[GRASS-git] [OSGeo/grass] 78e9da: r.out.mpeg fails because the output file name is e...
Markus Metz noreply at github.com
Fri May 24 13:06:53 PDT 2019
  Branch: refs/heads/master
  Home:   https://github.com/OSGeo/grass
  Commit: 78e9da1af300035ab1dbe4135ab79d1068aadd58
      https://github.com/OSGeo/grass/commit/78e9da1af300035ab1dbe4135ab79d1068aadd58
  Author: Markus Metz <markus.metz.giswork at gmail.com>
  Date:   2019-05-24 (Fri, 24 May 2019)
  Changed paths:
    M raster/r.out.mpeg/main.c
  Log Message:
  r.out.mpeg fails because the output file name is empty
This fix copies the output file name to the correct variable, as in GRASS 6
