        'National Land Cover Database (NLCD) - 2001': (1. / 3600, 30, 100),
+                        'National Land Cover Database (NLCD) - 2006': (1. / 3600, 30, 100),
+                        'National Land Cover Database (NLCD) - 2011': (1. / 3600, 30, 100)
+                'subset': {
+                        'Percent Developed Imperviousness',
+                        'Percent Tree Canopy',
+                        'Land Cover'
+                'extent': ['3 x 3 degree'],
+                'format': 'GeoTIFF',
+                'extension': 'tif',
+                'zip': True,
+                'srs': 'wgs84',
+                'interpolation': 'nearest',
+                'url_split': '/'
+        "naip": {
+                'product': 'USDA National Agriculture Imagery Program (NAIP)',
+                'dataset': {
+                        'Imagery - 1 meter (NAIP)': (1. / 3600 / 27, 1, 3)},
+                'subset': {},
+                'extent': [
+                        '3.75 x 3.75 minute',
+                'format': 'JPEG2000',
+                'extension': 'jp2',
+                'zip': False,
+                'srs': 'wgs84',
+                'url_split': '/'
+    # Set GRASS GUI options and flags to python variables
+    gui_product = options['product']
+    # Variable assigned from USGS product dictionary
+    nav_string = usgs_product_dict[gui_product]
+    product = nav_string['product']
+    product_format = nav_string['format']
+    product_extension = nav_string['extension']
+    product_is_zip = nav_string['zip']
+    product_srs = nav_string['srs']
+    product_proj4 = nav_string['srs_proj4']
+    product_interpolation = nav_string['interpolation']
+    product_url_split = nav_string['url_split']
+    product_extent = nav_string['extent']
+    gui_subset = None
+    # Parameter assignments for each dataset
+    if gui_product == 'ned':
+        gui_dataset = options['ned_dataset']
+        ned_api_name = ''
+        if options['ned_dataset'] == 'ned1sec':
+            ned_data_abbrv = 'ned_1arc_'
+            ned_api_name = '1 arc-second'
+        if options['ned_dataset'] == 'ned13sec':
+            ned_data_abbrv = 'ned_13arc_'
+            ned_api_name = '1/3 arc-second'
+        if options['ned_dataset'] == 'ned19sec':
+            ned_data_abbrv = 'ned_19arc_'
+            ned_api_name = '1/9 arc-second'
+        product_tag = product + " " + ned_api_name
+    if gui_product == 'nlcd':
+        gui_dataset = options['nlcd_dataset']
+        if options['nlcd_dataset'] == 'nlcd2001':
+            gui_dataset = 'National Land Cover Database (NLCD) - 2001'
+        if options['nlcd_dataset'] == 'nlcd2006':
+            gui_dataset = 'National Land Cover Database (NLCD) - 2006'
+        if options['nlcd_dataset'] == 'nlcd2011':
+            gui_dataset = 'National Land Cover Database (NLCD) - 2011'
+        if options['nlcd_subset'] == 'landcover':
+            gui_subset = 'Land Cover'
+        if options['nlcd_subset'] == 'impervious':
+            gui_subset = 'Percent Developed Imperviousness'
+        if options['nlcd_subset'] == 'canopy':
+            gui_subset = 'Percent Tree Canopy'
+        product_tag = gui_dataset
+    if gui_product == 'naip':
+        gui_dataset = 'Imagery - 1 meter (NAIP)'
+        product_tag = nav_string['product']
+    # Assigning further parameters from GUI
+    gui_output_layer = options['output_name']
+    gui_resampling_method = options['resampling_method']
+    gui_i_flag = flags['i']
+    gui_k_flag = flags['k']
+    work_dir = options['output_directory']
+    # Returns current units
+    try:
+        proj = gscript.parse_command('g.proj', flags='g')
+        if gscript.locn_is_latlong():
+            product_resolution = nav_string['dataset'][gui_dataset][0]
+        elif float(proj['meters']) == 1:
+            product_resolution = nav_string['dataset'][gui_dataset][1]
+        else:
+            # we assume feet
+            product_resolution = nav_string['dataset'][gui_dataset][2]
+    except TypeError:
+        product_resolution = False
+    if gui_resampling_method == 'default':
+        gui_resampling_method = nav_string['interpolation']
+        gscript.verbose(_("The default resampling method for product {product} is {res}").format(product=gui_product,
+                        res=product_interpolation))
+    # Get coordinates for current GRASS computational region and convert to USGS SRS
+    gregion = gscript.region()
+    min_coords = gscript.read_command('m.proj', coordinates=(gregion['w'], gregion['s']),
+                                      proj_out=product_proj4, separator='comma',
+                                      flags='d')
+    max_coords = gscript.read_command('m.proj', coordinates=(gregion['e'], gregion['n']),
+                                      flags='d')
+    min_list = min_coords.split(',')[:2]
+    max_list = max_coords.split(',')[:2]
+    list_bbox = min_list + max_list
+    str_bbox = ",".join((str(coord) for coord in list_bbox))
+    # Format variables for TNM API call
+    gui_prod_str = str(product_tag)
+    datasets = urllib.quote_plus(gui_prod_str)
+    prod_format = urllib.quote_plus(product_format)
+    prod_extent = urllib.quote_plus(product_extent[0])
+    # Create TNM API URL
+    base_TNM = "https://viewer.nationalmap.gov/tnmaccess/api/products?"
+    datasets_TNM = "datasets={0}".format(datasets)
+    bbox_TNM = "&bbox={0}".format(str_bbox)
+    prod_format_TNM = "&prodFormats={0}".format(prod_format)
+    TNM_API_URL = base_TNM + datasets_TNM + bbox_TNM + prod_format_TNM
+        TNM_API_URL += "&prodExtents={0}".format(prod_extent)
+    gscript.verbose("TNM API Query URL:\t{0}".format(TNM_API_URL))
+    # Query TNM API
+    try:
+        TNM_API_GET = urllib2.urlopen(TNM_API_URL, timeout=12)
+    except urllib2.URLError:
+        gscript.fatal(_("USGS TNM API query has timed out. Check network configuration. Please try again."))
+    except:
+    # Parse return JSON object from API query
+    try:
+        return_JSON = json.load(TNM_API_GET)
+        if return_JSON['errors']:
+            TNM_API_error = return_JSON['errors']
+            api_error_msg = "TNM API Error - {0}".format(str(TNM_API_error))
+            gscript.fatal(api_error_msg)
+    except:
+        gscript.fatal(_("Unable to load USGS JSON object."))
+    # Functions down_list() and exist_list() used to determine
+    # existing files and those that need to be downloaded.
+    def down_list():
+        dwnld_url.append(TNM_file_URL)
+        dwnld_size.append(TNM_file_size)
+        TNM_file_titles.append(TNM_file_title)
+        if product_is_zip:
+            extract_zip_list.append(local_zip_path)
+        if f['datasets'][0] not in dataset_name:
+            if len(dataset_name) <= 1:
+                dataset_name.append(str(f['datasets'][0]))
+    def exist_list():
+        exist_TNM_titles.append(TNM_file_title)
+        exist_dwnld_url.append(TNM_file_URL)
+            exist_zip_list.append(local_zip_path)
+        else:
+            exist_tile_list.append(local_tile_path)
+    # Assign needed parameters from returned JSON
+    tile_API_count = int(return_JSON['total'])
+    tiles_needed_count = 0
+    size_diff_tolerance = 5
+    exist_dwnld_size = 0
+    if tile_API_count > 0:
+        dwnld_size = []
+        dwnld_url = []
+        dataset_name = []
+        TNM_file_titles = []
+        exist_dwnld_url = []
+        exist_TNM_titles = []
+        exist_zip_list = []
+        exist_tile_list = []
+        extract_zip_list = []
+        # for each file returned, assign variables to needed parameters
+        for f in return_JSON['items']:
+            TNM_file_title = f['title']
+            TNM_file_URL = str(f['downloadURL'])
+            TNM_file_size = int(f['sizeInBytes'])
+            TNM_file_name = TNM_file_URL.split(product_url_split)[-1]
+                local_file_path = os.path.join(work_dir, ned_data_abbrv + TNM_file_name)
+                local_zip_path = os.path.join(work_dir, ned_data_abbrv + TNM_file_name)
+                local_tile_path = os.path.join(work_dir, ned_data_abbrv + TNM_file_name)
+            else:
+                local_file_path = os.path.join(work_dir, TNM_file_name)
+                local_zip_path = os.path.join(work_dir, TNM_file_name)
+                local_tile_path = os.path.join(work_dir, TNM_file_name)
+            file_exists = os.path.exists(local_file_path)
+            file_complete = None
+            # if file exists, but is incomplete, remove file and redownload
+            if file_exists:
+                existing_local_file_size = os.path.getsize(local_file_path)
+                # if local file is incomplete
+                if abs(existing_local_file_size - TNM_file_size) > size_diff_tolerance:
+                    # add file to cleanup list
+                    cleanup_list.append(local_file_path)
+                    # NLCD API query returns subsets that cannot be filtered before
+                    # results are returned. gui_subset is used to filter results.
+                    if not gui_subset:
+                        tiles_needed_count += 1
+                        down_list()
+                    else:
+                        if gui_subset in TNM_file_title:
+                            down_list()
+                        else:
+                            continue
+                else:
+                        exist_list()
+                        exist_dwnld_size += TNM_file_size
+                    else:
+                            exist_list()
+                        else:
+                            continue
+            else:
+                    down_list()
+                else:
+                        down_list()
+                        continue
+    # return fatal error if API query returns no results for GUI input
+    elif tile_API_count == 0:
+        gscript.fatal(_("TNM API ERROR or Zero tiles available for given input parameters."))
+    # number of files to be downloaded
+    file_download_count = len(dwnld_url)
+    # remove existing files from download lists
+    for t in exist_TNM_titles:
+        if t in TNM_file_titles:
+            TNM_file_titles.remove(t)
+    for url in exist_dwnld_url:
+        if url in dwnld_url:
+            dwnld_url.remove(url)
+    # messages to user about status of files to be kept, removed, or downloaded
+    if exist_zip_list:
+        exist_msg = _("\n{0} of {1} files/archive(s) exist locally and will be used by module.").format(len(exist_zip_list), tiles_needed_count)
+        gscript.message(exist_msg)
+    if exist_tile_list:
+        exist_msg = _("\n{0} of {1} files/archive(s) exist locally and will be used by module.").format(len(exist_tile_list), tiles_needed_count)
+    if cleanup_list:
+        cleanup_msg = _("\n{0} existing incomplete file(s) detected and removed. Run module again.").format(len(cleanup_list))
+        gscript.fatal(cleanup_msg)
+    # formats JSON size from bites into needed units for combined file size
+    if dwnld_size:
+        total_size = sum(dwnld_size)
+        len_total_size = len(str(total_size))
+        if 6 < len_total_size < 10:
+            total_size_float = total_size * 1e-6
+            total_size_str = str("{0:.2f}".format(total_size_float) + " MB")
+        if len_total_size >= 10:
+            total_size_float = total_size * 1e-9
+            total_size_str = str("{0:.2f}".format(total_size_float) + " GB")
+    else:
+        total_size_str = '0'
+    # Prints 'none' if all tiles available locally
+    if TNM_file_titles:
+        TNM_file_titles_info = "\n".join(TNM_file_titles)
+    else:
+        TNM_file_titles_info = 'none'
+    # Formatted return for 'i' flag
+    if file_download_count <= 0:
+        data_info = "USGS file(s) to download: NONE"
+            if tile_API_count != file_download_count:
+                if tiles_needed_count == 0:
+                    nlcd_unavailable = "NLCD {0} data unavailable for input parameters".format(gui_subset)
+                    gscript.fatal(nlcd_unavailable)
+    else:
+        data_info = (
+                     "USGS file(s) to download:",
+                     "Total download size:\t{size}",
+                     "Tile count:\t{count}",
+                     "USGS SRS:\t{srs}",
+                     "USGS tile titles:\n{tile}",
+        data_info = '\n'.join(data_info).format(size=total_size_str,
+                                                count=file_download_count,
+                                                srs=product_srs,
+                                                tile=TNM_file_titles_info)
+    print data_info
+    if gui_i_flag:
+        gscript.info(_("To download USGS data, remove <i> flag, and rerun r.in.usgs."))
+        sys.exit()
+    # USGS data download process
+        gscript.message(_("Extracting existing USGS Data..."))
+    else:
+        gscript.message(_("Downloading USGS Data..."))
+    TNM_count = len(dwnld_url)
+    download_count = 0
+    local_tile_path_list = []
+    local_zip_path_list = []
+    patch_names = []
+    # Download files
+    for url in dwnld_url:
+        # create file name by splitting name from returned url
+        # add file name to local download directory
+            file_name = ned_data_abbrv + url.split(product_url_split)[-1]
+            local_file_path = os.path.join(work_dir, file_name)
+        else:
+            file_name = url.split(product_url_split)[-1]
+        try:
+            # download files in chunks rather than write complete files to memory
+            dwnld_req = urllib2.urlopen(url, timeout=12)
+            download_bytes = int(dwnld_req.info()['Content-Length'])
+            CHUNK = 16 * 1024
+            with open(local_file_path, "wb+") as local_file:
+                count = 0
+                steps = int(download_bytes / CHUNK) + 1
+                while True:
+                    chunk = dwnld_req.read(CHUNK)
+                    gscript.percent(count, steps, 10)
+                    count += 1
+                    if not chunk:
+                        break
+                    local_file.write(chunk)
+            local_file.close()
+            download_count += 1
+            # determine if file is a zip archive or another format
+                local_zip_path_list.append(local_file_path)
+            else:
+                local_tile_path_list.append(local_file_path)
+            file_complete = "Download {0} of {1}: COMPLETE".format(
+                    download_count, TNM_count)
+            gscript.info(file_complete)
+            gscript.fatal(_("USGS download request has timed out. Network or formatting error."))
+        except StandardError:
+            if download_count:
+                file_failed = "Download {0} of {1}: FAILED".format(
+                gscript.fatal(file_failed)
+    # sets already downloaded zip files or tiles to be extracted or imported
+        for z in exist_zip_list:
+            local_zip_path_list.append(z)
+        for t in exist_tile_list:
+            local_tile_path_list.append(t)
+        if file_download_count == 0:
+            pass
+        else:
+            gscript.message("Extracting data...")
+        # for each zip archive, extract needed file
+        for z in local_zip_path_list:
+            # Extract tiles from ZIP archives
+            try:
+                with zipfile.ZipFile(z, "r") as read_zip:
+                    for f in read_zip.namelist():
+                        if f.endswith(product_extension):
+                            extracted_tile = os.path.join(work_dir, str(f))
+                            if os.path.exists(extracted_tile):
+                                os.remove(extracted_tile)
+                                read_zip.extract(f, work_dir)
+                            else:
+                    local_tile_path_list.append(extracted_tile)
+                    cleanup_list.append(extracted_tile)
+            except:
+                gscript.fatal(_("Unable to locate or extract IMG file from ZIP archive."))
+    # operations for extracted or complete files available locally
+    for t in local_tile_path_list:
+        # create variables for use in GRASS GIS import process
+        LT_file_name = os.path.basename(t)
+        LT_layer_name = os.path.splitext(LT_file_name)[0]
+        patch_names.append(LT_layer_name)
+        in_info = ("Importing and reprojecting {0}...").format(LT_file_name)
+        gscript.info(in_info)
+        # import to GRASS GIS
+        try:
+            gscript.run_command('r.import', input=t, output=LT_layer_name,
+                                resolution='value', resolution_value=product_resolution,
+                                extent="region", resample=product_interpolation)
+            # do not remove by default with NAIP, there are no zip files
+            if gui_product != 'naip' or not gui_k_flag:
+                cleanup_list.append(t)
+        except CalledModuleError:
+            in_error = ("Unable to import '{0}'").format(LT_file_name)
+            gscript.fatal(in_error)
+    # if control variables match and multiple files need to be patched,
+    # check product resolution, run r.patch
+    # Check that downloaded files match expected count
+    completed_tiles_count = len(local_tile_path_list)
+    if completed_tiles_count == tiles_needed_count:
+        if completed_tiles_count > 1:
+            try:
+                gscript.use_temp_region()
+                # set the resolution
+                if product_resolution:
+                    gscript.run_command('g.region', res=product_resolution, flags='a')
+                    for i in ('1', '2', '3', '4'):
+                        patch_names_i = [name + '.' + i for name in patch_names]
+                        gscript.run_command('r.patch', input=patch_names_i,
+                                            output=gui_output_layer + '.' + i)
+                else:
+                    gscript.run_command('r.patch', input=patch_names,
+                                        output=gui_output_layer)
+                gscript.del_temp_region()
+                out_info = ("Patched composite layer '{0}' added").format(gui_output_layer)
+                gscript.verbose(out_info)
+                # Remove files if 'k' flag
+                if not gui_k_flag:
+                            gscript.run_command('g.remove', type='raster',
+                                                name=patch_names_i, flags='f')
+                    else:
+                                            name=patch_names, flags='f')
+                gscript.fatal("Unable to patch tiles.")
+        elif completed_tiles_count == 1:
+                    gscript.run_command('g.rename', raster=(patch_names[0] + '.' + i, gui_output_layer + '.' + i))
+            else:
+                gscript.run_command('g.rename', raster=(patch_names[0], gui_output_layer))
+        temp_down_count = "\n{0} of {1} tile/s succesfully imported and patched.".format(completed_tiles_count,
+        tiles_needed_count)
+        gscript.info(temp_down_count)
+    else:
+        gscript.fatal("Error downloading files. Please retry.")
+    # Keep source files if 'k' flag active
+    if gui_k_flag:
+        src_msg = ("<k> flag selected: Source tiles remain in '{0}'").format(work_dir)
+        gscript.info(src_msg)
+    # set appropriate color table
+        gscript.run_command('r.colors', map=gui_output_layer, color='elevation')
+    # composite NAIP
+        gscript.run_command('g.region', raster=gui_output_layer + '.1')
+        gscript.run_command('r.composite', red=gui_output_layer + '.1',
+                            green=gui_output_layer + '.2', blue=gui_output_layer + '.3',
+def cleanup():
+    # Remove files in cleanup_list
+    for f in cleanup_list:
+        if os.path.exists(f):
+            gscript.try_remove(f)
+if __name__ == "__main__":
+    options, flags = gscript.parser()
+    atexit.register(cleanup)
+    sys.exit(main())
Property changes on: grass-addons/grass7/raster/r.in.usgs/r.in.usgs.py
Added: svn:executable
## -0,0 +1 ##
## -0,0 +1 ##
+text/x-python
## -0,0 +1 ##
+native
Added: grass-addons/grass7/raster/r.in.usgs/r_in_usgs.png
(Binary files differ)
Index: grass-addons/grass7/raster/r.in.usgs/r_in_usgs.png
--- grass-addons/grass7/raster/r.in.usgs/r_in_usgs.png	2018-05-04 21:19:33 UTC (rev 72682)
+++ grass-addons/grass7/raster/r.in.usgs/r_in_usgs.png	2018-05-05 03:16:50 UTC (rev 72683)
Property changes on: grass-addons/grass7/raster/r.in.usgs/r_in_usgs.png
## -0,0 +1 ##
+image/png
