[GRASS-SVN] r73975 - in grass-addons/grass7/imagery: i.modis/i.modis.import i.segment.stats i.variance
Thu Jan 17 22:18:31 PST 2019
Author: neteler
Date: 2019-01-17 22:18:31 -0800 (Thu, 17 Jan 2019)
New Revision: 73975
   grass-addons/grass7/imagery/i.modis/i.modis.import/i.modis.import.py
   grass-addons/grass7/imagery/i.segment.stats/i.segment.stats.py
   grass-addons/grass7/imagery/i.variance/i.variance.py
imagery addons: fix tab/space indentation; tabs are to be avoided, see https://trac.osgeo.org/grass/wiki/Submitting/Python?version=19#Editorsettingsfor4-spaceindentation
Modified: grass-addons/grass7/imagery/i.modis/i.modis.import/i.modis.import.py
--- grass-addons/grass7/imagery/i.modis/i.modis.import/i.modis.import.py	2019-01-18 05:34:41 UTC (rev 73974)
+++ grass-addons/grass7/imagery/i.modis/i.modis.import/i.modis.import.py	2019-01-18 06:18:31 UTC (rev 73975)
@@ -230,7 +230,7 @@
         conf = pm.confResample(spectr, res, pref, dat, resampl,
                                proj, zone, projpar)
         return conf
-    except IOError, e:
+    except IOError as e:
         grass.fatal(e)
Modified: grass-addons/grass7/imagery/i.segment.stats/i.segment.stats.py
--- grass-addons/grass7/imagery/i.segment.stats/i.segment.stats.py	2019-01-18 05:34:41 UTC (rev 73974)
+++ grass-addons/grass7/imagery/i.segment.stats/i.segment.stats.py	2019-01-18 06:18:31 UTC (rev 73975)
@@ -178,18 +178,18 @@
     rasters = options['rasters'].split(',') if options['rasters'] else []
     area_measures = options['area_measures'].split(',') if (options['area_measures'] and not flags['s']) else []
     if area_measures:
-	if not gscript.find_program('r.object.geometry', '--help'):
-		message = _("You need to install the addon r.object.geometry to be able")
-		message += _(" to calculate area measures.\n")
-		message += _(" You can install the addon with 'g.extension r.object.geometry'")
-		gscript.fatal(message)
+        if not gscript.find_program('r.object.geometry', '--help'):
+                message = _("You need to install the addon r.object.geometry to be able")
+                message += _(" to calculate area measures.\n")
+                message += _(" You can install the addon with 'g.extension r.object.geometry'")
+                gscript.fatal(message)
     neighborhood = True if flags['n'] else False
     if neighborhood:
-	if not gscript.find_program('r.neighborhoodmatrix', '--help'):
-		message = _("You need to install the addon r.neighborhoodmatrix to be able")
-		message += _(" You can install the addon with 'g.extension r.neighborhoodmatrix'")
+        if not gscript.find_program('r.neighborhoodmatrix', '--help'):
+                message = _("You need to install the addon r.neighborhoodmatrix to be able")
+                message += _(" You can install the addon with 'g.extension r.neighborhoodmatrix'")
     raster_statistics = options['raster_statistics'].split(',') if options['raster_statistics'] else []
     separator = gscript.separator(options['separator'])
@@ -205,7 +205,7 @@
             'mean': 7}
     geometry_stat_dict = {'cat': 0, 'area': 1, 'perimeter': 2,
-			'compact_square': 3, 'compact_circle': 4, 'fd' : 5,
+                        'compact_square': 3, 'compact_circle': 4, 'fd' : 5,
                         'xcoords': 6, 'ycoords': 7}
     if flags['r']:
@@ -214,23 +214,23 @@
     stats_temp_file = gscript.tempfile()
     if area_measures:
-	gscript.message(_("Calculating geometry statistics..."))
-	output_header += area_measures
-	stat_indices = [geometry_stat_dict[x] for x in area_measures]
+        gscript.message(_("Calculating geometry statistics..."))
+        output_header += area_measures
+        stat_indices = [geometry_stat_dict[x] for x in area_measures]
         gscript.run_command('r.object.geometry',
-     		      	    input_=segment_map,
-		      	    output=stats_temp_file,
-		      	    overwrite=True,
-		      	    quiet=True)
+                                  input_=segment_map,
+                                  output=stats_temp_file,
+                                  overwrite=True,
+                                  quiet=True)
-	firstline = True
-    	with open(stats_temp_file, 'r') as fin:
-	    for line in fin:
-		if firstline:
-		    firstline = False
-		    continue
-		values = line.rstrip().split('|')
-		output_dict[values[0]] = [values[x] for x in stat_indices]
+        firstline = True
+        with open(stats_temp_file, 'r') as fin:
+            for line in fin:
+                if firstline:
+                    firstline = False
+                    continue
+                values = line.rstrip().split('|')
+                output_dict[values[0]] = [values[x] for x in stat_indices]
     if rasters:
         if not flags['c']:
@@ -286,7 +286,7 @@
     # Calculating neighborhood statistics if requested
     if neighborhood:
-	gscript.message(_("Calculating neighborhood statistics..."))
+        gscript.message(_("Calculating neighborhood statistics..."))
         # Add neighbordhood statistics to headers
         original_nb_values = len(output_header) - 1
@@ -334,14 +334,14 @@
         with open(csvfile, 'wb') as f:
             f.write(separator.join(output_header)+"\n")
             for key in output_dict:
-		if len(output_dict[key]) + 1 == len(output_header):
+                if len(output_dict[key]) + 1 == len(output_header):
                     f.write(key+separator+separator.join(output_dict[key])+"\n")
-		else:
-		    error_objects.append(key)
+                else:
+                    error_objects.append(key)
         f.close()
     if vectormap:
-	gscript.message(_("Creating output vector map..."))
+        gscript.message(_("Creating output vector map..."))
         temporary_vect = 'segmstat_tmp_vect_%d' % os.getpid()
         gscript.run_command('r.to.vect',
                             input_=segment_map,
@@ -365,15 +365,15 @@
             addcol_statement = 'ALTER TABLE %s ADD COLUMN %s double precision;\n' % (temporary_vect, header)
             fsql.write(addcol_statement)
                     sql = "INSERT INTO %s VALUES (%s, %s);\n" % (temporary_vect, key, ",".join(output_dict[key]))
                     sql = sql.replace('inf', 'NULL')
                     sql = sql.replace('nan', 'NULL')
                     fsql.write(sql)
-		else:
-		    if not csvfile:
+                else:
+                    if not csvfile:
         fsql.write('END TRANSACTION;')
         fsql.close()
@@ -385,8 +385,8 @@
         object_string = ', '.join(error_objects[:100])
         message += _("\n\nObjects with errors (only first 100 are shown):\n%s" % object_string)
         gscript.message(message)
 if __name__ == "__main__":
     options, flags = gscript.parser()
     atexit.register(cleanup)
Modified: grass-addons/grass7/imagery/i.variance/i.variance.py
--- grass-addons/grass7/imagery/i.variance/i.variance.py	2019-01-18 05:34:41 UTC (rev 73974)
+++ grass-addons/grass7/imagery/i.variance/i.variance.py	2019-01-18 06:18:31 UTC (rev 73975)
@@ -2,15 +2,15 @@
-# MODULE:	i.variance
-# AUTHOR(S):	Moritz Lennert
+# MODULE:        i.variance
+# AUTHOR(S):        Moritz Lennert
-# PURPOSE:	Calculate variation of variance by variation of resolution
-# COPYRIGHT:	(C) 1997-2016 by the GRASS Development Team
+# PURPOSE:        Calculate variation of variance by variation of resolution
+# COPYRIGHT:        (C) 1997-2016 by the GRASS Development Team
-#		This program is free software under the GNU General Public
-#		License (>=v2). Read the file COPYING that comes with GRASS
-#		for details.
+#                This program is free software under the GNU General Public
+#                License (>=v2). Read the file COPYING that comes with GRASS
+#                for details.
 # Curtis E. Woodcock, Alan H. Strahler, The factor of scale in remote sensing,
@@ -92,18 +92,18 @@
   length = len(numbers)
   if length >= 2:
     if numbers[0] > numbers[1]:
-      maxima.append(0)
-      differences.append(numbers[0] - numbers[1])
+        maxima.append(0)
+        differences.append(numbers[0] - numbers[1])
     if length > 3:
       for i in range(1, length-1):
         if numbers[i] > numbers[i-1] and numbers[i] > numbers[i+1]:
-          maxima.append(i)
-          differences.append(min(numbers[i] - numbers[i-1], numbers[i] - numbers[i+1]))
+            maxima.append(i)
+            differences.append(min(numbers[i] - numbers[i-1], numbers[i] - numbers[i+1]))
-    if numbers[length-1] > numbers[length-2]:
-      maxima.append(length-1)
-      differences.append(numbers[length-1] - numbers[length-2])
+    if numbers[length-1] > numbers[length-2]:
+        maxima.append(length-1)
+        differences.append(numbers[length-1] - numbers[length-2])
   return maxima, differences
@@ -120,7 +120,7 @@
         min_cells = int(options['min_cells'])
     target_res = None
     if options['max_size']:
-    	target_res = float(options['max_size'])
+        target_res = float(options['max_size'])
     step = float(options['step'])
     global temp_resamp_map, temp_variance_map
@@ -138,9 +138,9 @@
     east = float(region['e'])
     if res % 1 == 0 and step % 1 == 0:
-	template_string = "%d,%f\n"
+        template_string = "%d,%f\n"
     else:
-	template_string = "%f,%f\n"
+        template_string = "%f,%f\n"
     if min_cells:
         target_res_cells = int(sqrt(((east - west) * (north - south)) / min_cells))
@@ -159,40 +159,40 @@
     gscript.message(_("Calculating variance at different resolutions"))
     while res <= target_res:
-	gscript.percent(res, target_res, step)
-	gscript.run_command('r.resamp.stats',
-			    input=input,
-			    output=temp_resamp_map,
-			    method='average',
-			    quiet=True,
-			    overwrite=True)
-	gscript.run_command('r.neighbors',
-			    input=temp_resamp_map,
-			    method='variance',
-			    output=temp_variance_map,
-			    quiet=True,
-			    overwrite=True)
-	varianceinfo = gscript.parse_command('r.univar',
-					     map_=temp_variance_map,
-					     flags='g',
-					     quiet=True)
+        gscript.percent(res, target_res, step)
+        gscript.run_command('r.resamp.stats',
+                            input=input,
+                            output=temp_resamp_map,
+                            method='average',
+                            quiet=True,
+                            overwrite=True)
+        gscript.run_command('r.neighbors',
+                            input=temp_resamp_map,
+                            method='variance',
+                            output=temp_variance_map,
+                            quiet=True,
+                            overwrite=True)
+        varianceinfo = gscript.parse_command('r.univar',
+                                             map_=temp_variance_map,
+                                             flags='g',
+                                             quiet=True)
         resolutions.append(res)
-	variances.append(float(varianceinfo['mean']))
-	res += step
+        variances.append(float(varianceinfo['mean']))
+        res += step
         region = gscript.parse_command('g.region',
-			    res=res,
-			    n=north,
-			    s=south,
-			    w=west,
-			    e=east,
-			    flags='ag')
-	cells = int(region['cells'])
+                            res=res,
+                            n=north,
+                            s=south,
+                            w=west,
+                            e=east,
+                            flags='ag')
+        cells = int(region['cells'])
     indices, differences = FindMaxima(variances)
     max_resolutions = [resolutions[x] for x in indices]
     gscript.message(_("resolution,min_diff"))
     for i in range(len(max_resolutions)):
-        print "%g,%g" % (max_resolutions[i], differences[i])
+        print("%g,%g" % (max_resolutions[i], differences[i]))
     if output:
         header = "resolution,variance\n"
@@ -213,7 +213,6 @@
         else:
             plt.savefig(plot_output)
