[GRASS-git] [OSGeo/grass] ae610b: GRASS GIS 8.0 changes (#1597)
Markus Neteler noreply at github.com
Mon May 31 12:10:04 PDT 2021
  Branch: refs/heads/master
  Home:   https://github.com/OSGeo/grass
  Commit: ae610b8daed135f4051dd3ea010ba60f2bf30add
      https://github.com/OSGeo/grass/commit/ae610b8daed135f4051dd3ea010ba60f2bf30add
  Author: Markus Neteler <neteler at gmail.com>
  Date:   2021-05-31 (Mon, 31 May 2021)
  Changed paths:
    M .github/workflows/build_osgeo4w.sh
    M .github/workflows/osgeo4w.yml
    M .github/workflows/test_simple.sh
    M .github/workflows/test_thorough.sh
    M CHANGES
    M CITING
    M INSTALL
    M NEWS
    M README.md
    M REQUIREMENTS.html
    M TODO
    M db/db.login/db.login.html
    M db/drivers/mysql/grass-mesql.html
    M display/d.legend.vect/d.legend.vect.html
    M display/d.mon/main.c
    M display/d.vect.thematic/d.vect.thematic.html
    M doc/grass_database.html
    M doc/infrastructure.md
    M doc/python/script/r.example.html
    M doc/raster/r.example/r.example.html
    M doc/vector/v.example/v.example.html
    M docker/alpine/Dockerfile_alpine
    M docker/alpine/Dockerfile_alpine_latest
    M docker/debian/Dockerfile_debian_pdal
    M docker/ubuntu/Dockerfile_ubuntu_pdal
    M general/g.findfile/g.findfile.html
    M general/g.gui/g.gui.html
    M general/g.message/g.message.html
    M general/g.parser/g.parser.html
    M general/g.version/g.version.html
    M grasslib.dox
    M gui/icons/grass.desktop
    M gui/wxpython/README
    M gui/wxpython/docs/wxGUI.html
    M gui/wxpython/docs/wxGUI.toolboxes.html
    M gui/wxpython/docs/wxgui_sphinx/src/wxgui_toolboxes.rst
    M gui/wxpython/image2target/ii2t_gis_set.py
    M gui/wxpython/mapdisp/frame.py
    M gui/wxpython/mapwin/base.py
    M gui/wxpython/rlisetup/functions.py
    M gui/wxpython/rlisetup/g.gui.rlisetup.html
    M gui/wxpython/vdigit/g.gui.vdigit.html
    M gui/wxpython/xml/menudata.README
    M imagery/i.topo.corr/test_i.topo.corr_synthetic_DEM_NC.sh
    M include/Make/Grass.make
    M include/VERSION
    M include/grass/gis.h
    M lib/db/sqlp/sql.html
    M lib/gis/parser_wps.c
    M lib/gpde/gpdelib.dox
    M lib/init/Makefile
    M lib/init/README
    A lib/init/grass.html
    M lib/init/grass.py
    M lib/init/grass.sh
    R lib/init/grass7.html
    M lib/init/helptext.html
    M lib/init/variables.html
    M lib/vector/vectorlib_faq.dox
    M locale/README
    M locale/po/grasslibs_ar.po
    M locale/po/grasslibs_bn.po
    M locale/po/grasslibs_cs.po
    M locale/po/grasslibs_de.po
    M locale/po/grasslibs_el.po
    M locale/po/grasslibs_es.po
    M locale/po/grasslibs_fi.po
    M locale/po/grasslibs_fr.po
    M locale/po/grasslibs_hu.po
    M locale/po/grasslibs_id_ID.po
    M locale/po/grasslibs_it.po
    M locale/po/grasslibs_ja.po
    M locale/po/grasslibs_ko.po
    M locale/po/grasslibs_lv.po
    M locale/po/grasslibs_ml.po
    M locale/po/grasslibs_pl.po
    M locale/po/grasslibs_pt.po
    M locale/po/grasslibs_pt_BR.po
    M locale/po/grasslibs_ro.po
    M locale/po/grasslibs_ru.po
    M locale/po/grasslibs_si.po
    M locale/po/grasslibs_sl.po
    M locale/po/grasslibs_ta.po
    M locale/po/grasslibs_th.po
    M locale/po/grasslibs_tr.po
    M locale/po/grasslibs_uk.po
    M locale/po/grasslibs_vi.po
    M locale/po/grasslibs_zh.po
    M locale/po/grasslibs_zh_CN.po
    M man/build_graphical_index.py
    M man/build_html.py
    M man/build_rest.py
    M man/sphinx/Makefile
    M man/sphinx/conf.py
    M man/sphinx/make.bat
    M mswindows/Installer-Files/WinGRASS-README.url
    M mswindows/crosscompile.sh
    M python/grass/docs/src/gunittest_running_tests.rst
    M python/grass/docs/src/pygrass_gis.rst
    M python/grass/docs/src/pygrass_index.rst
    M python/grass/docs/src/pygrass_messages.rst
    M python/grass/docs/src/pygrass_raster.rst
    M python/grass/docs/src/pygrass_vector.rst
    M python/grass/docs/src/script_intro.rst
    M python/grass/gunittest/README.md
    M python/grass/gunittest/multirunner.py
    M python/grass/pygrass/modules/shortcuts.py
    M python/grass/pygrass/vector/__init__.py
    M python/grass/script/core.py
    M python/grass/script/setup.py
    M python/grass/temporal/stds_export.py
    M raster/r.compress/r.compress.html
    M raster/r.li/TODO
    M raster/r.li/r.li.cwed/r.li.cwed.html
    M raster/r.li/r.li.daemon/daemon.c
    M raster/r.li/r.li.dominance/r.li.dominance.html
    M raster/r.li/r.li.edgedensity/r.li.edgedensity.html
    M raster/r.li/r.li.html
    M raster/r.li/r.li.mpa/r.li.mpa.html
    M raster/r.li/r.li.mps/r.li.mps.html
    M raster/r.li/r.li.padcv/r.li.padcv.html
    M raster/r.li/r.li.padrange/r.li.padrange.html
    M raster/r.li/r.li.padsd/r.li.padsd.html
    M raster/r.li/r.li.patchdensity/r.li.patchdensity.html
    M raster/r.li/r.li.patchnum/r.li.patchnum.html
    M raster/r.li/r.li.pielou/r.li.pielou.html
    M raster/r.li/r.li.renyi/r.li.renyi.html
    M raster/r.li/r.li.richness/r.li.richness.html
    M raster/r.li/r.li.shannon/r.li.shannon.html
    M raster/r.li/r.li.shape/r.li.shape.html
    M raster/r.li/r.li.simpson/r.li.simpson.html
    M raster/r.li/r.li.testing_nc_asc.sh
    M raster/r.li/r.li.testing_sp_mov.sh
    M raster/r.stream.extract/r.stream.extract.html
    M raster/r.surf.idw/r.surf.idw.html
    M raster/r.texture/r.texture.html
    M raster/r.water.outlet/r.water.outlet.html
    M raster/rasterintro.html
    M raster3d/r3.out.netcdf/main.c
    M rpm/grass.spec
    M scripts/g.extension/g.extension.html
    M scripts/g.extension/g.extension.py
    M scripts/r.in.srtm/r.in.srtm.html
    M temporal/t.rast.accumulate/t.rast.accumulate.html
    M testsuite/README.md
    M testsuite/examples/test_framework_GRASS_GIS_with_NC.conf
    M testsuite/examples/test_framework_GRASS_GIS_with_NC.sh
    M utils/g.html2man/ghtml.py
    M utils/mkhtml.py
    M vector/v.build/v.build.html
    M vector/v.info/v.info.html
    M vector/v.out.postgis/v.out.postgis.html
    M vector/vectorintro.html
  Log Message:
* html pages: update to GRASS GIS 8.0.dev
* C files: update to GRASS GIS 8.0.dev
* RST files: update to GRASS GIS 8.0.dev
* Python files: update to GRASS GIS 8.0.dev
* core files: update to GRASS GIS 8.0.dev
* misc files: update to GRASS GIS 8.0.dev
* fix broken URL
* db.login manual: fix Windows path
* manual: fix path (Windows)
* grass_database manual: add Windows cmd line startup example
* path name cosmetics
* REQUIREMENTS.html: oldest still-alive Python version is 3.6
* typo fix: depreciated --> deprecated
* startup script: rename grass80 to grass
* added place of rc file on Windows
* gmake8 -> gmake
* grass79 -> grass
* grass80 -> grass
* version: change to generic 8.0.dev
* Windows: have a versionless and versioned startup script
