[GRASS-git] [OSGeo/grass] 67235c: doc: Refine the command line parsing doc for C (#1...
Denis Ovsienko noreply at github.com
Sat Oct 17 06:01:15 PDT 2020
  Branch: refs/heads/releasebranch_7_8
  Home:   https://github.com/OSGeo/grass
  Commit: 67235cb991e7cafd1e8a188dba1d3ac95b0769e6
      https://github.com/OSGeo/grass/commit/67235cb991e7cafd1e8a188dba1d3ac95b0769e6
  Author: Denis Ovsienko <denis at ovsienko.info>
  Date:   2020-10-17 (Sat, 17 Oct 2020)
  Changed paths:
    M lib/gis/gislib_cmdline_parsing.dox
  Log Message:
  doc: Refine the command line parsing doc for C (#1010)
Improve punctuation. Fix some grammar. Put which/that right. Reword some
sentences for clarity. Fix a few broken references. Lose some passive
voice. Relabel two sections to match the text. Wrap all structure member
names with <b>, wrap all inline C code fragments with <tt>. Amend the
example C code to get the whitespace around "set"/"not set" right in all
cases. Consistently use $ as the command line prompt in all CLI examples.
Use <th> for table header rows. Show answers[] elements as strings, not
integers.
