[GRASS-git] [OSGeo/grass] 2cbcbc: scripts: Enable ambiguous variable name warning (#...
Vaclav Petras noreply at github.com
Thu Apr 8 20:03:47 PDT 2021
  Branch: refs/heads/master
  Home:   https://github.com/OSGeo/grass
  Commit: 2cbcbc76dbed9faa0670e44572479ebefa93a51e
      https://github.com/OSGeo/grass/commit/2cbcbc76dbed9faa0670e44572479ebefa93a51e
  Author: Vaclav Petras <wenzeslaus at gmail.com>
  Date:   2021-04-08 (Thu, 08 Apr 2021)
  Changed paths:
    M scripts/.flake8
    M scripts/d.correlate/d.correlate.py
    M scripts/d.rast.edit/d.rast.edit.py
    M scripts/db.in.ogr/db.in.ogr.py
    M scripts/i.in.spotvgt/i.in.spotvgt.py
    M scripts/i.pansharpen/i.pansharpen.py
    M scripts/i.spectral/i.spectral.py
    M scripts/v.report/v.report.py
  Log Message:
  scripts: Enable ambiguous variable name warning (#1515)
Enable Flake8 warning about ambiguous variables name l in scripts.
Fix clear cases such as l is line.
Use per file ignores to ignore the rest.
