[GRASS-SVN] r74226 - in grass/trunk: lib/python/gunittest/testsuite	lib/python/pygrass/gis/testsuite	lib/python/pygrass/messages/testsuite	lib/python/pygrass/modules/grid/testsuite	lib/python/pygrass/modules/interface/testsuite	lib/python/pygrass/modules/testsuite	lib/python/pygrass/raster/testsuite lib/python/pygrass/rpc/testsuite	lib/python/pygrass/shell/testsuite lib/python/pygrass/testsuite	lib/python/pygrass/vector/testsuite	lib/python/script/testsuite lib/python/temporal/testsuite	temporal/t.rast.extract/testsuite temporal/t.rast.univar/testsuite	temporal/t.rast3d.extract/testsuite	temporal/t.rast3d.univar/testsuite vector/v.extract/testsuite	vector/v.in.lidar/testsuite vector/v.in.pdal/testsuite
    svn_grass at osgeo.org
    Tue Mar 12 15:22:35 PDT 2019
Author: neteler
Date: 2019-03-12 15:22:35 -0700 (Tue, 12 Mar 2019)
New Revision: 74226
Added:
   grass/trunk/lib/python/gunittest/testsuite/test_gunitest_doctests.py
   grass/trunk/lib/python/pygrass/gis/testsuite/test_pygrass_gis_doctests.py
   grass/trunk/lib/python/pygrass/messages/testsuite/test_pygrass_messages_doctests.py
   grass/trunk/lib/python/pygrass/modules/grid/testsuite/test_pygrass_modules_grid_doctests.py
   grass/trunk/lib/python/pygrass/modules/interface/testsuite/test_pygrass_modules_interface_doctests.py
   grass/trunk/lib/python/pygrass/modules/testsuite/test_pygrass_modules_doctests.py
   grass/trunk/lib/python/pygrass/raster/testsuite/test_pygrass_raster.py
   grass/trunk/lib/python/pygrass/raster/testsuite/test_pygrass_raster_doctests.py
   grass/trunk/lib/python/pygrass/rpc/testsuite/test_pygrass_rpc_doctests.py
   grass/trunk/lib/python/pygrass/shell/testsuite/test_pygrass_shell_doctests.py
   grass/trunk/lib/python/pygrass/testsuite/test_pygrass_doctests.py
   grass/trunk/lib/python/pygrass/vector/testsuite/test_pygrass_vector_doctests.py
   grass/trunk/lib/python/script/testsuite/test_script_doctests.py
   grass/trunk/lib/python/script/testsuite/test_script_raster.py
   grass/trunk/lib/python/temporal/testsuite/test_temporal_doctests.py
   grass/trunk/temporal/t.rast.extract/testsuite/test_t_rast_extract.py
   grass/trunk/temporal/t.rast.univar/testsuite/test_t_rast_univar.py
   grass/trunk/temporal/t.rast3d.extract/testsuite/test_t_rast3d_extract.py
   grass/trunk/temporal/t.rast3d.univar/testsuite/test_t_rast3d_univar.py
   grass/trunk/vector/v.extract/testsuite/test_v_extract.py
   grass/trunk/vector/v.in.lidar/testsuite/test_v_in_lidar_basic.py
   grass/trunk/vector/v.in.lidar/testsuite/test_v_in_lidar_filter.py
   grass/trunk/vector/v.in.lidar/testsuite/test_v_in_pdal_basic.py
   grass/trunk/vector/v.in.lidar/testsuite/test_v_in_pdal_filter.py
Removed:
   grass/trunk/lib/python/gunittest/testsuite/test_doctests.py
   grass/trunk/lib/python/pygrass/gis/testsuite/test_doctests.py
   grass/trunk/lib/python/pygrass/messages/testsuite/test_doctests.py
   grass/trunk/lib/python/pygrass/modules/grid/testsuite/test_doctests.py
   grass/trunk/lib/python/pygrass/modules/interface/testsuite/test_doctests.py
   grass/trunk/lib/python/pygrass/modules/testsuite/test_doctests.py
   grass/trunk/lib/python/pygrass/raster/testsuite/test_doctests.py
   grass/trunk/lib/python/pygrass/raster/testsuite/test_raster.py
   grass/trunk/lib/python/pygrass/rpc/testsuite/test_doctests.py
   grass/trunk/lib/python/pygrass/shell/testsuite/test_doctests.py
   grass/trunk/lib/python/pygrass/testsuite/test_doctests.py
   grass/trunk/lib/python/pygrass/vector/testsuite/test_doctests.py
   grass/trunk/lib/python/script/testsuite/test_doctests.py
   grass/trunk/lib/python/script/testsuite/test_raster.py
   grass/trunk/lib/python/temporal/testsuite/test_doctests.py
   grass/trunk/temporal/t.rast.extract/testsuite/test_extract.py
   grass/trunk/temporal/t.rast.univar/testsuite/test_univar.py
   grass/trunk/temporal/t.rast3d.extract/testsuite/test_extract.py
   grass/trunk/temporal/t.rast3d.univar/testsuite/test_univar.py
   grass/trunk/vector/v.extract/testsuite/test_extract.py
   grass/trunk/vector/v.in.lidar/testsuite/basic_test.py
   grass/trunk/vector/v.in.lidar/testsuite/filter_test.py
   grass/trunk/vector/v.in.pdal/testsuite/basic_test.py
   grass/trunk/vector/v.in.pdal/testsuite/filter_test.py
testsuite: use unique names on test modules to better support pytest (fixes #3792) (contributed by pmav99)
Deleted: grass/trunk/lib/python/gunittest/testsuite/test_doctests.py
--- grass/trunk/lib/python/gunittest/testsuite/test_doctests.py	2019-03-12 21:48:48 UTC (rev 74225)
+++ grass/trunk/lib/python/gunittest/testsuite/test_doctests.py	2019-03-12 22:22:35 UTC (rev 74226)
@@ -1,41 +0,0 @@
-# -*- coding: utf-8 -*-
-Tests checkers
-import doctest
-import grass.gunittest.case
-import grass.gunittest.main
-import grass.gunittest.utils
-import grass.gunittest.gmodules
-import grass.gunittest.checkers
-# doctest does not allow changing the base classes of test case, skip test case
-# and test suite, so we need to create a new type which inherits from our class
-# and contains doctest's methods
-# the alternative is to copy 500 from doctest and change what is needed
-# (this might be necessary anyway because of the reports and stdout and stderr)
-doctest.DocFileCase = type('DocFileCase',
-                           (grass.gunittest.case.TestCase,),
-                           dict(doctest.DocFileCase.__dict__))
-doctest.SkipDocTestCase = type('SkipDocTestCase',
-                               dict(doctest.SkipDocTestCase.__dict__))
-def load_tests(loader, tests, ignore):
-    # TODO: this must be somewhere when doctest is called, not here
-    # TODO: ultimate solution is not to use _ as a buildin in lib/python
-    # for now it is the only place where it works
-    grass.gunittest.utils.do_doctest_gettext_workaround()
-    # this should be called at some top level
-    tests.addTests(doctest.DocTestSuite(grass.gunittest.gmodules))
-    tests.addTests(doctest.DocTestSuite(grass.gunittest.checkers))
-    return tests
-if __name__ == '__main__':
-    grass.gunittest.main.test()
Copied: grass/trunk/lib/python/gunittest/testsuite/test_gunitest_doctests.py (from rev 74225, grass/trunk/lib/python/gunittest/testsuite/test_doctests.py)
--- grass/trunk/lib/python/gunittest/testsuite/test_gunitest_doctests.py	                        (rev 0)
+++ grass/trunk/lib/python/gunittest/testsuite/test_gunitest_doctests.py	2019-03-12 22:22:35 UTC (rev 74226)
@@ -0,0 +1,41 @@
+# -*- coding: utf-8 -*-
+Tests checkers
+import doctest
+import grass.gunittest.case
+import grass.gunittest.main
+import grass.gunittest.utils
+import grass.gunittest.gmodules
+import grass.gunittest.checkers
+# doctest does not allow changing the base classes of test case, skip test case
+# and test suite, so we need to create a new type which inherits from our class
+# and contains doctest's methods
+# the alternative is to copy 500 from doctest and change what is needed
+# (this might be necessary anyway because of the reports and stdout and stderr)
+doctest.DocFileCase = type('DocFileCase',
+                           (grass.gunittest.case.TestCase,),
+                           dict(doctest.DocFileCase.__dict__))
+doctest.SkipDocTestCase = type('SkipDocTestCase',
+                               dict(doctest.SkipDocTestCase.__dict__))
+def load_tests(loader, tests, ignore):
+    # TODO: this must be somewhere when doctest is called, not here
+    # TODO: ultimate solution is not to use _ as a buildin in lib/python
+    # for now it is the only place where it works
+    grass.gunittest.utils.do_doctest_gettext_workaround()
+    # this should be called at some top level
+    tests.addTests(doctest.DocTestSuite(grass.gunittest.gmodules))
+    tests.addTests(doctest.DocTestSuite(grass.gunittest.checkers))
+    return tests
+if __name__ == '__main__':
+    grass.gunittest.main.test()
Deleted: grass/trunk/lib/python/pygrass/gis/testsuite/test_doctests.py
--- grass/trunk/lib/python/pygrass/gis/testsuite/test_doctests.py	2019-03-12 21:48:48 UTC (rev 74225)
+++ grass/trunk/lib/python/pygrass/gis/testsuite/test_doctests.py	2019-03-12 22:22:35 UTC (rev 74226)
@@ -1,52 +0,0 @@
-Tests checkers
-import doctest
-from grass.pygrass import gis
-from grass.pygrass.gis import region
-    from grass.pygrass import utils
-    from grass.script.core import run_command
-    utils.create_test_vector_map(gis.test_vector_name)
-    utils.create_test_vector_map(gis.region.test_vector_name)
-    run_command("g.region", n=50, s=0, e=60, w=0, res=1)
-    run_command("r.mapcalc", expression="%s = 1"%(gis.test_raster_name),
-                             overwrite=True)
-    run_command("r.mapcalc", expression="%s = 1"%(gis.region.test_raster_name),
-                             overwrite=True)
-    run_command("g.region", n=40, s=0, e=40, w=0, res=2)
-    tests.addTests(doctest.DocTestSuite(gis))
-    tests.addTests(doctest.DocTestSuite(region))
-    return tests
Copied: grass/trunk/lib/python/pygrass/gis/testsuite/test_pygrass_gis_doctests.py (from rev 74225, grass/trunk/lib/python/pygrass/gis/testsuite/test_doctests.py)
--- grass/trunk/lib/python/pygrass/gis/testsuite/test_pygrass_gis_doctests.py	                        (rev 0)
+++ grass/trunk/lib/python/pygrass/gis/testsuite/test_pygrass_gis_doctests.py	2019-03-12 22:22:35 UTC (rev 74226)
@@ -0,0 +1,52 @@
+Tests checkers
+import doctest
+from grass.pygrass import gis
+from grass.pygrass.gis import region
+    from grass.pygrass import utils
+    from grass.script.core import run_command
+    utils.create_test_vector_map(gis.test_vector_name)
+    utils.create_test_vector_map(gis.region.test_vector_name)
+    run_command("g.region", n=50, s=0, e=60, w=0, res=1)
+    run_command("r.mapcalc", expression="%s = 1"%(gis.test_raster_name),
+                             overwrite=True)
+    run_command("r.mapcalc", expression="%s = 1"%(gis.region.test_raster_name),
+                             overwrite=True)
+    run_command("g.region", n=40, s=0, e=40, w=0, res=2)
+    tests.addTests(doctest.DocTestSuite(gis))
+    tests.addTests(doctest.DocTestSuite(region))
+    return tests
Deleted: grass/trunk/lib/python/pygrass/messages/testsuite/test_doctests.py
--- grass/trunk/lib/python/pygrass/messages/testsuite/test_doctests.py	2019-03-12 21:48:48 UTC (rev 74225)
+++ grass/trunk/lib/python/pygrass/messages/testsuite/test_doctests.py	2019-03-12 22:22:35 UTC (rev 74226)
@@ -1,39 +0,0 @@
-Tests checkers
-import doctest
-import grass.pygrass.messages as gmessages
-    tests.addTests(doctest.DocTestSuite(gmessages))
-    return tests
Copied: grass/trunk/lib/python/pygrass/messages/testsuite/test_pygrass_messages_doctests.py (from rev 74225, grass/trunk/lib/python/pygrass/messages/testsuite/test_doctests.py)
--- grass/trunk/lib/python/pygrass/messages/testsuite/test_pygrass_messages_doctests.py	                        (rev 0)
+++ grass/trunk/lib/python/pygrass/messages/testsuite/test_pygrass_messages_doctests.py	2019-03-12 22:22:35 UTC (rev 74226)
@@ -0,0 +1,39 @@
+Tests checkers
+import doctest
+import grass.pygrass.messages as gmessages
+    tests.addTests(doctest.DocTestSuite(gmessages))
+    return tests
Deleted: grass/trunk/lib/python/pygrass/modules/grid/testsuite/test_doctests.py
--- grass/trunk/lib/python/pygrass/modules/grid/testsuite/test_doctests.py	2019-03-12 21:48:48 UTC (rev 74225)
+++ grass/trunk/lib/python/pygrass/modules/grid/testsuite/test_doctests.py	2019-03-12 22:22:35 UTC (rev 74226)
@@ -1,39 +0,0 @@
-Tests checkers
-import doctest
-import grass.pygrass.modules as gmodules
-    tests.addTests(doctest.DocTestSuite(gmodules.shortcuts))
-    return tests
Copied: grass/trunk/lib/python/pygrass/modules/grid/testsuite/test_pygrass_modules_grid_doctests.py (from rev 74225, grass/trunk/lib/python/pygrass/modules/grid/testsuite/test_doctests.py)
--- grass/trunk/lib/python/pygrass/modules/grid/testsuite/test_pygrass_modules_grid_doctests.py	                        (rev 0)
+++ grass/trunk/lib/python/pygrass/modules/grid/testsuite/test_pygrass_modules_grid_doctests.py	2019-03-12 22:22:35 UTC (rev 74226)
@@ -0,0 +1,39 @@
+Tests checkers
+import doctest
+import grass.pygrass.modules as gmodules
+    tests.addTests(doctest.DocTestSuite(gmodules.shortcuts))
+    return tests
Deleted: grass/trunk/lib/python/pygrass/modules/interface/testsuite/test_doctests.py
--- grass/trunk/lib/python/pygrass/modules/interface/testsuite/test_doctests.py	2019-03-12 21:48:48 UTC (rev 74225)
+++ grass/trunk/lib/python/pygrass/modules/interface/testsuite/test_doctests.py	2019-03-12 22:22:35 UTC (rev 74226)
@@ -1,42 +0,0 @@
-Tests checkers
-import doctest
-    tests.addTests(doctest.DocTestSuite(gmodules.interface.flag))
-    tests.addTests(doctest.DocTestSuite(gmodules.interface.module))
-    tests.addTests(doctest.DocTestSuite(gmodules.interface.parameter))
-    return tests
Copied: grass/trunk/lib/python/pygrass/modules/interface/testsuite/test_pygrass_modules_interface_doctests.py (from rev 74225, grass/trunk/lib/python/pygrass/modules/interface/testsuite/test_doctests.py)
--- grass/trunk/lib/python/pygrass/modules/interface/testsuite/test_pygrass_modules_interface_doctests.py	                        (rev 0)
+++ grass/trunk/lib/python/pygrass/modules/interface/testsuite/test_pygrass_modules_interface_doctests.py	2019-03-12 22:22:35 UTC (rev 74226)
@@ -0,0 +1,42 @@
+Tests checkers
+import doctest
+    tests.addTests(doctest.DocTestSuite(gmodules.interface.flag))
+    tests.addTests(doctest.DocTestSuite(gmodules.interface.module))
+    tests.addTests(doctest.DocTestSuite(gmodules.interface.parameter))
+    return tests
Deleted: grass/trunk/lib/python/pygrass/modules/testsuite/test_doctests.py
--- grass/trunk/lib/python/pygrass/modules/testsuite/test_doctests.py	2019-03-12 21:48:48 UTC (rev 74225)
+++ grass/trunk/lib/python/pygrass/modules/testsuite/test_doctests.py	2019-03-12 22:22:35 UTC (rev 74226)
@@ -1,43 +0,0 @@
-Tests checkers
-import doctest
-from grass.pygrass.modules import shortcuts, grid, interface
-    tests.addTests(doctest.DocTestSuite(interface))
-    tests.addTests(doctest.DocTestSuite(grid.grid))
-    tests.addTests(doctest.DocTestSuite(grid.patch))
-    tests.addTests(doctest.DocTestSuite(grid.split))
-    tests.addTests(doctest.DocTestSuite(shortcuts))
-    return tests
Copied: grass/trunk/lib/python/pygrass/modules/testsuite/test_pygrass_modules_doctests.py (from rev 74225, grass/trunk/lib/python/pygrass/modules/testsuite/test_doctests.py)
--- grass/trunk/lib/python/pygrass/modules/testsuite/test_pygrass_modules_doctests.py	                        (rev 0)
+++ grass/trunk/lib/python/pygrass/modules/testsuite/test_pygrass_modules_doctests.py	2019-03-12 22:22:35 UTC (rev 74226)
@@ -0,0 +1,43 @@
+Tests checkers
+import doctest
+from grass.pygrass.modules import shortcuts, grid, interface
+    tests.addTests(doctest.DocTestSuite(interface))
+    tests.addTests(doctest.DocTestSuite(grid.grid))
+    tests.addTests(doctest.DocTestSuite(grid.patch))
+    tests.addTests(doctest.DocTestSuite(grid.split))
+    tests.addTests(doctest.DocTestSuite(shortcuts))
+    return tests
Deleted: grass/trunk/lib/python/pygrass/raster/testsuite/test_doctests.py
--- grass/trunk/lib/python/pygrass/raster/testsuite/test_doctests.py	2019-03-12 21:48:48 UTC (rev 74225)
+++ grass/trunk/lib/python/pygrass/raster/testsuite/test_doctests.py	2019-03-12 22:22:35 UTC (rev 74226)
@@ -1,73 +0,0 @@
-Tests checkers
-import doctest
-import grass.pygrass.raster as pgrass
-    from grass.pygrass.modules import Module
-    Module("g.region", n=40, s=0, e=40, w=0, res=10)
-    Module("r.mapcalc",
-        expression="%s = row() + (10 * col())" % (pgrass.test_raster_name),
-        overwrite=True)
-    Module("r.support", map=pgrass.test_raster_name,
-        title="A test map",
-        history="Generated by r.mapcalc",
-        description="This is a test map")
-    cats = """11:A
-            12:B
-            13:C
-            14:D
-            21:E
-            22:F
-            23:G
-            24:H
-            31:I
-            32:J
-            33:K
-            34:L
-            41:M
-            42:n
-            43:O
-            44:P"""
-    Module("r.category", rules="-", map=pgrass.test_raster_name,
-           stdin_=cats, separator=":")
-        expression="%s = row() + (10 * col())" % (pgrass.abstract.test_raster_name),
-        overwrite=True)
-    tests.addTests(doctest.DocTestSuite(pgrass))
-    tests.addTests(doctest.DocTestSuite(pgrass.abstract))
-    return tests
Copied: grass/trunk/lib/python/pygrass/raster/testsuite/test_pygrass_raster.py (from rev 74225, grass/trunk/lib/python/pygrass/raster/testsuite/test_raster.py)
--- grass/trunk/lib/python/pygrass/raster/testsuite/test_pygrass_raster.py	                        (rev 0)
+++ grass/trunk/lib/python/pygrass/raster/testsuite/test_pygrass_raster.py	2019-03-12 22:22:35 UTC (rev 74226)
@@ -0,0 +1,93 @@
+from grass.exceptions import OpenError
+from grass.gunittest.case import TestCase
+from grass.gunittest.main import test
+from grass.pygrass.raster import RasterRow
+class RasterRowTestCase(TestCase):
+    name = "RasterRowTestCase_map"
+    @classmethod
+    def setUpClass(cls):
+        """Create test raster map and region"""
+        cls.use_temp_region()
+        cls.runModule("g.region", n=40, s=0, e=40, w=0, res=10)
+        cls.runModule("r.mapcalc", expression="%s = row() + (10.0 * col())" % (cls.name),
+            overwrite=True)
+    @classmethod
+    def tearDownClass(cls):
+        """Remove the generated vector map, if exist"""
+        cls.runModule("g.remove", flags='f', type='raster',
+                      name=cls.name)
+        cls.del_temp_region()
+    def test_type(self):
+        r = RasterRow(self.name)
+        r.open(mode='r')
+        self.assertTrue(r.mtype, 'DCELL')
+        r.close()
+    def test_isopen(self):
+        self.assertFalse(r.is_open())
+        r.open(mode='r')
+        self.assertTrue(r.is_open())
+        r.close()
+    def test_name(self):
+        r.open(mode='r')
+        self.assertEqual(r.name, self.name)
+        fullname = "{name}@{mapset}".format(name=r.name, mapset=r.mapset)
+        self.assertEqual(r.fullname(), fullname)
+        r.close()
+    def test_exist(self):
+        notexist = RasterRow(self.name + 'notexist')
+        self.assertFalse(notexist.exist())
+        exist = RasterRow(self.name)
+        self.assertTrue(exist.exist())
+    def test_open_r(self):
+        with self.assertRaises(OpenError):
+            # raster does not exist
+            notexist.open(mode='r')
+        r.open(mode='r', mtype='FCELL')
+        # ignore the mtype if is open in read mode
+        self.assertEqual(r.mtype, 'DCELL')
+        r.close()
+    def test_open_w(self):
+            # raster type is not defined!
+            r.open(mode='w')
+            # raster already exist
+            r.open(mode='w', mtype='DCELL')
+        # open in write mode and overwrite
+        r.open(mode='w', mtype='DCELL', overwrite=True)
+        r.close()
+    def test_row_range(self):
+        with self.assertRaises(IndexError):
+            # Map is not open yet
+            r[1]
+            # Index is out of range
+            r.open()
+            r[9999]
+        r.close()
+    test()
Copied: grass/trunk/lib/python/pygrass/raster/testsuite/test_pygrass_raster_doctests.py (from rev 74225, grass/trunk/lib/python/pygrass/raster/testsuite/test_doctests.py)
--- grass/trunk/lib/python/pygrass/raster/testsuite/test_pygrass_raster_doctests.py	                        (rev 0)
+++ grass/trunk/lib/python/pygrass/raster/testsuite/test_pygrass_raster_doctests.py	2019-03-12 22:22:35 UTC (rev 74226)
@@ -0,0 +1,73 @@
+Tests checkers
+import doctest
+import grass.pygrass.raster as pgrass
+    from grass.pygrass.modules import Module
+    Module("g.region", n=40, s=0, e=40, w=0, res=10)
+    Module("r.mapcalc",
+        expression="%s = row() + (10 * col())" % (pgrass.test_raster_name),
+        overwrite=True)
+    Module("r.support", map=pgrass.test_raster_name,
+        title="A test map",
+        history="Generated by r.mapcalc",
+        description="This is a test map")
+    cats = """11:A
+            12:B
+            13:C
+            14:D
+            21:E
+            22:F
+            23:G
+            24:H
+            31:I
+            32:J
+            33:K
+            34:L
+            41:M
+            42:n
+            43:O
+            44:P"""
+    Module("r.category", rules="-", map=pgrass.test_raster_name,
+           stdin_=cats, separator=":")
+        expression="%s = row() + (10 * col())" % (pgrass.abstract.test_raster_name),
+        overwrite=True)
+    tests.addTests(doctest.DocTestSuite(pgrass))
+    tests.addTests(doctest.DocTestSuite(pgrass.abstract))
+    return tests
Deleted: grass/trunk/lib/python/pygrass/raster/testsuite/test_raster.py
--- grass/trunk/lib/python/pygrass/raster/testsuite/test_raster.py	2019-03-12 21:48:48 UTC (rev 74225)
+++ grass/trunk/lib/python/pygrass/raster/testsuite/test_raster.py	2019-03-12 22:22:35 UTC (rev 74226)
@@ -1,93 +0,0 @@
-from grass.exceptions import OpenError
-from grass.gunittest.case import TestCase
-from grass.gunittest.main import test
-from grass.pygrass.raster import RasterRow
-class RasterRowTestCase(TestCase):
-    name = "RasterRowTestCase_map"
-    @classmethod
-    def setUpClass(cls):
-        """Create test raster map and region"""
-        cls.use_temp_region()
-        cls.runModule("g.region", n=40, s=0, e=40, w=0, res=10)
-        cls.runModule("r.mapcalc", expression="%s = row() + (10.0 * col())" % (cls.name),
-            overwrite=True)
-    @classmethod
-    def tearDownClass(cls):
-        """Remove the generated vector map, if exist"""
-        cls.runModule("g.remove", flags='f', type='raster',
-                      name=cls.name)
-        cls.del_temp_region()
-    def test_type(self):
-        r = RasterRow(self.name)
-        r.open(mode='r')
-        self.assertTrue(r.mtype, 'DCELL')
-        r.close()
-    def test_isopen(self):
-        self.assertFalse(r.is_open())
-        r.open(mode='r')
-        self.assertTrue(r.is_open())
-        r.close()
-    def test_name(self):
-        r.open(mode='r')
-        self.assertEqual(r.name, self.name)
-        fullname = "{name}@{mapset}".format(name=r.name, mapset=r.mapset)
-        self.assertEqual(r.fullname(), fullname)
-        r.close()
-    def test_exist(self):
-        notexist = RasterRow(self.name + 'notexist')
-        self.assertFalse(notexist.exist())
-        exist = RasterRow(self.name)
-        self.assertTrue(exist.exist())
-    def test_open_r(self):
-        with self.assertRaises(OpenError):
-            # raster does not exist
-            notexist.open(mode='r')
-        r.open(mode='r', mtype='FCELL')
-        # ignore the mtype if is open in read mode
-        self.assertEqual(r.mtype, 'DCELL')
-        r.close()
-    def test_open_w(self):
-            # raster type is not defined!
-            r.open(mode='w')
-            # raster already exist
-            r.open(mode='w', mtype='DCELL')
-        # open in write mode and overwrite
-        r.open(mode='w', mtype='DCELL', overwrite=True)
-        r.close()
-    def test_row_range(self):
-        with self.assertRaises(IndexError):
-            # Map is not open yet
-            r[1]
-            # Index is out of range
-            r.open()
-            r[9999]
-        r.close()
-    test()
Deleted: grass/trunk/lib/python/pygrass/rpc/testsuite/test_doctests.py
--- grass/trunk/lib/python/pygrass/rpc/testsuite/test_doctests.py	2019-03-12 21:48:48 UTC (rev 74225)
+++ grass/trunk/lib/python/pygrass/rpc/testsuite/test_doctests.py	2019-03-12 22:22:35 UTC (rev 74226)
@@ -1,49 +0,0 @@
-Tests checkers
-import doctest
-import grass.pygrass.rpc as pygrpc
-    Module("r.mapcalc", expression="%s = row() + (10 * col())"%(pygrpc.test_raster_name),
-                             overwrite=True)
-    utils.create_test_vector_map(pygrpc.test_vector_name)
-    tests.addTests(doctest.DocTestSuite(pygrpc))
-    tests.addTests(doctest.DocTestSuite(pygrpc.base))
-    return tests
Copied: grass/trunk/lib/python/pygrass/rpc/testsuite/test_pygrass_rpc_doctests.py (from rev 74225, grass/trunk/lib/python/pygrass/rpc/testsuite/test_doctests.py)
--- grass/trunk/lib/python/pygrass/rpc/testsuite/test_pygrass_rpc_doctests.py	                        (rev 0)
+++ grass/trunk/lib/python/pygrass/rpc/testsuite/test_pygrass_rpc_doctests.py	2019-03-12 22:22:35 UTC (rev 74226)
@@ -0,0 +1,49 @@
+Tests checkers
+import doctest
+import grass.pygrass.rpc as pygrpc
+    Module("r.mapcalc", expression="%s = row() + (10 * col())"%(pygrpc.test_raster_name),
+                             overwrite=True)
+    utils.create_test_vector_map(pygrpc.test_vector_name)
+    tests.addTests(doctest.DocTestSuite(pygrpc))
+    tests.addTests(doctest.DocTestSuite(pygrpc.base))
+    return tests
Deleted: grass/trunk/lib/python/pygrass/shell/testsuite/test_doctests.py
--- grass/trunk/lib/python/pygrass/shell/testsuite/test_doctests.py	2019-03-12 21:48:48 UTC (rev 74225)
+++ grass/trunk/lib/python/pygrass/shell/testsuite/test_doctests.py	2019-03-12 22:22:35 UTC (rev 74226)
@@ -1,40 +0,0 @@
-Tests checkers
-import doctest
-from grass.pygrass.shell import conversion, show
-    tests.addTests(doctest.DocTestSuite(conversion))
-    tests.addTests(doctest.DocTestSuite(show))
-    return tests
Copied: grass/trunk/lib/python/pygrass/shell/testsuite/test_pygrass_shell_doctests.py (from rev 74225, grass/trunk/lib/python/pygrass/shell/testsuite/test_doctests.py)
--- grass/trunk/lib/python/pygrass/shell/testsuite/test_pygrass_shell_doctests.py	                        (rev 0)
+++ grass/trunk/lib/python/pygrass/shell/testsuite/test_pygrass_shell_doctests.py	2019-03-12 22:22:35 UTC (rev 74226)
@@ -0,0 +1,40 @@
+Tests checkers
+import doctest
+from grass.pygrass.shell import conversion, show
+    tests.addTests(doctest.DocTestSuite(conversion))
+    tests.addTests(doctest.DocTestSuite(show))
+    return tests
Deleted: grass/trunk/lib/python/pygrass/testsuite/test_doctests.py
--- grass/trunk/lib/python/pygrass/testsuite/test_doctests.py	2019-03-12 21:48:48 UTC (rev 74225)
+++ grass/trunk/lib/python/pygrass/testsuite/test_doctests.py	2019-03-12 22:22:35 UTC (rev 74226)
@@ -1,47 +0,0 @@
-Tests checkers
-import doctest
-import grass.pygrass.utils as gutils
-    gutils.create_test_vector_map(gutils.test_vector_name)
-    run_command("r.mapcalc", expression="%s = 1"%(gutils.test_raster_name),
-                             overwrite=True)
-    tests.addTests(doctest.DocTestSuite(gutils))
-    return tests
Copied: grass/trunk/lib/python/pygrass/testsuite/test_pygrass_doctests.py (from rev 74225, grass/trunk/lib/python/pygrass/testsuite/test_doctests.py)
--- grass/trunk/lib/python/pygrass/testsuite/test_pygrass_doctests.py	                        (rev 0)
+++ grass/trunk/lib/python/pygrass/testsuite/test_pygrass_doctests.py	2019-03-12 22:22:35 UTC (rev 74226)
@@ -0,0 +1,47 @@
+Tests checkers
+import doctest
+import grass.pygrass.utils as gutils
+    gutils.create_test_vector_map(gutils.test_vector_name)
+    run_command("r.mapcalc", expression="%s = 1"%(gutils.test_raster_name),
+                             overwrite=True)
+    tests.addTests(doctest.DocTestSuite(gutils))
+    return tests
Deleted: grass/trunk/lib/python/pygrass/vector/testsuite/test_doctests.py
--- grass/trunk/lib/python/pygrass/vector/testsuite/test_doctests.py	2019-03-12 21:48:48 UTC (rev 74225)
+++ grass/trunk/lib/python/pygrass/vector/testsuite/test_doctests.py	2019-03-12 22:22:35 UTC (rev 74226)
@@ -1,54 +0,0 @@
-Tests checkers
-import doctest
-import grass.pygrass.vector as gvector
-    utils.create_test_vector_map(gvector.test_vector_name)
-    utils.create_test_vector_map(gvector.abstract.test_vector_name)
-    utils.create_test_vector_map(gvector.geometry.test_vector_name)
-    utils.create_test_vector_map(gvector.find.test_vector_name)
-    utils.create_test_vector_map(gvector.table.test_vector_name)
-    tests.addTests(doctest.DocTestSuite(gvector))
-    tests.addTests(doctest.DocTestSuite(gvector.abstract))
-    tests.addTests(doctest.DocTestSuite(gvector.basic))
-    tests.addTests(doctest.DocTestSuite(gvector.find))
-    tests.addTests(doctest.DocTestSuite(gvector.geometry))
-    tests.addTests(doctest.DocTestSuite(gvector.sql))
-    tests.addTests(doctest.DocTestSuite(gvector.table))
-    return tests
Copied: grass/trunk/lib/python/pygrass/vector/testsuite/test_pygrass_vector_doctests.py (from rev 74225, grass/trunk/lib/python/pygrass/vector/testsuite/test_doctests.py)
--- grass/trunk/lib/python/pygrass/vector/testsuite/test_pygrass_vector_doctests.py	                        (rev 0)
+++ grass/trunk/lib/python/pygrass/vector/testsuite/test_pygrass_vector_doctests.py	2019-03-12 22:22:35 UTC (rev 74226)
@@ -0,0 +1,54 @@
+Tests checkers
+import doctest
+import grass.pygrass.vector as gvector
+    utils.create_test_vector_map(gvector.test_vector_name)
+    utils.create_test_vector_map(gvector.abstract.test_vector_name)
+    utils.create_test_vector_map(gvector.geometry.test_vector_name)
+    utils.create_test_vector_map(gvector.find.test_vector_name)
+    utils.create_test_vector_map(gvector.table.test_vector_name)
+    tests.addTests(doctest.DocTestSuite(gvector))
+    tests.addTests(doctest.DocTestSuite(gvector.abstract))
+    tests.addTests(doctest.DocTestSuite(gvector.basic))
+    tests.addTests(doctest.DocTestSuite(gvector.find))
+    tests.addTests(doctest.DocTestSuite(gvector.geometry))
+    tests.addTests(doctest.DocTestSuite(gvector.sql))
+    tests.addTests(doctest.DocTestSuite(gvector.table))
+    return tests
Deleted: grass/trunk/lib/python/script/testsuite/test_doctests.py
--- grass/trunk/lib/python/script/testsuite/test_doctests.py	2019-03-12 21:48:48 UTC (rev 74225)
+++ grass/trunk/lib/python/script/testsuite/test_doctests.py	2019-03-12 22:22:35 UTC (rev 74226)
@@ -1,39 +0,0 @@
-Tests checkers
-import doctest
-import grass.script.array as garray
-    tests.addTests(doctest.DocTestSuite(garray))
-    return tests
Deleted: grass/trunk/lib/python/script/testsuite/test_raster.py
--- grass/trunk/lib/python/script/testsuite/test_raster.py	2019-03-12 21:48:48 UTC (rev 74225)
+++ grass/trunk/lib/python/script/testsuite/test_raster.py	2019-03-12 22:22:35 UTC (rev 74226)
@@ -1,45 +0,0 @@
-Created on Thu Feb 18 09:42:23 2016
- at author: lucadelu
-import grass.script as gscript
-class TestRaster(TestCase):
-    """Test raster functions"""
-    raster = 'testrasterscript'
-    region = gscript.region()
-    coords = (region['e'] - 1, region['n'] - 1)
-    @classmethod
-        cls.runModule("r.mapcalc", expression="testrasterscript = 100",
-                      overwrite=True)
-    @classmethod
-        cls.runModule("g.remove", type='raster', name='testrasterscript',
-                      flags='f')
-    def test_raster_what(self):
-        res = gscript.raster_what(self.raster, [self.coords])[0]
-        self.assertEquals(int(res[self.raster]['value']), 100)
-        res = gscript.raster_what(self.raster, [self.coords],
-                                  localized=True)[0]
-        self.assertEquals(int(res[self.raster][_('value')]), 100)
-    def test_raster_info(self):
-        res = gscript.raster_info(self.raster)
-        self.assertEquals(str(res['cols']), str(self.region['cols']))
-        self.assertEquals(str(res['north']), str(self.region['n']))
-    test()
Copied: grass/trunk/lib/python/script/testsuite/test_script_doctests.py (from rev 74225, grass/trunk/lib/python/script/testsuite/test_doctests.py)
--- grass/trunk/lib/python/script/testsuite/test_script_doctests.py	                        (rev 0)
+++ grass/trunk/lib/python/script/testsuite/test_script_doctests.py	2019-03-12 22:22:35 UTC (rev 74226)
@@ -0,0 +1,39 @@
+Tests checkers
+import doctest
+import grass.script.array as garray
+    tests.addTests(doctest.DocTestSuite(garray))
+    return tests
Copied: grass/trunk/lib/python/script/testsuite/test_script_raster.py (from rev 74225, grass/trunk/lib/python/script/testsuite/test_raster.py)
--- grass/trunk/lib/python/script/testsuite/test_script_raster.py	                        (rev 0)
+++ grass/trunk/lib/python/script/testsuite/test_script_raster.py	2019-03-12 22:22:35 UTC (rev 74226)
@@ -0,0 +1,45 @@
+Created on Thu Feb 18 09:42:23 2016
+ at author: lucadelu
+import grass.script as gscript
+class TestRaster(TestCase):
+    """Test raster functions"""
+    raster = 'testrasterscript'
+    region = gscript.region()
+    coords = (region['e'] - 1, region['n'] - 1)
+    @classmethod
+        cls.runModule("r.mapcalc", expression="testrasterscript = 100",
+                      overwrite=True)
+    @classmethod
+        cls.runModule("g.remove", type='raster', name='testrasterscript',
+                      flags='f')
+    def test_raster_what(self):
+        res = gscript.raster_what(self.raster, [self.coords])[0]
+        self.assertEquals(int(res[self.raster]['value']), 100)
+        res = gscript.raster_what(self.raster, [self.coords],
+                                  localized=True)[0]
+        self.assertEquals(int(res[self.raster][_('value')]), 100)
+    def test_raster_info(self):
+        res = gscript.raster_info(self.raster)
+        self.assertEquals(str(res['cols']), str(self.region['cols']))
+        self.assertEquals(str(res['north']), str(self.region['n']))
+    test()
Deleted: grass/trunk/lib/python/temporal/testsuite/test_doctests.py
--- grass/trunk/lib/python/temporal/testsuite/test_doctests.py	2019-03-12 21:48:48 UTC (rev 74225)
+++ grass/trunk/lib/python/temporal/testsuite/test_doctests.py	2019-03-12 22:22:35 UTC (rev 74226)
@@ -1,52 +0,0 @@
-Temporal framework doctests
-import doctest
-import grass.temporal
-    tests.addTests(doctest.DocTestSuite(grass.temporal.abstract_dataset))
-    tests.addTests(doctest.DocTestSuite(grass.temporal.abstract_map_dataset))
-    tests.addTests(doctest.DocTestSuite(grass.temporal.abstract_space_time_dataset))
-    tests.addTests(doctest.DocTestSuite(grass.temporal.base))
-    tests.addTests(doctest.DocTestSuite(grass.temporal.core))
-    tests.addTests(doctest.DocTestSuite(grass.temporal.datetime_math))
-    # Unexpected error here
-    #tests.addTests(doctest.DocTestSuite(grass.temporal.list_stds))
-    tests.addTests(doctest.DocTestSuite(grass.temporal.metadata))
-    tests.addTests(doctest.DocTestSuite(grass.temporal.register))
-    tests.addTests(doctest.DocTestSuite(grass.temporal.space_time_datasets))
-    tests.addTests(doctest.DocTestSuite(grass.temporal.spatial_extent))
-    tests.addTests(doctest.DocTestSuite(grass.temporal.spatial_topology_dataset_connector))
-    tests.addTests(doctest.DocTestSuite(grass.temporal.spatio_temporal_relationships))
-    tests.addTests(doctest.DocTestSuite(grass.temporal.temporal_extent))
-    tests.addTests(doctest.DocTestSuite(grass.temporal.temporal_granularity))
-    tests.addTests(doctest.DocTestSuite(grass.temporal.temporal_topology_dataset_connector))
-    # Algebra is still very experimental
-    tests.addTests(doctest.DocTestSuite(grass.temporal.temporal_algebra))
-    tests.addTests(doctest.DocTestSuite(grass.temporal.temporal_raster3d_algebra))
-    tests.addTests(doctest.DocTestSuite(grass.temporal.temporal_raster_algebra))
-    tests.addTests(doctest.DocTestSuite(grass.temporal.temporal_raster_base_algebra))
-    tests.addTests(doctest.DocTestSuite(grass.temporal.temporal_operator))
-    tests.addTests(doctest.DocTestSuite(grass.temporal.temporal_vector_algebra))
-    tests.addTests(doctest.DocTestSuite(grass.temporal.c_libraries_interface))
-    return tests
Copied: grass/trunk/lib/python/temporal/testsuite/test_temporal_doctests.py (from rev 74225, grass/trunk/lib/python/temporal/testsuite/test_doctests.py)
--- grass/trunk/lib/python/temporal/testsuite/test_temporal_doctests.py	                        (rev 0)
+++ grass/trunk/lib/python/temporal/testsuite/test_temporal_doctests.py	2019-03-12 22:22:35 UTC (rev 74226)
@@ -0,0 +1,52 @@
+Temporal framework doctests
+import doctest
+import grass.temporal
+    tests.addTests(doctest.DocTestSuite(grass.temporal.abstract_dataset))
+    tests.addTests(doctest.DocTestSuite(grass.temporal.abstract_map_dataset))
+    tests.addTests(doctest.DocTestSuite(grass.temporal.abstract_space_time_dataset))
+    tests.addTests(doctest.DocTestSuite(grass.temporal.base))
+    tests.addTests(doctest.DocTestSuite(grass.temporal.core))
+    tests.addTests(doctest.DocTestSuite(grass.temporal.datetime_math))
+    # Unexpected error here
+    #tests.addTests(doctest.DocTestSuite(grass.temporal.list_stds))
+    tests.addTests(doctest.DocTestSuite(grass.temporal.metadata))
+    tests.addTests(doctest.DocTestSuite(grass.temporal.register))
+    tests.addTests(doctest.DocTestSuite(grass.temporal.space_time_datasets))
+    tests.addTests(doctest.DocTestSuite(grass.temporal.spatial_extent))
+    tests.addTests(doctest.DocTestSuite(grass.temporal.spatial_topology_dataset_connector))
+    tests.addTests(doctest.DocTestSuite(grass.temporal.spatio_temporal_relationships))
+    tests.addTests(doctest.DocTestSuite(grass.temporal.temporal_extent))
+    tests.addTests(doctest.DocTestSuite(grass.temporal.temporal_granularity))
+    tests.addTests(doctest.DocTestSuite(grass.temporal.temporal_topology_dataset_connector))
+    # Algebra is still very experimental
+    tests.addTests(doctest.DocTestSuite(grass.temporal.temporal_algebra))
+    tests.addTests(doctest.DocTestSuite(grass.temporal.temporal_raster3d_algebra))
+    tests.addTests(doctest.DocTestSuite(grass.temporal.temporal_raster_algebra))
+    tests.addTests(doctest.DocTestSuite(grass.temporal.temporal_raster_base_algebra))
+    tests.addTests(doctest.DocTestSuite(grass.temporal.temporal_operator))
+    tests.addTests(doctest.DocTestSuite(grass.temporal.temporal_vector_algebra))
+    tests.addTests(doctest.DocTestSuite(grass.temporal.c_libraries_interface))
+    return tests
Deleted: grass/trunk/temporal/t.rast.extract/testsuite/test_extract.py
--- grass/trunk/temporal/t.rast.extract/testsuite/test_extract.py	2019-03-12 21:48:48 UTC (rev 74225)
+++ grass/trunk/temporal/t.rast.extract/testsuite/test_extract.py	2019-03-12 22:22:35 UTC (rev 74226)
@@ -1,212 +0,0 @@
-"""Test t.rast.extract
-(C) 2014 by the GRASS Development Team
-This program is free software under the GNU General Public
-License (>=v2). Read the file COPYING that comes with GRASS
-for details.
- at author Soeren Gebbert
-import grass.pygrass.modules as pymod
-import subprocess
-from grass.gunittest.gmodules import SimpleModule
-class TestRasterExtraction(TestCase):
-    @classmethod
-        """Initiate the temporal GIS and set the region
-        cls.runModule("g.gisenv",  set="TGIS_USE_CURRENT_MAPSET=1")
-        cls.runModule("g.region",  s=0,  n=80,  w=0,  e=120,  b=0,  t=50,  res=10,  res3=10)
-        cls.runModule("r.mapcalc", expression="prec_1 = 100",  overwrite=True)
-        cls.runModule("r.mapcalc", expression="prec_2 = 200",  overwrite=True)
-        cls.runModule("r.mapcalc", expression="prec_3 = 300",  overwrite=True)
-        cls.runModule("r.mapcalc", expression="prec_4 = 400",  overwrite=True)
-        cls.runModule("r.mapcalc", expression="prec_5 = 500",  overwrite=True)
-        cls.runModule("r.mapcalc", expression="prec_6 = 600",  overwrite=True)
-        cls.runModule("t.create", type="strds", temporaltype="absolute",
-                      output="precip_abs1", title="A test",
-                      description="A test", overwrite=True)
-        cls.runModule("t.register", flags="i", type="raster", input="precip_abs1",
-                      maps="prec_1,prec_2,prec_3,prec_4,prec_5,prec_6",
-                      start="2001-01-01", increment="3 months", overwrite=True)
-    @classmethod
-        """Remove the temporary region
-    def setUp(self):
-        """Create input data for transient groundwater flow computation
-        # Use always the current mapset as temporal database
-        self.runModule("r.mapcalc", expression="prec_1 = 100",  overwrite=True)
-        self.runModule("r.mapcalc", expression="prec_2 = 200",  overwrite=True)
-        self.runModule("r.mapcalc", expression="prec_3 = 300",  overwrite=True)
-        self.runModule("r.mapcalc", expression="prec_4 = 400",  overwrite=True)
-        self.runModule("r.mapcalc", expression="prec_5 = 500",  overwrite=True)
-        self.runModule("r.mapcalc", expression="prec_6 = 600",  overwrite=True)
-        self.runModule("t.create",  type="strds",  temporaltype="absolute",
-                                     output="precip_abs1",  title="A test",  description="A test",  overwrite=True)
-        self.runModule("t.register",  flags="i",  type="raster",  input="precip_abs1",
-    def tearDown(self):
-        """Remove generated data"""
-        self.runModule("t.remove",  flags="rf",  type="strds",
-                                   inputs="precip_abs2")
-    def test_selection(self):
-        """Perform a simple selection by datetime"""
-        self.assertModule("t.rast.extract",  input="precip_abs1",  output="precip_abs2",
-                                      where="start_time > '2001-06-01'")
-        #self.assertModule("t.info",  flags="g",  input="precip_abs2")
-        tinfo_string="""start_time='2001-07-01 00:00:00'
-        end_time='2002-07-01 00:00:00'
-        granularity='3 months'
-        map_time=interval
-        north=80.0
-        south=0.0
-        east=120.0
-        west=0.0
-        top=0.0
-        bottom=0.0
-        aggregation_type=None
-        number_of_maps=4
-        nsres_min=10.0
-        nsres_max=10.0
-        ewres_min=10.0
-        ewres_max=10.0
-        min_min=300.0
-        min_max=600.0
-        max_min=300.0
-        max_max=600.0"""
-        info = SimpleModule("t.info", flags="g", input="precip_abs2")
-        self.assertModuleKeyValue(module=info, reference=tinfo_string, precision=2, sep="=")
-    def test_selection_and_expression(self):
-        """Perform a selection by datetime and a r.mapcalc expression"""
-                                      where="start_time > '2001-06-01'",
-                                      expression=" if(precip_abs1 > 400, precip_abs1, null())",
-                                      basename="new_prec",  nprocs=2,  overwrite=True)
-        tinfo_string="""start_time='2002-01-01 00:00:00'
-        map_time=interval
-        north=80.0
-        south=0.0
-        east=120.0
-        west=0.0
-        top=0.0
-        bottom=0.0
-        number_of_maps=2
-        nsres_min=10.0
-        nsres_max=10.0
-        ewres_min=10.0
-        ewres_max=10.0
-        min_min=500.0
-        min_max=600.0
-        max_min=500.0
-        max_max=600.0"""
-    def test_expression_with_empty_maps(self):
-        """Perform r.mapcalc expression and register empty maps"""
-        self.assertModule("t.rast.extract",  flags="n",  input="precip_abs1",  output="precip_abs2",
-        tinfo_string="""start_time='2001-01-01 00:00:00'
-        map_time=interval
-        north=80.0
-        south=0.0
-        east=120.0
-        west=0.0
-        top=0.0
-        bottom=0.0
-        number_of_maps=6
-        nsres_min=10.0
-        nsres_max=10.0
-        ewres_min=10.0
-        ewres_max=10.0
-        min_min=500.0
-        min_max=600.0
-        max_min=500.0
-        max_max=600.0"""
-    def test_time_suffix_with_expression(self):
-        """Perform extract with time suffix support and test if maps exists"""
-                          output="precip_abs2", basename="new_prec",
-                          nprocs=2,  overwrite=True, suffix="time",
-                          expression="if(precip_abs1 > 400, precip_abs1, null())")
-        self.assertRasterExists('new_prec_2001_01_01T00_00_00')
-        self.assertRasterDoesNotExist('new_prec_2001_01')
-    def test_num_suffix_with_expression(self):
-                          nprocs=2,  overwrite=True, suffix='num%03',
-        self.assertRasterExists('new_prec_001')
-        self.assertRasterDoesNotExist('new_prec_00001')
-class TestRasterExtractionFails(TestCase):
-    @classmethod
-    @classmethod
-    def test_error_handling(self):
-        # No input
-        self.assertModuleFail("t.rast.extract",  output="precip_abs2", basename="new_prec")
-        # No output
-        self.assertModuleFail("t.rast.extract",  input="precip_abs1",  basename="new_prec")
-        # No basename
-        self.assertModuleFail("t.rast.extract",  input="precip_abs1",  output="precip_abs2",
-                          expression=" if(precip_abs1 > 400, precip_abs1, null())")
-    from grass.gunittest.main import test
-    test()
Copied: grass/trunk/temporal/t.rast.extract/testsuite/test_t_rast_extract.py (from rev 74225, grass/trunk/temporal/t.rast.extract/testsuite/test_extract.py)
--- grass/trunk/temporal/t.rast.extract/testsuite/test_t_rast_extract.py	                        (rev 0)
+++ grass/trunk/temporal/t.rast.extract/testsuite/test_t_rast_extract.py	2019-03-12 22:22:35 UTC (rev 74226)
@@ -0,0 +1,212 @@
+"""Test t.rast.extract
+(C) 2014 by the GRASS Development Team
+This program is free software under the GNU General Public
+License (>=v2). Read the file COPYING that comes with GRASS
+for details.
+ at author Soeren Gebbert
+import grass.pygrass.modules as pymod
+import subprocess
+from grass.gunittest.gmodules import SimpleModule
+class TestRasterExtraction(TestCase):
+    @classmethod
+        """Initiate the temporal GIS and set the region
+        cls.runModule("g.gisenv",  set="TGIS_USE_CURRENT_MAPSET=1")
+        cls.runModule("g.region",  s=0,  n=80,  w=0,  e=120,  b=0,  t=50,  res=10,  res3=10)
+        cls.runModule("r.mapcalc", expression="prec_1 = 100",  overwrite=True)
+        cls.runModule("r.mapcalc", expression="prec_2 = 200",  overwrite=True)
+        cls.runModule("r.mapcalc", expression="prec_3 = 300",  overwrite=True)
+        cls.runModule("r.mapcalc", expression="prec_4 = 400",  overwrite=True)
+        cls.runModule("r.mapcalc", expression="prec_5 = 500",  overwrite=True)
+        cls.runModule("r.mapcalc", expression="prec_6 = 600",  overwrite=True)
+        cls.runModule("t.create", type="strds", temporaltype="absolute",
+                      output="precip_abs1", title="A test",
+                      description="A test", overwrite=True)
+        cls.runModule("t.register", flags="i", type="raster", input="precip_abs1",
+                      maps="prec_1,prec_2,prec_3,prec_4,prec_5,prec_6",
+                      start="2001-01-01", increment="3 months", overwrite=True)
+    @classmethod
+        """Remove the temporary region
+    def setUp(self):
+        """Create input data for transient groundwater flow computation
+        # Use always the current mapset as temporal database
+        self.runModule("r.mapcalc", expression="prec_1 = 100",  overwrite=True)
+        self.runModule("r.mapcalc", expression="prec_2 = 200",  overwrite=True)
+        self.runModule("r.mapcalc", expression="prec_3 = 300",  overwrite=True)
+        self.runModule("r.mapcalc", expression="prec_4 = 400",  overwrite=True)
+        self.runModule("r.mapcalc", expression="prec_5 = 500",  overwrite=True)
+        self.runModule("r.mapcalc", expression="prec_6 = 600",  overwrite=True)
+        self.runModule("t.create",  type="strds",  temporaltype="absolute",
+                                     output="precip_abs1",  title="A test",  description="A test",  overwrite=True)
+        self.runModule("t.register",  flags="i",  type="raster",  input="precip_abs1",
+    def tearDown(self):
+        """Remove generated data"""
+        self.runModule("t.remove",  flags="rf",  type="strds",
+                                   inputs="precip_abs2")
+    def test_selection(self):
+        """Perform a simple selection by datetime"""
+        self.assertModule("t.rast.extract",  input="precip_abs1",  output="precip_abs2",
+                                      where="start_time > '2001-06-01'")
+        #self.assertModule("t.info",  flags="g",  input="precip_abs2")
+        tinfo_string="""start_time='2001-07-01 00:00:00'
+        end_time='2002-07-01 00:00:00'
+        granularity='3 months'
+        map_time=interval
+        north=80.0
+        south=0.0
+        east=120.0
+        west=0.0
+        top=0.0
+        bottom=0.0
+        aggregation_type=None
+        number_of_maps=4
+        nsres_min=10.0
+        nsres_max=10.0
+        ewres_min=10.0
+        ewres_max=10.0
+        min_min=300.0
+        min_max=600.0
+        max_min=300.0
+        max_max=600.0"""
+        info = SimpleModule("t.info", flags="g", input="precip_abs2")
+        self.assertModuleKeyValue(module=info, reference=tinfo_string, precision=2, sep="=")
+    def test_selection_and_expression(self):
+        """Perform a selection by datetime and a r.mapcalc expression"""
+                                      where="start_time > '2001-06-01'",
+                                      expression=" if(precip_abs1 > 400, precip_abs1, null())",
+                                      basename="new_prec",  nprocs=2,  overwrite=True)
+        tinfo_string="""start_time='2002-01-01 00:00:00'
+        map_time=interval
+        north=80.0
+        south=0.0
+        east=120.0
+        west=0.0
+        top=0.0
+        bottom=0.0
+        number_of_maps=2
+        nsres_min=10.0
+        nsres_max=10.0
+        ewres_min=10.0
+        ewres_max=10.0
+        min_min=500.0
+        min_max=600.0
+        max_min=500.0
+        max_max=600.0"""
+    def test_expression_with_empty_maps(self):
+        """Perform r.mapcalc expression and register empty maps"""
+        self.assertModule("t.rast.extract",  flags="n",  input="precip_abs1",  output="precip_abs2",
+        tinfo_string="""start_time='2001-01-01 00:00:00'
+        map_time=interval
+        north=80.0
+        south=0.0
+        east=120.0
+        west=0.0
+        top=0.0
+        bottom=0.0
+        number_of_maps=6
+        nsres_min=10.0
+        nsres_max=10.0
+        ewres_min=10.0
+        ewres_max=10.0
+        min_min=500.0
+        min_max=600.0
+        max_min=500.0
+        max_max=600.0"""
+    def test_time_suffix_with_expression(self):
+        """Perform extract with time suffix support and test if maps exists"""
+                          output="precip_abs2", basename="new_prec",
+                          nprocs=2,  overwrite=True, suffix="time",
+                          expression="if(precip_abs1 > 400, precip_abs1, null())")
+        self.assertRasterExists('new_prec_2001_01_01T00_00_00')
+        self.assertRasterDoesNotExist('new_prec_2001_01')
+    def test_num_suffix_with_expression(self):
+                          nprocs=2,  overwrite=True, suffix='num%03',
+        self.assertRasterExists('new_prec_001')
+        self.assertRasterDoesNotExist('new_prec_00001')
+class TestRasterExtractionFails(TestCase):
+    @classmethod
+    @classmethod
+    def test_error_handling(self):
+        # No input
+        self.assertModuleFail("t.rast.extract",  output="precip_abs2", basename="new_prec")
+        # No output
+        self.assertModuleFail("t.rast.extract",  input="precip_abs1",  basename="new_prec")
+        # No basename
+        self.assertModuleFail("t.rast.extract",  input="precip_abs1",  output="precip_abs2",
+                          expression=" if(precip_abs1 > 400, precip_abs1, null())")
+    from grass.gunittest.main import test
+    test()
Copied: grass/trunk/temporal/t.rast.univar/testsuite/test_t_rast_univar.py (from rev 74225, grass/trunk/temporal/t.rast.univar/testsuite/test_univar.py)
--- grass/trunk/temporal/t.rast.univar/testsuite/test_t_rast_univar.py	                        (rev 0)
+++ grass/trunk/temporal/t.rast.univar/testsuite/test_t_rast_univar.py	2019-03-12 22:22:35 UTC (rev 74226)
@@ -0,0 +1,155 @@
+"""Test t.rast.univar
+for details.
+class TestRasterUnivar(TestCase):
+    @classmethod
+        cls.runModule("g.region",  s=0,  n=80,  w=0,  e=120,  b=0,  t=50,  res=1,  res3=1)
+        cls.runModule("r.mapcalc", expression="a_1 = 100",  overwrite=True)
+        cls.runModule("r.mapcalc", expression="a_2 = 200",  overwrite=True)
+        cls.runModule("r.mapcalc", expression="a_3 = 300",  overwrite=True)
+        cls.runModule("r.mapcalc", expression="a_4 = 400",  overwrite=True)
+                                 output="A",  title="A test",  description="A test",
+                                 overwrite=True)
+        cls.runModule("t.register",  flags="i",  type="raster",  input="A",
+                                     maps="a_1,a_2,a_3,a_4",  start="2001-01-01",
+                                     increment="3 months",  overwrite=True)
+    @classmethod
+        cls.runModule("t.remove",  flags="rf",  type="strds",
+                                   inputs="A")
+    def test_1(self):
+        t_rast_univar = SimpleModule("t.rast.univar", input="A",
+                                                      where="start_time >= '2001-01-01'",
+                                                      overwrite=True, verbose=True)
+        self.runModule("g.region", res=1)
+        self.assertModule(t_rast_univar)
+        univar_text="""id|start|end|mean|min|max|mean_of_abs|stddev|variance|coeff_var|sum|null_cells|cells|non_null_cells
+a_1 at testing|2001-01-01 00:00:00|2001-04-01 00:00:00|100|100|100|100|0|0|0|960000|0|9600|9600
+a_2 at testing|2001-04-01 00:00:00|2001-07-01 00:00:00|200|200|200|200|0|0|0|1920000|0|9600|9600
+a_3 at testing|2001-07-01 00:00:00|2001-10-01 00:00:00|300|300|300|300|0|0|0|2880000|0|9600|9600
+a_4 at testing|2001-10-01 00:00:00|2002-01-01 00:00:00|400|400|400|400|0|0|0|3840000|0|9600|9600
+        for ref, res in zip(univar_text.split("\n"), t_rast_univar.outputs.stdout.split("\n")):
+            if ref and res:
+                ref_line = ref.split("|", 1)[1]
+                res_line = res.split("|", 1)[1]
+                self.assertLooksLike(ref_line,  res_line)
+    def test_2(self):
+                                                      where="start_time >= '2001-03-01'",
+            if ref and res:
+    def test_3(self):
+        self.runModule("g.region", res=10)
+a_2 at testing|2001-04-01 00:00:00|2001-07-01 00:00:00|200|200|200|200|0|0|0|19200|0|96|96
+a_3 at testing|2001-07-01 00:00:00|2001-10-01 00:00:00|300|300|300|300|0|0|0|28800|0|96|96
+a_4 at testing|2001-10-01 00:00:00|2002-01-01 00:00:00|400|400|400|400|0|0|0|38400|0|96|96
+            if ref and res:
+    def test_4(self):
+        self.assertModule("t.rast.univar", input="A", flags="r",
+                                           output="univar_output.txt",
+        univar_output = open("univar_output.txt", "r").read()
+        for ref, res in zip(univar_text.split("\n"), univar_output.split("\n")):
+            if ref and res:
+    def test_5(self):
+        self.assertModule("t.rast.univar", input="A", flags="ru",
+        univar_text="""a_2 at testing|2001-04-01 00:00:00|2001-07-01 00:00:00|200|200|200|200|0|0|0|1920000|0|9600|9600
+            if ref and res:
+    def test_6_error_handling_empty_strds(self):
+        # Empty strds
+        self.assertModuleFail("t.rast.univar", input="A",
+                                           where="start_time >= '2015-03-01'",
+    def test_7_error_handling_no_input(self):
+        # No input
+        self.assertModuleFail("t.rast.univar",  output="out.txt")
+    test()
Deleted: grass/trunk/temporal/t.rast.univar/testsuite/test_univar.py
--- grass/trunk/temporal/t.rast.univar/testsuite/test_univar.py	2019-03-12 21:48:48 UTC (rev 74225)
+++ grass/trunk/temporal/t.rast.univar/testsuite/test_univar.py	2019-03-12 22:22:35 UTC (rev 74226)
@@ -1,155 +0,0 @@
-"""Test t.rast.univar
-for details.
-class TestRasterUnivar(TestCase):
-    @classmethod
-        cls.runModule("g.region",  s=0,  n=80,  w=0,  e=120,  b=0,  t=50,  res=1,  res3=1)
-        cls.runModule("r.mapcalc", expression="a_1 = 100",  overwrite=True)
-        cls.runModule("r.mapcalc", expression="a_2 = 200",  overwrite=True)
-        cls.runModule("r.mapcalc", expression="a_3 = 300",  overwrite=True)
-        cls.runModule("r.mapcalc", expression="a_4 = 400",  overwrite=True)
-                                 output="A",  title="A test",  description="A test",
-                                 overwrite=True)
-        cls.runModule("t.register",  flags="i",  type="raster",  input="A",
-                                     maps="a_1,a_2,a_3,a_4",  start="2001-01-01",
-                                     increment="3 months",  overwrite=True)
-    @classmethod
-        cls.runModule("t.remove",  flags="rf",  type="strds",
-                                   inputs="A")
-    def test_1(self):
-        t_rast_univar = SimpleModule("t.rast.univar", input="A",
-                                                      where="start_time >= '2001-01-01'",
-                                                      overwrite=True, verbose=True)
-        self.runModule("g.region", res=1)
-        self.assertModule(t_rast_univar)
-        univar_text="""id|start|end|mean|min|max|mean_of_abs|stddev|variance|coeff_var|sum|null_cells|cells|non_null_cells
-a_1 at testing|2001-01-01 00:00:00|2001-04-01 00:00:00|100|100|100|100|0|0|0|960000|0|9600|9600
-a_2 at testing|2001-04-01 00:00:00|2001-07-01 00:00:00|200|200|200|200|0|0|0|1920000|0|9600|9600
-a_3 at testing|2001-07-01 00:00:00|2001-10-01 00:00:00|300|300|300|300|0|0|0|2880000|0|9600|9600
-a_4 at testing|2001-10-01 00:00:00|2002-01-01 00:00:00|400|400|400|400|0|0|0|3840000|0|9600|9600
-        for ref, res in zip(univar_text.split("\n"), t_rast_univar.outputs.stdout.split("\n")):
-            if ref and res:
-                ref_line = ref.split("|", 1)[1]
-                res_line = res.split("|", 1)[1]
-                self.assertLooksLike(ref_line,  res_line)
-    def test_2(self):
-                                                      where="start_time >= '2001-03-01'",
-            if ref and res:
-    def test_3(self):
-        self.runModule("g.region", res=10)
-a_2 at testing|2001-04-01 00:00:00|2001-07-01 00:00:00|200|200|200|200|0|0|0|19200|0|96|96
-a_3 at testing|2001-07-01 00:00:00|2001-10-01 00:00:00|300|300|300|300|0|0|0|28800|0|96|96
-a_4 at testing|2001-10-01 00:00:00|2002-01-01 00:00:00|400|400|400|400|0|0|0|38400|0|96|96
-            if ref and res:
-    def test_4(self):
-        self.assertModule("t.rast.univar", input="A", flags="r",
-                                           output="univar_output.txt",
-        univar_output = open("univar_output.txt", "r").read()
-        for ref, res in zip(univar_text.split("\n"), univar_output.split("\n")):
-            if ref and res:
-    def test_5(self):
-        self.assertModule("t.rast.univar", input="A", flags="ru",
-        univar_text="""a_2 at testing|2001-04-01 00:00:00|2001-07-01 00:00:00|200|200|200|200|0|0|0|1920000|0|9600|9600
-            if ref and res:
-    def test_6_error_handling_empty_strds(self):
-        # Empty strds
-        self.assertModuleFail("t.rast.univar", input="A",
-                                           where="start_time >= '2015-03-01'",
-    def test_7_error_handling_no_input(self):
-        # No input
-        self.assertModuleFail("t.rast.univar",  output="out.txt")
-    test()
Deleted: grass/trunk/temporal/t.rast3d.extract/testsuite/test_extract.py
--- grass/trunk/temporal/t.rast3d.extract/testsuite/test_extract.py	2019-03-12 21:48:48 UTC (rev 74225)
+++ grass/trunk/temporal/t.rast3d.extract/testsuite/test_extract.py	2019-03-12 22:22:35 UTC (rev 74226)
@@ -1,163 +0,0 @@
-"""Test t.rast3d.extract
-for details.
-:authors: Soeren Gebbert
-import subprocess
-class TestRaster3dExtraction(TestCase):
-    @classmethod
-    @classmethod
-    def setUp(self):
-        self.runModule("r3.mapcalc", expression="a1 = 100",  overwrite=True)
-        self.runModule("r3.mapcalc", expression="a2 = 200",  overwrite=True)
-        self.runModule("r3.mapcalc", expression="a3 = 300",  overwrite=True)
-        self.runModule("r3.mapcalc", expression="a4 = 400",  overwrite=True)
-        self.runModule("r3.mapcalc", expression="a5 = 500",  overwrite=True)
-        self.runModule("r3.mapcalc", expression="a6 = 600",  overwrite=True)
-        self.runModule("t.create",  type="str3ds",  temporaltype="absolute",
-                                     output="A",  title="A test",  description="A test",  overwrite=True)
-        self.runModule("t.register",  flags="i",  type="raster_3d",  input="A",
-                                     maps="a1,a2,a3,a4,a5,a6",
-        self.runModule("t.remove",  flags="rf",  type="str3ds",
-                                   inputs="A,B")
-        self.assertModule("t.rast3d.extract",  input="A",  output="B",
-        #self.assertModule("t.info",  flags="g",  input="B")
-        map_time=interval
-        number_of_maps=4
-        min_min=300.0
-        min_max=600.0
-        max_min=300.0
-        max_max=600.0"""
-        info = SimpleModule("t.info", flags="g",  type="str3ds", input="B")
-        """Perform a selection by datetime and a r3.mapcalc expression"""
-                                      expression=" if(A > 400, A, null())",
-                                      basename="b",  nprocs=2,  overwrite=True)
-        map_time=interval
-        number_of_maps=2
-        min_min=500.0
-        min_max=600.0
-        max_min=500.0
-        max_max=600.0"""
-        """Perform r3.mapcalc expression and register empty maps"""
-        self.assertModule("t.rast3d.extract",  flags="n",  input="A",  output="B",
-        map_time=interval
-        number_of_maps=6
-        min_min=500.0
-        min_max=600.0
-        max_min=500.0
-        max_max=600.0"""
-        self.assertModule("t.rast3d.extract",  flags="n",  input="A", nprocs=2,
-                          output="B", basename="b", overwrite=True,
-                          suffix="time", expression="if(A > 400, A, null())")
-        self.assertRaster3dExists('b_2001_01_01T00_00_00')
-        self.assertRaster3dDoesNotExist('b_2001_01')
-                          suffix='num%03', expression="if(A > 400, A, null())")
-        self.assertRaster3dExists('b_001')
-        self.assertRaster3dDoesNotExist('b_00001')
-class TestRaster3dExtractionFails(TestCase):
-    @classmethod
-    @classmethod
-        # No input
-        self.assertModuleFail("t.rast3d.extract",  output="B", basename="b")
-        # No output
-        self.assertModuleFail("t.rast3d.extract",  input="A",  basename="b")
-        # No basename
-        self.assertModuleFail("t.rast3d.extract",  input="A",  output="B",
-                          expression=" if(A > 400, A, null())")
-    test()
Copied: grass/trunk/temporal/t.rast3d.extract/testsuite/test_t_rast3d_extract.py (from rev 74225, grass/trunk/temporal/t.rast3d.extract/testsuite/test_extract.py)
--- grass/trunk/temporal/t.rast3d.extract/testsuite/test_t_rast3d_extract.py	                        (rev 0)
+++ grass/trunk/temporal/t.rast3d.extract/testsuite/test_t_rast3d_extract.py	2019-03-12 22:22:35 UTC (rev 74226)
@@ -0,0 +1,163 @@
+"""Test t.rast3d.extract
+for details.
+:authors: Soeren Gebbert
+import subprocess
+class TestRaster3dExtraction(TestCase):
+    @classmethod
+    @classmethod
+    def setUp(self):
+        self.runModule("r3.mapcalc", expression="a1 = 100",  overwrite=True)
+        self.runModule("r3.mapcalc", expression="a2 = 200",  overwrite=True)
+        self.runModule("r3.mapcalc", expression="a3 = 300",  overwrite=True)
+        self.runModule("r3.mapcalc", expression="a4 = 400",  overwrite=True)
+        self.runModule("r3.mapcalc", expression="a5 = 500",  overwrite=True)
+        self.runModule("r3.mapcalc", expression="a6 = 600",  overwrite=True)
+        self.runModule("t.create",  type="str3ds",  temporaltype="absolute",
+                                     output="A",  title="A test",  description="A test",  overwrite=True)
+        self.runModule("t.register",  flags="i",  type="raster_3d",  input="A",
+                                     maps="a1,a2,a3,a4,a5,a6",
+        self.runModule("t.remove",  flags="rf",  type="str3ds",
+                                   inputs="A,B")
+        self.assertModule("t.rast3d.extract",  input="A",  output="B",
+        #self.assertModule("t.info",  flags="g",  input="B")
+        map_time=interval
+        number_of_maps=4
+        min_min=300.0
+        min_max=600.0
+        max_min=300.0
+        max_max=600.0"""
+        info = SimpleModule("t.info", flags="g",  type="str3ds", input="B")
+        """Perform a selection by datetime and a r3.mapcalc expression"""
+                                      expression=" if(A > 400, A, null())",
+                                      basename="b",  nprocs=2,  overwrite=True)
+        map_time=interval
+        number_of_maps=2
+        min_min=500.0
+        min_max=600.0
+        max_min=500.0
+        max_max=600.0"""
+        """Perform r3.mapcalc expression and register empty maps"""
+        self.assertModule("t.rast3d.extract",  flags="n",  input="A",  output="B",
+        map_time=interval
+        number_of_maps=6
+        min_min=500.0
+        min_max=600.0
+        max_min=500.0
+        max_max=600.0"""
+        self.assertModule("t.rast3d.extract",  flags="n",  input="A", nprocs=2,
+                          output="B", basename="b", overwrite=True,
+                          suffix="time", expression="if(A > 400, A, null())")
+        self.assertRaster3dExists('b_2001_01_01T00_00_00')
+        self.assertRaster3dDoesNotExist('b_2001_01')
+                          suffix='num%03', expression="if(A > 400, A, null())")
+        self.assertRaster3dExists('b_001')
+        self.assertRaster3dDoesNotExist('b_00001')
+class TestRaster3dExtractionFails(TestCase):
+    @classmethod
+    @classmethod
+        # No input
+        self.assertModuleFail("t.rast3d.extract",  output="B", basename="b")
+        # No output
+        self.assertModuleFail("t.rast3d.extract",  input="A",  basename="b")
+        # No basename
+        self.assertModuleFail("t.rast3d.extract",  input="A",  output="B",
+                          expression=" if(A > 400, A, null())")
+    test()
Copied: grass/trunk/temporal/t.rast3d.univar/testsuite/test_t_rast3d_univar.py (from rev 74225, grass/trunk/temporal/t.rast3d.univar/testsuite/test_univar.py)
--- grass/trunk/temporal/t.rast3d.univar/testsuite/test_t_rast3d_univar.py	                        (rev 0)
+++ grass/trunk/temporal/t.rast3d.univar/testsuite/test_t_rast3d_univar.py	2019-03-12 22:22:35 UTC (rev 74226)
@@ -0,0 +1,133 @@
+for details.
+    @classmethod
+        cls.runModule("r3.mapcalc", expression="a_1 = 100",  overwrite=True)
+        cls.runModule("r3.mapcalc", expression="a_2 = 200",  overwrite=True)
+        cls.runModule("r3.mapcalc", expression="a_3 = 300",  overwrite=True)
+        cls.runModule("r3.mapcalc", expression="a_4 = 400",  overwrite=True)
+        cls.runModule("t.create",  type="str3ds",  temporaltype="absolute",
+                                   overwrite=True)
+        cls.runModule("t.register",  flags="i",  type="raster_3d",  input="A",
+    @classmethod
+        cls.runModule("t.remove",  flags="rf",  type="str3ds",
+                                   inputs="A")
+    def test_1(self):
+        t_rast3d_univar = SimpleModule("t.rast3d.univar", input="A",
+        self.assertModule(t_rast3d_univar)
+a_1 at testing|2001-01-01 00:00:00|2001-04-01 00:00:00|100|100|100|100|0|0|0|48000000|0|480000|480000
+a_2 at testing|2001-04-01 00:00:00|2001-07-01 00:00:00|200|200|200|200|0|0|0|96000000|0|480000|480000
+a_3 at testing|2001-07-01 00:00:00|2001-10-01 00:00:00|300|300|300|300|0|0|0|144000000|0|480000|480000
+a_4 at testing|2001-10-01 00:00:00|2002-01-01 00:00:00|400|400|400|400|0|0|0|192000000|0|480000|480000
+        for ref, res in zip(univar_text.split("\n"), t_rast3d_univar.outputs.stdout.split("\n")):
+            if ref and res:
+    def test_2(self):
+            if ref and res:
+    def test_3(self):
+        self.assertModule("t.rast3d.univar", input="A",
+            if ref and res:
+    def test_4(self):
+                                             output="univar_output.txt", flags="s",
+        univar_text="""a_2 at testing|2001-04-01 00:00:00|2001-07-01 00:00:00|200|200|200|200|0|0|0|96000000|0|480000|480000
+            if ref and res:
+    def test_5_error_handling_empty_strds(self):
+        # Empty str3ds
+        self.assertModuleFail("t.rast3d.univar", input="A",
+    def test_6_error_handling_no_input(self):
+        # No input
+        self.assertModuleFail("t.rast3d.univar",  output="out.txt")
+    test()
Deleted: grass/trunk/temporal/t.rast3d.univar/testsuite/test_univar.py
--- grass/trunk/temporal/t.rast3d.univar/testsuite/test_univar.py	2019-03-12 21:48:48 UTC (rev 74225)
+++ grass/trunk/temporal/t.rast3d.univar/testsuite/test_univar.py	2019-03-12 22:22:35 UTC (rev 74226)
@@ -1,133 +0,0 @@
-for details.
-    @classmethod
-        cls.runModule("r3.mapcalc", expression="a_1 = 100",  overwrite=True)
-        cls.runModule("r3.mapcalc", expression="a_2 = 200",  overwrite=True)
-        cls.runModule("r3.mapcalc", expression="a_3 = 300",  overwrite=True)
-        cls.runModule("r3.mapcalc", expression="a_4 = 400",  overwrite=True)
-        cls.runModule("t.create",  type="str3ds",  temporaltype="absolute",
-                                   overwrite=True)
-        cls.runModule("t.register",  flags="i",  type="raster_3d",  input="A",
-    @classmethod
-        cls.runModule("t.remove",  flags="rf",  type="str3ds",
-                                   inputs="A")
-    def test_1(self):
-        t_rast3d_univar = SimpleModule("t.rast3d.univar", input="A",
-        self.assertModule(t_rast3d_univar)
-a_1 at testing|2001-01-01 00:00:00|2001-04-01 00:00:00|100|100|100|100|0|0|0|48000000|0|480000|480000
-a_2 at testing|2001-04-01 00:00:00|2001-07-01 00:00:00|200|200|200|200|0|0|0|96000000|0|480000|480000
-a_3 at testing|2001-07-01 00:00:00|2001-10-01 00:00:00|300|300|300|300|0|0|0|144000000|0|480000|480000
-a_4 at testing|2001-10-01 00:00:00|2002-01-01 00:00:00|400|400|400|400|0|0|0|192000000|0|480000|480000
-        for ref, res in zip(univar_text.split("\n"), t_rast3d_univar.outputs.stdout.split("\n")):
-            if ref and res:
-    def test_2(self):
-            if ref and res:
-    def test_3(self):
-        self.assertModule("t.rast3d.univar", input="A",
-            if ref and res:
-    def test_4(self):
-                                             output="univar_output.txt", flags="s",
-        univar_text="""a_2 at testing|2001-04-01 00:00:00|2001-07-01 00:00:00|200|200|200|200|0|0|0|96000000|0|480000|480000
-            if ref and res:
-    def test_5_error_handling_empty_strds(self):
-        # Empty str3ds
-        self.assertModuleFail("t.rast3d.univar", input="A",
-    def test_6_error_handling_no_input(self):
-        # No input
-        self.assertModuleFail("t.rast3d.univar",  output="out.txt")
-    test()
Deleted: grass/trunk/vector/v.extract/testsuite/test_extract.py
--- grass/trunk/vector/v.extract/testsuite/test_extract.py	2019-03-12 21:48:48 UTC (rev 74225)
+++ grass/trunk/vector/v.extract/testsuite/test_extract.py	2019-03-12 22:22:35 UTC (rev 74226)
@@ -1,94 +0,0 @@
-Name:       v.extract test
-Purpose:    Tests v.extract and its flags/options.
-Author:     Sunveer Singh, Google Code-in 2017
-Copyright:  (C) 2017 by Sunveer Singh and the GRASS Development Team
-Licence:    This program is free software under the GNU General Public
-	            License (>=v2). Read the file COPYING that comes with GRASS
-	            for details.
-import os
-from grass.script.core import read_command
-TABLE_1="""cat|MAJORRDS_|ROAD_NAME|MULTILANE|PROPYEAR|OBJECTID|SHAPE_LEN
-1|1|NC-50|no|0|1|4825.369405
-2|2|NC-50|no|0|2|14392.589058
-3|3|NC-98|no|0|3|3212.981242
-4|4|NC-50|no|0|4|13391.907552
-TABLE_2="""cat|onemap_pro|PERIMETER|GEOL250_|GEOL250_ID|GEO_NAME|SHAPE_area|SHAPE_len
-1|963738.75|4083.97998|2|1|Zml|963738.608571|4083.979839
-2|22189124|26628.261719|3|2|Zmf|22189123.2296|26628.261112
-3|579286.875|3335.55835|4|3|Zml|579286.829631|3335.557182
-4|20225526|33253|5|4|Zml|20225526.6368|33253.000508
-5|450650720|181803.765625|6|5|Ybgg|450650731.029|181803.776199
-TABLE_3="""cat|MAJORRDS_|ROAD_NAME|MULTILANE|PROPYEAR|OBJECTID|SHAPE_LEN
-5|5|NC-98|no|0|5|7196.001495
-6|6||no|0|6|10185.513951
-7|7|US-1|yes|0|7|13655.438596
-8|8||no|0|8|797.901095
-9|9|NC-98|no|0|9|14772.176241
-class TestRasterreport(TestCase):
-    input="roadsmajor"
-    output="testoutput"
-    geology='geology'
-    @classmethod
-    @classmethod
-    def tearDown(cls):
-        cls.runModule('g.remove', flags='f', type='vector', name=cls.output)
-    def test_flagd(self):
-        """Testing flag d """
-        self.assertModule('v.extract', input=self.input, output=self.output, cats="1,2,3,4")
-        category = read_command('v.db.select', map=self.output,
-	                        separator='pipe')
-        self.assertEqual(first=TABLE_1.replace('\n', os.linesep),
-	                         second=category,
-	                         msg="Attribute table has wrong entries")
-    def test_cats2(self):
-        """Testing cats=2 """
-        self.assertModule('v.extract', input=self.geology, output=self.output, flags='d', cats="1,2,3,4,5")
-	                        separator='pipe')
-        self.assertEqual(first=TABLE_2.replace('\n', os.linesep),
-	                         second=category,
-    def test_flagt(self):
-        """Testing Falg T"""
-        self.assertModule('v.extract', input=self.input, output=self.output, flags='t', cats=1 )
-    def test_flatr(self):
-        """Testing flag r """
-        self.assertModule('v.extract', input=self.geology, output=self.output, flags='r', cats=1 )
-    def  test_where(self):
-        """Testing where"""
-        self.assertModule('v.extract', input=self.input, output=self.output, flags='d',
-                            where="cat < 10")
-	                        separator='pipe')
-        self.assertEqual(first=TABLE_3.replace('\n', os.linesep),
-	                         second=category,
-    test()
Copied: grass/trunk/vector/v.extract/testsuite/test_v_extract.py (from rev 74225, grass/trunk/vector/v.extract/testsuite/test_extract.py)
--- grass/trunk/vector/v.extract/testsuite/test_v_extract.py	                        (rev 0)
+++ grass/trunk/vector/v.extract/testsuite/test_v_extract.py	2019-03-12 22:22:35 UTC (rev 74226)
@@ -0,0 +1,94 @@
+Name:       v.extract test
+Purpose:    Tests v.extract and its flags/options.
+Author:     Sunveer Singh, Google Code-in 2017
+Copyright:  (C) 2017 by Sunveer Singh and the GRASS Development Team
+Licence:    This program is free software under the GNU General Public
+	            License (>=v2). Read the file COPYING that comes with GRASS
+	            for details.
+import os
+from grass.script.core import read_command
+TABLE_1="""cat|MAJORRDS_|ROAD_NAME|MULTILANE|PROPYEAR|OBJECTID|SHAPE_LEN
+1|1|NC-50|no|0|1|4825.369405
+2|2|NC-50|no|0|2|14392.589058
+3|3|NC-98|no|0|3|3212.981242
+4|4|NC-50|no|0|4|13391.907552
+TABLE_2="""cat|onemap_pro|PERIMETER|GEOL250_|GEOL250_ID|GEO_NAME|SHAPE_area|SHAPE_len
+1|963738.75|4083.97998|2|1|Zml|963738.608571|4083.979839
+2|22189124|26628.261719|3|2|Zmf|22189123.2296|26628.261112
+3|579286.875|3335.55835|4|3|Zml|579286.829631|3335.557182
+4|20225526|33253|5|4|Zml|20225526.6368|33253.000508
+5|450650720|181803.765625|6|5|Ybgg|450650731.029|181803.776199
+TABLE_3="""cat|MAJORRDS_|ROAD_NAME|MULTILANE|PROPYEAR|OBJECTID|SHAPE_LEN
+5|5|NC-98|no|0|5|7196.001495
+6|6||no|0|6|10185.513951
+7|7|US-1|yes|0|7|13655.438596
+8|8||no|0|8|797.901095
+9|9|NC-98|no|0|9|14772.176241
+class TestRasterreport(TestCase):
+    input="roadsmajor"
+    output="testoutput"
+    geology='geology'
+    @classmethod
+    @classmethod
+    def tearDown(cls):
+        cls.runModule('g.remove', flags='f', type='vector', name=cls.output)
+    def test_flagd(self):
+        """Testing flag d """
+        self.assertModule('v.extract', input=self.input, output=self.output, cats="1,2,3,4")
+        category = read_command('v.db.select', map=self.output,
+	                        separator='pipe')
+        self.assertEqual(first=TABLE_1.replace('\n', os.linesep),
+	                         second=category,
+	                         msg="Attribute table has wrong entries")
+    def test_cats2(self):
+        """Testing cats=2 """
+        self.assertModule('v.extract', input=self.geology, output=self.output, flags='d', cats="1,2,3,4,5")
+	                        separator='pipe')
+        self.assertEqual(first=TABLE_2.replace('\n', os.linesep),
+	                         second=category,
+    def test_flagt(self):
+        """Testing Falg T"""
+        self.assertModule('v.extract', input=self.input, output=self.output, flags='t', cats=1 )
+    def test_flatr(self):
+        """Testing flag r """
+        self.assertModule('v.extract', input=self.geology, output=self.output, flags='r', cats=1 )
+    def  test_where(self):
+        """Testing where"""
+        self.assertModule('v.extract', input=self.input, output=self.output, flags='d',
+                            where="cat < 10")
+	                        separator='pipe')
+        self.assertEqual(first=TABLE_3.replace('\n', os.linesep),
+	                         second=category,
+if __name__ == '__main__':
+    test()
Deleted: grass/trunk/vector/v.in.lidar/testsuite/basic_test.py
--- grass/trunk/vector/v.in.lidar/testsuite/basic_test.py	2019-03-12 21:48:48 UTC (rev 74225)
+++ grass/trunk/vector/v.in.lidar/testsuite/basic_test.py	2019-03-12 22:22:35 UTC (rev 74226)
@@ -1,68 +0,0 @@
-Name:      decimation_test
-Purpose:   v.in.lidar decimation test
-Author:    Vaclav Petras
-Copyright: (C) 2015 by Vaclav Petras and the GRASS Development Team
-           for details.
-import os
-class BasicTest(TestCase):
-    """Test case for watershed module
-    This tests expects v.random and v.out.lidar to work properly.
-    # Setup variables to be used for outputs
-    vector_points = 'vinlidar_basic_original'
-    imported_points = 'vinlidar_basic_imported'
-    las_file = 'vinlidar_basic_points.las'
-    npoints = 300
-    @classmethod
-        """Ensures expected computational region and generated data"""
-        cls.runModule('g.region', n=20, s=10, e=25, w=15, res=1)
-        cls.runModule('v.random', flags='zb', output=cls.vector_points,
-            npoints=cls.npoints, zmin=200, zmax=500, seed=100)
-        cls.runModule('v.out.lidar', input=cls.vector_points,
-            output=cls.las_file)
-    @classmethod
-        """Remove the temporary region and generated data"""
-            name=cls.vector_points)
-        if os.path.isfile(cls.las_file):
-            os.remove(cls.las_file)
-        """Remove the outputs created by the import
-        This is executed after each test run.
-        self.runModule('g.remove', flags='f', type='vector',
-            name=self.imported_points)
-    def test_output_identical(self):
-        """Test to see if the standard outputs are created"""
-        self.assertModule('v.in.lidar', input=self.las_file,
-            output=self.imported_points, flags='bt')
-        self.assertVectorExists(self.imported_points)
-        self.assertVectorEqualsVector(
-            actual=self.imported_points,
-            reference=self.vector_points,
-            digits=2, precision=.01)
-if __name__ == '__main__':
-    test()
Deleted: grass/trunk/vector/v.in.lidar/testsuite/filter_test.py
--- grass/trunk/vector/v.in.lidar/testsuite/filter_test.py	2019-03-12 21:48:48 UTC (rev 74225)
+++ grass/trunk/vector/v.in.lidar/testsuite/filter_test.py	2019-03-12 22:22:35 UTC (rev 74226)
@@ -1,208 +0,0 @@
-           for details.
-import os
-POINTS = """\
-17.46938776,18.67346939,143,1,1,2
-20.93877551,17.44897959,125,1,1,2
-18.89795918,14.18367347,130,1,1,3
-15.91836735,10.67346939,126,1,1,3
-21.26530612,11.04081633,128,1,2,3
-22.24489796,13.89795918,123,2,2,3
-23.79591837,17.12244898,151,1,2,3
-17.2244898,16.34693878,124,2,2,4
-17.14285714,14.10204082,134,1,3,4
-19.87755102,11.81632653,146,2,3,4
-18.48979592,11.48979592,140.6,2,3,4
-21.26530612,15.73469388,147,3,3,5
-21.18367347,19.32653061,138,1,3,5
-23.91836735,18.83673469,144,2,3,5
-23.51020408,13.65306122,143,3,3,5
-23.55102041,11.32653061,123,1,4,5
-18.41009273,14.51618034,140.4,2,4,5
-22.13996161,17.2278263,147,3,4,5
-21.41013052,11.05432488,132,4,4,5
-class FilterTest(TestCase):
-    """Test case for filter and selection options
-    vector_points = 'vinlidar_filters_original'
-    imported_points = 'vinlidar_filters_imported'
-    las_file = 'vinlidar_filters_points.las'
-    npoints = 300
-    @classmethod
-        cls.runModule('v.in.ascii', input='-', stdin_=POINTS,
-                      flags='z', z=3, cat=0, separator='comma',
-                      output=cls.vector_points,
-                      columns="x double precision, y double precision,"
-                              " z double precision, return_n integer,"
-                              " n_returns integer, class_n integer")
-                      input=cls.vector_points, layer=1,
-                      output=cls.las_file,
-                      return_column='return_n',
-                      n_returns_column='n_returns',
-                      class_column='class_n')
-    @classmethod
-    def test_no_filter(self):
-        This shows if the inpute data are as expected.
-        self.assertVectorFitsTopoInfo(
-            vector=self.imported_points,
-            reference=dict(points=19))
-    def return_filter(self, name, npoints):
-        """Mid return filter test"""
-            output=self.imported_points, flags='bt',
-            return_filter=name)
-            reference=dict(points=npoints))
-    def test_first_return_filter(self):
-        """First return filter test"""
-        self.return_filter('first', 9)
-    def test_mid_return_filter(self):
-        self.return_filter('mid', 5)
-    def test_last_return_filter(self):
-        """Last return filter test"""
-        self.return_filter('last', 5)
-    def class_filter(self, class_n, npoints):
-        """Actual code for testing class filter"""
-            class_filter=class_n)
-    def test_class_2_filter(self):
-        """Test to filter classes"""
-        self.class_filter(2, 2)
-    def test_class_3_filter(self):
-        self.class_filter(3, 5)
-    def test_class_4_filter(self):
-        self.class_filter(4, 4)
-    def test_class_5_filter(self):
-        self.class_filter(5, 8)
-    def return_and_class_filter(self, return_name, class_n, npoints):
-        """Return and class filter combined test code"""
-            return_filter=return_name, class_filter=class_n)
-    def test_first_return_and_class_filter(self):
-        """Combined test for return and class"""
-        self.return_and_class_filter('first', 2, 2)
-    def test_last_return_and_class_filter(self):
-        self.return_and_class_filter('last', 5, 3)
-    def zrange_filter(self, zrange, npoints):
-        """Actual code for zrange option test"""
-            zrange=zrange)
-    def test_zrange_filter(self):
-        """Test zrange option"""
-        self.zrange_filter((130.1, 139.9), 3)
-    def test_non_int_zrange_filter(self):
-        """Test zrange option with float number
-        One test point has z right under and one other right above the min.
-        self.zrange_filter((140.5, 900), 8)
-    def test_zrange_and_class_filter(self):
-        """zrange and class_filter option combined test"""
-            zrange=(141, 900), class_filter=5)
-            reference=dict(points=4))
-    def test_zrange_and_return_filter(self):
-            zrange=(141, 900), return_filter='last')
-            reference=dict(points=2))
-    test()
Copied: grass/trunk/vector/v.in.lidar/testsuite/test_v_in_lidar_basic.py (from rev 74225, grass/trunk/vector/v.in.lidar/testsuite/basic_test.py)
--- grass/trunk/vector/v.in.lidar/testsuite/test_v_in_lidar_basic.py	                        (rev 0)
+++ grass/trunk/vector/v.in.lidar/testsuite/test_v_in_lidar_basic.py	2019-03-12 22:22:35 UTC (rev 74226)
@@ -0,0 +1,68 @@
+Name:      decimation_test
+Purpose:   v.in.lidar decimation test
+Author:    Vaclav Petras
+Copyright: (C) 2015 by Vaclav Petras and the GRASS Development Team
+           for details.
+import os
+class BasicTest(TestCase):
+    """Test case for watershed module
+    This tests expects v.random and v.out.lidar to work properly.
+    # Setup variables to be used for outputs
+    vector_points = 'vinlidar_basic_original'
+    imported_points = 'vinlidar_basic_imported'
+    las_file = 'vinlidar_basic_points.las'
+    npoints = 300
+    @classmethod
+        """Ensures expected computational region and generated data"""
+        cls.runModule('g.region', n=20, s=10, e=25, w=15, res=1)
+        cls.runModule('v.random', flags='zb', output=cls.vector_points,
+            npoints=cls.npoints, zmin=200, zmax=500, seed=100)
+        cls.runModule('v.out.lidar', input=cls.vector_points,
+            output=cls.las_file)
+    @classmethod
+        """Remove the temporary region and generated data"""
+            name=cls.vector_points)
+        if os.path.isfile(cls.las_file):
+            os.remove(cls.las_file)
+        """Remove the outputs created by the import
+        This is executed after each test run.
+        self.runModule('g.remove', flags='f', type='vector',
+            name=self.imported_points)
+    def test_output_identical(self):
+        """Test to see if the standard outputs are created"""
+        self.assertModule('v.in.lidar', input=self.las_file,
+            output=self.imported_points, flags='bt')
+        self.assertVectorExists(self.imported_points)
+        self.assertVectorEqualsVector(
+            actual=self.imported_points,
+            reference=self.vector_points,
+            digits=2, precision=.01)
+    test()
Copied: grass/trunk/vector/v.in.lidar/testsuite/test_v_in_lidar_filter.py (from rev 74225, grass/trunk/vector/v.in.lidar/testsuite/filter_test.py)
--- grass/trunk/vector/v.in.lidar/testsuite/test_v_in_lidar_filter.py	                        (rev 0)
+++ grass/trunk/vector/v.in.lidar/testsuite/test_v_in_lidar_filter.py	2019-03-12 22:22:35 UTC (rev 74226)
@@ -0,0 +1,208 @@
+           for details.
+import os
+POINTS = """\
+17.46938776,18.67346939,143,1,1,2
+20.93877551,17.44897959,125,1,1,2
+18.89795918,14.18367347,130,1,1,3
+15.91836735,10.67346939,126,1,1,3
+21.26530612,11.04081633,128,1,2,3
+22.24489796,13.89795918,123,2,2,3
+23.79591837,17.12244898,151,1,2,3
+17.2244898,16.34693878,124,2,2,4
+17.14285714,14.10204082,134,1,3,4
+19.87755102,11.81632653,146,2,3,4
+18.48979592,11.48979592,140.6,2,3,4
+21.26530612,15.73469388,147,3,3,5
+21.18367347,19.32653061,138,1,3,5
+23.91836735,18.83673469,144,2,3,5
+23.51020408,13.65306122,143,3,3,5
+23.55102041,11.32653061,123,1,4,5
+18.41009273,14.51618034,140.4,2,4,5
+22.13996161,17.2278263,147,3,4,5
+21.41013052,11.05432488,132,4,4,5
+class FilterTest(TestCase):
+    """Test case for filter and selection options
+    vector_points = 'vinlidar_filters_original'
+    imported_points = 'vinlidar_filters_imported'
+    las_file = 'vinlidar_filters_points.las'
+    npoints = 300
+    @classmethod
+    def setUpClass(cls):
+        cls.use_temp_region()
+        cls.runModule('v.in.ascii', input='-', stdin_=POINTS,
+                      flags='z', z=3, cat=0, separator='comma',
+                      output=cls.vector_points,
+                      columns="x double precision, y double precision,"
+                              " z double precision, return_n integer,"
+                              " n_returns integer, class_n integer")
+                      input=cls.vector_points, layer=1,
+                      output=cls.las_file,
+                      return_column='return_n',
+                      n_returns_column='n_returns',
+                      class_column='class_n')
+    @classmethod
+    def tearDownClass(cls):
+        cls.del_temp_region()
+    def test_no_filter(self):
+        This shows if the inpute data are as expected.
+        self.assertVectorFitsTopoInfo(
+            vector=self.imported_points,
+            reference=dict(points=19))
+    def return_filter(self, name, npoints):
+        """Mid return filter test"""
+            output=self.imported_points, flags='bt',
+            return_filter=name)
+            reference=dict(points=npoints))
+    def test_first_return_filter(self):
+        """First return filter test"""
+        self.return_filter('first', 9)
+    def test_mid_return_filter(self):
+        self.return_filter('mid', 5)
+    def test_last_return_filter(self):
+        """Last return filter test"""
+        self.return_filter('last', 5)
+    def class_filter(self, class_n, npoints):
+        """Actual code for testing class filter"""
+            class_filter=class_n)
+    def test_class_2_filter(self):
+        """Test to filter classes"""
+        self.class_filter(2, 2)
+    def test_class_3_filter(self):
+        self.class_filter(3, 5)
+    def test_class_4_filter(self):
+        self.class_filter(4, 4)
+    def test_class_5_filter(self):
+        self.class_filter(5, 8)
+    def return_and_class_filter(self, return_name, class_n, npoints):
+        """Return and class filter combined test code"""
+            return_filter=return_name, class_filter=class_n)
+    def test_first_return_and_class_filter(self):
+        """Combined test for return and class"""
+        self.return_and_class_filter('first', 2, 2)
+    def test_last_return_and_class_filter(self):
+        self.return_and_class_filter('last', 5, 3)
+    def zrange_filter(self, zrange, npoints):
+        """Actual code for zrange option test"""
+            zrange=zrange)
+    def test_zrange_filter(self):
+        """Test zrange option"""
+        self.zrange_filter((130.1, 139.9), 3)
+    def test_non_int_zrange_filter(self):
+        """Test zrange option with float number
+        One test point has z right under and one other right above the min.
+        self.zrange_filter((140.5, 900), 8)
+    def test_zrange_and_class_filter(self):
+        """zrange and class_filter option combined test"""
+            zrange=(141, 900), class_filter=5)
+            reference=dict(points=4))
+    def test_zrange_and_return_filter(self):
+            zrange=(141, 900), return_filter='last')
+            reference=dict(points=2))
+    test()
Copied: grass/trunk/vector/v.in.lidar/testsuite/test_v_in_pdal_basic.py (from rev 74225, grass/trunk/vector/v.in.pdal/testsuite/basic_test.py)
--- grass/trunk/vector/v.in.lidar/testsuite/test_v_in_pdal_basic.py	                        (rev 0)
+++ grass/trunk/vector/v.in.lidar/testsuite/test_v_in_pdal_basic.py	2019-03-12 22:22:35 UTC (rev 74226)
@@ -0,0 +1,71 @@
+Name:      basic_test
+Purpose:   v.in.pdal basic functionality test
+           for details.
+import os
+from grass.gunittest.case import TestCase
+from grass.gunittest.main import test
+    vector_generated = 'vinlidar_basic_generated'
+    npoints = 300
+    @classmethod
+        cls.runModule('v.random', flags='zb', output=cls.vector_generated,
+        cls.runModule('v.category', input=cls.vector_generated,
+            output=cls.vector_points, option='del', cat=-1)
+    @classmethod
+            name=(cls.vector_points, cls.vector_generated))
+    def test_same_data(self):
+        self.assertModule('v.in.pdal', input=self.las_file, flags='c',
+            output=self.imported_points)
+    test()
Copied: grass/trunk/vector/v.in.lidar/testsuite/test_v_in_pdal_filter.py (from rev 74225, grass/trunk/vector/v.in.pdal/testsuite/filter_test.py)
--- grass/trunk/vector/v.in.lidar/testsuite/test_v_in_pdal_filter.py	                        (rev 0)
+++ grass/trunk/vector/v.in.lidar/testsuite/test_v_in_pdal_filter.py	2019-03-12 22:22:35 UTC (rev 74226)
@@ -0,0 +1,208 @@
+Name:      filter_test
+Purpose:   v.in.pdal test if various filters and selections
+           for details.
+import os
+POINTS = """\
+    npoints = 300
+    @classmethod
+    @classmethod
+            zrange=zrange)
+    test()
Deleted: grass/trunk/vector/v.in.pdal/testsuite/basic_test.py
--- grass/trunk/vector/v.in.pdal/testsuite/basic_test.py	2019-03-12 21:48:48 UTC (rev 74225)
+++ grass/trunk/vector/v.in.pdal/testsuite/basic_test.py	2019-03-12 22:22:35 UTC (rev 74226)
@@ -1,71 +0,0 @@
-Name:      basic_test
-Purpose:   v.in.pdal basic functionality test
-           for details.
-import os
-from grass.gunittest.case import TestCase
-from grass.gunittest.main import test
-    vector_generated = 'vinlidar_basic_generated'
-    npoints = 300
-    @classmethod
-    def setUpClass(cls):
-        cls.use_temp_region()
-        cls.runModule('v.random', flags='zb', output=cls.vector_generated,
-        cls.runModule('v.category', input=cls.vector_generated,
-            output=cls.vector_points, option='del', cat=-1)
-    @classmethod
-    def tearDownClass(cls):
-            name=(cls.vector_points, cls.vector_generated))
-        cls.del_temp_region()
-    def test_same_data(self):
-        self.assertModule('v.in.pdal', input=self.las_file, flags='c',
-            output=self.imported_points)
-    test()
Deleted: grass/trunk/vector/v.in.pdal/testsuite/filter_test.py
--- grass/trunk/vector/v.in.pdal/testsuite/filter_test.py	2019-03-12 21:48:48 UTC (rev 74225)
+++ grass/trunk/vector/v.in.pdal/testsuite/filter_test.py	2019-03-12 22:22:35 UTC (rev 74226)
@@ -1,208 +0,0 @@
-Name:      filter_test
-Purpose:   v.in.pdal test if various filters and selections
-           for details.
-import os
-POINTS = """\
-    npoints = 300
-    @classmethod
-    @classmethod
-            zrange=zrange)
-    test()
