[GRASS-SVN] r73620 - in grass/branches/releasebranch_7_4/lib/vector: diglib rtree
Mon Oct 29 01:30:16 PDT 2018
Author: mmetz
Date: 2018-10-29 01:30:16 -0700 (Mon, 29 Oct 2018)
New Revision: 73620
   grass/branches/releasebranch_7_4/lib/vector/diglib/spindex_rw.c
   grass/branches/releasebranch_7_4/lib/vector/rtree/index.c
   grass/branches/releasebranch_7_4/lib/vector/rtree/io.c
vectorlib: fix size estimation of spatial indices (backport trunk r73618)
Modified: grass/branches/releasebranch_7_4/lib/vector/diglib/spindex_rw.c
--- grass/branches/releasebranch_7_4/lib/vector/diglib/spindex_rw.c	2018-10-29 08:30:04 UTC (rev 73619)
+++ grass/branches/releasebranch_7_4/lib/vector/diglib/spindex_rw.c	2018-10-29 08:30:16 UTC (rev 73620)
@@ -65,7 +65,8 @@
     /* use ptr->off_t_size = 4 if possible */
     if (sizeof(off_t) > 4) {
-	size = ptr->Node_spidx->n_nodes * ptr->Node_spidx->nodesize;
+	size = 145;	/* max header size, see below */
+	size += ptr->Node_spidx->n_nodes * ptr->Node_spidx->nodesize;
 	size += ptr->Line_spidx->n_nodes * ptr->Line_spidx->nodesize;
 	size += ptr->Area_spidx->n_nodes * ptr->Area_spidx->nodesize;
 	size += ptr->Isle_spidx->n_nodes * ptr->Isle_spidx->nodesize;
Modified: grass/branches/releasebranch_7_4/lib/vector/rtree/index.c
--- grass/branches/releasebranch_7_4/lib/vector/rtree/index.c	2018-10-29 08:30:04 UTC (rev 73619)
+++ grass/branches/releasebranch_7_4/lib/vector/rtree/index.c	2018-10-29 08:30:16 UTC (rev 73620)
@@ -84,13 +84,13 @@
     new_rtree->free_nodes.pos = NULL;
     new_rtree->rectsize = new_rtree->nsides_alloc * sizeof(RectReal);
+    new_rtree->branchsize = sizeof(struct RTree_Branch) -
+                            sizeof(struct RTree_Rect) +
+			    new_rtree->rectsize;
     new_rtree->nodesize = sizeof(struct RTree_Node) -
-                          MAXCARD * sizeof(RectReal *) +
-			  MAXCARD * new_rtree->rectsize;
+                          sizeof(struct RTree_Branch *) +
+			  MAXCARD * new_rtree->branchsize;
-    new_rtree->branchsize = sizeof(struct RTree_Branch) -
-                            sizeof(RectReal *) + new_rtree->rectsize;
     /* create empty root node */
     n = RTreeAllocNode(new_rtree, 0);
     new_rtree->rootlevel = n->level = 0;       /* leaf */
Modified: grass/branches/releasebranch_7_4/lib/vector/rtree/io.c
--- grass/branches/releasebranch_7_4/lib/vector/rtree/io.c	2018-10-29 08:30:04 UTC (rev 73619)
+++ grass/branches/releasebranch_7_4/lib/vector/rtree/io.c	2018-10-29 08:30:16 UTC (rev 73620)
@@ -18,10 +18,12 @@
 #include <stdlib.h>
 #include <stdio.h>
+#include <string.h>
 #include <sys/types.h>
 #include <unistd.h>
 #include <assert.h>
-#include <grass/config.h>
+#include <errno.h>
+#include <grass/gis.h>
 #include "index.h"
 /* #define USAGE_SWAP */
@@ -153,8 +155,12 @@
     size_t size = 0;
-    size += write(t->fd, b->rect.boundary, t->rectsize);
-    size += write(t->fd, &(b->child), sizeof(union RTree_Child));
+    if (write(t->fd, b->rect.boundary, t->rectsize) != t->rectsize)
+	G_fatal_error("RTreeWriteBranch(): Unable to write (%s)", strerror(errno));
+    size += t->rectsize;
+    if (write(t->fd, &(b->child), sizeof(union RTree_Child)) != sizeof(union RTree_Child))
+    size += sizeof(union RTree_Child);
     return size;
@@ -166,8 +172,12 @@
     size_t size = 0;
     /* file position must be set first with RTreeGetFNodePos() */
-    size += write(t->fd, &(n->count), sizeof(int));
-    size += write(t->fd, &(n->level), sizeof(int));
+    if (write(t->fd, &(n->count), sizeof(int)) != sizeof(int))
+	G_fatal_error("RTreeWriteNode(): Unable to write (%s)", strerror(errno));
+    size += sizeof(int);
+    if (write(t->fd, &(n->level), sizeof(int)) != sizeof(int))
     for (i = 0; i < MAXCARD; i++) {
 	size += RTreeWriteBranch(&(n->branch[i]), t);
