[GRASS-SVN] r73699 - grass/branches/releasebranch_7_4
Sat Nov 24 01:51:40 PST 2018
Author: neteler
Date: 2018-11-24 01:51:40 -0800 (Sat, 24 Nov 2018)
New Revision: 73699
   grass/branches/releasebranch_7_4/config.guess
   grass/branches/releasebranch_7_4/config.sub
config.guess + config.sub: updated from http://git.savannah.gnu.org/cgit/config.git/plain/
Modified: grass/branches/releasebranch_7_4/config.guess
--- grass/branches/releasebranch_7_4/config.guess	2018-11-24 09:49:47 UTC (rev 73698)
+++ grass/branches/releasebranch_7_4/config.guess	2018-11-24 09:51:40 UTC (rev 73699)
@@ -890,7 +890,7 @@
 	echo "$UNAME_MACHINE"-pc-uwin
 	exit ;;
     amd64:CYGWIN*:*:* | x86_64:CYGWIN*:*:*)
-	echo x86_64-unknown-cygwin
+	echo x86_64-pc-cygwin
 	exit ;;
     prep*:SunOS:5.*:*)
 	echo powerpcle-unknown-solaris2"`echo "$UNAME_RELEASE"|sed -e 's/[^.]*//'`"
Modified: grass/branches/releasebranch_7_4/config.sub
--- grass/branches/releasebranch_7_4/config.sub	2018-11-24 09:49:47 UTC (rev 73698)
+++ grass/branches/releasebranch_7_4/config.sub	2018-11-24 09:51:40 UTC (rev 73699)
@@ -89,7 +89,7 @@
     - )	# Use stdin as input.
        break ;;
-       echo "$me: invalid option $1$help"
+       echo "$me: invalid option $1$help" >&2
        exit 1 ;;
     *local*)
@@ -149,7 +149,7 @@
 		esac
-		# A lone config we happen to match not fitting any patern
+		# A lone config we happen to match not fitting any pattern
 		case $field1-$field2 in
 			decstation-3100)
 				basic_machine=mips-dec
@@ -950,7 +950,7 @@
 # Decode basic machines in the full and proper CPU-Company form.
 case $cpu-$vendor in
-	# Here we handle the default manufacturer of certain CPU types in cannonical form. It is in
+	# Here we handle the default manufacturer of certain CPU types in canonical form. It is in
 	# some cases the only manufacturer, in others, it is the most popular.
 	craynv-unknown)
 		vendor=cray
@@ -1101,7 +1101,7 @@
 		cpu=`echo "$cpu" | sed 's/^xscale/arm/'`
-	# Recognize the cannonical CPU Types that limit and/or modify the
+	# Recognize the canonical CPU Types that limit and/or modify the
 	# company names they are paired with.
 	cr16-*)
 		os=${os:-elf}
@@ -1150,7 +1150,7 @@
-		# Recognize the cannonical CPU types that are allowed with any
+		# Recognize the canonical CPU types that are allowed with any
 		# company name.
 		case $cpu in
 			1750a | 580 \
@@ -1161,6 +1161,7 @@
 			| alpha64 | alpha64ev[4-8] | alpha64ev56 | alpha64ev6[78] \
 			| alphapca5[67] | alpha64pca5[67] \
 			| am33_2.0 \
+			| amdgcn \
 			| arc | arceb \
 			| arm  | arm[lb]e | arme[lb] | armv* \
 			| avr | avr32 \
@@ -1360,7 +1361,7 @@
 	     | powermax* | dnix* | nx6 | nx7 | sei* | dragonfly* \
 	     | skyos* | haiku* | rdos* | toppers* | drops* | es* \
 	     | onefs* | tirtos* | phoenix* | fuchsia* | redox* | bme* \
-	     | midnightbsd*)
+	     | midnightbsd* | amdhsa*)
 	# Remember, each alternative MUST END IN *, to match a version number.
 	qnx*)
