[GRASS-SVN] r73631 - in grass-addons/grass7/raster/r.green: . r.green.biomassfor r.green.gshp r.green.hydro r.green.install
Wed Oct 31 04:07:34 PDT 2018
Author: neteler
Date: 2018-10-31 04:07:34 -0700 (Wed, 31 Oct 2018)
New Revision: 73631
   grass-addons/grass7/raster/r.green/r.green.biomassfor/r.green.biomassfor.html
   grass-addons/grass7/raster/r.green/r.green.gshp/r.green.gshp.html
   grass-addons/grass7/raster/r.green/r.green.html
   grass-addons/grass7/raster/r.green/r.green.hydro/r.green.hydro.html
   grass-addons/grass7/raster/r.green/r.green.install/r.green.install.html
r.green addon: initial manual page cleanup
Modified: grass-addons/grass7/raster/r.green/r.green.biomassfor/r.green.biomassfor.html
--- grass-addons/grass7/raster/r.green/r.green.biomassfor/r.green.biomassfor.html	2018-10-31 10:53:58 UTC (rev 73630)
+++ grass-addons/grass7/raster/r.green/r.green.biomassfor/r.green.biomassfor.html	2018-10-31 11:07:34 UTC (rev 73631)
@@ -1,8 +1,22 @@
 <h2>DESCRIPTION</h2>
-Compute the energy potential of biomass from the forestry residues,
-considering different limits and constraints (e.g. legal, technical, economic).
+The <em>r.green.biomassfor</em> suite computes the energy potential of biomass from
+the forestry residues, considering different limits and constraints (e.g. legal,
+technical, economic).
+<p>
+The <em>r.green.biomassfor</em> suite consists of the following different parts:<br><br>
+<ul>
+<li><a href="r.green.biomassfor.html">r.green.biomassfor</a> - computes the energy potential of biomass from the forestry residues, considering different limits and constraints (e.g. legal, technical, economic).</li>
+<li><a href="r.green.biomassfor.theoretical.html">r.green.biomassfor.theoretical</a> - Estimates potential bioenergy depending on forest increment, forest management and forest treatment</li>
+<li><a href="r.green.biomassfor.legal.html">r.green.biomassfor.legal</a> - Estimates potential bioenergy depending on forest increment, forest management and forest treatment </li>
+<li><a href="r.green.biomassfor.technical.html">r.green.biomassfor.tecnical</a> - Estimates the quantity of woody biomass obtained from a forest surface where extraction is possible given a particular level of mechanisation </li>
+<li><a href="r.green.biomassfor.financial.html">r.green.biomassfor.financial</a> - Estimates bioenergy that can be collected to supply heating plants or biomass logistic centres and that is associated with a positive net revenue for the entire production process</li>
+<li><a href="r.green.biomassfor.recommended.html">r.green.biomassfor.recommended</a> - Estimates potential bioenergy according to environmental restriction </li>
+<li><a href="r.green.biomassfor.impact.html">r.green.biomassfor.impact</a> - Calculates impact and multifunctionality values </li>
+</ul>
 <h2>NOTES</h2>
 <h2>EXAMPLE</h2>
@@ -12,14 +26,7 @@
 <h2>SEE ALSO</h2>
 <em>
-  <a href="r.green.html">r.green</a>,
-  <a href="r.green.biomassfor.html">r.green.biomassfor</a>,
-  <a href="r.green.biomassfor.theoretical.html">r.green.biomassfor.theoretical</a>,
-  <a href="r.green.biomassfor.legal.html">r.green.biomassfor.legal</a>,
-  <a href="r.green.biomassfor.technical.html">r.green.biomassfor.tecnical</a>,
-  <a href="r.green.biomassfor.economic.html">r.green.biomassfor.economic</a>,
-  <a href="r.green.biomassfor.recommended.html">r.green.biomassfor.recommended</a>,
-  <a href="r.green.biomassfor.impact.html">r.green.biomassfor.economic</a>
+<a href="r.green.html">r.green</a> - overview page
 </em>
 <h2>AUTHORS</h2>
Modified: grass-addons/grass7/raster/r.green/r.green.gshp/r.green.gshp.html
--- grass-addons/grass7/raster/r.green/r.green.gshp/r.green.gshp.html	2018-10-31 10:53:58 UTC (rev 73630)
+++ grass-addons/grass7/raster/r.green/r.green.gshp/r.green.gshp.html	2018-10-31 11:07:34 UTC (rev 73631)
@@ -1,24 +1,36 @@
-The module r.green.gshp computes the Ground Source Heat Pump potential. <br>
-It is composed of several programs considering different limits (e.g. theoretical, planning, technical, economic/finacial constraints).<br>
+The <em>r.green.gshp</em> suite computes the Ground Source Heat Pump potential.<br>
+It is composed of several programs considering different limits (e.g. theoretical,
+planning, technical, economic/financial constraints).
+<p>
-The module r.green.gshp consists of the following different parts:<br><br>
+The <em>r.green.gshp</em> suite consists of the following different parts:<br><br>
-- <a href="r.green.gshp.theoretical.html">r.green.gshp.theoretical</a><br>
-  Calculates for each single Borehole Heat Exchanger (BHE) the maximum power/energy potential, assessed through the G.POT method.<br><br>
+<ul>
+<li><a href="r.green.gshp.theoretical.html">r.green.gshp.theoretical</a> -
+  Calculates for each single Borehole Heat Exchanger (BHE) the maximum power/energy potential, assessed through the G.POT method.</li>
+<li>further methods to be implemented</li>
-- <a href="r.green.gshp.planning.html">r.green.gshp.planning</a><br>
-  [status: not implemented yet] consider legal, ecological constraints and the user's recommendations to plan the use of the GSHP system<br><br>
+<li><a href="r.green.gshp.planning.html">r.green.gshp.planning</a> -
+  [status: not implemented yet] consider legal, ecological constraints and the user's recommendations to plan the use of the GSHP system</li>
-- <a href="r.green.gshp.technical.html">r.green.gshp.technical</a><br>
+<li><a href="r.green.gshp.technical.html">r.green.gshp.technical</a> -
   [status: testing] calculates the length of a BHE following the ASHRAE methodology.<br><br>
-- <a href="r.green.gshp.financial.html">r.green.gshp.financial</a><br>
-  [status: not implemented yet] computes the economic and financial feasibility of the ground source heat plants<br><br>
+<li><a href="r.green.gshp.financial.html">r.green.gshp.financial</a><br>
+  [status: not implemented yet] computes the economic and financial feasibility of the ground source heat plants</li>
+</ul>
+<h2>SEE ALSO</h2>
+<em>
+</em>
 <h2>AUTHORS</h2>
-For authors and references, please refer to each module of r.green.
+For authors and references, please refer to the respective module of <em>r.green</em>.
 <p><i>Last changed: $Date$</i>
Modified: grass-addons/grass7/raster/r.green/r.green.html
--- grass-addons/grass7/raster/r.green/r.green.html	2018-10-31 10:53:58 UTC (rev 73630)
+++ grass-addons/grass7/raster/r.green/r.green.html	2018-10-31 11:07:34 UTC (rev 73631)
@@ -19,9 +19,19 @@
 <!-- meta page description: Computes the residual energy potential of different renewable energies like biomass or hydropower -->
-<em>r.green</em> computes the residual energy potential of different
-renewable energies like biomass or hydropower.<br>
-The tool is organized in the modules r.green.hydro and r.green.biomass
+The <em>r.green</em> suite computes the residual energy potential of different
+renewable energies like biomass, ground source heat pumps, or hydropower.
+<p>
+The tool is organized in the module groups:
+<ul>
+    the energy potential of biomass from the forestry residues</li>
+<li><a href="r.green.gshp.html">r.green.gshp</a> - computes the Ground Source
+    Heat Pump potential</li>
+<li><a href="r.green.hydro.html">r.green.hydro</a> - computes the hydropower potential</li>
+</ul>
 for which are composed of several programs considering different limits
 (e.g. theoretical, recommended, legal, technical, ecological and economic constraints).<br>
 These different scenarios can be compared so that the residual energy
@@ -28,7 +38,8 @@
 potential and the suitable places for constructing a new power plant can be identified.<br>
 <p>
-All the modules of the tool r.green can be installed in GRASS as following:
+All the modules of the tool r.green can be installed in GRASS GIS as following
+(see also <a href="r.green.install.html">r.green.install</a>):
 <div class="code"><pre>
 g.extension r.green
@@ -47,12 +58,14 @@
 <h2>SEE ALSO</h2>
 <em>
-  <a href="r.green.hydro.html">r.green.hydro</a>
+<a href="r.green.install.html">r.green.install</a>,
+<a href="r.green.biomassfor.html">r.green.biomassfor</a>,
+<a href="r.green.gshp.html">r.green.gshp</a>,
+<a href="r.green.hydro.html">r.green.hydro</a>
 </em>
 <h2>AUTHORS</h2>
-For authors, please refer to each module of r.green.
Modified: grass-addons/grass7/raster/r.green/r.green.hydro/r.green.hydro.html
--- grass-addons/grass7/raster/r.green/r.green.hydro/r.green.hydro.html	2018-10-31 10:53:58 UTC (rev 73630)
+++ grass-addons/grass7/raster/r.green/r.green.hydro/r.green.hydro.html	2018-10-31 11:07:34 UTC (rev 73631)
@@ -1,9 +1,9 @@
-The module r.green.hydro computes the hydropower potential. <br>
+The <em>r.green.hydro</em> suite computes the hydropower potential. <br>
 It is composed of several programs considering different limits (e.g. theoretical, recommended, legal, technical, ecological and economic constraints).<br>
-The module r.green.hydro consists of the following six different parts:<br><br>
+The <em>r.green.hydro</em> suite consists of the following six different parts:<br><br>
 - <a href="r.green.hydro.theoretical.html">r.green.hydro.theoretical</a><br>
   calculates for each basin the theoretical maximum hydropower energy potential<br>
@@ -40,8 +40,14 @@
   input vector map:       considered rivers<br>
   output vector maps: - potential river segments               - intake and restitution of each potential plant<br><br>
+<h2>SEE ALSO</h2>
+<em>
+</em>
 <h2>AUTHORS</h2>
Modified: grass-addons/grass7/raster/r.green/r.green.install/r.green.install.html
--- grass-addons/grass7/raster/r.green/r.green.install/r.green.install.html	2018-10-31 10:53:58 UTC (rev 73630)
+++ grass-addons/grass7/raster/r.green/r.green.install/r.green.install.html	2018-10-31 11:07:34 UTC (rev 73631)
@@ -1,6 +1,6 @@
-<em>r.green.install</em> check that all the necessary python libraries like scipy and numexpr are present in the python path. The module also check post-installation troubles that sometimes may occur.
+<em>r.green.install</em> checks that all the necessary python libraries like scipy and numexpr are present in the python path. The module also check post-installation troubles that sometimes may occur.
 <h2>NOTES</h2>
@@ -50,16 +50,21 @@
 r.green.istall -i
 </pre></div><br>
-Check the list of suggested libraries with the previous table. If they agree, you can proceede with the installation.
+Check the list of suggested libraries with the previous table. If they agree, you can proceed with the installation.
 If you install the Energy menu, use the following command:
-r.green.istall -x
+r.green.install -x
 </pre></div><br>
 Close GRASS and restart the programm to have in the the menu the session energy with all the r.green modules.
+<h2>SEE ALSO</h2>
+<em>
+</em>
 <h2>AUTHORS</h2>
 Pietro Zambelli (Eurac Research, Bolzano, Italy)
