[GRASS-SVN] r73456 - grass/branches/releasebranch_7_4
    svn_grass at osgeo.org
    Fri Sep 28 14:46:18 PDT 2018
Author: neteler
Date: 2018-09-28 14:46:18 -0700 (Fri, 28 Sep 2018)
New Revision: 73456
   grass/branches/releasebranch_7_4/configure
config.guess + config.sub: updated from http://git.savannah.gnu.org/cgit/config.git/plain/
Modified: grass/branches/releasebranch_7_4/configure
--- grass/branches/releasebranch_7_4/configure	2018-09-28 21:45:52 UTC (rev 73455)
+++ grass/branches/releasebranch_7_4/configure	2018-09-28 21:46:18 UTC (rev 73456)
@@ -12230,7 +12230,58 @@
   fi
 fi
+for ac_declaration in \
+   '#include <stdlib.h>' \
+   'extern "C" void std::exit (int) throw (); using std::exit;' \
+   'extern "C" void std::exit (int); using std::exit;' \
+   'extern "C" void exit (int) throw ();' \
+   'extern "C" void exit (int);' \
+   'void exit (int);'
+do
+  cat > conftest.$ac_ext <<EOF
+#line 12244 "configure"
+#include "confdefs.h"
+#include <stdlib.h>
+$ac_declaration
+int main() {
+exit (42);
+; return 0; }
+EOF
+if { (eval echo configure:12252: \"$ac_compile\") 1>&5; (eval $ac_compile) 2>&5; }; then
 else
+  echo "configure: failed program was:" >&5
+  cat conftest.$ac_ext >&5
+  rm -rf conftest*
+  continue
+fi
+rm -f conftest*
+#line 12262 "configure"
+$ac_declaration
+int main() {
+exit (42);
+; return 0; }
+EOF
+if { (eval echo configure:12269: \"$ac_compile\") 1>&5; (eval $ac_compile) 2>&5; }; then
+  rm -rf conftest*
+  break
+else
+fi
+rm -f conftest*
+done
+if test -n "$ac_declaration"; then
+  echo '#ifdef __cplusplus' >>confdefs.h
+  echo $ac_declaration      >>confdefs.h
+  echo '#endif'             >>confdefs.h
+fi
+else
 	CXX=
 	CXXFLAGS=
@@ -12243,7 +12294,7 @@
 echo $ac_n "checking whether to use openDWG""... $ac_c" 1>&6
-echo "configure:12247: checking whether to use openDWG" >&5
+echo "configure:12298: checking whether to use openDWG" >&5
 echo "$ac_t"""$with_opendwg"" 1>&6
 case "$with_opendwg" in
 	"no")	USE_OPENDWG=	;;
@@ -12263,7 +12314,7 @@
 echo $ac_n "checking for location of openDGW includes""... $ac_c" 1>&6
-echo "configure:12267: checking for location of openDGW includes" >&5
+echo "configure:12318: checking for location of openDGW includes" >&5
 case "$with_opendwg_includes" in
 y | ye | yes | n | no)
 	{ echo "configure: error: *** You must supply a directory to --with-opendwg-includes." 1>&2; exit 1; }
@@ -12289,15 +12340,15 @@
 do
 ac_safe=`echo "$ac_hdr" | sed 'y%./+-%__p_%'`
 echo $ac_n "checking for $ac_hdr""... $ac_c" 1>&6
-echo "configure:12293: checking for $ac_hdr" >&5
+echo "configure:12344: checking for $ac_hdr" >&5
-#line 12296 "configure"
+#line 12347 "configure"
 #include <$ac_hdr>
 EOF
 ac_try="$ac_cpp conftest.$ac_ext >/dev/null 2>conftest.out"
-{ (eval echo configure:12301: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:12352: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
 ac_err=`grep -v '^ *+' conftest.out | grep -v "^conftest.${ac_ext}\$"`
 if test -z "$ac_err"; then
   rm -rf conftest*
@@ -12331,7 +12382,7 @@
 echo $ac_n "checking for location of openDWG library""... $ac_c" 1>&6
-echo "configure:12335: checking for location of openDWG library" >&5
+echo "configure:12386: checking for location of openDWG library" >&5
 case "$with_opendwg_libs" in
 	{ echo "configure: error: *** You must supply a directory to --with-opendwg-libs." 1>&2; exit 1; }
@@ -12372,7 +12423,7 @@
 echo $ac_n "checking whether to use POSIX threads""... $ac_c" 1>&6
-echo "configure:12376: checking whether to use POSIX threads" >&5
+echo "configure:12427: checking whether to use POSIX threads" >&5
 echo "$ac_t"""$with_pthread"" 1>&6
 case "$with_pthread" in
 	"no")	USE_PTHREAD=	;;
@@ -12392,7 +12443,7 @@
 echo $ac_n "checking for location of POSIX threads includes""... $ac_c" 1>&6
-echo "configure:12396: checking for location of POSIX threads includes" >&5
+echo "configure:12447: checking for location of POSIX threads includes" >&5
 case "$with_pthread_includes" in
 	{ echo "configure: error: *** You must supply a directory to --with-pthread-includes." 1>&2; exit 1; }
@@ -12418,15 +12469,15 @@
 do
-echo "configure:12422: checking for $ac_hdr" >&5
+echo "configure:12473: checking for $ac_hdr" >&5
-#line 12425 "configure"
+#line 12476 "configure"
 #include <$ac_hdr>
 EOF
-{ (eval echo configure:12430: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:12481: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
   rm -rf conftest*
@@ -12460,7 +12511,7 @@
 echo $ac_n "checking for location of POSIX threads library""... $ac_c" 1>&6
-echo "configure:12464: checking for location of POSIX threads library" >&5
+echo "configure:12515: checking for location of POSIX threads library" >&5
 case "$with_pthread_libs" in
 	{ echo "configure: error: *** You must supply a directory to --with-pthread-libs." 1>&2; exit 1; }
@@ -12485,10 +12536,10 @@
 LIBS="  $LIBS"
 LDFLAGS=" $LDFLAGS"
 echo $ac_n "checking for pthread_create""... $ac_c" 1>&6
-echo "configure:12489: checking for pthread_create" >&5
+echo "configure:12540: checking for pthread_create" >&5
-#line 12492 "configure"
+#line 12543 "configure"
 /* System header to define __stub macros and hopefully few prototypes,
     which can conflict with char pthread_create(); below.  */
@@ -12511,7 +12562,7 @@
 ; return 0; }
 EOF
-if { (eval echo configure:12515: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:12566: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
   eval "ac_cv_func_pthread_create=yes"
 else
@@ -12538,13 +12589,13 @@
 echo $ac_n "checking for pthread_create in -lpthread""... $ac_c" 1>&6
-echo "configure:12542: checking for pthread_create in -lpthread" >&5
+echo "configure:12593: checking for pthread_create in -lpthread" >&5
 ac_lib_var=`echo pthread'_'pthread_create | sed 'y%./+-%__p_%'`
 ac_save_LIBS="$LIBS"
 LIBS="-lpthread  $LIBS"
-#line 12548 "configure"
+#line 12599 "configure"
 /* Override any gcc2 internal prototype to avoid an error.  */
 /* We use char because int might match the return type of a gcc2
@@ -12555,7 +12606,7 @@
 pthread_create()
 ; return 0; }
 EOF
-if { (eval echo configure:12559: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:12610: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
   eval "ac_cv_lib_$ac_lib_var=yes"
 else
@@ -12605,7 +12656,7 @@
 echo $ac_n "checking whether to use OpenMP""... $ac_c" 1>&6
-echo "configure:12609: checking whether to use OpenMP" >&5
+echo "configure:12660: checking whether to use OpenMP" >&5
 echo "$ac_t"""$with_openmp"" 1>&6
 case "$with_openmp" in
 	"no")	USE_OPENMP=	;;
@@ -12626,7 +12677,7 @@
 echo $ac_n "checking for location of OpenMP includes""... $ac_c" 1>&6
-echo "configure:12630: checking for location of OpenMP includes" >&5
+echo "configure:12681: checking for location of OpenMP includes" >&5
 case "$with_openmp_includes" in
 	{ echo "configure: error: *** You must supply a directory to --with-openmp-includes." 1>&2; exit 1; }
@@ -12652,15 +12703,15 @@
 do
-echo "configure:12656: checking for $ac_hdr" >&5
+echo "configure:12707: checking for $ac_hdr" >&5
-#line 12659 "configure"
+#line 12710 "configure"
 #include <$ac_hdr>
 EOF
-{ (eval echo configure:12664: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:12715: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
   rm -rf conftest*
@@ -12698,7 +12749,7 @@
 echo $ac_n "checking for location of OpenMP library""... $ac_c" 1>&6
-echo "configure:12702: checking for location of OpenMP library" >&5
+echo "configure:12753: checking for location of OpenMP library" >&5
 case "$with_openmp_libs" in
 	{ echo "configure: error: *** You must supply a directory to --with-openmp-libs." 1>&2; exit 1; }
@@ -12723,10 +12774,10 @@
 LIBS="  $LIBS"
 LDFLAGS=" $LDFLAGS"
 echo $ac_n "checking for GOMP_parallel_start""... $ac_c" 1>&6
-echo "configure:12727: checking for GOMP_parallel_start" >&5
+echo "configure:12778: checking for GOMP_parallel_start" >&5
-#line 12730 "configure"
+#line 12781 "configure"
     which can conflict with char GOMP_parallel_start(); below.  */
@@ -12749,7 +12800,7 @@
 ; return 0; }
 EOF
-if { (eval echo configure:12753: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:12804: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
   eval "ac_cv_func_GOMP_parallel_start=yes"
 else
@@ -12776,13 +12827,13 @@
 echo $ac_n "checking for GOMP_parallel_start in -lgomp""... $ac_c" 1>&6
-echo "configure:12780: checking for GOMP_parallel_start in -lgomp" >&5
+echo "configure:12831: checking for GOMP_parallel_start in -lgomp" >&5
 ac_lib_var=`echo gomp'_'GOMP_parallel_start | sed 'y%./+-%__p_%'`
 LIBS="-lgomp  $LIBS"
-#line 12786 "configure"
+#line 12837 "configure"
@@ -12793,7 +12844,7 @@
 ; return 0; }
 EOF
-if { (eval echo configure:12797: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:12848: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -12866,7 +12917,7 @@
 echo $ac_n "checking whether to use OpenCL""... $ac_c" 1>&6
-echo "configure:12870: checking whether to use OpenCL" >&5
+echo "configure:12921: checking whether to use OpenCL" >&5
 echo "$ac_t"""$with_opencl"" 1>&6
 case "$with_opencl" in
 	"no")	USE_OPENCL=	;;
@@ -12886,7 +12937,7 @@
 echo $ac_n "checking for location of OpenCL includes""... $ac_c" 1>&6
-echo "configure:12890: checking for location of OpenCL includes" >&5
+echo "configure:12941: checking for location of OpenCL includes" >&5
 case "$with_opencl_includes" in
 	{ echo "configure: error: *** You must supply a directory to --with-opencl-includes." 1>&2; exit 1; }
@@ -12913,15 +12964,15 @@
 do
-echo "configure:12917: checking for $ac_hdr" >&5
+echo "configure:12968: checking for $ac_hdr" >&5
-#line 12920 "configure"
+#line 12971 "configure"
 #include <$ac_hdr>
 EOF
-{ (eval echo configure:12925: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:12976: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
   rm -rf conftest*
@@ -12961,10 +13012,10 @@
 LIBS="-framework OpenCL  $LIBS"
 LDFLAGS=" $LDFLAGS"
 echo $ac_n "checking for clGetPlatformInfo""... $ac_c" 1>&6
-echo "configure:12965: checking for clGetPlatformInfo" >&5
+echo "configure:13016: checking for clGetPlatformInfo" >&5
-#line 12968 "configure"
+#line 13019 "configure"
     which can conflict with char clGetPlatformInfo(); below.  */
@@ -12987,7 +13038,7 @@
 ; return 0; }
 EOF
-if { (eval echo configure:12991: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:13042: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
   eval "ac_cv_func_clGetPlatformInfo=yes"
 else
@@ -13026,15 +13077,15 @@
 do
-echo "configure:13030: checking for $ac_hdr" >&5
+echo "configure:13081: checking for $ac_hdr" >&5
-#line 13033 "configure"
+#line 13084 "configure"
 #include <$ac_hdr>
 EOF
-{ (eval echo configure:13038: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:13089: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
   rm -rf conftest*
@@ -13067,7 +13118,7 @@
     # With OpenCL library directory
 echo $ac_n "checking for location of OpenCL library""... $ac_c" 1>&6
-echo "configure:13071: checking for location of OpenCL library" >&5
+echo "configure:13122: checking for location of OpenCL library" >&5
 case "$with_opencl_libs" in
 	{ echo "configure: error: *** You must supply a directory to --with-opencl-libs." 1>&2; exit 1; }
@@ -13091,13 +13142,13 @@
 echo $ac_n "checking for clGetPlatformInfo in -lOpenCL""... $ac_c" 1>&6
-echo "configure:13095: checking for clGetPlatformInfo in -lOpenCL" >&5
+echo "configure:13146: checking for clGetPlatformInfo in -lOpenCL" >&5
 ac_lib_var=`echo OpenCL'_'clGetPlatformInfo | sed 'y%./+-%__p_%'`
 LIBS="-lOpenCL  $LIBS"
-#line 13101 "configure"
+#line 13152 "configure"
@@ -13108,7 +13159,7 @@
 clGetPlatformInfo()
 ; return 0; }
 EOF
-if { (eval echo configure:13112: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:13163: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -13168,7 +13219,7 @@
      fi
      echo $ac_n "checking for special C compiler options needed for large files""... $ac_c" 1>&6
-echo "configure:13172: checking for special C compiler options needed for large files" >&5
+echo "configure:13223: checking for special C compiler options needed for large files" >&5
 ac_cv_sys_largefile_CC=no
         largefile_cc_opt=""
@@ -13176,7 +13227,7 @@
 	  # IRIX 6.2 and later do not support large files by default,
 	  # so use the C compiler's -n32 option if that helps.
-#line 13180 "configure"
+#line 13231 "configure"
 #include <sys/types.h>
     /* Check that off_t can represent 2**63 - 1 correctly.
@@ -13192,7 +13243,7 @@
 ; return 0; }
 EOF
-if { (eval echo configure:13196: \"$ac_compile\") 1>&5; (eval $ac_compile) 2>&5; }; then
+if { (eval echo configure:13247: \"$ac_compile\") 1>&5; (eval $ac_compile) 2>&5; }; then
 else
@@ -13201,7 +13252,7 @@
   ac_save_CC="${CC-cc}"
 	     CC="$CC -n32"
-#line 13205 "configure"
+#line 13256 "configure"
@@ -13217,7 +13268,7 @@
 ; return 0; }
 EOF
-if { (eval echo configure:13221: \"$ac_compile\") 1>&5; (eval $ac_compile) 2>&5; }; then
+if { (eval echo configure:13272: \"$ac_compile\") 1>&5; (eval $ac_compile) 2>&5; }; then
   rm -rf conftest*
   ac_cv_sys_largefile_CC=' -n32'
 else
@@ -13244,11 +13295,11 @@
      fi
      echo $ac_n "checking for _FILE_OFFSET_BITS value needed for large files""... $ac_c" 1>&6
-echo "configure:13248: checking for _FILE_OFFSET_BITS value needed for large files" >&5
+echo "configure:13299: checking for _FILE_OFFSET_BITS value needed for large files" >&5
 ac_cv_sys_file_offset_bits=no
-#line 13252 "configure"
+#line 13303 "configure"
@@ -13264,7 +13315,7 @@
 ; return 0; }
 EOF
-if { (eval echo configure:13268: \"$ac_compile\") 1>&5; (eval $ac_compile) 2>&5; }; then
+if { (eval echo configure:13319: \"$ac_compile\") 1>&5; (eval $ac_compile) 2>&5; }; then
 else
@@ -13271,7 +13322,7 @@
   rm -rf conftest*
-#line 13275 "configure"
+#line 13326 "configure"
 #define _FILE_OFFSET_BITS 64
@@ -13289,7 +13340,7 @@
 ; return 0; }
 EOF
-if { (eval echo configure:13293: \"$ac_compile\") 1>&5; (eval $ac_compile) 2>&5; }; then
+if { (eval echo configure:13344: \"$ac_compile\") 1>&5; (eval $ac_compile) 2>&5; }; then
   rm -rf conftest*
   ac_cv_sys_file_offset_bits=64
 else
@@ -13315,11 +13366,11 @@
    fi
      echo $ac_n "checking for _LARGE_FILES value needed for large files""... $ac_c" 1>&6
-echo "configure:13319: checking for _LARGE_FILES value needed for large files" >&5
+echo "configure:13370: checking for _LARGE_FILES value needed for large files" >&5
 ac_cv_sys_large_files=no
-#line 13323 "configure"
+#line 13374 "configure"
@@ -13335,7 +13386,7 @@
 ; return 0; }
 EOF
-if { (eval echo configure:13339: \"$ac_compile\") 1>&5; (eval $ac_compile) 2>&5; }; then
+if { (eval echo configure:13390: \"$ac_compile\") 1>&5; (eval $ac_compile) 2>&5; }; then
 else
@@ -13342,7 +13393,7 @@
   rm -rf conftest*
-#line 13346 "configure"
+#line 13397 "configure"
 #define _LARGE_FILES 1
@@ -13360,7 +13411,7 @@
 ; return 0; }
 EOF
-if { (eval echo configure:13364: \"$ac_compile\") 1>&5; (eval $ac_compile) 2>&5; }; then
+if { (eval echo configure:13415: \"$ac_compile\") 1>&5; (eval $ac_compile) 2>&5; }; then
   rm -rf conftest*
   ac_cv_sys_large_files=1
 else
@@ -13386,11 +13437,11 @@
    fi
      echo $ac_n "checking for _LARGEFILE_SOURCE value needed for large files""... $ac_c" 1>&6
-echo "configure:13390: checking for _LARGEFILE_SOURCE value needed for large files" >&5
+echo "configure:13441: checking for _LARGEFILE_SOURCE value needed for large files" >&5
 ac_cv_sys_largefile_source=no
-#line 13394 "configure"
+#line 13445 "configure"
 #include <stdio.h>
 int main() {
@@ -13397,7 +13448,7 @@
 return !fseeko;
 ; return 0; }
 EOF
-if { (eval echo configure:13401: \"$ac_compile\") 1>&5; (eval $ac_compile) 2>&5; }; then
+if { (eval echo configure:13452: \"$ac_compile\") 1>&5; (eval $ac_compile) 2>&5; }; then
 else
@@ -13404,7 +13455,7 @@
   rm -rf conftest*
-#line 13408 "configure"
+#line 13459 "configure"
 #define _LARGEFILE_SOURCE 1
 #include <stdio.h>
@@ -13413,7 +13464,7 @@
 return !fseeko;
 ; return 0; }
 EOF
-if { (eval echo configure:13417: \"$ac_compile\") 1>&5; (eval $ac_compile) 2>&5; }; then
+if { (eval echo configure:13468: \"$ac_compile\") 1>&5; (eval $ac_compile) 2>&5; }; then
   rm -rf conftest*
   ac_cv_sys_largefile_source=1
 else
@@ -13445,11 +13496,11 @@
 ac_save_cflags=${CFLAGS}
 CFLAGS="$LFS_CFLAGS ${ac_save_cflags}"
-echo "configure:13449: checking for _LARGEFILE_SOURCE value needed for large files" >&5
+echo "configure:13500: checking for _LARGEFILE_SOURCE value needed for large files" >&5
-#line 13453 "configure"
+#line 13504 "configure"
 #include <stdio.h>
 int main() {
@@ -13456,7 +13507,7 @@
 return !fseeko;
 ; return 0; }
 EOF
-if { (eval echo configure:13460: \"$ac_compile\") 1>&5; (eval $ac_compile) 2>&5; }; then
+if { (eval echo configure:13511: \"$ac_compile\") 1>&5; (eval $ac_compile) 2>&5; }; then
 else
@@ -13463,7 +13514,7 @@
   rm -rf conftest*
-#line 13467 "configure"
+#line 13518 "configure"
 #include <stdio.h>
@@ -13472,7 +13523,7 @@
 return !fseeko;
 ; return 0; }
 EOF
-if { (eval echo configure:13476: \"$ac_compile\") 1>&5; (eval $ac_compile) 2>&5; }; then
+if { (eval echo configure:13527: \"$ac_compile\") 1>&5; (eval $ac_compile) 2>&5; }; then
   rm -rf conftest*
 else
@@ -13502,11 +13553,11 @@
    # If you want fseeko and ftello with glibc, upgrade to a fixed glibc.
    echo $ac_n "checking for fseeko""... $ac_c" 1>&6
-echo "configure:13506: checking for fseeko" >&5
+echo "configure:13557: checking for fseeko" >&5
 ac_cv_func_fseeko=no
-#line 13510 "configure"
+#line 13561 "configure"
 #include <stdio.h>
 int main() {
@@ -13513,7 +13564,7 @@
 return fseeko && fseeko (stdin, 0, 0);
 ; return 0; }
 EOF
-if { (eval echo configure:13517: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:13568: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
   ac_cv_func_fseeko=yes
 else
@@ -13530,10 +13581,10 @@
    fi
 echo $ac_n "checking if system supports Large Files at all""... $ac_c" 1>&6
-echo "configure:13534: checking if system supports Large Files at all" >&5
+echo "configure:13585: checking if system supports Large Files at all" >&5
-#line 13537 "configure"
+#line 13588 "configure"
 #include <stdio.h>
@@ -13565,7 +13616,7 @@
 #endif
 ; return 0; }
 EOF
-if { (eval echo configure:13569: \"$ac_compile\") 1>&5; (eval $ac_compile) 2>&5; }; then
+if { (eval echo configure:13620: \"$ac_compile\") 1>&5; (eval $ac_compile) 2>&5; }; then
   rm -rf conftest*
   ac_cv_largefiles=yes
 else
