[GRASS-SVN] r72691 - in grass/branches/releasebranch_7_2: gui/wxpython/iscatt imagery/i.fft lib/imagery locale/po
Sat May 5 05:36:15 PDT 2018
Author: neteler
Date: 2018-05-05 05:36:15 -0700 (Sat, 05 May 2018)
New Revision: 72691
   grass/branches/releasebranch_7_2/gui/wxpython/iscatt/iscatt_core.py
   grass/branches/releasebranch_7_2/imagery/i.fft/i.fft.html
   grass/branches/releasebranch_7_2/lib/imagery/iscatt_core.c
   grass/branches/releasebranch_7_2/locale/po/grasslibs_ar.po
   grass/branches/releasebranch_7_2/locale/po/grasslibs_cs.po
   grass/branches/releasebranch_7_2/locale/po/grasslibs_de.po
   grass/branches/releasebranch_7_2/locale/po/grasslibs_el.po
   grass/branches/releasebranch_7_2/locale/po/grasslibs_es.po
   grass/branches/releasebranch_7_2/locale/po/grasslibs_fi.po
   grass/branches/releasebranch_7_2/locale/po/grasslibs_fr.po
   grass/branches/releasebranch_7_2/locale/po/grasslibs_id_ID.po
   grass/branches/releasebranch_7_2/locale/po/grasslibs_it.po
   grass/branches/releasebranch_7_2/locale/po/grasslibs_ja.po
   grass/branches/releasebranch_7_2/locale/po/grasslibs_ko.po
   grass/branches/releasebranch_7_2/locale/po/grasslibs_lv.po
   grass/branches/releasebranch_7_2/locale/po/grasslibs_ml.po
   grass/branches/releasebranch_7_2/locale/po/grasslibs_pl.po
   grass/branches/releasebranch_7_2/locale/po/grasslibs_pt.po
   grass/branches/releasebranch_7_2/locale/po/grasslibs_pt_BR.po
   grass/branches/releasebranch_7_2/locale/po/grasslibs_ro.po
   grass/branches/releasebranch_7_2/locale/po/grasslibs_ru.po
   grass/branches/releasebranch_7_2/locale/po/grasslibs_si.po
   grass/branches/releasebranch_7_2/locale/po/grasslibs_sl.po
   grass/branches/releasebranch_7_2/locale/po/grasslibs_ta.po
   grass/branches/releasebranch_7_2/locale/po/grasslibs_th.po
   grass/branches/releasebranch_7_2/locale/po/grasslibs_tr.po
   grass/branches/releasebranch_7_2/locale/po/grasslibs_uk.po
   grass/branches/releasebranch_7_2/locale/po/grasslibs_vi.po
   grass/branches/releasebranch_7_2/locale/po/grasslibs_zh.po
Fix a couple of spelling errors reported by lintian QA tool (thanks to Bas Couwenberg, fixes #3557)
Modified: grass/branches/releasebranch_7_2/gui/wxpython/iscatt/iscatt_core.py
--- grass/branches/releasebranch_7_2/gui/wxpython/iscatt/iscatt_core.py	2018-05-05 12:35:52 UTC (rev 72690)
+++ grass/branches/releasebranch_7_2/gui/wxpython/iscatt/iscatt_core.py	2018-05-05 12:36:15 UTC (rev 72691)
@@ -426,7 +426,7 @@
 class ScattPlotsCondsData:
-    """Data structure for selected areas in scatter plot(condtions).
+    """Data structure for selected areas in scatter plot(conditions).
     def __init__(self, an_data):
Modified: grass/branches/releasebranch_7_2/imagery/i.fft/i.fft.html
--- grass/branches/releasebranch_7_2/imagery/i.fft/i.fft.html	2018-05-05 12:35:52 UTC (rev 72690)
+++ grass/branches/releasebranch_7_2/imagery/i.fft/i.fft.html	2018-05-05 12:36:15 UTC (rev 72691)
@@ -44,7 +44,7 @@
 for computing the Discrete Fourier Transform (DFT) in one or more
 dimensions, of both real and complex data, and of arbitrary input size.
 <li> John A. Richards, 1986. Remote Sensing Digital Image Analysis, Springer-Verlag.
-<li>Personal communication, between progam author and Ali R. Vali,
+<li>Personal communication, between program author and Ali R. Vali,
 Space Research Center, <A HREF="http://www.utexas.edu">University of Texas</a>, Austin, 1990.
 </ul>
Modified: grass/branches/releasebranch_7_2/lib/imagery/iscatt_core.c
--- grass/branches/releasebranch_7_2/lib/imagery/iscatt_core.c	2018-05-05 12:35:52 UTC (rev 72690)
+++ grass/branches/releasebranch_7_2/lib/imagery/iscatt_core.c	2018-05-05 12:36:15 UTC (rev 72691)
@@ -252,7 +252,7 @@
     f_cat_rast = fopen(cat_rast, "rb+");
     if (!f_cat_rast) {
-	G_warning(_("Unable to open category raster condtions file <%s>."),
+	G_warning(_("Unable to open category raster conditions file <%s>."),
 		  cat_rast);
 	return -1;
@@ -541,7 +541,7 @@
-	    /* check condtions defined in scatter plots */
+	    /* check conditions defined in scatter plots */
 	    for (i_scatt = 0; i_scatt < scatts_conds->n_a_scatts; i_scatt++) {
 		b_1_rast_row = bands_rows[scatts_bands[i_scatt * 2]];
 		b_2_rast_row = bands_rows[scatts_bands[i_scatt * 2 + 1]];
Modified: grass/branches/releasebranch_7_2/locale/po/grasslibs_ar.po
--- grass/branches/releasebranch_7_2/locale/po/grasslibs_ar.po	2018-05-05 12:35:52 UTC (rev 72690)
+++ grass/branches/releasebranch_7_2/locale/po/grasslibs_ar.po	2018-05-05 12:36:15 UTC (rev 72691)
@@ -9710,7 +9710,7 @@
 #: ../lib/imagery/iscatt_core.c:255
 #, fuzzy, c-format
-msgid "Unable to open category raster condtions file <%s>."
+msgid "Unable to open category raster conditions file <%s>."
 msgstr "datum لم يمكن فتح ملف جدول : %s"
 #: ../lib/imagery/iscatt_core.c:263
Modified: grass/branches/releasebranch_7_2/locale/po/grasslibs_cs.po
--- grass/branches/releasebranch_7_2/locale/po/grasslibs_cs.po	2018-05-05 12:35:52 UTC (rev 72690)
+++ grass/branches/releasebranch_7_2/locale/po/grasslibs_cs.po	2018-05-05 12:36:15 UTC (rev 72691)
@@ -9096,7 +9096,7 @@
 #, c-format
 msgstr ""
Modified: grass/branches/releasebranch_7_2/locale/po/grasslibs_de.po
--- grass/branches/releasebranch_7_2/locale/po/grasslibs_de.po	2018-05-05 12:35:52 UTC (rev 72690)
+++ grass/branches/releasebranch_7_2/locale/po/grasslibs_de.po	2018-05-05 12:36:15 UTC (rev 72691)
@@ -9086,7 +9086,7 @@
 #, c-format
 msgstr ""
Modified: grass/branches/releasebranch_7_2/locale/po/grasslibs_el.po
--- grass/branches/releasebranch_7_2/locale/po/grasslibs_el.po	2018-05-05 12:35:52 UTC (rev 72690)
+++ grass/branches/releasebranch_7_2/locale/po/grasslibs_el.po	2018-05-05 12:36:15 UTC (rev 72691)
@@ -9081,7 +9081,7 @@
 #, c-format
 msgstr ""
Modified: grass/branches/releasebranch_7_2/locale/po/grasslibs_es.po
--- grass/branches/releasebranch_7_2/locale/po/grasslibs_es.po	2018-05-05 12:35:52 UTC (rev 72690)
+++ grass/branches/releasebranch_7_2/locale/po/grasslibs_es.po	2018-05-05 12:36:15 UTC (rev 72691)
@@ -9174,7 +9174,7 @@
 #, c-format
 msgstr "No ha sido posible abrir archivo de condiciones de categorías ráster <%s>."
Modified: grass/branches/releasebranch_7_2/locale/po/grasslibs_fi.po
--- grass/branches/releasebranch_7_2/locale/po/grasslibs_fi.po	2018-05-05 12:35:52 UTC (rev 72690)
+++ grass/branches/releasebranch_7_2/locale/po/grasslibs_fi.po	2018-05-05 12:36:15 UTC (rev 72691)
@@ -9072,7 +9072,7 @@
 #, c-format
 msgstr ""
Modified: grass/branches/releasebranch_7_2/locale/po/grasslibs_fr.po
--- grass/branches/releasebranch_7_2/locale/po/grasslibs_fr.po	2018-05-05 12:35:52 UTC (rev 72690)
+++ grass/branches/releasebranch_7_2/locale/po/grasslibs_fr.po	2018-05-05 12:36:15 UTC (rev 72691)
@@ -9265,7 +9265,7 @@
 #, c-format
 msgstr "Impossible d'ouvrir le fichier <%s> de catégories du raster."
Modified: grass/branches/releasebranch_7_2/locale/po/grasslibs_id_ID.po
--- grass/branches/releasebranch_7_2/locale/po/grasslibs_id_ID.po	2018-05-05 12:35:52 UTC (rev 72690)
+++ grass/branches/releasebranch_7_2/locale/po/grasslibs_id_ID.po	2018-05-05 12:36:15 UTC (rev 72691)
@@ -3733,7 +3733,7 @@
 #, c-format
 msgstr ""
Modified: grass/branches/releasebranch_7_2/locale/po/grasslibs_it.po
--- grass/branches/releasebranch_7_2/locale/po/grasslibs_it.po	2018-05-05 12:35:52 UTC (rev 72690)
+++ grass/branches/releasebranch_7_2/locale/po/grasslibs_it.po	2018-05-05 12:36:15 UTC (rev 72691)
@@ -9123,7 +9123,7 @@
 #, c-format
 msgstr ""
Modified: grass/branches/releasebranch_7_2/locale/po/grasslibs_ja.po
--- grass/branches/releasebranch_7_2/locale/po/grasslibs_ja.po	2018-05-05 12:35:52 UTC (rev 72690)
+++ grass/branches/releasebranch_7_2/locale/po/grasslibs_ja.po	2018-05-05 12:36:15 UTC (rev 72691)
@@ -9082,7 +9082,7 @@
 #, c-format
 msgstr ""
Modified: grass/branches/releasebranch_7_2/locale/po/grasslibs_ko.po
--- grass/branches/releasebranch_7_2/locale/po/grasslibs_ko.po	2018-05-05 12:35:52 UTC (rev 72690)
+++ grass/branches/releasebranch_7_2/locale/po/grasslibs_ko.po	2018-05-05 12:36:15 UTC (rev 72691)
@@ -9066,7 +9066,7 @@
 #, c-format
 msgstr ""
Modified: grass/branches/releasebranch_7_2/locale/po/grasslibs_lv.po
--- grass/branches/releasebranch_7_2/locale/po/grasslibs_lv.po	2018-05-05 12:35:52 UTC (rev 72690)
+++ grass/branches/releasebranch_7_2/locale/po/grasslibs_lv.po	2018-05-05 12:36:15 UTC (rev 72691)
@@ -9083,7 +9083,7 @@
 #, c-format
 msgstr ""
Modified: grass/branches/releasebranch_7_2/locale/po/grasslibs_ml.po
--- grass/branches/releasebranch_7_2/locale/po/grasslibs_ml.po	2018-05-05 12:35:52 UTC (rev 72690)
+++ grass/branches/releasebranch_7_2/locale/po/grasslibs_ml.po	2018-05-05 12:36:15 UTC (rev 72691)
 #, c-format
 msgstr ""
Modified: grass/branches/releasebranch_7_2/locale/po/grasslibs_pl.po
--- grass/branches/releasebranch_7_2/locale/po/grasslibs_pl.po	2018-05-05 12:35:52 UTC (rev 72690)
+++ grass/branches/releasebranch_7_2/locale/po/grasslibs_pl.po	2018-05-05 12:36:15 UTC (rev 72691)
@@ -9120,7 +9120,7 @@
 #, c-format
 msgstr ""
Modified: grass/branches/releasebranch_7_2/locale/po/grasslibs_pt.po
--- grass/branches/releasebranch_7_2/locale/po/grasslibs_pt.po	2018-05-05 12:35:52 UTC (rev 72690)
+++ grass/branches/releasebranch_7_2/locale/po/grasslibs_pt.po	2018-05-05 12:36:15 UTC (rev 72691)
@@ -9084,7 +9084,7 @@
 #, c-format
 msgstr ""
Modified: grass/branches/releasebranch_7_2/locale/po/grasslibs_pt_BR.po
--- grass/branches/releasebranch_7_2/locale/po/grasslibs_pt_BR.po	2018-05-05 12:35:52 UTC (rev 72690)
+++ grass/branches/releasebranch_7_2/locale/po/grasslibs_pt_BR.po	2018-05-05 12:36:15 UTC (rev 72691)
@@ -9071,7 +9071,7 @@
 #, c-format
 msgstr ""
Modified: grass/branches/releasebranch_7_2/locale/po/grasslibs_ro.po
--- grass/branches/releasebranch_7_2/locale/po/grasslibs_ro.po	2018-05-05 12:35:52 UTC (rev 72690)
+++ grass/branches/releasebranch_7_2/locale/po/grasslibs_ro.po	2018-05-05 12:36:15 UTC (rev 72691)
 #, c-format
 msgstr ""
Modified: grass/branches/releasebranch_7_2/locale/po/grasslibs_ru.po
--- grass/branches/releasebranch_7_2/locale/po/grasslibs_ru.po	2018-05-05 12:35:52 UTC (rev 72690)
+++ grass/branches/releasebranch_7_2/locale/po/grasslibs_ru.po	2018-05-05 12:36:15 UTC (rev 72691)
@@ -9091,7 +9091,7 @@
 #, c-format
 msgstr ""
Modified: grass/branches/releasebranch_7_2/locale/po/grasslibs_si.po
--- grass/branches/releasebranch_7_2/locale/po/grasslibs_si.po	2018-05-05 12:35:52 UTC (rev 72690)
+++ grass/branches/releasebranch_7_2/locale/po/grasslibs_si.po	2018-05-05 12:36:15 UTC (rev 72691)
@@ -3739,7 +3739,7 @@
 #, c-format
 msgstr ""
Modified: grass/branches/releasebranch_7_2/locale/po/grasslibs_sl.po
--- grass/branches/releasebranch_7_2/locale/po/grasslibs_sl.po	2018-05-05 12:35:52 UTC (rev 72690)
+++ grass/branches/releasebranch_7_2/locale/po/grasslibs_sl.po	2018-05-05 12:36:15 UTC (rev 72691)
@@ -9793,7 +9793,7 @@
 #, fuzzy, c-format
 msgstr "Nezmožen odpreti datoteko s tabelo fundamentalne točke: %s"
Modified: grass/branches/releasebranch_7_2/locale/po/grasslibs_ta.po
--- grass/branches/releasebranch_7_2/locale/po/grasslibs_ta.po	2018-05-05 12:35:52 UTC (rev 72690)
+++ grass/branches/releasebranch_7_2/locale/po/grasslibs_ta.po	2018-05-05 12:36:15 UTC (rev 72691)
@@ -388,7 +388,7 @@
 #, c-format
 msgstr ""
Modified: grass/branches/releasebranch_7_2/locale/po/grasslibs_th.po
--- grass/branches/releasebranch_7_2/locale/po/grasslibs_th.po	2018-05-05 12:35:52 UTC (rev 72690)
+++ grass/branches/releasebranch_7_2/locale/po/grasslibs_th.po	2018-05-05 12:36:15 UTC (rev 72691)
@@ -9073,7 +9073,7 @@
 #, c-format
 msgstr ""
Modified: grass/branches/releasebranch_7_2/locale/po/grasslibs_tr.po
--- grass/branches/releasebranch_7_2/locale/po/grasslibs_tr.po	2018-05-05 12:35:52 UTC (rev 72690)
+++ grass/branches/releasebranch_7_2/locale/po/grasslibs_tr.po	2018-05-05 12:36:15 UTC (rev 72691)
 #, c-format
 msgstr ""
Modified: grass/branches/releasebranch_7_2/locale/po/grasslibs_uk.po
--- grass/branches/releasebranch_7_2/locale/po/grasslibs_uk.po	2018-05-05 12:35:52 UTC (rev 72690)
+++ grass/branches/releasebranch_7_2/locale/po/grasslibs_uk.po	2018-05-05 12:36:15 UTC (rev 72691)
@@ -3745,7 +3745,7 @@
 #, c-format
 msgstr ""
Modified: grass/branches/releasebranch_7_2/locale/po/grasslibs_vi.po
--- grass/branches/releasebranch_7_2/locale/po/grasslibs_vi.po	2018-05-05 12:35:52 UTC (rev 72690)
+++ grass/branches/releasebranch_7_2/locale/po/grasslibs_vi.po	2018-05-05 12:36:15 UTC (rev 72691)
@@ -9075,7 +9075,7 @@
 #, c-format
 msgstr ""
Modified: grass/branches/releasebranch_7_2/locale/po/grasslibs_zh.po
--- grass/branches/releasebranch_7_2/locale/po/grasslibs_zh.po	2018-05-05 12:35:52 UTC (rev 72690)
+++ grass/branches/releasebranch_7_2/locale/po/grasslibs_zh.po	2018-05-05 12:36:15 UTC (rev 72691)
 #, c-format
 msgstr ""
