[GRASS-SVN] r73235 - in grass/branches/releasebranch_7_6/raster: r.random.cells r.random.surface
Mon Sep 3 13:04:40 PDT 2018
Author: mmetz
Date: 2018-09-03 13:04:40 -0700 (Mon, 03 Sep 2018)
New Revision: 73235
   grass/branches/releasebranch_7_6/raster/r.random.cells/init.c
   grass/branches/releasebranch_7_6/raster/r.random.cells/main.c
   grass/branches/releasebranch_7_6/raster/r.random.cells/random.c
   grass/branches/releasebranch_7_6/raster/r.random.cells/ransurf.h
   grass/branches/releasebranch_7_6/raster/r.random.surface/init.c
   grass/branches/releasebranch_7_6/raster/r.random.surface/main.c
   grass/branches/releasebranch_7_6/raster/r.random.surface/random.c
   grass/branches/releasebranch_7_6/raster/r.random.surface/ransurf.h
r.random.cells, r.random.surface: use G_drand48(), fixes #2496 (backport trunk r73234)
Modified: grass/branches/releasebranch_7_6/raster/r.random.cells/init.c
--- grass/branches/releasebranch_7_6/raster/r.random.cells/init.c	2018-09-03 20:03:54 UTC (rev 73234)
+++ grass/branches/releasebranch_7_6/raster/r.random.cells/init.c	2018-09-03 20:04:40 UTC (rev 73235)
@@ -79,19 +79,16 @@
     G_debug(3, "(MaxDist):%.12lf", MaxDist);
     MaxDistSq = MaxDist * MaxDist;
     if (!SeedStuff->answer) {
-	Seed = (int)getpid();
+	Seed = -1;
     else {
 	sscanf(SeedStuff->answer, "%d", &(Seed));
-    if (Seed > SEED_MAX) {
-	Seed = Seed % SEED_MAX;
-    else if (Seed < SEED_MIN) {
-	while (Seed < SEED_MIN)
-	    Seed += SEED_MAX - SEED_MIN;
+    if (Seed < 0)
+	G_srand48_auto();
+    else
+	G_srand48(Seed);
     G_message(_("Generating raster map <%s>..."),
 	      Output->answer);
Modified: grass/branches/releasebranch_7_6/raster/r.random.cells/main.c
--- grass/branches/releasebranch_7_6/raster/r.random.cells/main.c	2018-09-03 20:03:54 UTC (rev 73234)
+++ grass/branches/releasebranch_7_6/raster/r.random.cells/main.c	2018-09-03 20:04:40 UTC (rev 73235)
@@ -74,7 +74,7 @@
     SeedStuff->type = TYPE_INTEGER;
     SeedStuff->required = NO;
     SeedStuff->description =
-	_("Random seed (SEED_MIN >= value >= SEED_MAX) (default [random])");
+	_("Random seed, default [random]");
     if (G_parser(argc, argv))
 	exit(EXIT_FAILURE);
Modified: grass/branches/releasebranch_7_6/raster/r.random.cells/random.c
--- grass/branches/releasebranch_7_6/raster/r.random.cells/random.c	2018-09-03 20:03:54 UTC (rev 73234)
+++ grass/branches/releasebranch_7_6/raster/r.random.cells/random.c	2018-09-03 20:04:40 UTC (rev 73235)
@@ -4,53 +4,10 @@
 #include "ransurf.h"
-#define M1 259200
-#define IA1 7141
-#define IC1 54773
-#define RM1 (1.0/M1)
-#define M2 134456
-#define IA2 8121
-#define IC2 28411
-#define RM2 (1.0/M2)
-#define M3 243000
-#define IA3 4561
-#define IC3 51349
 /* ran1() returns a double with a value between 0.0 and 1.0             */
 double ran1(void)
-    static long ix1, ix2, ix3;
-    static double r[98];
-    double temp;
-    static int iff = 0;
-    int j;
     G_debug(2, "ran1()");
-    if (Seed < 0 || iff == 0) {
-	iff = 1;
-	ix1 = (IC1 - Seed) % M1;
-	ix1 = (IA1 * ix1 + IC1) % M1;
-	ix2 = ix1 % M2;
-	ix3 = ix1 % M3;
-	for (j = 1; j <= 97; j++) {
-	    ix2 = (IA2 * ix2 + IC2) % M2;
-	    r[j] = (ix1 + ix2 * RM2) * RM1;
-	Seed = 1;
-    ix3 = (IA3 * ix3 + IC3) % M3;
-    j = 1 + ((97 * ix3) / M3);
-    if (j > 97 || j < 1)
-	G_fatal_error(_("RAN1: j == %d shouldn't happen"), j);
-    temp = r[j];
-    return temp;
+    return G_drand48();
Modified: grass/branches/releasebranch_7_6/raster/r.random.cells/ransurf.h
--- grass/branches/releasebranch_7_6/raster/r.random.cells/ransurf.h	2018-09-03 20:03:54 UTC (rev 73234)
+++ grass/branches/releasebranch_7_6/raster/r.random.cells/ransurf.h	2018-09-03 20:04:40 UTC (rev 73235)
@@ -7,8 +7,6 @@
 #define ODD(a)	((a) & 1)
-#define SEED_MAX		54772
-#define SEED_MIN		0
 #define PI       		M_PI
 #define CELLSORTER struct cell_sorter_
Modified: grass/branches/releasebranch_7_6/raster/r.random.surface/init.c
--- grass/branches/releasebranch_7_6/raster/r.random.surface/init.c	2018-09-03 20:03:54 UTC (rev 73234)
+++ grass/branches/releasebranch_7_6/raster/r.random.surface/init.c	2018-09-03 20:04:40 UTC (rev 73235)
@@ -94,33 +94,15 @@
     Theory = 0;
     NumSeeds = 0;
     Seeds = (int *)G_malloc(NumMaps * sizeof(int));
+    Seed = -1;
     if (!SeedStuff->answers) {
 	for (i = 0; i < NumMaps; i++) {
-	    Seeds[i] = SEED_MIN - 1;
+	    Seeds[i] = -1;
     else {
 	for (i = 0; (Number = SeedStuff->answers[i]) && i < NumMaps; i++) {
 	    sscanf(Number, "%d", &(Seeds[i]));
-	    if (Seeds[i] > SEED_MAX) {
-		sprintf(msg, _("Seed (%d) larger than maximum (%d)"),
-			Seeds[i], SEED_MAX);
-		Seeds[i] = Seeds[i] % SEED_MAX;
-		sprintf(msg2, _(" seed is set to %d"), Seeds[i]);
-		strcat(msg, msg2);
-		G_warning("%s", msg);
-	    else if (Seeds[i] < SEED_MIN) {
-		sprintf(msg, _("Seed (%d) smaller than minimum (%d)"),
-			Seeds[i], SEED_MIN);
-		while (Seeds[i] < SEED_MIN)
-		    Seeds[i] += SEED_MAX - SEED_MIN;
 	}			/* /for */
     }				/* /else */
Modified: grass/branches/releasebranch_7_6/raster/r.random.surface/main.c
--- grass/branches/releasebranch_7_6/raster/r.random.surface/main.c	2018-09-03 20:03:54 UTC (rev 73234)
+++ grass/branches/releasebranch_7_6/raster/r.random.surface/main.c	2018-09-03 20:04:40 UTC (rev 73235)
@@ -99,7 +99,7 @@
-	_("Random seed (SEED_MIN >= value >= SEED_MAX), default [random]");
     range_high_stuff = G_define_option();
     range_high_stuff->key = "high";
@@ -127,8 +127,10 @@
 	G_message(_("Generating raster map <%s>..."), OutNames[DoMap]);
-	if (Seeds[DoMap] == SEED_MIN - 1)
-	    Seeds[DoMap] = (int)(ran1() * SEED_MAX);
+	if (Seeds[DoMap] < 0)
+	    G_srand48_auto();
+	else
+	    G_srand48(Seeds[DoMap]);
 	MapSeed = Seed = Seeds[DoMap];
 	ZeroMapCells();
Modified: grass/branches/releasebranch_7_6/raster/r.random.surface/random.c
--- grass/branches/releasebranch_7_6/raster/r.random.surface/random.c	2018-09-03 20:03:54 UTC (rev 73234)
+++ grass/branches/releasebranch_7_6/raster/r.random.surface/random.c	2018-09-03 20:04:40 UTC (rev 73235)
@@ -2,54 +2,10 @@
 #include <grass/gis.h>
-#define M1 259200
-#define IA1 7141
-#define IC1 54773
-#define M2 134456
-#define IA2 8121
-#define IC2 28411
-#define M3 243000
-#define IA3 4561
-#define IC3 51349
 double ran1(void)
-    double temp;
-    int j;
-	iff = 1;
-	ix2 = ix1 % M2;
-	ix3 = ix1 % M3;
-	Seed = 1;
-	G_fatal_error("RAN1: j==%d shouldn't happen", j);
-    temp = r[j];
-    return temp;
Modified: grass/branches/releasebranch_7_6/raster/r.random.surface/ransurf.h
--- grass/branches/releasebranch_7_6/raster/r.random.surface/ransurf.h	2018-09-03 20:03:54 UTC (rev 73234)
+++ grass/branches/releasebranch_7_6/raster/r.random.surface/ransurf.h	2018-09-03 20:04:40 UTC (rev 73235)
@@ -8,8 +8,6 @@
-#define SEED_MIN		0
 #define MAX_INTERVAL		10
 #define MIN_INTERVAL		-10
 /* DELTA_T is the inverse of the number of subdivisions within the      */
