[GRASS-git] [OSGeo/grass-addons] 8b8bcd: wxGUI wx.metadata: Fix launch g.gui.metadata, g.gu...
Tomas Zigo noreply at github.com
Thu Jul 2 12:49:09 PDT 2020
  Branch: refs/heads/master
  Home:   https://github.com/OSGeo/grass-addons
  Commit: 8b8bcd4710e538d733c1abb5306eebbdbd2c6ff4
      https://github.com/OSGeo/grass-addons/commit/8b8bcd4710e538d733c1abb5306eebbdbd2c6ff4
  Author: Tomas Zigo <50632337+tmszi at users.noreply.github.com>
  Date:   2020-07-02 (Thu, 02 Jul 2020)
  Changed paths:
  Log Message:
  wxGUI wx.metadata: Fix launch g.gui.metadata, g.gui.cswbrowser (#222)
* wx.metadata/g.gui.metadata: fix wx.FileDialog widget window style
* wx.metadata/g.gui.metadata: fix event handler function binding
* wx.metadata/g.gui.metadata: fix CustomTreeCtrl widget GetSelections method
* wx.metadata/mdlib: fix removeNonAscii function return value
* wx.metadata/mdlib: fix encode string
* wx.metadata/mdlib: fix wx.BoxSizer widget Add method params
* wx.metadata/g.gui.metadata: remove add left wx.Panel widget into wx.BoxSizer widget
* wx.metadata/g.gui.metadata: update wx.SplitterWindow widget size
* wx.metadata/mdlib: increase plus/minus wx.Button widget size (show label)
* wx.metadata/g.gui.metadata, mdlib: fix wx.BoxSizer widget add spacer with Add method
* wx.metadata/mdlib: fix wx.ListCtrl widget wxPyDeprecationWarning
* wx.metadata/mdlib: fix wx.ListCtrl widget set tooltip
* wx.metadata/mdlib: fix decode string
* wx.metadata/mdlib: fix add web service layer
* wx.metadata/mdlib: fix constraints builder dialog layout
* wx.metadata/mdlib: fix constraints builder dialog constraints validation
* wx.metadata/mdlib: fix slice stop index
* wx.metadata/mdlib: remove unused code line
* wx.metadata/mdlib: fix result list wx.ListCtrl widget vertical expand
* wx.metadata/g.gui.metadata: set class config attr (req for the CswPublisher class init)
* wx.metadata/g.gui.metadata, mdlib: replace add space Add method with AddSpacer method (minim. vertical space between widgets)
* wx.metadata/g.gui.metadata: fix not overflow duplicated item widget from ScrolledPanel widget during scrolling
* wx.metadata/mdlib: fix compare two metadata items (remove metadata item)
* wx.metadata/g.gui.metadata.py: remove calling non exist method
* wx.metadata/mdlib: fix pdf doc logo path
* wx.metadata/mdlib: replace google api for generate static map img with osm api (https://github.com/jperelli/osm-static-maps)
* wx.metadata/mdlib: fix write output pdf doc
* wx.metadata/g.gui.metadata.py: fix wx.TreeCtrl widget wxPyDeprecationWarning
* wx.metadata/mdlib: set static map img service url geojson query param with arg (rectangle polygon)
* wx.metadata/mdlib: fix script file header, import py modules according flake8
* wx.metadata/mdlib: set static map img url debug info
* wx.metadata/db.csw.admin: fix missing manual html file error during compilation
* wx.metadata/mdlib: fix transform static map bounds coords to the wgs84
* wx.metadata/db.csw.admin, g.gui.cswbrowser, g.gui.metadata, t.info.iso, v.info.iso: fix import mdlib
* wx.metadata/mdlib: fix missing wxgui path
* wx.metadata/mdlib: fix static map zoom max value
* wx.metadata: improve code of checking add-on py libs dependencies
* wx.metadata/g.gui.cswbrowser, g.gui.metadata: add basic module description
* wx.metadata/mdlib: fix module name
* wx.metadata/mdlib: fix map name
* wx.metadata/mdlib, t.info.iso, v.info.iso: fix flake8-strict errors
* wx.metadata/g.gui.cswbrowser, mdlib: set busy cursor after click on the search btn widget
* wx.metadata/g.gui.cswbrowser, mdlib: fix insert 'unknown' type, wx.ListCtrl widget result item
* wx.metadata/r.info.iso: fix flake8-strict errors
* wx.metadata/t.info.iso: fix write result to output file name destination
