[GRASS-SVN] r74484 - grass/trunk/vector/v.in.pdal
    svn_grass at osgeo.org
    Wed May 15 14:09:54 PDT 2019
Author: wenzeslaus
Date: 2019-05-15 14:09:54 -0700 (Wed, 15 May 2019)
New Revision: 74484
   grass/trunk/vector/v.in.pdal/main.cpp
v.in.pdal: use PDAL streaming instead of PointView
The memory consumption no longer depends on the point cloud size.
Instead, it is fixed internally. Higher number of points to store
does not make it faster, so keeping it small.
What was a loop is now a lambda used as a callback in the StreamCallbackFilter
which filters and writes the vector points.
The limit on category number (GV_CAT_MAX) is enforced in the reader,
so we don't check it when reading (if cat is requested).
Modified: grass/trunk/vector/v.in.pdal/main.cpp
--- grass/trunk/vector/v.in.pdal/main.cpp	2019-05-15 21:01:46 UTC (rev 74483)
+++ grass/trunk/vector/v.in.pdal/main.cpp	2019-05-15 21:09:54 UTC (rev 74484)
@@ -15,12 +15,13 @@
 #include <pdal/PointTable.hpp>
-#include <pdal/PointView.hpp>
+#include <pdal/PointLayout.hpp>
 #include <pdal/StageFactory.hpp>
 #include <pdal/io/LasReader.hpp>
 #include <pdal/io/LasHeader.hpp>
 #include <pdal/Options.hpp>
 #include <pdal/filters/ReprojectionFilter.hpp>
+#include <pdal/filters/StreamCallbackFilter.hpp>
 extern "C"
@@ -73,7 +74,7 @@
 void pdal_point_to_grass(struct Map_info *output_vector,
                          struct line_pnts *points, struct line_cats *cats,
-                         pdal::PointViewPtr point_view, pdal::PointId idx,
+                         pdal::PointRef& point,
                          struct GLidarLayers *layers, int cat,
                          pdal::Dimension::Id dim_to_use_as_z)
@@ -81,9 +82,9 @@
     Vect_reset_cats(cats);
     using namespace pdal::Dimension;
-    double x = point_view->getFieldAs<double>(Id::X, idx);
-    double y = point_view->getFieldAs<double>(Id::Y, idx);
-    double z = point_view->getFieldAs<double>(dim_to_use_as_z, idx);
+    double x = point.getFieldAs<double>(Id::X);
+    double y = point.getFieldAs<double>(Id::Y);
+    double z = point.getFieldAs<double>(dim_to_use_as_z);
     /* TODO: optimize for case with no layers, by adding
      * and if to skip all the other ifs */
@@ -91,19 +92,19 @@
         Vect_cat_set(cats, layers->id_layer, cat);
     if (layers->return_layer) {
-        int return_n = point_view->getFieldAs<int>(Id::ReturnNumber, idx);
-        int n_returns = point_view->getFieldAs<int>(Id::NumberOfReturns, idx);
+        int return_n = point.getFieldAs<int>(Id::ReturnNumber);
+        int n_returns = point.getFieldAs<int>(Id::NumberOfReturns);
         int return_c = return_to_cat(return_n, n_returns);
         Vect_cat_set(cats, layers->return_layer, return_c);
     if (layers->class_layer) {
         Vect_cat_set(cats, layers->class_layer,
-                     point_view->getFieldAs<int>(Id::Classification, idx));
+                     point.getFieldAs<int>(Id::Classification));
     if (layers->rgb_layer) {
-        int red = point_view->getFieldAs<int>(Id::Red, idx);
-        int green = point_view->getFieldAs<int>(Id::Green, idx);
-        int blue = point_view->getFieldAs<int>(Id::Blue, idx);
+        int red = point.getFieldAs<int>(Id::Red);
+        int green = point.getFieldAs<int>(Id::Green);
+        int blue = point.getFieldAs<int>(Id::Blue);
         int rgb = red;
         rgb = (rgb << 8) + green;
         rgb = (rgb << 8) + blue;
@@ -402,9 +403,13 @@
         G_fatal_error("Cannot determine input file type of <%s>",
                       in_opt->answer);
+    pdal::Options las_opts;
     pdal::Option las_opt("filename", in_opt->answer);
-    pdal::Options las_opts;
     las_opts.add(las_opt);
+    // if storing of cat is requested, limit the reader count
+    pdal::Option count_opt("count", GV_CAT_MAX);
+    if (layers.id_layer)
+        las_opts.add(count_opt);
     // TODO: free reader
     // using plain pointer because we need to keep the last stage pointer
     pdal::Stage * reader = factory.createStage(pdal_read_driver);
@@ -466,7 +471,7 @@
     if (height_filter_flag->answer) {
-        // TODO: we should test with if (point_view->hasDim(Id::Classification))
+        // TODO: we should test with if (point_layout->hasDim(Id::Classification))
         // but we don't have the info yet
         // TODO: free this or change pointer type to shared
         pdal::Stage * height_stage(factory.createStage("filters.height"));
@@ -477,8 +482,13 @@
         last_stage = height_stage;
-    pdal::PointTable point_table;
-    last_stage->prepare(point_table);
+    pdal::StreamCallbackFilter stream_filter;
+    stream_filter.setInput(*last_stage);
+    // there is no difference between 1 and 10k points in memory
+    // consumption, so using 10k in case it is faster for some cases
+    pdal::point_count_t point_table_capacity = 10000;
+    pdal::FixedPointTable point_table(point_table_capacity);
+    stream_filter.prepare(point_table);
     // getting projection is possible only after prepare
     if (over_flag->answer) {
@@ -499,9 +509,10 @@
     G_important_message(_("Running PDAL algorithms..."));
-    pdal::PointViewSet point_view_set = last_stage->execute(point_table);
-    pdal::PointViewPtr point_view = *point_view_set.begin();
+    // get the layout to see the dimensions
+    pdal::PointLayoutPtr point_layout = point_table.layout();
     // TODO: test also z
     // TODO: the falses for filters should be perhaps fatal error
     // (bad input) or warning if filter was requested by the user
@@ -508,8 +519,8 @@
     // update layers we are writing based on what is in the data
     // update usage of our filters as well
-    if (point_view->hasDim(pdal::Dimension::Id::ReturnNumber) &&
-        point_view->hasDim(pdal::Dimension::Id::NumberOfReturns)) {
+    if (point_layout->hasDim(pdal::Dimension::Id::ReturnNumber) &&
+        point_layout->hasDim(pdal::Dimension::Id::NumberOfReturns)) {
         use_return_filter = true;
     else {
@@ -521,7 +532,7 @@
         use_return_filter = false;
-    if (point_view->hasDim(pdal::Dimension::Id::Classification)) {
+    if (point_layout->hasDim(pdal::Dimension::Id::Classification)) {
         use_class_filter = true;
     else {
@@ -533,9 +544,9 @@
         use_class_filter = false;
-    if (!(point_view->hasDim(pdal::Dimension::Id::Red) &&
-          point_view->hasDim(pdal::Dimension::Id::Green) &&
-          point_view->hasDim(pdal::Dimension::Id::Blue))) {
+    if (!(point_layout->hasDim(pdal::Dimension::Id::Red) &&
+          point_layout->hasDim(pdal::Dimension::Id::Green) &&
+          point_layout->hasDim(pdal::Dimension::Id::Blue))) {
         if (layers.rgb_layer) {
             layers.rgb_layer = 0;
             G_warning(_("Cannot store RGB colors because the input"
@@ -554,7 +565,8 @@
     // height is stored as a new attribute
-        dim_to_use_as_z = point_view->layout()->findDim("Height");
+        // TODO: This needs to be reviewed on Height vs Elevation
+        dim_to_use_as_z = point_layout->findDim("Height");
         if (dim_to_use_as_z == pdal::Dimension::Id::Unknown)
             G_fatal_error(_("Cannot identify the height dimension"
                             " (probably something changed in PDAL)"));
@@ -562,7 +574,7 @@
     // this is just for sure, we test the individual dimensions before
     // TODO: should we test Z explicitly as well?
-    if (!point_view->hasDim(dim_to_use_as_z))
+    if (!point_layout->hasDim(dim_to_use_as_z))
         G_fatal_error(_("Dataset doesn't have requested dimension '%s'"
                         " with ID %d (possibly a programming error)"),
                       pdal::Dimension::name(dim_to_use_as_z).c_str(),
@@ -579,54 +591,68 @@
     int cat = 1;
     bool cat_max_reached = false;
-    for (pdal::PointId idx = 0; idx < point_view->size(); ++idx) {
+    // define callback
+    // Capture all values for reading by value, except for the ones
+    // for writing which we capture by reference.
+    // False is the proper value to return as a PDAL filter when
+    // point is filtered out (and should not be used by next stage).
+    // Here the return value does not matter unless we split this into
+    // two or more stages.
+    auto cb = [=, &cat, &cat_max_reached,
+               &n_outside, &zrange_filtered, &n_filtered,
+               &n_class_filtered, &class_filter, &return_filter_struct,
+               &output_vector, &layers](pdal::PointRef& point) -> bool
         // TODO: avoid duplication of reading the attributes here and when writing if needed
-        double x = point_view->getFieldAs<double>(pdal::Dimension::Id::X, idx);
-        double y = point_view->getFieldAs<double>(pdal::Dimension::Id::Y, idx);
+        double x = point.getFieldAs<double>(pdal::Dimension::Id::X);
+        double y = point.getFieldAs<double>(pdal::Dimension::Id::Y);
         if (use_spatial_filter) {
             if (x < xmin || x > xmax || y < ymin || y > ymax) {
                 n_outside++;
-                continue;
+                return false;
         if (use_zrange) {
             if (z < zrange_min || z > zrange_max) {
                 zrange_filtered++;
-                continue;
+                return false;
         if (use_return_filter) {
             int return_n =
-                point_view->getFieldAs<int>(pdal::Dimension::Id::ReturnNumber, idx);
+                point.getFieldAs<int>(pdal::Dimension::Id::ReturnNumber);
             int n_returns =
-                point_view->getFieldAs<int>(pdal::Dimension::Id::NumberOfReturns, idx);
+                point.getFieldAs<int>(pdal::Dimension::Id::NumberOfReturns);
             if (return_filter_is_out
                 (&return_filter_struct, return_n, n_returns)) {
                 n_filtered++;
-                continue;
+                return false;
         if (use_class_filter) {
             int point_class =
-                point_view->getFieldAs<int>(pdal::Dimension::Id::Classification, idx);
+                point.getFieldAs<int>(pdal::Dimension::Id::Classification);
             if (class_filter_is_out(&class_filter, point_class)) {
                 n_class_filtered++;
-                continue;
+                return false;
-        pdal_point_to_grass(&output_vector, points, cats, point_view,
-                            idx, &layers, cat, dim_to_use_as_z);
+        pdal_point_to_grass(&output_vector, points, cats, point,
+                            &layers, cat, dim_to_use_as_z);
         if (layers.id_layer) {
-            // TODO: perhaps it would be better to use the max cat afterwards
-            if (cat == GV_CAT_MAX) {
-                cat_max_reached = true;
-                break;
+            // we limit the count of imported points, so we don't
+            // need to check if we reached GV_CAT_MAX
             cat++;
+        return true;
+    // set the callback and run the actual processing
+    stream_filter.setCallback(cb);
+    stream_filter.execute(point_table);
     // not building topology by default
     Vect_close(&output_vector);
