[GRASS-SVN] r73654 - grass/trunk/vector/v.select/testsuite
Wed Nov 7 07:56:49 PST 2018
Author: mlennert
Date: 2018-11-07 07:56:49 -0800 (Wed, 07 Nov 2018)
New Revision: 73654
   grass/trunk/vector/v.select/testsuite/test_v_select.py
v.select (testsuite): use self for the specific instance, not cls
Modified: grass/trunk/vector/v.select/testsuite/test_v_select.py
--- grass/trunk/vector/v.select/testsuite/test_v_select.py	2018-11-07 15:42:54 UTC (rev 73653)
+++ grass/trunk/vector/v.select/testsuite/test_v_select.py	2018-11-07 15:56:49 UTC (rev 73654)
@@ -31,7 +31,7 @@
         cls.del_temp_region()
     def tearDown(self):
-        self.runModule('g.remove', type='vector', flags='f', name=cls.output)
+        self.runModule('g.remove', type='vector', flags='f', name=self.output)
     def test_opo(self):
         """Testing operator overlap"""
