[GRASS-SVN] r74359 -	grass-addons/grass7/imagery/i.sentinel/i.sentinel.download
    svn_grass at osgeo.org
    Tue Apr  9 11:10:24 PDT 2019
Author: martinl
Date: 2019-04-09 11:10:24 -0700 (Tue, 09 Apr 2019)
New Revision: 74359
   grass-addons/grass7/imagery/i.sentinel/i.sentinel.download/i.sentinel.download.html
   grass-addons/grass7/imagery/i.sentinel/i.sentinel.download/i.sentinel.download.py
i.sentinel.download: implement query option (thanks to MarkusN for initial patch)
Modified: grass-addons/grass7/imagery/i.sentinel/i.sentinel.download/i.sentinel.download.html
--- grass-addons/grass7/imagery/i.sentinel/i.sentinel.download/i.sentinel.download.html	2019-04-09 09:07:30 UTC (rev 74358)
+++ grass-addons/grass7/imagery/i.sentinel/i.sentinel.download/i.sentinel.download.html	2019-04-09 18:10:24 UTC (rev 74359)
@@ -79,6 +79,13 @@
 Sentinel-2 data, maximum <b>clouds</b> cover percentage.
 <p>
+Extra search keywords can be specified with <b>query</b>. Multiple keywords
+can be listed separated with comma (e.g. 'polarisationmode=HH,orbitdirection=Ascending').
+Note that ESA maintains a
+<a href="https://scihub.copernicus.eu/twiki/do/view/SciHubUserGuide/FullTextSearch">list of valid search keywords</a>
+that can be used with <b>query</b>.
+<p>
 In case a Sentinel data download was interrupted, <em>i.sentinel.download</em>
 will continue to download once the command is restarted and the partially
 downloaded file (with <tt>.incomplete</tt> file extention) still present.
Modified: grass-addons/grass7/imagery/i.sentinel/i.sentinel.download/i.sentinel.download.py
--- grass-addons/grass7/imagery/i.sentinel/i.sentinel.download/i.sentinel.download.py	2019-04-09 09:07:30 UTC (rev 74358)
+++ grass-addons/grass7/imagery/i.sentinel/i.sentinel.download/i.sentinel.download.py	2019-04-09 18:10:24 UTC (rev 74359)
@@ -89,6 +89,12 @@
 #% guisection: Filter
 #%end
 #%option
+#% key: query
+#% type: string
+#% description: Extra search keywords to use in the query
+#% guisection: Filter
+#%end
+#%option
 #% key: uuid
 #% type: string
 #% multiple: yes
@@ -117,7 +123,7 @@
 #%end
 #%rules
 #% required: output,-l
-#% excludes: uuid,map,area_relation,clouds,producttype,start,end,limit,sort,order
+#% excludes: uuid,map,area_relation,clouds,producttype,start,end,limit,query,sort,order
 #%end
 import os
@@ -176,7 +182,7 @@
         self._products_df_sorted = None
     def filter(self, area, area_relation,
-               clouds=None, producttype=None, limit=None,
+               clouds=None, producttype=None, limit=None, query={},
                start=None, end=None, sortby=[], asc=True):
         args = {}
         if clouds:
@@ -195,9 +201,18 @@
             end = 'NOW'
         else:
             end = end.replace('-', '')
+        if query:
+            redefined = [value for value in args.keys() if value in query.keys()]
+            if redefined:
+                gs.warning("Query overwrites defined options ({})".format(
+                    ','.join(redefined)
+            args.update(query)
+        gs.debug("Query: area={} area_relation={} date=({}, {}) args={}".format(
+            area, area_relation, start, end, args
+        ), debug=1)
         products = self._api.query(
             area=area, area_relation=area_relation,
             date=(start, end),
             **args
@@ -388,11 +403,17 @@
         if options['uuid']:
             downloader.set_uuid(options['uuid'].split(','))
         else:
+            query = {}
+            if options['query']:
+                for item in options['query'].split(','):
+                    k, v = item.split('=')
+                    query[k] = v
             downloader.filter(area=map_box,
                               area_relation=options['area_relation'],
                               clouds=options['clouds'],
                               producttype=options['producttype'],
                               limit=options['limit'],
+                              query=query,
                               start=options['start'],
                               end=options['end'],
                               sortby=sortby,
