[GRASS-SVN] r72747 - grass/branches/releasebranch_7_4/lib/vector/Vlib
Mon May 28 12:52:30 PDT 2018
Author: mmetz
Date: 2018-05-28 12:52:30 -0700 (Mon, 28 May 2018)
New Revision: 72747
   grass/branches/releasebranch_7_4/lib/vector/Vlib/intersect2.c
Vlib: fix with_z = 0 for Vect_line_check_intersection2() and Vect_line_intersection2(), fixes #3567 (backport trunk r72746)
Modified: grass/branches/releasebranch_7_4/lib/vector/Vlib/intersect2.c
--- grass/branches/releasebranch_7_4/lib/vector/Vlib/intersect2.c	2018-05-28 19:51:49 UTC (rev 72746)
+++ grass/branches/releasebranch_7_4/lib/vector/Vlib/intersect2.c	2018-05-28 19:52:30 UTC (rev 72747)
@@ -581,8 +581,8 @@
 int
 Vect_line_intersection2(struct line_pnts *APoints,
 		        struct line_pnts *BPoints,
-		        struct bound_box *ABox,
-		        struct bound_box *BBox,
+		        struct bound_box *pABox,
+		        struct bound_box *pBBox,
 		        struct line_pnts ***ALines,
 		        struct line_pnts ***BLines,
 		        int *nalines, int *nblines, int with_z)
@@ -594,7 +594,7 @@
     struct line_pnts **XLines, *Points;
     struct line_pnts *Points1, *Points2;	/* first, second points */
     int seg1, seg2, vert1, vert2;
-    struct bound_box abbox;
+    struct bound_box ABox, BBox, abbox;
     struct boq bo_queue;
     struct qitem qi, *found;
     struct RB_TREE *bo_ta, *bo_tb;
@@ -681,25 +681,36 @@
      *  we have to break both A and B  at once i.e. in one Vect_line_intersection () call.
-    if (!same && !Vect_box_overlap(ABox, BBox)) {
+    /* don't modify original bboxes: make a copy of the bboxes */
+    ABox = *pABox;
+    BBox = *pBBox;
+    if (!with_z) {
+	ABox.T = BBox.T = PORT_DOUBLE_MAX;
+	ABox.B = BBox.B = -PORT_DOUBLE_MAX;
+    if (!same && !Vect_box_overlap(&ABox, &BBox)) {
 	return 0;
     /* overlap box of A line and B line */
-    abbox = *ABox;
+    abbox = BBox;
     if (!same) {
-	if (abbox.N > BBox->N)
-	    abbox.N = BBox->N;
-	if (abbox.S < BBox->S)
-	    abbox.S = BBox->S;
-	if (abbox.E > BBox->E)
-	    abbox.E = BBox->E;
-	if (abbox.W < BBox->W)
-	    abbox.W = BBox->W;
-	if (abbox.T > BBox->T)
-	    abbox.T = BBox->T;
-	if (abbox.B < BBox->B)
-	    abbox.B = BBox->B;
+	if (abbox.N > ABox.N)
+	    abbox.N = ABox.N;
+	if (abbox.S < ABox.S)
+	    abbox.S = ABox.S;
+	if (abbox.E > ABox.E)
+	    abbox.E = ABox.E;
+	if (abbox.W < ABox.W)
+	    abbox.W = ABox.W;
+	if (with_z) {
+	    if (abbox.T > BBox.T)
+		abbox.T = BBox.T;
+	    if (abbox.B < BBox.B)
+		abbox.B = BBox.B;
     abbox.N += rethresh;
@@ -706,8 +717,10 @@
     abbox.S -= rethresh;
     abbox.E += rethresh;
     abbox.W -= rethresh;
-    abbox.T += rethresh;
-    abbox.B -= rethresh;
+    if (with_z) {
+	abbox.T += rethresh;
+	abbox.B -= rethresh;
     if (APnts->n_points < 2 || BPnts->n_points < 2) {
 	G_fatal_error("Intersection with points is not yet supported");
@@ -1317,6 +1330,10 @@
     dig_line_box(APoints, &ABox);
     dig_line_box(BPoints, &BBox);
+    if (!with_z) {
     if (!Vect_box_overlap(&ABox, &BBox)) {
 	return 0;
@@ -1332,18 +1349,22 @@
 	abbox.E = ABox.E;
 	abbox.W = ABox.W;
-    if (abbox.T > ABox.T)
-	abbox.T = ABox.T;
-    if (abbox.B < ABox.B)
-	abbox.B = ABox.B;
+    if (with_z) {
+	if (abbox.T > ABox.T)
+	    abbox.T = ABox.T;
+	if (abbox.B < ABox.B)
+	    abbox.B = ABox.B;
     /* initialize queue */
     bo_queue.count = 0;
     bo_queue.alloc = 2 * (APnts->n_points + BPnts->n_points);
