[GRASS-SVN] r73244 - in grass-addons/grass7/imagery: . i.rh
Tue Sep 4 01:37:38 PDT 2018
Author: ychemin
Date: 2018-09-04 01:37:38 -0700 (Tue, 04 Sep 2018)
New Revision: 73244
Added:
   grass-addons/grass7/imagery/i.rh/
   grass-addons/grass7/imagery/i.rh/Makefile
   grass-addons/grass7/imagery/i.rh/i.rh.html
   grass-addons/grass7/imagery/i.rh/main.c
   grass-addons/grass7/imagery/i.rh/rh.c
   grass-addons/grass7/imagery/Makefile
added i.rh
Modified: grass-addons/grass7/imagery/Makefile
--- grass-addons/grass7/imagery/Makefile	2018-09-04 05:57:32 UTC (rev 73243)
+++ grass-addons/grass7/imagery/Makefile	2018-09-04 08:37:38 UTC (rev 73244)
@@ -21,6 +21,7 @@
         i.modis \
         i.points.auto \
 	i.pysptools.unmix \
+	i.rh \
 	i.rotate \
 	i.segment.gsoc \
 	i.segment.hierarchical \
Added: grass-addons/grass7/imagery/i.rh/Makefile
--- grass-addons/grass7/imagery/i.rh/Makefile	                        (rev 0)
+++ grass-addons/grass7/imagery/i.rh/Makefile	2018-09-04 08:37:38 UTC (rev 73244)
@@ -0,0 +1,10 @@
+MODULE_TOPDIR = ../..
+PGM = i.rh
+LIBES = $(GISLIB) $(RASTERLIB)
+DEPENDENCIES = $(GISDEP) $(RASTERDEP)
+include $(MODULE_TOPDIR)/include/Make/Module.make
+default: cmd
Added: grass-addons/grass7/imagery/i.rh/i.rh.html
--- grass-addons/grass7/imagery/i.rh/i.rh.html	                        (rev 0)
+++ grass-addons/grass7/imagery/i.rh/i.rh.html	2018-09-04 08:37:38 UTC (rev 73244)
@@ -0,0 +1,30 @@
+<h2>DESCRIPTION</h2>
+<em>i.rh</em> calculates the relative humidity
+-s will return saturated water vapour instead.
+-a will return actual water vapour instead.
+<h2>NOTES</h2>
+<h2>REFERENCES</h2>
+https://www.researchgate.net/publication/227247013_High-resolution_Surface_Relative_Humidity_Computation_Using_MODIS_Image_in_Peninsular_Malaysia/
+<h2>SEE ALSO</h2>
+<em>
+<a href="i.vi.html">i.vi</a><br>
+<a href="i.albedo.html">i.albedo</a><br>
+<a href="i.wi.html">i.vi</a><br>
+</em>
+<h2>AUTHOR</h2>
+Yann Chemin, Plumergat, France<br>
+<p>
+<i>Last changed: $Date: 2017-01-19 15:39:35 +0000 (Thu, 19 Jan 2017) $</i>
Added: grass-addons/grass7/imagery/i.rh/main.c
--- grass-addons/grass7/imagery/i.rh/main.c	                        (rev 0)
+++ grass-addons/grass7/imagery/i.rh/main.c	2018-09-04 08:37:38 UTC (rev 73244)
@@ -0,0 +1,223 @@
+ * MODULE:       i.rh
+ * AUTHOR(S):    Yann Chemin - yann.chemin at gmail.com
+ * PURPOSE:      Calculates relative humidity
+ * COPYRIGHT:    (C) 2017-2019 by the GRASS Development Team
+ *               This program is free software under the GNU General Public
+ *   	    	 License (>=v2). Read the file COPYING that comes with GRASS
+ *   	    	 for details.
+#include <stdio.h>
+#include <stdlib.h>
+#include <string.h>
+#include <grass/gis.h>
+#include <grass/raster.h>
+#include <grass/glocale.h>
+double rh(double PW,double Pa,double Ta,double dem);
+double esat(double tamean);
+double eact(double esat,double rh);
+int main(int argc, char *argv[])
+    struct Cell_head cellhd;	/*region+header info */
+    char *mapset="";		/*mapset name */
+    int nrows, ncols;
+    int row, col;
+    struct GModule *module;
+    struct Option *input1, *input2, *input3, *input4, *output1;
+    struct Flag *flag1, *flag2;
+    struct History history;	/*metadata */
+    char *name;			/*input raster name */
+    char *result1;		/*output raster name */
+    int infd_pw, infd_pa, infd_ta, infd_dem;
+    int outfd1;
+    char *pw, *pa, *ta, *dem;
+    int i = 0, j = 0;
+    void *inrast_pw, *inrast_pa, *inrast_ta, *inrast_dem;
+    CELL * outrast1;
+    RASTER_MAP_TYPE data_type_output = CELL_TYPE;
+    RASTER_MAP_TYPE data_type_pw;
+    RASTER_MAP_TYPE data_type_pa;
+    RASTER_MAP_TYPE data_type_ta;
+    RASTER_MAP_TYPE data_type_dem;
+    G_gisinit(argv[0]);
+    module = G_define_module();
+    G_add_keyword(_("imagery"));
+    G_add_keyword(_("atmosphere"));
+    G_add_keyword(_("humidity"));
+    G_add_keyword(_("water vapour"));
+    G_add_keyword(_("precipitable water"));
+    module->description = _("Water in atmosphere: relative humidity, water vapour (saturated, actual)");
+    /* Define the different options */
+    input1 = G_define_standard_option(G_OPT_R_INPUT);
+    input1->key = "pw";
+    input1->description = _("Name of the Precipitable Water layer");
+    input2 = G_define_standard_option(G_OPT_R_INPUT);
+    input2->key = "pa";
+    input2->description = _("Name of the Atmospheric Pressure layer");
+    input3 = G_define_standard_option(G_OPT_R_INPUT);
+    input3->key = "ta";
+    input3->description = _("Name of the mean daily air temperature layer");
+    input4 = G_define_standard_option(G_OPT_R_INPUT);
+    input4->key = "dem";
+    input4->description = _("Name of the elevation layer");
+    output1 = G_define_standard_option(G_OPT_R_OUTPUT);
+    output1->description = _("Name of the output layer");
+    flag1 = G_define_flag();
+    flag1->key = 's';
+    flag1->description = _("Output the saturated water vapour (esat)");
+    flag2 = G_define_flag();
+    flag2->key = 'a';
+    flag2->description = _("Output the actual water vapour (eact)");
+    if (G_parser(argc, argv))
+	exit(EXIT_FAILURE);
+    pw = input1->answer;
+    pa = input2->answer;
+    ta = input3->answer;
+    dem = input4->answer;
+    result1 = output1->answer;
+    if(flag1->answer && flag2->answer)
+	G_fatal_error(_("Cannot output both esat and eact, please choose"));
+    data_type_pw = Rast_map_type(pw, mapset);
+    if ((infd_pw = Rast_open_old(pw, mapset)) < 0)
+	G_fatal_error(_("Cannot open cell file [%s]"), pw);
+    Rast_get_cellhd(pw, mapset, &cellhd);
+    inrast_pw = Rast_allocate_buf(data_type_pw);
+    data_type_pa = Rast_map_type(pa, mapset);
+    if ((infd_pa = Rast_open_old(pa, mapset)) < 0)
+	    G_fatal_error(_("Cannot open cell file [%s]"), pa);
+    Rast_get_cellhd(pa, mapset, &cellhd);
+    inrast_pa = Rast_allocate_buf(data_type_pa);
+    data_type_ta = Rast_map_type(ta, mapset);
+    if ((infd_ta = Rast_open_old(ta, mapset)) < 0)
+	    G_fatal_error(_("Cannot open cell file [%s]"), ta);
+    Rast_get_cellhd(ta, mapset, &cellhd);
+    inrast_ta = Rast_allocate_buf(data_type_ta);
+    data_type_dem = Rast_map_type(dem, mapset);
+    if ((infd_dem = Rast_open_old(dem, mapset)) < 0)
+	    G_fatal_error(_("Cannot open cell file [%s]"), dem);
+    Rast_get_cellhd(dem, mapset, &cellhd);
+    inrast_dem = Rast_allocate_buf(data_type_dem);
+    G_debug(3, "number of rows %d", cellhd.rows);
+    nrows = Rast_window_rows();
+    ncols = Rast_window_cols();
+    outrast1 = Rast_allocate_buf(data_type_output);
+    /* Create New raster files */
+    if ((outfd1 = Rast_open_new(result1, data_type_output)) < 0)
+	G_fatal_error(_("Could not open <%s>"), result1);
+    /* Process pixels */
+    for (row = 0; row < nrows; row++)
+	CELL d;
+	DCELL d_pw;
+	DCELL d_pa;
+	DCELL d_ta;
+	DCELL d_dem;
+	G_percent(row, nrows, 2);
+        /* read input maps */
+        Rast_get_row(infd_pw, inrast_pw, row, data_type_pw);
+	Rast_get_row(infd_pa, inrast_pa, row, data_type_pa);
+	Rast_get_row(infd_ta, inrast_ta, row, data_type_ta);
+	Rast_get_row(infd_dem, inrast_dem, row, data_type_dem);
+	/*process the data */
+	for (col = 0; col < ncols; col++)
+	    switch (data_type_pw) {
+	    case CELL_TYPE:
+		d_pw = (double)((CELL *) inrast_pw)[col];
+		break;
+	    case FCELL_TYPE:
+		d_pw = (double)((FCELL *) inrast_pw)[col];
+		break;
+	    case DCELL_TYPE:
+		d_pw = ((DCELL *) inrast_pw)[col];
+		break;
+            switch (data_type_pa) {
+		case CELL_TYPE:
+		    d_pa = (double)((CELL *) inrast_pa)[col];
+		    break;
+		case FCELL_TYPE:
+		    d_pa = (double)((FCELL *) inrast_pa)[col];
+		    break;
+		case DCELL_TYPE:
+		    d_pa = ((DCELL *) inrast_pa)[col];
+		    break;
+	    switch (data_type_ta) {
+		case CELL_TYPE:
+		    d_ta = (double)((CELL *) inrast_ta)[col];
+		    break;
+		case FCELL_TYPE:
+		    d_ta = (double)((FCELL *) inrast_ta)[col];
+		    break;
+		case DCELL_TYPE:
+		    d_ta = ((DCELL *) inrast_ta)[col];
+		    break;
+	    switch (data_type_dem) {
+	    case CELL_TYPE:
+		d_dem = (double)((CELL *) inrast_dem)[col];
+		break;
+	    case FCELL_TYPE:
+		d_dem = (double)((FCELL *) inrast_dem)[col];
+		break;
+	    case DCELL_TYPE:
+		d_dem = ((DCELL *) inrast_dem)[col];
+		break;
+	    if (Rast_is_d_null_value(&d_pw) ||
+		 Rast_is_d_null_value(&d_pa) ||
+		 Rast_is_d_null_value(&d_ta) ||
+		 Rast_is_d_null_value(&d_dem)) {
+		Rast_set_c_null_value(&outrast1[col], 1);
+	    else {
+		d_rh = rh(pw,pa,ta,dem);
+		d_esat = esat(ta);
+		d_eact = eact(d_esat,d_rh);
+		if(flag1->answer) d=d_esat;
+		else if(flag2->answer) d=d_eact;
+		else d=d_rh;
+		outrast1[col] = d;
+	Rast_put_row(outfd1, outrast1, data_type_output);
+    free(inrast_pw);
+    free(inrast_pa);
+    free(inrast_ta);
+    free(inrast_dem);
+    free(outrast1);
+    Rast_close(infd_pw);
+    Rast_close(infd_pa);
+    Rast_close(infd_ta);
+    Rast_close(infd_dem);
+    Rast_close(outfd1);
+    Rast_short_history(result1, "raster", &history);
+    Rast_command_history(&history);
+    Rast_write_history(result1, &history);
+    exit(EXIT_SUCCESS);
Added: grass-addons/grass7/imagery/i.rh/rh.c
--- grass-addons/grass7/imagery/i.rh/rh.c	                        (rev 0)
+++ grass-addons/grass7/imagery/i.rh/rh.c	2018-09-04 08:37:38 UTC (rev 73244)
@@ -0,0 +1,37 @@
+#include<stdio.h>
+#include<math.h>
+double rh(double PW,double Pa,double Ta,double dem){
+	https{//www.researchgate.net/publication/227247013_High-resolution_Surface_Relative_Humidity_Computation_Using_MODIS_Image_in_Peninsular_Malaysia/
+	PW <- MOD05_L2 product
+	Pa <- MOD07 product
+	Pa <- 1013.3-0.1038*dem
+	Ta <- MOD07 product
+	Ta <- -0.0065*dem+TaMOD07 (if dem>400m)
+	https{//ladsweb.modaps.eosdis.nasa.gov/archive/allData/61/MOD05_L2/
+	https{//ladsweb.modaps.eosdis.nasa.gov/archive/allData/61/MOD07_L2/
+	/*Specific Humidity*/
+	q=0.001*(-0.0762*PW*PW+1.753*PW+12.405);
+	ta=-0.0065*dem+Ta;
+	a=17.2694*ta/(ta+238.3);
+	return(q*Pa/(380*exp(a)));
+double esat(double tamean){
+	esat{ saturated vapour pressure
+	tamean{ air temperature daily mean
+	return(610.78*exp(17.2694*tamean/(tamean+238.3));
+double eact(double esat,double rh){
+	eact{ actual vapour pressure
+	rh{ relative humidity
+	return(0.01*esat*rh);
