[GRASS-git] [OSGeo/grass] 40b598: Indent most of C code (#2544)
Vaclav Petras noreply at github.com
Sat Aug 27 09:12:35 PDT 2022
  Branch: refs/heads/main
  Home:   https://github.com/OSGeo/grass
  Commit: 40b598233c196df1c08a6222da24f2307841d1c5
      https://github.com/OSGeo/grass/commit/40b598233c196df1c08a6222da24f2307841d1c5
  Author: Vaclav Petras <wenzeslaus at gmail.com>
  Date:   2022-08-27 (Sat, 27 Aug 2022)
  Changed paths:
    M db/db.columns/main.c
    M db/db.connect/main.c
    M db/db.copy/main.c
    M db/db.createdb/main.c
    M db/db.databases/main.c
    M db/db.describe/main.c
    M db/db.describe/printtab.c
    M db/db.drivers/main.c
    M db/db.dropdb/main.c
    M db/db.execute/main.c
    M db/db.login/main.c
    M db/db.select/main.c
    M db/db.select/printtab.c
    M db/db.tables/main.c
    M db/drivers/dbf/column.c
    M db/drivers/dbf/create_table.c
    M db/drivers/dbf/cursor.c
    M db/drivers/dbf/db.c
    M db/drivers/dbf/dbfexe.c
    M db/drivers/dbf/describe.c
    M db/drivers/dbf/execute.c
    M db/drivers/dbf/fetch.c
    M db/drivers/dbf/globals.h
    M db/drivers/dbf/listtab.c
    M db/drivers/dbf/main.c
    M db/drivers/dbf/main_debug.c
    M db/drivers/dbf/select.c
    M db/drivers/dbf/table.c
    M db/drivers/mysql/create_table.c
    M db/drivers/mysql/cursor.c
    M db/drivers/mysql/db.c
    M db/drivers/mysql/dbe.c
    M db/drivers/mysql/describe.c
    M db/drivers/mysql/execute.c
    M db/drivers/mysql/fetch.c
    M db/drivers/mysql/globals.h
    M db/drivers/mysql/index.c
    M db/drivers/mysql/listtab.c
    M db/drivers/mysql/main.c
    M db/drivers/mysql/parse.c
    M db/drivers/mysql/replace.c
    M db/drivers/mysql/select.c
    M db/drivers/odbc/connect.c
    M db/drivers/odbc/create_table.c
    M db/drivers/odbc/cursor.c
    M db/drivers/odbc/db.c
    M db/drivers/odbc/describe.c
    M db/drivers/odbc/execute.c
    M db/drivers/odbc/fetch.c
    M db/drivers/odbc/globals.h
    M db/drivers/odbc/listdb.c
    M db/drivers/odbc/listtab.c
    M db/drivers/odbc/main.c
    M db/drivers/odbc/odbc.h
    M db/drivers/odbc/select.c
    M db/drivers/odbc/table.c
    M db/drivers/ogr/cursor.c
    M db/drivers/ogr/db.c
    M db/drivers/ogr/describe.c
    M db/drivers/ogr/driver.c
    M db/drivers/ogr/error.c
    M db/drivers/ogr/execute.c
    M db/drivers/ogr/fetch.c
    M db/drivers/ogr/globals.h
    M db/drivers/ogr/listtab.c
    M db/drivers/ogr/main.c
    M db/drivers/ogr/select.c
    M db/drivers/postgres/create_table.c
    M db/drivers/postgres/cursor.c
    M db/drivers/postgres/db.c
    M db/drivers/postgres/describe.c
    M db/drivers/postgres/error.c
    M db/drivers/postgres/execute.c
    M db/drivers/postgres/fetch.c
    M db/drivers/postgres/globals.h
    M db/drivers/postgres/index.c
    M db/drivers/postgres/listdb.c
    M db/drivers/postgres/listtab.c
    M db/drivers/postgres/main.c
    M db/drivers/postgres/parse.c
    M db/drivers/postgres/priv.c
    M db/drivers/postgres/select.c
    M db/drivers/postgres/table.c
    M db/drivers/sqlite/create_table.c
    M db/drivers/sqlite/cursor.c
    M db/drivers/sqlite/db.c
    M db/drivers/sqlite/describe.c
    M db/drivers/sqlite/execute.c
    M db/drivers/sqlite/fetch.c
    M db/drivers/sqlite/globals.h
    M db/drivers/sqlite/index.c
    M db/drivers/sqlite/listdb.c
    M db/drivers/sqlite/listtab.c
    M db/drivers/sqlite/main.c
    M db/drivers/sqlite/select.c
    M db/drivers/sqlite/table.c
    M display/d.barscale/draw_scale.c
    M display/d.barscale/main.c
    M display/d.barscale/options.h
    M display/d.colorlist/main.c
    M display/d.colortable/main.c
    M display/d.erase/main.c
    M display/d.extract/extract.c
    M display/d.extract/main.c
    M display/d.font/main.c
    M display/d.fontlist/main.c
    M display/d.geodesic/main.c
    M display/d.geodesic/plot.c
    M display/d.graph/do_graph.c
    M display/d.graph/graphics.c
    M display/d.graph/main.c
    M display/d.grid/main.c
    M display/d.grid/plot.c
    M display/d.his/his.c
    M display/d.his/main.c
    M display/d.histogram/bar.c
    M display/d.histogram/bar.h
    M display/d.histogram/dhist.h
    M display/d.histogram/draw_slice.c
    M display/d.histogram/get_stats.c
    M display/d.histogram/main.c
    M display/d.histogram/pie.c
    M display/d.histogram/pie.h
    M display/d.info/main.c
    M display/d.labels/color.c
    M display/d.labels/do_labels.c
    M display/d.labels/local_proto.h
    M display/d.labels/main.c
    M display/d.legend.vect/draw.c
    M display/d.legend.vect/main.c
    M display/d.legend/draw.c
    M display/d.legend/histogram.c
    M display/d.legend/main.c
    M display/d.linegraph/main.c
    M display/d.mon/list.c
    M display/d.mon/main.c
    M display/d.mon/proto.h
    M display/d.mon/select.c
    M display/d.mon/start.c
    M display/d.mon/stop.c
    M display/d.northarrow/main.c
    M display/d.path/main.c
    M display/d.path/proto.h
    M display/d.path/select.c
    M display/d.profile/main.c
    M display/d.rast.arrow/main.c
    M display/d.rast.num/main.c
    M display/d.rast/display.c
    M display/d.rast/main.c
    M display/d.rast/mask.c
    M display/d.rgb/main.c
    M display/d.rhumbline/main.c
    M display/d.rhumbline/plot.c
    M display/d.text/main.c
    M display/d.title/fancy.c
    M display/d.title/main.c
    M display/d.title/normal.c
    M display/d.vect.chart/bar.c
    M display/d.vect.chart/global.h
    M display/d.vect.chart/main.c
    M display/d.vect.chart/pie.c
    M display/d.vect.chart/plot.c
    M display/d.vect.thematic/area.c
    M display/d.vect.thematic/display.c
    M display/d.vect.thematic/legend.c
    M display/d.vect.thematic/local_proto.h
    M display/d.vect.thematic/main.c
    M display/d.vect.thematic/plot1.c
    M display/d.where/main.c
    M display/d.where/where.c
    M general/g.access/exp_perms.c
    M general/g.access/get_perms.c
    M general/g.access/main.c
    M general/g.access/set_perms.c
    M general/g.cairocomp/main.c
    M general/g.copy/main.c
    M general/g.dirseps/main.c
    M general/g.filename/main.c
    M general/g.findetc/main.c
    M general/g.findfile/local_proto.h
    M general/g.findfile/main.c
    M general/g.gisenv/main.c
    M general/g.gui/main.c
    M general/g.list/global.h
    M general/g.list/list.c
    M general/g.list/main.c
    M general/g.mapset/main.c
    M general/g.mapsets/get_maps.c
    M general/g.mapsets/list.c
    M general/g.mapsets/local_proto.h
    M general/g.mapsets/main.c
    M general/g.message/main.c
    M general/g.mkfontcap/freetype_fonts.c
    M general/g.mkfontcap/main.c
    M general/g.mkfontcap/stroke_fonts.c
    M general/g.parser/main.c
    M general/g.parser/parse.c
    M general/g.parser/revoke.c
    M general/g.parser/rules.c
    M general/g.parser/standard_option.c
    M general/g.parser/translate.c
    M general/g.pnmcomp/main.c
    M general/g.ppmtopng/main.c
    M general/g.proj/create.c
    M general/g.proj/datumtrans.c
    M general/g.proj/input.c
    M general/g.proj/list_codes.c
    M general/g.proj/local_proto.h
    M general/g.proj/main.c
    M general/g.proj/output.c
    M general/g.region/adjust.c
    M general/g.region/main.c
    M general/g.region/printwindow.c
    M general/g.region/zoom.c
    M general/g.remove/check_reclass.c
    M general/g.remove/construct_pattern.c
    M general/g.remove/main.c
    M general/g.rename/main.c
    M general/g.setproj/get_datum.c
    M general/g.setproj/get_deg.c
    M general/g.setproj/get_num.c
    M general/g.setproj/get_stp.c
    M general/g.setproj/local_proto.h
    M general/g.setproj/main.c
    M general/g.setproj/proj.c
    M general/g.tempfile/main.c
    M general/g.version/main.c
    M general/manage/lister/cell.c
    M general/manage/lister/vector.c
    M imagery/i.albedo/bb_alb_aster.c
    M imagery/i.albedo/bb_alb_aster2bands.c
    M imagery/i.albedo/bb_alb_landsat.c
    M imagery/i.albedo/bb_alb_landsat8.c
    M imagery/i.albedo/bb_alb_modis.c
    M imagery/i.albedo/functions.h
    M imagery/i.albedo/main.c
    M imagery/i.aster.toar/main.c
    M imagery/i.atcorr/6s.h
    M imagery/i.atcorr/abstra.h
    M imagery/i.atcorr/aerosolconcentration.h
    M imagery/i.atcorr/aerosolmodel.h
    M imagery/i.atcorr/altitude.h
    M imagery/i.atcorr/atmosmodel.h
    M imagery/i.atcorr/common.h
    M imagery/i.atcorr/date.h
    M imagery/i.atcorr/gauss.h
    M imagery/i.atcorr/geomcond.h
    M imagery/i.atcorr/interp.h
    M imagery/i.atcorr/iwave.h
    M imagery/i.atcorr/output.h
    M imagery/i.atcorr/transform.h
    M imagery/i.biomass/biomass.c
    M imagery/i.biomass/main.c
    M imagery/i.biomass/solar_day.c
    M imagery/i.cca/local_proto.h
    M imagery/i.cca/main.c
    M imagery/i.cca/matrix.c
    M imagery/i.cca/stats.c
    M imagery/i.cca/transform.c
    M imagery/i.cluster/checkpt.c
    M imagery/i.cluster/main.c
    M imagery/i.cluster/open_files.c
    M imagery/i.cluster/print1.c
    M imagery/i.cluster/print2.c
    M imagery/i.cluster/print3.c
    M imagery/i.cluster/print4.c
    M imagery/i.cluster/print5.c
    M imagery/i.cluster/print6.c
    M imagery/i.cluster/timer.c
    M imagery/i.eb.eta/eta.c
    M imagery/i.eb.eta/main.c
    M imagery/i.eb.evapfr/evap_fr.c
    M imagery/i.eb.evapfr/main.c
    M imagery/i.eb.evapfr/soilmoisture.c
    M imagery/i.eb.netrad/main.c
    M imagery/i.eb.netrad/r_net.c
    M imagery/i.eb.soilheatflux/g0.c
    M imagery/i.eb.soilheatflux/main.c
    M imagery/i.emissivity/emissivity_generic.c
    M imagery/i.emissivity/main.c
    M imagery/i.evapo.mh/main.c
    M imagery/i.evapo.mh/mh_eto.c
    M imagery/i.evapo.mh/mh_original.c
    M imagery/i.evapo.mh/mh_samani.c
    M imagery/i.evapo.pt/main.c
    M imagery/i.evapo.pt/pt_daily_et.c
    M imagery/i.evapo.pt/pt_delta.c
    M imagery/i.evapo.time/main.c
    M imagery/i.fft/main.c
    M imagery/i.find/main.c
    M imagery/i.gensig/alloc.c
    M imagery/i.gensig/can_invert.c
    M imagery/i.gensig/check.c
    M imagery/i.gensig/closefiles.c
    M imagery/i.gensig/copy.c
    M imagery/i.gensig/covariance.c
    M imagery/i.gensig/eigen.c
    M imagery/i.gensig/get_train.c
    M imagery/i.gensig/labels.c
    M imagery/i.gensig/lookup_class.c
    M imagery/i.gensig/main.c
    M imagery/i.gensig/means.c
    M imagery/i.gensig/openfiles.c
    M imagery/i.gensig/parse.c
    M imagery/i.gensig/read_train.c
    M imagery/i.gensig/write_sig.c
    M imagery/i.gensigset/closefiles.c
    M imagery/i.gensigset/get_train.c
    M imagery/i.gensigset/invert.c
    M imagery/i.gensigset/labels.c
    M imagery/i.gensigset/lookup_class.c
    M imagery/i.gensigset/main.c
    M imagery/i.gensigset/openfiles.c
    M imagery/i.gensigset/parse.c
    M imagery/i.gensigset/read_data.c
    M imagery/i.gensigset/read_train.c
    M imagery/i.gensigset/subcluster.c
    M imagery/i.gensigset/write_sig.c
    M imagery/i.group/main.c
    M imagery/i.his.rgb/closefiles.c
    M imagery/i.his.rgb/globals.h
    M imagery/i.his.rgb/his2rgb.c
    M imagery/i.his.rgb/main.c
    M imagery/i.his.rgb/openfiles.c
    M imagery/i.ifft/main.c
    M imagery/i.landsat.acca/algorithm.c
    M imagery/i.landsat.acca/main.c
    M imagery/i.landsat.acca/tools.c
    M imagery/i.landsat.toar/earth_sun.c
    M imagery/i.landsat.toar/landsat.c
    M imagery/i.landsat.toar/landsat.h
    M imagery/i.landsat.toar/landsat_met.c
    M imagery/i.landsat.toar/landsat_set.c
    M imagery/i.landsat.toar/main.c
    M imagery/i.maxlik/classify.c
    M imagery/i.maxlik/hist.c
    M imagery/i.maxlik/invert.c
    M imagery/i.maxlik/main.c
    M imagery/i.maxlik/open.c
    M imagery/i.modis.qc/main.c
    M imagery/i.modis.qc/mcd43B2a.c
    M imagery/i.modis.qc/mcd43B2b.c
    M imagery/i.modis.qc/mcd43B2c.c
    M imagery/i.modis.qc/mcd43B2qa.c
    M imagery/i.modis.qc/mod09A1a.c
    M imagery/i.modis.qc/mod09A1c.c
    M imagery/i.modis.qc/mod09A1d.c
    M imagery/i.modis.qc/mod09A1e.c
    M imagery/i.modis.qc/mod09A1sa.c
    M imagery/i.modis.qc/mod09A1sb.c
    M imagery/i.modis.qc/mod09A1sc.c
    M imagery/i.modis.qc/mod09A1sd.c
    M imagery/i.modis.qc/mod09A1se.c
    M imagery/i.modis.qc/mod09A1sf.c
    M imagery/i.modis.qc/mod09A1sg.c
    M imagery/i.modis.qc/mod09A1sh.c
    M imagery/i.modis.qc/mod09A1si.c
    M imagery/i.modis.qc/mod09A1sj.c
    M imagery/i.modis.qc/mod09A1sk.c
    M imagery/i.modis.qc/mod09CMGa.c
    M imagery/i.modis.qc/mod09CMGc.c
    M imagery/i.modis.qc/mod09CMGd.c
    M imagery/i.modis.qc/mod09CMGe.c
    M imagery/i.modis.qc/mod09CMGia.c
    M imagery/i.modis.qc/mod09CMGib.c
    M imagery/i.modis.qc/mod09CMGic.c
    M imagery/i.modis.qc/mod09CMGid.c
    M imagery/i.modis.qc/mod09CMGie.c
    M imagery/i.modis.qc/mod09CMGif.c
    M imagery/i.modis.qc/mod09CMGig.c
    M imagery/i.modis.qc/mod09CMGih.c
    M imagery/i.modis.qc/mod09CMGii.c
    M imagery/i.modis.qc/mod09CMGij.c
    M imagery/i.modis.qc/mod09CMGik.c
    M imagery/i.modis.qc/mod09CMGil.c
    M imagery/i.modis.qc/mod09CMGim.c
    M imagery/i.modis.qc/mod09CMGin.c
    M imagery/i.modis.qc/mod09GAa.c
    M imagery/i.modis.qc/mod09GAc.c
    M imagery/i.modis.qc/mod09GAd.c
    M imagery/i.modis.qc/mod09GAe.c
    M imagery/i.modis.qc/mod09GAsa.c
    M imagery/i.modis.qc/mod09GAsb.c
    M imagery/i.modis.qc/mod09GAsc.c
    M imagery/i.modis.qc/mod09GAsd.c
    M imagery/i.modis.qc/mod09GAse.c
    M imagery/i.modis.qc/mod09GAsf.c
    M imagery/i.modis.qc/mod09GAsg.c
    M imagery/i.modis.qc/mod09GAsh.c
    M imagery/i.modis.qc/mod09GAsi.c
    M imagery/i.modis.qc/mod09GAsj.c
    M imagery/i.modis.qc/mod09GAsk.c
    M imagery/i.modis.qc/mod09Q1a.c
    M imagery/i.modis.qc/mod09Q1b.c
    M imagery/i.modis.qc/mod09Q1c.c
    M imagery/i.modis.qc/mod09Q1d.c
    M imagery/i.modis.qc/mod09Q1e.c
    M imagery/i.modis.qc/mod09Q1f.c
    M imagery/i.modis.qc/mod11A1a.c
    M imagery/i.modis.qc/mod11A1b.c
    M imagery/i.modis.qc/mod11A1c.c
    M imagery/i.modis.qc/mod11A1d.c
    M imagery/i.modis.qc/mod11A2a.c
    M imagery/i.modis.qc/mod11A2b.c
    M imagery/i.modis.qc/mod11A2c.c
    M imagery/i.modis.qc/mod11A2d.c
    M imagery/i.modis.qc/mod13A2a.c
    M imagery/i.modis.qc/mod13A2b.c
    M imagery/i.modis.qc/mod13A2c.c
    M imagery/i.modis.qc/mod13A2d.c
    M imagery/i.modis.qc/mod13A2e.c
    M imagery/i.modis.qc/mod13A2f.c
    M imagery/i.modis.qc/mod13A2g.c
    M imagery/i.modis.qc/mod13A2h.c
    M imagery/i.modis.qc/mod13A2i.c
    M imagery/i.modis.qc/mod13Q1a.c
    M imagery/i.modis.qc/mod13Q1b.c
    M imagery/i.modis.qc/mod13Q1c.c
    M imagery/i.modis.qc/mod13Q1d.c
    M imagery/i.modis.qc/mod13Q1e.c
    M imagery/i.modis.qc/mod13Q1f.c
    M imagery/i.modis.qc/mod13Q1g.c
    M imagery/i.modis.qc/mod13Q1h.c
    M imagery/i.modis.qc/mod13Q1i.c
    M imagery/i.ortho.photo/i.ortho.camera/main.c
    M imagery/i.ortho.photo/i.ortho.elev/main.c
    M imagery/i.ortho.photo/i.ortho.init/main.c
    M imagery/i.ortho.photo/i.ortho.photo/menu.c
    M imagery/i.ortho.photo/i.ortho.rectify/angle.c
    M imagery/i.ortho.photo/i.ortho.rectify/aver_z.c
    M imagery/i.ortho.photo/i.ortho.rectify/bilinear.c
    M imagery/i.ortho.photo/i.ortho.rectify/bilinear_f.c
    M imagery/i.ortho.photo/i.ortho.rectify/cp.c
    M imagery/i.ortho.photo/i.ortho.rectify/cubic.c
    M imagery/i.ortho.photo/i.ortho.rectify/cubic_f.c
    M imagery/i.ortho.photo/i.ortho.rectify/defs.h
    M imagery/i.ortho.photo/i.ortho.rectify/env.c
    M imagery/i.ortho.photo/i.ortho.rectify/equ.c
    M imagery/i.ortho.photo/i.ortho.rectify/exec.c
    M imagery/i.ortho.photo/i.ortho.rectify/get_wind.c
    M imagery/i.ortho.photo/i.ortho.rectify/global.h
    M imagery/i.ortho.photo/i.ortho.rectify/lanczos.c
    M imagery/i.ortho.photo/i.ortho.rectify/local_proto.h
    M imagery/i.ortho.photo/i.ortho.rectify/main.c
    M imagery/i.ortho.photo/i.ortho.rectify/nearest.c
    M imagery/i.ortho.photo/i.ortho.rectify/readcell.c
    M imagery/i.ortho.photo/i.ortho.rectify/rectify.c
    M imagery/i.ortho.photo/i.ortho.rectify/report.c
    M imagery/i.ortho.photo/i.ortho.rectify/target.c
    M imagery/i.ortho.photo/i.ortho.target/main.c
    M imagery/i.ortho.photo/i.ortho.transform/main.c
    M imagery/i.ortho.photo/lib/cam_info.c
    M imagery/i.ortho.photo/lib/camera.c
    M imagery/i.ortho.photo/lib/conz_points.c
    M imagery/i.ortho.photo/lib/elev.c
    M imagery/i.ortho.photo/lib/find_camera.c
    M imagery/i.ortho.photo/lib/find_init.c
    M imagery/i.ortho.photo/lib/fopen_camera.c
    M imagery/i.ortho.photo/lib/funcdefs.h
    M imagery/i.ortho.photo/lib/georef.c
    M imagery/i.ortho.photo/lib/init_info.c
    M imagery/i.ortho.photo/lib/isnull.c
    M imagery/i.ortho.photo/lib/m_add.c
    M imagery/i.ortho.photo/lib/m_copy.c
    M imagery/i.ortho.photo/lib/m_inverse.c
    M imagery/i.ortho.photo/lib/m_mult.c
    M imagery/i.ortho.photo/lib/m_transpose.c
    M imagery/i.ortho.photo/lib/m_zero.c
    M imagery/i.ortho.photo/lib/mat.h
    M imagery/i.ortho.photo/lib/open_camera.c
    M imagery/i.ortho.photo/lib/orthophoto.h
    M imagery/i.ortho.photo/lib/orthoref.c
    M imagery/i.ortho.photo/lib/ref_points.c
    M imagery/i.ortho.photo/lib/title_camera.c
    M imagery/i.pca/main.c
    M imagery/i.pca/support.c
    M imagery/i.rectify/bilinear.c
    M imagery/i.rectify/bilinear_f.c
    M imagery/i.rectify/cp.c
    M imagery/i.rectify/cubic.c
    M imagery/i.rectify/cubic_f.c
    M imagery/i.rectify/defs.h
    M imagery/i.rectify/env.c
    M imagery/i.rectify/exec.c
    M imagery/i.rectify/get_wind.c
    M imagery/i.rectify/global.h
    M imagery/i.rectify/lanczos.c
    M imagery/i.rectify/local_proto.h
    M imagery/i.rectify/main.c
    M imagery/i.rectify/nearest.c
    M imagery/i.rectify/readcell.c
    M imagery/i.rectify/rectify.c
    M imagery/i.rectify/report.c
    M imagery/i.rectify/target.c
    M imagery/i.rgb.his/closefiles.c
    M imagery/i.rgb.his/globals.h
    M imagery/i.rgb.his/main.c
    M imagery/i.rgb.his/openfiles.c
    M imagery/i.rgb.his/rgb2his.c
    M imagery/i.segment/cluster.c
    M imagery/i.segment/create_isegs.c
    M imagery/i.segment/flag.c
    M imagery/i.segment/iseg.h
    M imagery/i.segment/main.c
    M imagery/i.segment/mean_shift.c
    M imagery/i.segment/ngbrtree.c
    M imagery/i.segment/ngbrtree.h
    M imagery/i.segment/open_files.c
    M imagery/i.segment/parse_args.c
    M imagery/i.segment/pavl.c
    M imagery/i.segment/pavl.h
    M imagery/i.segment/rclist.c
    M imagery/i.segment/region_growing.c
    M imagery/i.segment/regtree.c
    M imagery/i.segment/regtree.h
    M imagery/i.segment/watershed.c
    M imagery/i.segment/write_output.c
    M imagery/i.smap/alpha_max.c
    M imagery/i.smap/bouman.h
    M imagery/i.smap/closefiles.c
    M imagery/i.smap/decimate.c
    M imagery/i.smap/history.c
    M imagery/i.smap/interp.c
    M imagery/i.smap/invert.c
    M imagery/i.smap/labels.c
    M imagery/i.smap/main.c
    M imagery/i.smap/model.c
    M imagery/i.smap/multialloc.c
    M imagery/i.smap/openfiles.c
    M imagery/i.smap/parse.c
    M imagery/i.smap/read_block.c
    M imagery/i.smap/reg_util.c
    M imagery/i.smap/region.h
    M imagery/i.smap/segment.c
    M imagery/i.smap/solve.c
    M imagery/i.smap/write_img.c
    M imagery/i.target/main.c
    M imagery/i.topo.corr/correction.c
    M imagery/i.topo.corr/illumination.c
    M imagery/i.topo.corr/main.c
    M imagery/i.vi/arvi.c
    M imagery/i.vi/dvi.c
    M imagery/i.vi/evi.c
    M imagery/i.vi/evi2.c
    M imagery/i.vi/gari.c
    M imagery/i.vi/gemi.c
    M imagery/i.vi/gvi.c
    M imagery/i.vi/ipvi.c
    M imagery/i.vi/main.c
    M imagery/i.vi/msavi.c
    M imagery/i.vi/msavi2.c
    M imagery/i.vi/ndvi.c
    M imagery/i.vi/ndwi.c
    M imagery/i.vi/pvi.c
    M imagery/i.vi/savi.c
    M imagery/i.vi/sr.c
    M imagery/i.vi/vari.c
    M imagery/i.vi/wdvi.c
    M imagery/i.zc/main.c
    M include/grass/arraystats.h
    M include/grass/blas.h
    M include/grass/btree.h
    M include/grass/calc.h
    M include/grass/cluster.h
    M include/grass/datetime.h
    M include/grass/dbmi.h
    M include/grass/defs/Paintlib.h
    M include/grass/defs/cluster.h
    M include/grass/defs/datetime.h
    M include/grass/defs/dbmi.h
    M include/grass/defs/devlib.h
    M include/grass/defs/display.h
    M include/grass/defs/form.h
    M include/grass/defs/gis.h
    M include/grass/defs/glocale.h
    M include/grass/defs/gmath.h
    M include/grass/defs/gprojects.h
    M include/grass/defs/imagery.h
    M include/grass/defs/la.h
    M include/grass/defs/manage.h
    M include/grass/defs/neta.h
    M include/grass/defs/nviz.h
    M include/grass/defs/ogsf.h
    M include/grass/defs/raster.h
    M include/grass/defs/raster3d.h
    M include/grass/defs/rbtree.h
    M include/grass/defs/rowio.h
    M include/grass/defs/sqlp.h
    M include/grass/defs/vector.h
    M include/grass/defs/vedit.h
    M include/grass/display.h
    M include/grass/fontcap.h
    M include/grass/gis.h
    M include/grass/gmath.h
    M include/grass/gprojects.h
    M include/grass/imagery.h
    M include/grass/la.h
    M include/grass/lapack.h
    M include/grass/linkm.h
    M include/grass/manage.h
    M include/grass/nviz.h
    M include/grass/ogsf.h
    M include/grass/raster.h
    M include/grass/raster3d.h
    M include/grass/rbtree.h
    M include/grass/rowio.h
    M include/grass/segment.h
    M include/grass/sqlp.h
    M include/grass/symbol.h
    M include/grass/temporal.h
    M include/grass/vect/dig_defines.h
    M include/grass/vect/dig_externs.h
    M include/grass/vect/dig_macros.h
    M include/grass/vect/dig_structs.h
    M include/grass/vect/digit.h
    M include/grass/vedit.h
    M lib/arraystats/basic.c
    M lib/arraystats/class.c
    M lib/bitmap/bitmap.c
    M lib/bitmap/main.c
    M lib/bitmap/smain.c
    M lib/bitmap/sparse.c
    M lib/btree/create.c
    M lib/btree/find.c
    M lib/btree/free.c
    M lib/btree/next.c
    M lib/btree/test/try.c
    M lib/btree/update.c
    M lib/btree2/kdtree.c
    M lib/btree2/rbtree.c
    M lib/cairodriver/box.c
    M lib/cairodriver/cairodriver.h
    M lib/cairodriver/color.c
    M lib/cairodriver/draw.c
    M lib/cairodriver/draw_bitmap.c
    M lib/cairodriver/driver.c
    M lib/cairodriver/erase.c
    M lib/cairodriver/graph.c
    M lib/cairodriver/line_width.c
    M lib/cairodriver/raster.c
    M lib/cairodriver/read.c
    M lib/cairodriver/read_bmp.c
    M lib/cairodriver/read_ppm.c
    M lib/cairodriver/read_xid.c
    M lib/cairodriver/set_window.c
    M lib/cairodriver/text.c
    M lib/cairodriver/write.c
    M lib/cairodriver/write_bmp.c
    M lib/cairodriver/write_ppm.c
    M lib/cairodriver/write_xid.c
    M lib/cdhc/andrsnde.c
    M lib/cdhc/andrsndn.c
    M lib/cdhc/as177.c
    M lib/cdhc/as181.c
    M lib/cdhc/as241.c
    M lib/cdhc/as66.c
    M lib/cdhc/chisqe.c
    M lib/cdhc/chisqn.c
    M lib/cdhc/cvmw2e.c
    M lib/cdhc/cvmw2n.c
    M lib/cdhc/dagstndn.c
    M lib/cdhc/dcmp.c
    M lib/cdhc/dmax.c
    M lib/cdhc/dmaxe.c
    M lib/cdhc/durbins.c
    M lib/cdhc/enormp.c
    M lib/cdhc/extreme.c
    M lib/cdhc/geary.c
    M lib/cdhc/kotz.c
    M lib/cdhc/local_proto.h
    M lib/cdhc/normp.c
    M lib/cdhc/omnibus.c
    M lib/cdhc/royston.c
    M lib/cdhc/shapiro1.c
    M lib/cdhc/shapiro2.c
    M lib/cdhc/shapiroe.c
    M lib/cdhc/test.c
    M lib/cdhc/watsonue.c
    M lib/cdhc/watsonun.c
    M lib/cdhc/weisberg.c
    M lib/cdhc/xinormal.c
    M lib/cluster/c_assign.c
    M lib/cluster/c_begin.c
    M lib/cluster/c_clear.c
    M lib/cluster/c_distinct.c
    M lib/cluster/c_exec.c
    M lib/cluster/c_execmem.c
    M lib/cluster/c_means.c
    M lib/cluster/c_merge.c
    M lib/cluster/c_nclasses.c
    M lib/cluster/c_point.c
    M lib/cluster/c_reassign.c
    M lib/cluster/c_reclass.c
    M lib/cluster/c_sep.c
    M lib/cluster/c_sig.c
    M lib/cluster/c_sum2.c
    M lib/datetime/between.c
    M lib/datetime/change.c
    M lib/datetime/diff.c
    M lib/datetime/error.c
    M lib/datetime/format.c
    M lib/datetime/incr1.c
    M lib/datetime/incr2.c
    M lib/datetime/incr3.c
    M lib/datetime/local.c
    M lib/datetime/misc.c
    M lib/datetime/scan.c
    M lib/datetime/type.c
    M lib/datetime/tz1.c
    M lib/datetime/tz2.c
    M lib/datetime/values.c
    M lib/db/dbmi_base/alloc.c
    M lib/db/dbmi_base/case.c
    M lib/db/dbmi_base/column.c
    M lib/db/dbmi_base/columnfmt.c
    M lib/db/dbmi_base/connect.c
    M lib/db/dbmi_base/cursor.c
    M lib/db/dbmi_base/datetime.c
    M lib/db/dbmi_base/dbmscap.c
    M lib/db/dbmi_base/dbstubs.h
    M lib/db/dbmi_base/default_name.c
    M lib/db/dbmi_base/dirent.c
    M lib/db/dbmi_base/error.c
    M lib/db/dbmi_base/handle.c
    M lib/db/dbmi_base/index.c
    M lib/db/dbmi_base/interval.c
    M lib/db/dbmi_base/isdir.c
    M lib/db/dbmi_base/legal_dbname.c
    M lib/db/dbmi_base/login.c
    M lib/db/dbmi_base/ret_codes.c
    M lib/db/dbmi_base/sqlCtype.c
    M lib/db/dbmi_base/sqltype.c
    M lib/db/dbmi_base/string.c
    M lib/db/dbmi_base/strip.c
    M lib/db/dbmi_base/table.c
    M lib/db/dbmi_base/test/test_columns.c
    M lib/db/dbmi_base/test/test_dbmi_base_lib.h
    M lib/db/dbmi_base/test/test_main.c
    M lib/db/dbmi_base/test/test_table.c
    M lib/db/dbmi_base/token.c
    M lib/db/dbmi_base/value.c
    M lib/db/dbmi_base/valuefmt.c
    M lib/db/dbmi_base/whoami.c
    M lib/db/dbmi_base/xdr.c
    M lib/db/dbmi_base/xdrchar.c
    M lib/db/dbmi_base/xdrcolumn.c
    M lib/db/dbmi_base/xdrdatetime.c
    M lib/db/dbmi_base/xdrdouble.c
    M lib/db/dbmi_base/xdrfloat.c
    M lib/db/dbmi_base/xdrhandle.c
    M lib/db/dbmi_base/xdrindex.c
    M lib/db/dbmi_base/xdrint.c
    M lib/db/dbmi_base/xdrprocedure.c
    M lib/db/dbmi_base/xdrshort.c
    M lib/db/dbmi_base/xdrstring.c
    M lib/db/dbmi_base/xdrtable.c
    M lib/db/dbmi_base/xdrtoken.c
    M lib/db/dbmi_base/xdrvalue.c
    M lib/db/dbmi_base/zero.c
    M lib/db/dbmi_client/c_add_col.c
    M lib/db/dbmi_client/c_bindupdate.c
    M lib/db/dbmi_client/c_close_cur.c
    M lib/db/dbmi_client/c_closedb.c
    M lib/db/dbmi_client/c_create_idx.c
    M lib/db/dbmi_client/c_create_tab.c
    M lib/db/dbmi_client/c_createdb.c
    M lib/db/dbmi_client/c_delete.c
    M lib/db/dbmi_client/c_deletedb.c
    M lib/db/dbmi_client/c_desc_table.c
    M lib/db/dbmi_client/c_drop_col.c
    M lib/db/dbmi_client/c_drop_index.c
    M lib/db/dbmi_client/c_drop_tab.c
    M lib/db/dbmi_client/c_execute.c
    M lib/db/dbmi_client/c_fetch.c
    M lib/db/dbmi_client/c_finddb.c
    M lib/db/dbmi_client/c_insert.c
    M lib/db/dbmi_client/c_list_drivers.c
    M lib/db/dbmi_client/c_list_idx.c
    M lib/db/dbmi_client/c_list_tabs.c
    M lib/db/dbmi_client/c_listdb.c
    M lib/db/dbmi_client/c_opendb.c
    M lib/db/dbmi_client/c_openinsert.c
    M lib/db/dbmi_client/c_openselect.c
    M lib/db/dbmi_client/c_openupdate.c
    M lib/db/dbmi_client/c_priv.c
    M lib/db/dbmi_client/c_rows.c
    M lib/db/dbmi_client/c_update.c
    M lib/db/dbmi_client/c_version.c
    M lib/db/dbmi_client/column.c
    M lib/db/dbmi_client/copy_tab.c
    M lib/db/dbmi_client/db.c
    M lib/db/dbmi_client/delete_tab.c
    M lib/db/dbmi_client/handler.c
    M lib/db/dbmi_client/printtab.c
    M lib/db/dbmi_client/select.c
    M lib/db/dbmi_client/shutdown.c
    M lib/db/dbmi_client/start.c
    M lib/db/dbmi_client/table.c
    M lib/db/dbmi_driver/d_add_col.c
    M lib/db/dbmi_driver/d_bindupdate.c
    M lib/db/dbmi_driver/d_close_cur.c
    M lib/db/dbmi_driver/d_closedb.c
    M lib/db/dbmi_driver/d_create_idx.c
    M lib/db/dbmi_driver/d_create_tab.c
    M lib/db/dbmi_driver/d_createdb.c
    M lib/db/dbmi_driver/d_delete.c
    M lib/db/dbmi_driver/d_deletedb.c
    M lib/db/dbmi_driver/d_desc_table.c
    M lib/db/dbmi_driver/d_drop_col.c
    M lib/db/dbmi_driver/d_drop_index.c
    M lib/db/dbmi_driver/d_drop_tab.c
    M lib/db/dbmi_driver/d_error.c
    M lib/db/dbmi_driver/d_execute.c
    M lib/db/dbmi_driver/d_fetch.c
    M lib/db/dbmi_driver/d_finddb.c
    M lib/db/dbmi_driver/d_insert.c
    M lib/db/dbmi_driver/d_list_idx.c
    M lib/db/dbmi_driver/d_list_tabs.c
    M lib/db/dbmi_driver/d_listdb.c
    M lib/db/dbmi_driver/d_mkdir.c
    M lib/db/dbmi_driver/d_opendb.c
    M lib/db/dbmi_driver/d_openinsert.c
    M lib/db/dbmi_driver/d_openselect.c
    M lib/db/dbmi_driver/d_openupdate.c
    M lib/db/dbmi_driver/d_priv.c
    M lib/db/dbmi_driver/d_rows.c
    M lib/db/dbmi_driver/d_update.c
    M lib/db/dbmi_driver/d_version.c
    M lib/db/dbmi_driver/driver.c
    M lib/db/dbmi_driver/driver_state.c
    M lib/db/dbmi_driver/procs.h
    M lib/db/sqlp/alloc.c
    M lib/db/sqlp/print.c
    M lib/db/sqlp/sql.c
    M lib/db/sqlp/test/sqlptest.c
    M lib/db/stubs/listdb.c
    M lib/db/stubs/open_update.c
    M lib/dspf/cell_table.c
    M lib/dspf/cube_io.c
    M lib/dspf/dspf_header.c
    M lib/dspf/print_info.c
    M lib/dspf/struct_copy.c
    M lib/dspf/viz.h
    M lib/external/ccmath/atou1.c
    M lib/external/ccmath/atovm.c
    M lib/external/ccmath/ccmath.h
    M lib/external/ccmath/chouse.c
    M lib/external/ccmath/chousv.c
    M lib/external/ccmath/cmattr.c
    M lib/external/ccmath/cmcpy.c
    M lib/external/ccmath/cminv.c
    M lib/external/ccmath/cmmul.c
    M lib/external/ccmath/cmmult.c
    M lib/external/ccmath/cmprt.c
    M lib/external/ccmath/csolv.c
    M lib/external/ccmath/cvmul.c
    M lib/external/ccmath/evmax.c
    M lib/external/ccmath/hconj.c
    M lib/external/ccmath/hevmax.c
    M lib/external/ccmath/hmgen.c
    M lib/external/ccmath/house.c
    M lib/external/ccmath/housev.c
    M lib/external/ccmath/ldumat.c
    M lib/external/ccmath/ldvmat.c
    M lib/external/ccmath/matprt.c
    M lib/external/ccmath/mattr.c
    M lib/external/ccmath/mcopy.c
    M lib/external/ccmath/minv.c
    M lib/external/ccmath/mmul.c
    M lib/external/ccmath/ortho.c
    M lib/external/ccmath/otrma.c
    M lib/external/ccmath/otrsm.c
    M lib/external/ccmath/psinv.c
    M lib/external/ccmath/qrbdi.c
    M lib/external/ccmath/qrbdu1.c
    M lib/external/ccmath/qrbdv.c
    M lib/external/ccmath/qrecvc.c
    M lib/external/ccmath/qreval.c
    M lib/external/ccmath/qrevec.c
    M lib/external/ccmath/rmmult.c
    M lib/external/ccmath/ruinv.c
    M lib/external/ccmath/smgen.c
    M lib/external/ccmath/solv.c
    M lib/external/ccmath/solvps.c
    M lib/external/ccmath/solvru.c
    M lib/external/ccmath/solvtd.c
    M lib/external/ccmath/sv2u1v.c
    M lib/external/ccmath/sv2uv.c
    M lib/external/ccmath/sv2val.c
    M lib/external/ccmath/svdu1v.c
    M lib/external/ccmath/svduv.c
    M lib/external/ccmath/svdval.c
    M lib/external/ccmath/trncm.c
    M lib/external/ccmath/trnm.c
    M lib/external/ccmath/unfl.c
    M lib/external/ccmath/unitary.c
    M lib/external/ccmath/utrncm.c
    M lib/external/ccmath/utrnhm.c
    M lib/external/ccmath/vmul.c
    M lib/external/shapelib/dbfopen.c
    M lib/external/shapelib/safileio.c
    M lib/external/shapelib/shapefil.h
    M lib/external/shapelib/shpopen.c
    M lib/gis/G.h
    M lib/gis/adj_cellhd.c
    M lib/gis/alloc.c
    M lib/gis/aprintf.c
    M lib/gis/area.c
    M lib/gis/area_ellipse.c
    M lib/gis/area_poly1.c
    M lib/gis/area_poly2.c
    M lib/gis/area_sphere.c
    M lib/gis/ascii_chk.c
    M lib/gis/asprintf.c
    M lib/gis/basename.c
    M lib/gis/bres_line.c
    M lib/gis/clicker.c
    M lib/gis/cmprbzip.c
    M lib/gis/cmprlz4.c
    M lib/gis/cmprrle.c
    M lib/gis/cmprzlib.c
    M lib/gis/cmprzstd.c
    M lib/gis/color_rules.c
    M lib/gis/color_str.c
    M lib/gis/commas.c
    M lib/gis/compress.c
    M lib/gis/compress.h
    M lib/gis/copy_dir.c
    M lib/gis/counter.c
    M lib/gis/date.c
    M lib/gis/datum.c
    M lib/gis/debug.c
    M lib/gis/distance.c
    M lib/gis/endian.c
    M lib/gis/env.c
    M lib/gis/error.c
    M lib/gis/file_name.c
    M lib/gis/find_etc.c
    M lib/gis/find_file.c
    M lib/gis/find_rast3d.c
    M lib/gis/find_vect.c
    M lib/gis/geodesic.c
    M lib/gis/geodist.c
    M lib/gis/get_ellipse.c
    M lib/gis/get_projinfo.c
    M lib/gis/get_window.c
    M lib/gis/getl.c
    M lib/gis/gisbase.c
    M lib/gis/gisinit.c
    M lib/gis/handler.c
    M lib/gis/home.c
    M lib/gis/ilist.c
    M lib/gis/intersect.c
    M lib/gis/is.c
    M lib/gis/key_value1.c
    M lib/gis/key_value2.c
    M lib/gis/key_value3.c
    M lib/gis/key_value4.c
    M lib/gis/legal_name.c
    M lib/gis/line_dist.c
    M lib/gis/list.c
    M lib/gis/ll_format.c
    M lib/gis/ll_scan.c
    M lib/gis/locale.c
    M lib/gis/location.c
    M lib/gis/lrand48.c
    M lib/gis/ls.c
    M lib/gis/ls_filter.c
    M lib/gis/lz4.c
    M lib/gis/lz4.h
    M lib/gis/mach_name.c
    M lib/gis/make_loc.c
    M lib/gis/make_mapset.c
    M lib/gis/mapcase.c
    M lib/gis/mapset.c
    M lib/gis/mapset_msc.c
    M lib/gis/mapset_nme.c
    M lib/gis/mkstemp.c
    M lib/gis/myname.c
    M lib/gis/named_colr.c
    M lib/gis/nl_to_spaces.c
    M lib/gis/nme_in_mps.c
    M lib/gis/open.c
    M lib/gis/open_misc.c
    M lib/gis/overwrite.c
    M lib/gis/pager.c
    M lib/gis/parser.c
    M lib/gis/parser_dependencies.c
    M lib/gis/parser_help.c
    M lib/gis/parser_html.c
    M lib/gis/parser_interface.c
    M lib/gis/parser_json.c
    M lib/gis/parser_local_proto.h
    M lib/gis/parser_rest.c
    M lib/gis/parser_script.c
    M lib/gis/parser_standard_options.c
    M lib/gis/parser_wps.c
    M lib/gis/paths.c
    M lib/gis/percent.c
    M lib/gis/plot.c
    M lib/gis/pole_in_poly.c
    M lib/gis/popen.c
    M lib/gis/progrm_nme.c
    M lib/gis/proj1.c
    M lib/gis/proj2.c
    M lib/gis/proj3.c
    M lib/gis/put_window.c
    M lib/gis/putenv.c
    M lib/gis/radii.c
    M lib/gis/rd_cellhd.c
    M lib/gis/remove.c
    M lib/gis/rename.c
    M lib/gis/rhumbline.c
    M lib/gis/rotate.c
    M lib/gis/seek.c
    M lib/gis/set_window.c
    M lib/gis/short_way.c
    M lib/gis/snprintf.c
    M lib/gis/spawn.c
    M lib/gis/strings.c
    M lib/gis/tempfile.c
    M lib/gis/timestamp.c
    M lib/gis/token.c
    M lib/gis/trim_dec.c
    M lib/gis/units.c
    M lib/gis/user_config.c
    M lib/gis/verbose.c
    M lib/gis/view.c
    M lib/gis/whoami.c
    M lib/gis/win32_pipes.c
    M lib/gis/wind_2_box.c
    M lib/gis/wind_format.c
    M lib/gis/wind_in.c
    M lib/gis/wind_limits.c
    M lib/gis/wind_overlap.c
    M lib/gis/wind_scan.c
    M lib/gis/window_map.c
    M lib/gis/worker.c
    M lib/gis/wr_cellhd.c
    M lib/gis/writ_zeros.c
    M lib/gis/xdr.c
    M lib/gmath/blas_level_1.c
    M lib/gmath/blas_level_2.c
    M lib/gmath/blas_level_3.c
    M lib/gmath/brent.c
    M lib/gmath/ccmath_grass_wrapper.c
    M lib/gmath/dalloc.c
    M lib/gmath/del2g.c
    M lib/gmath/eigen_tools.c
    M lib/gmath/fft.c
    M lib/gmath/findzc.c
    M lib/gmath/gauss.c
    M lib/gmath/getg.c
    M lib/gmath/ialloc.c
    M lib/gmath/la.c
    M lib/gmath/lu.c
    M lib/gmath/max_pow2.c
    M lib/gmath/mult.c
    M lib/gmath/rand1.c
    M lib/gmath/solvers_classic_iter.c
    M lib/gmath/solvers_direct.c
    M lib/gmath/solvers_direct_cholesky_band.c
    M lib/gmath/solvers_krylov.c
    M lib/gmath/sparse_matrix.c
    M lib/gmath/symmetric_band_matrix.c
    M lib/gmath/test/bench_blas2.c
    M lib/gmath/test/bench_blas3.c
    M lib/gmath/test/bench_solver_direct.c
    M lib/gmath/test/bench_solver_krylov.c
    M lib/gmath/test/test_blas1.c
    M lib/gmath/test/test_blas2.c
    M lib/gmath/test/test_blas3.c
    M lib/gmath/test/test_ccmath_wrapper.c
    M lib/gmath/test/test_gmath_lib.h
    M lib/gmath/test/test_main.c
    M lib/gmath/test/test_matrix_conversion.c
    M lib/gmath/test/test_solvers.c
    M lib/gmath/test/test_tools.c
    M lib/gmath/test/test_tools_les.c
    M lib/gpde/N_gwflow.h
    M lib/gpde/N_heatflow.h
    M lib/gpde/N_pde.h
    M lib/gpde/N_solute_transport.h
    M lib/gpde/n_arrays.c
    M lib/gpde/n_arrays_calc.c
    M lib/gpde/n_arrays_io.c
    M lib/gpde/n_geom.c
    M lib/gpde/n_gradient.c
    M lib/gpde/n_gradient_calc.c
    M lib/gpde/n_gwflow.c
    M lib/gpde/n_les.c
    M lib/gpde/n_les_assemble.c
    M lib/gpde/n_parse_options.c
    M lib/gpde/n_solute_transport.c
    M lib/gpde/n_tools.c
    M lib/gpde/n_upwind.c
    M lib/gpde/test/test_arrays.c
    M lib/gpde/test/test_assemble.c
    M lib/gpde/test/test_geom.c
    M lib/gpde/test/test_gpde_lib.h
    M lib/gpde/test/test_gradient.c
    M lib/gpde/test/test_gwflow.c
    M lib/gpde/test/test_heat.c
    M lib/gpde/test/test_les.c
    M lib/gpde/test/test_main.c
    M lib/gpde/test/test_solute_transport.c
    M lib/gpde/test/test_tools.c
    M lib/imagery/alloc.c
    M lib/imagery/eol.c
    M lib/imagery/fopen.c
    M lib/imagery/georef.c
    M lib/imagery/georef_tps.c
    M lib/imagery/group.c
    M lib/imagery/iclass.c
    M lib/imagery/iclass_bands.c
    M lib/imagery/iclass_local_proto.h
    M lib/imagery/iclass_perimeter.c
    M lib/imagery/iclass_signatures.c
    M lib/imagery/iclass_statistics.c
    M lib/imagery/iscatt_core.c
    M lib/imagery/iscatt_structs.c
    M lib/imagery/loc_info.c
    M lib/imagery/points.c
    M lib/imagery/ref.c
    M lib/imagery/sig.c
    M lib/imagery/sigset.c
    M lib/imagery/target.c
    M lib/imagery/title.c
    M lib/imagery/var.c
    M lib/init/clean_temp.c
    M lib/init/echo.c
    M lib/init/lock.c
    M lib/init/run.c
    M lib/init/winlocale.c
    M lib/lidar/InterpSpline.c
    M lib/lidar/lidar.h
    M lib/lidar/raster.c
    M lib/lidar/zones.c
    M lib/linkm/dispose.c
    M lib/linkm/init.c
    M lib/linkm/new.c
    M lib/linkm/test/linkm.c
    M lib/linkm/test/malloc.c
    M lib/linkm/test/speed.c
    M lib/linkm/test/speed2.c
    M lib/linkm/test/speed3.c
    M lib/linkm/test/try.c
    M lib/linkm/test/try2.c
    M lib/manage/add_elem.c
    M lib/manage/do_copy.c
    M lib/manage/do_list.c
    M lib/manage/do_remove.c
    M lib/manage/do_rename.c
    M lib/manage/empty.c
    M lib/manage/find.c
    M lib/manage/get_len.c
    M lib/manage/list.c
    M lib/manage/option.c
    M lib/manage/read_list.c
    M lib/manage/show_elem.c
    M lib/manage/sighold.c
    M lib/nviz/change_view.c
    M lib/nviz/cplanes_obj.c
    M lib/nviz/draw.c
    M lib/nviz/exag.c
    M lib/nviz/lights.c
    M lib/nviz/map_obj.c
    M lib/nviz/nviz.c
    M lib/nviz/position.c
    M lib/nviz/render.c
    M lib/ogsf/gk.c
    M lib/ogsf/gk2.c
    M lib/ogsf/gp.c
    M lib/ogsf/gp2.c
    M lib/ogsf/gp3.c
    M lib/ogsf/gpd.c
    M lib/ogsf/gs.c
    M lib/ogsf/gs2.c
    M lib/ogsf/gs3.c
    M lib/ogsf/gs_bm.c
    M lib/ogsf/gs_norms.c
    M lib/ogsf/gs_query.c
    M lib/ogsf/gs_util.c
    M lib/ogsf/gsd_cplane.c
    M lib/ogsf/gsd_fringe.c
    M lib/ogsf/gsd_img_ppm.c
    M lib/ogsf/gsd_img_tif.c
    M lib/ogsf/gsd_label.c
    M lib/ogsf/gsd_legend.c
    M lib/ogsf/gsd_objs.c
    M lib/ogsf/gsd_prim.c
    M lib/ogsf/gsd_surf.c
    M lib/ogsf/gsd_views.c
    M lib/ogsf/gsd_wire.c
    M lib/ogsf/gsdiff.c
    M lib/ogsf/gsdrape.c
    M lib/ogsf/gsds.c
    M lib/ogsf/gsget.c
    M lib/ogsf/gsget.h
    M lib/ogsf/gsx.c
    M lib/ogsf/gv.c
    M lib/ogsf/gv2.c
    M lib/ogsf/gv3.c
    M lib/ogsf/gv_quick.c
    M lib/ogsf/gvd.c
    M lib/ogsf/gvl.c
    M lib/ogsf/gvl2.c
    M lib/ogsf/gvl3.c
    M lib/ogsf/gvl_calc.c
    M lib/ogsf/gvl_calc2.c
    M lib/ogsf/gvl_file.c
    M lib/ogsf/gvld.c
    M lib/ogsf/mc33_table.h
    M lib/ogsf/trans.c
    M lib/pngdriver/box.c
    M lib/pngdriver/color.c
    M lib/pngdriver/color_table.c
    M lib/pngdriver/draw.c
    M lib/pngdriver/draw_bitmap.c
    M lib/pngdriver/draw_line.c
    M lib/pngdriver/draw_point.c
    M lib/pngdriver/driver.c
    M lib/pngdriver/erase.c
    M lib/pngdriver/graph_close.c
    M lib/pngdriver/graph_set.c
    M lib/pngdriver/line_width.c
    M lib/pngdriver/pngdriver.h
    M lib/pngdriver/point.c
    M lib/pngdriver/polygon.c
    M lib/pngdriver/raster.c
    M lib/pngdriver/read.c
    M lib/pngdriver/read_bmp.c
    M lib/pngdriver/read_png.c
    M lib/pngdriver/read_ppm.c
    M lib/pngdriver/set_window.c
    M lib/pngdriver/write.c
    M lib/pngdriver/write_bmp.c
    M lib/pngdriver/write_png.c
    M lib/pngdriver/write_ppm.c
    M lib/proj/convert.c
    M lib/proj/datum.c
    M lib/proj/do_proj.c
    M lib/proj/ellipse.c
    M lib/proj/ftol.c
    M lib/proj/get_proj.c
    M lib/psdriver/color.c
    M lib/psdriver/draw.c
    M lib/psdriver/draw_bitmap.c
    M lib/psdriver/driver.c
    M lib/psdriver/erase.c
    M lib/psdriver/graph_close.c
    M lib/psdriver/graph_set.c
    M lib/psdriver/line_width.c
    M lib/psdriver/psdriver.h
    M lib/psdriver/raster.c
    M lib/psdriver/set_window.c
    M lib/raster/R.h
    M lib/raster/align_window.c
    M lib/raster/alloc_cell.c
    M lib/raster/cats.c
    M lib/raster/cell_stats.c
    M lib/raster/cell_title.c
    M lib/raster/cellstats_eq.c
    M lib/raster/close.c
    M lib/raster/color_compat.c
    M lib/raster/color_free.c
    M lib/raster/color_get.c
    M lib/raster/color_hist.c
    M lib/raster/color_init.c
    M lib/raster/color_insrt.c
    M lib/raster/color_look.c
    M lib/raster/color_org.c
    M lib/raster/color_out.c
    M lib/raster/color_rand.c
    M lib/raster/color_range.c
    M lib/raster/color_read.c
    M lib/raster/color_remove.c
    M lib/raster/color_rule.c
    M lib/raster/color_rule_get.c
    M lib/raster/color_rules.c
    M lib/raster/color_set.c
    M lib/raster/color_write.c
    M lib/raster/color_xform.c
    M lib/raster/format.c
    M lib/raster/fpreclass.c
    M lib/raster/gdal.c
    M lib/raster/get_row.c
    M lib/raster/get_row_colr.c
    M lib/raster/histo_eq.c
    M lib/raster/histogram.c
    M lib/raster/history.c
    M lib/raster/init.c
    M lib/raster/interp.c
    M lib/raster/null_val.c
    M lib/raster/open.c
    M lib/raster/put_cellhd.c
    M lib/raster/put_row.c
    M lib/raster/put_title.c
    M lib/raster/quant.c
    M lib/raster/quant_io.c
    M lib/raster/quant_rw.c
    M lib/raster/range.c
    M lib/raster/rast_to_img_string.c
    M lib/raster/raster.c
    M lib/raster/raster_metadata.c
    M lib/raster/reclass.c
    M lib/raster/sample.c
    M lib/raster/set_window.c
    M lib/raster/vrt.c
    M lib/raster/window.c
    M lib/raster/window_map.c
    M lib/raster3d/alloc.c
    M lib/raster3d/cache.c
    M lib/raster3d/cache1.c
    M lib/raster3d/cachehash.c
    M lib/raster3d/cats.c
    M lib/raster3d/changeprecision.c
    M lib/raster3d/changetype.c
    M lib/raster3d/close.c
    M lib/raster3d/color.c
    M lib/raster3d/defaults.c
    M lib/raster3d/doubleio.c
    M lib/raster3d/error.c
    M lib/raster3d/filecompare.c
    M lib/raster3d/filename.c
    M lib/raster3d/fpcompress.c
    M lib/raster3d/fpxdr.c
    M lib/raster3d/getblock.c
    M lib/raster3d/getvalue.c
    M lib/raster3d/gradient.c
    M lib/raster3d/header.c
    M lib/raster3d/headerinfo.c
    M lib/raster3d/history.c
    M lib/raster3d/index.c
    M lib/raster3d/intio.c
    M lib/raster3d/keys.c
    M lib/raster3d/long.c
    M lib/raster3d/mask.c
    M lib/raster3d/maskfn.c
    M lib/raster3d/misc.c
    M lib/raster3d/null.c
    M lib/raster3d/open.c
    M lib/raster3d/open2.c
    M lib/raster3d/param.c
    M lib/raster3d/putvalue.c
    M lib/raster3d/range.c
    M lib/raster3d/raster3d_intern.h
    M lib/raster3d/region.c
    M lib/raster3d/resample.c
    M lib/raster3d/retile.c
    M lib/raster3d/rle.c
    M lib/raster3d/test/test_coordinate_transform.c
    M lib/raster3d/test/test_main.c
    M lib/raster3d/test/test_put_get_value.c
    M lib/raster3d/test/test_put_get_value_large_file.c
    M lib/raster3d/test/test_tools.c
    M lib/raster3d/tilealloc.c
    M lib/raster3d/tileio.c
    M lib/raster3d/tilemath.c
    M lib/raster3d/tileread.c
    M lib/raster3d/tilewrite.c
    M lib/raster3d/volume.c
    M lib/raster3d/window.c
    M lib/raster3d/windowio.c
    M lib/raster3d/writeascii.c
    M lib/rowio/fileno.c
    M lib/rowio/forget.c
    M lib/rowio/get.c
    M lib/rowio/put.c
    M lib/rowio/release.c
    M lib/rowio/setup.c
    M lib/rst/data/dataquad.c
    M lib/rst/data/dataquad.h
    M lib/rst/interp_float/distance.c
    M lib/rst/interp_float/func2d.c
    M lib/rst/interp_float/init2d.c
    M lib/rst/interp_float/input2d.c
    M lib/rst/interp_float/interp2d.c
    M lib/rst/interp_float/interpf.h
    M lib/rst/interp_float/matrix.c
    M lib/rst/interp_float/minmax.c
    M lib/rst/interp_float/output2d.c
    M lib/rst/interp_float/point2d.c
    M lib/rst/interp_float/resout2d.c
    M lib/rst/interp_float/ressegm2d.c
    M lib/rst/interp_float/secpar2d.c
    M lib/rst/interp_float/segmen2d.c
    M lib/rst/interp_float/segmen2d_parallel.c
    M lib/rst/interp_float/vinput2d.c
    M lib/rst/interp_float/write2d.c
    M lib/rst/qtree/qtree.c
    M lib/rst/qtree/qtree.h
    M lib/stats/c_ave.c
    M lib/stats/c_count.c
    M lib/stats/c_divr.c
    M lib/stats/c_intr.c
    M lib/stats/c_kurt.c
    M lib/stats/c_max.c
    M lib/stats/c_maxx.c
    M lib/stats/c_median.c
    M lib/stats/c_min.c
    M lib/stats/c_minx.c
    M lib/stats/c_mode.c
    M lib/stats/c_percentile.c
    M lib/stats/c_range.c
    M lib/stats/c_reg.c
    M lib/stats/c_skew.c
    M lib/stats/c_stddev.c
    M lib/stats/c_sum.c
    M lib/stats/c_thresh.c
    M lib/stats/c_var.c
    M lib/stats/sort_cell.c
    M lib/symbol/read.c
    M lib/symbol/stroke.c
    M lib/temporal/lib/connect.c
    M lib/temporal/lib/default_name.c
    M lib/temporal/lib/map_list.c
    M lib/vector/Vlib/area.c
    M lib/vector/Vlib/area_pg.c
    M lib/vector/Vlib/array.c
    M lib/vector/Vlib/ascii.c
    M lib/vector/Vlib/box.c
    M lib/vector/Vlib/break_lines.c
    M lib/vector/Vlib/break_polygons.c
    M lib/vector/Vlib/bridges.c
    M lib/vector/Vlib/buffer.c
    M lib/vector/Vlib/buffer2.c
    M lib/vector/Vlib/build.c
    M lib/vector/Vlib/build_nat.c
    M lib/vector/Vlib/build_ogr.c
    M lib/vector/Vlib/build_pg.c
    M lib/vector/Vlib/build_sfa.c
    M lib/vector/Vlib/cats.c
    M lib/vector/Vlib/cindex.c
    M lib/vector/Vlib/clean_nodes.c
    M lib/vector/Vlib/close.c
    M lib/vector/Vlib/close_nat.c
    M lib/vector/Vlib/close_ogr.c
    M lib/vector/Vlib/close_pg.c
    M lib/vector/Vlib/color_read.c
    M lib/vector/Vlib/color_remove.c
    M lib/vector/Vlib/color_write.c
    M lib/vector/Vlib/constraint.c
    M lib/vector/Vlib/copy.c
    M lib/vector/Vlib/dangles.c
    M lib/vector/Vlib/dbcolumns.c
    M lib/vector/Vlib/dgraph.c
    M lib/vector/Vlib/dgraph.h
    M lib/vector/Vlib/e_intersect.c
    M lib/vector/Vlib/e_intersect.h
    M lib/vector/Vlib/field.c
    M lib/vector/Vlib/find.c
    M lib/vector/Vlib/geos.c
    M lib/vector/Vlib/geos_to_wktb.c
    M lib/vector/Vlib/graph.c
    M lib/vector/Vlib/handler.c
    M lib/vector/Vlib/header.c
    M lib/vector/Vlib/header_finfo.c
    M lib/vector/Vlib/hist.c
    M lib/vector/Vlib/init_head.c
    M lib/vector/Vlib/intersect.c
    M lib/vector/Vlib/intersect2.c
    M lib/vector/Vlib/legal_vname.c
    M lib/vector/Vlib/level.c
    M lib/vector/Vlib/level_two.c
    M lib/vector/Vlib/line.c
    M lib/vector/Vlib/list.c
    M lib/vector/Vlib/local_proto.h
    M lib/vector/Vlib/map.c
    M lib/vector/Vlib/merge_lines.c
    M lib/vector/Vlib/net_analyze.c
    M lib/vector/Vlib/net_build.c
    M lib/vector/Vlib/open.c
    M lib/vector/Vlib/open_nat.c
    M lib/vector/Vlib/open_ogr.c
    M lib/vector/Vlib/open_pg.c
    M lib/vector/Vlib/overlap.c
    M lib/vector/Vlib/overlay.c
    M lib/vector/Vlib/pg_local_proto.h
    M lib/vector/Vlib/poly.c
    M lib/vector/Vlib/read.c
    M lib/vector/Vlib/read_nat.c
    M lib/vector/Vlib/read_ogr.c
    M lib/vector/Vlib/read_pg.c
    M lib/vector/Vlib/read_sfa.c
    M lib/vector/Vlib/remove_areas.c
    M lib/vector/Vlib/remove_duplicates.c
    M lib/vector/Vlib/rewind.c
    M lib/vector/Vlib/rewind_nat.c
    M lib/vector/Vlib/rewind_ogr.c
    M lib/vector/Vlib/rewind_pg.c
    M lib/vector/Vlib/rtree_search.c
    M lib/vector/Vlib/select.c
    M lib/vector/Vlib/simple_features.c
    M lib/vector/Vlib/sindex.c
    M lib/vector/Vlib/snap.c
    M lib/vector/Vlib/tin.c
    M lib/vector/Vlib/type.c
    M lib/vector/Vlib/write.c
    M lib/vector/Vlib/write_nat.c
    M lib/vector/Vlib/write_ogr.c
    M lib/vector/Vlib/write_pg.c
    M lib/vector/Vlib/write_sfa.c
    M lib/vector/diglib/allocation.c
    M lib/vector/diglib/angle.c
    M lib/vector/diglib/box.c
    M lib/vector/diglib/cindex.c
    M lib/vector/diglib/cindex_rw.c
    M lib/vector/diglib/file.c
    M lib/vector/diglib/frmt.c
    M lib/vector/diglib/head.c
    M lib/vector/diglib/inside.c
    M lib/vector/diglib/line_dist.c
    M lib/vector/diglib/linecros.c
    M lib/vector/diglib/list.c
    M lib/vector/diglib/plus.c
    M lib/vector/diglib/plus_area.c
    M lib/vector/diglib/plus_line.c
    M lib/vector/diglib/plus_node.c
    M lib/vector/diglib/plus_struct.c
    M lib/vector/diglib/poly.c
    M lib/vector/diglib/port_init.c
    M lib/vector/diglib/port_test.c
    M lib/vector/diglib/portable.c
    M lib/vector/diglib/prune.c
    M lib/vector/diglib/spindex.c
    M lib/vector/diglib/spindex_rw.c
    M lib/vector/diglib/struct_alloc.c
    M lib/vector/diglib/test.c
    M lib/vector/diglib/type.c
    M lib/vector/diglib/update.c
    M lib/vector/neta/articulation_point.c
    M lib/vector/neta/bridge.c
    M lib/vector/neta/centrality.c
    M lib/vector/neta/components.c
    M lib/vector/neta/flow.c
    M lib/vector/neta/path.c
    M lib/vector/neta/spanningtree.c
    M lib/vector/neta/timetables.c
    M lib/vector/neta/utils.c
    M lib/vector/rtree/card.c
    M lib/vector/rtree/docs/test.c
    M lib/vector/rtree/gammavol.c
    M lib/vector/rtree/index.c
    M lib/vector/rtree/index.h
    M lib/vector/rtree/indexf.c
    M lib/vector/rtree/indexm.c
    M lib/vector/rtree/io.c
    M lib/vector/rtree/node.c
    M lib/vector/rtree/rect.c
    M lib/vector/rtree/rtree.h
    M lib/vector/rtree/split.c
    M lib/vector/rtree/test_suite/test_basics.c
    M lib/vector/rtree/test_suite/test_main.c
    M lib/vector/vedit/break.c
    M lib/vector/vedit/cats.c
    M lib/vector/vedit/chtype.c
    M lib/vector/vedit/copy.c
    M lib/vector/vedit/delete.c
    M lib/vector/vedit/distance.c
    M lib/vector/vedit/extend.c
    M lib/vector/vedit/flip.c
    M lib/vector/vedit/merge.c
    M lib/vector/vedit/move.c
    M lib/vector/vedit/render.c
    M lib/vector/vedit/select.c
    M lib/vector/vedit/snap.c
    M lib/vector/vedit/vertex.c
    M lib/vector/vedit/zbulk.c
    M misc/m.cogo/main.c
    M misc/m.measure/main.c
    M misc/m.nviz.image/args.c
    M misc/m.nviz.image/cplane.c
    M misc/m.nviz.image/local_proto.h
    M misc/m.nviz.image/main.c
    M misc/m.nviz.image/surface.c
    M misc/m.nviz.image/vector.c
    M misc/m.nviz.image/volume.c
    M misc/m.nviz.image/write_img.c
    M misc/m.nviz.script/main.c
    M misc/m.transform/main.c
    M raster/r.basins.fill/main.c
    M raster/r.basins.fill/read_map.c
    M raster/r.buffer/execute.c
    M raster/r.buffer/find_dist.c
    M raster/r.buffer/init.c
    M raster/r.buffer/main.c
    M raster/r.buffer/parse_dist.c
    M raster/r.buffer/process_at.c
    M raster/r.buffer/process_left.c
    M raster/r.buffer/process_rite.c
    M raster/r.buffer/process_row.c
    M raster/r.buffer/read_map.c
    M raster/r.buffer/support.c
    M raster/r.buffer/write_map.c
    M raster/r.buildvrt/link.c
    M raster/r.buildvrt/main.c
    M raster/r.buildvrt/proto.h
    M raster/r.carve/enforce.h
    M raster/r.carve/enforce_ds.c
    M raster/r.carve/lobf.c
    M raster/r.carve/main.c
    M raster/r.carve/raster.c
    M raster/r.carve/support.c
    M raster/r.carve/vect.c
    M raster/r.category/cats.c
    M raster/r.category/main.c
    M raster/r.circle/main.c
    M raster/r.coin/format.c
    M raster/r.coin/main.c
    M raster/r.coin/make_coin.c
    M raster/r.coin/print_coin.c
    M raster/r.coin/print_hdr.c
    M raster/r.coin/prnt_entry.c
    M raster/r.coin/totals.c
    M raster/r.colors.out/raster3d_main.c
    M raster/r.colors.out/raster_main.c
    M raster/r.colors/edit_colors.c
    M raster/r.colors/local_proto.h
    M raster/r.colors/raster3d_main.c
    M raster/r.colors/raster_main.c
    M raster/r.colors/rules.c
    M raster/r.colors/stats.c
    M raster/r.composite/main.c
    M raster/r.compress/main.c
    M raster/r.contour/cont.c
    M raster/r.contour/local_proto.h
    M raster/r.contour/main.c
    M raster/r.cost/cost.h
    M raster/r.cost/flag.c
    M raster/r.cost/heap.c
    M raster/r.cost/main.c
    M raster/r.covar/main.c
    M raster/r.cross/cats.c
    M raster/r.cross/cross.c
    M raster/r.cross/glob.h
    M raster/r.cross/main.c
    M raster/r.cross/renumber.c
    M raster/r.cross/store.c
    M raster/r.describe/describe.c
    M raster/r.describe/dumplist.c
    M raster/r.describe/local_proto.h
    M raster/r.describe/main.c
    M raster/r.describe/tree.c
    M raster/r.distance/defs.h
    M raster/r.distance/distance.c
    M raster/r.distance/edges.c
    M raster/r.distance/labels.c
    M raster/r.distance/main.c
    M raster/r.distance/parse.c
    M raster/r.distance/report.c
    M raster/r.drain/filldir.c
    M raster/r.drain/main.c
    M raster/r.drain/resolve.c
    M raster/r.drain/tinf.c
    M raster/r.drain/tinf.h
    M raster/r.external.out/main.c
    M raster/r.external/colors.c
    M raster/r.external/link.c
    M raster/r.external/list.c
    M raster/r.external/main.c
    M raster/r.external/proj.c
    M raster/r.external/proto.h
    M raster/r.external/window.c
    M raster/r.fill.dir/dopolys.c
    M raster/r.fill.dir/filldir.c
    M raster/r.fill.dir/main.c
    M raster/r.fill.dir/ppupdate.c
    M raster/r.fill.dir/resolve.c
    M raster/r.fill.dir/tinf.c
    M raster/r.fill.dir/tinf.h
    M raster/r.fill.dir/wtrshed.c
    M raster/r.fill.stats/cell_funcs.c
    M raster/r.fill.stats/cell_funcs.h
    M raster/r.fill.stats/main.c
    M raster/r.flow/aspect.c
    M raster/r.flow/io.c
    M raster/r.flow/main.c
    M raster/r.flow/mem.c
    M raster/r.flow/precomp.c
    M raster/r.flow/r.flow.h
    M raster/r.geomorphon/geom.c
    M raster/r.geomorphon/local_proto.h
    M raster/r.geomorphon/main.c
    M raster/r.geomorphon/pattern.c
    M raster/r.grow.distance/main.c
    M raster/r.gwflow/main.c
    M raster/r.his/his.c
    M raster/r.his/main.c
    M raster/r.horizon/main.c
    M raster/r.in.ascii/gethead.c
    M raster/r.in.ascii/main.c
    M raster/r.in.bin/gmt_grd.h
    M raster/r.in.bin/main.c
    M raster/r.in.gdal/main.c
    M raster/r.in.gdal/proj.c
    M raster/r.in.gridatb/adjcellhd.c
    M raster/r.in.gridatb/check_ready.c
    M raster/r.in.gridatb/file_io.c
    M raster/r.in.gridatb/main.c
    M raster/r.in.lidar/info.c
    M raster/r.in.lidar/local_proto.h
    M raster/r.in.lidar/main.c
    M raster/r.in.lidar/point_binning.c
    M raster/r.in.lidar/string_list.c
    M raster/r.in.lidar/support.c
    M raster/r.in.mat/main.c
    M raster/r.in.pdal/bin_write.c
    M raster/r.in.png/main.c
    M raster/r.in.poly/get_item.c
    M raster/r.in.poly/getformat.c
    M raster/r.in.poly/local_proto.h
    M raster/r.in.poly/main.c
    M raster/r.in.poly/poly2rast.c
    M raster/r.in.poly/raster.c
    M raster/r.in.xyz/main.c
    M raster/r.in.xyz/support.c
    M raster/r.info/main.c
    M raster/r.info/reclas_txt.c
    M raster/r.kappa/calc_kappa.c
    M raster/r.kappa/main.c
    M raster/r.kappa/prt2csv_mat.c
    M raster/r.kappa/prt_hdr.c
    M raster/r.kappa/prt_label.c
    M raster/r.kappa/prt_mat.c
    M raster/r.kappa/stats.c
    M raster/r.kappa/sum.c
    M raster/r.lake/main.c
    M raster/r.latlong/main.c
    M raster/r.mapcalc/column_shift.c
    M raster/r.mapcalc/evaluate.c
    M raster/r.mapcalc/expression.c
    M raster/r.mapcalc/expression.h
    M raster/r.mapcalc/function.c
    M raster/r.mapcalc/main.c
    M raster/r.mapcalc/map.c
    M raster/r.mapcalc/map3.c
    M raster/r.mapcalc/mapcalc.h
    M raster/r.mapcalc/xarea.c
    M raster/r.mapcalc/xcoor.c
    M raster/r.mapcalc/xcoor3.c
    M raster/r.mapcalc/xres.c
    M raster/r.mapcalc/xres3.c
    M raster/r.mapcalc/xrowcol.c
    M raster/r.mfilter/apply.c
    M raster/r.mfilter/execute.c
    M raster/r.mfilter/filter.h
    M raster/r.mfilter/getfilt.c
    M raster/r.mfilter/getrow.c
    M raster/r.mfilter/main.c
    M raster/r.mfilter/perform.c
    M raster/r.mfilter/uppercase.c
    M raster/r.mode/main.c
    M raster/r.mode/read_stats.c
    M raster/r.mode/write_rec.c
    M raster/r.neighbors/bufs.c
    M raster/r.neighbors/divr_cats.c
    M raster/r.neighbors/gather.c
    M raster/r.neighbors/intr_cats.c
    M raster/r.neighbors/main.c
    M raster/r.neighbors/ncb.h
    M raster/r.neighbors/readcell.c
    M raster/r.neighbors/readweights.c
    M raster/r.null/main.c
    M raster/r.null/mask.c
    M raster/r.out.ascii/formspecific.c
    M raster/r.out.ascii/main.c
    M raster/r.out.bin/gmt_grd.h
    M raster/r.out.bin/main.c
    M raster/r.out.gdal/attr.c
    M raster/r.out.gdal/export_band.c
    M raster/r.out.gdal/local_proto.h
    M raster/r.out.gdal/main.c
    M raster/r.out.gridatb/main.c
    M raster/r.out.mat/main.c
    M raster/r.out.mpeg/main.c
    M raster/r.out.mpeg/write.c
    M raster/r.out.png/main.c
    M raster/r.out.png/pngfunc.h
    M raster/r.out.pov/main.c
    M raster/r.out.ppm/main.c
    M raster/r.out.ppm3/main.c
    M raster/r.out.vrml/main.c
    M raster/r.out.vrml/put_grid.c
    M raster/r.out.vrml/put_view.c
    M raster/r.out.vrml/pv.h
    M raster/r.out.vrml/vrml.c
    M raster/r.out.vtk/main.c
    M raster/r.out.vtk/parameters.c
    M raster/r.out.vtk/parameters.h
    M raster/r.out.vtk/writeascii.c
    M raster/r.out.vtk/writeascii.h
    M raster/r.param.scale/close_down.c
    M raster/r.param.scale/disp_matrix.c
    M raster/r.param.scale/feature.c
    M raster/r.param.scale/find_normal.c
    M raster/r.param.scale/interface.c
    M raster/r.param.scale/main.c
    M raster/r.param.scale/nrutil.c
    M raster/r.param.scale/nrutil.h
    M raster/r.param.scale/open_files.c
    M raster/r.param.scale/param.c
    M raster/r.param.scale/param.h
    M raster/r.param.scale/process.c
    M raster/r.param.scale/write_cols.c
    M raster/r.patch/do_patch.c
    M raster/r.patch/main.c
    M raster/r.patch/support.c
    M raster/r.path/main.c
    M raster/r.path/pavlrc.c
    M raster/r.path/pavlrc.h
    M raster/r.profile/input.c
    M raster/r.profile/local_proto.h
    M raster/r.profile/main.c
    M raster/r.profile/read_rast.c
    M raster/r.proj/bilinear.c
    M raster/r.proj/bilinear_f.c
    M raster/r.proj/bordwalk.c
    M raster/r.proj/cubic.c
    M raster/r.proj/cubic_f.c
    M raster/r.proj/lanczos.c
    M raster/r.proj/main.c
    M raster/r.proj/nearest.c
    M raster/r.proj/r.proj.h
    M raster/r.proj/readcell.c
    M raster/r.quant/global.h
    M raster/r.quant/main.c
    M raster/r.quant/read_rules.c
    M raster/r.quantile/main.c
    M raster/r.random.cells/flag.c
    M raster/r.random.cells/gasdev.c
    M raster/r.random.cells/indep.c
    M raster/r.random.cells/init.c
    M raster/r.random.cells/main.c
    M raster/r.random.surface/calcsd.c
    M raster/r.random.surface/calcsurf.c
    M raster/r.random.surface/dd.c
    M raster/r.random.surface/digits.c
    M raster/r.random.surface/gasdev.c
    M raster/r.random.surface/gennorm.c
    M raster/r.random.surface/init.c
    M raster/r.random.surface/local_proto.h
    M raster/r.random.surface/main.c
    M raster/r.random.surface/makebigf.c
    M raster/r.random.surface/makepp.c
    M raster/r.random.surface/save.c
    M raster/r.random.surface/zero.c
    M raster/r.random/count.c
    M raster/r.random/main.c
    M raster/r.random/random.c
    M raster/r.random/support.c
    M raster/r.reclass/add_rule.c
    M raster/r.reclass/input.c
    M raster/r.reclass/main.c
    M raster/r.reclass/parse.c
    M raster/r.reclass/range.c
    M raster/r.reclass/reclass.c
    M raster/r.reclass/rule.h
    M raster/r.reclass/stats.c
    M raster/r.recode/main.c
    M raster/r.recode/read_rules.c
    M raster/r.recode/recode.c
    M raster/r.region/main.c
    M raster/r.regression.line/main.c
    M raster/r.regression.multi/main.c
    M raster/r.relief/main.c
    M raster/r.report/format.c
    M raster/r.report/global.h
    M raster/r.report/header.c
    M raster/r.report/label.c
    M raster/r.report/parse.c
    M raster/r.report/prt_report.c
    M raster/r.report/prt_unit.c
    M raster/r.report/report.c
    M raster/r.report/stats.c
    M raster/r.report/sums.c
    M raster/r.resamp.bspline/bspline.h
    M raster/r.resamp.bspline/crosscorr.c
    M raster/r.resamp.bspline/main.c
    M raster/r.resamp.bspline/resamp.c
    M raster/r.resamp.filter/main.c
    M raster/r.resamp.interp/main.c
    M raster/r.resamp.rst/main.c
    M raster/r.resamp.stats/main.c
    M raster/r.resample/main.c
    M raster/r.rescale.eq/get_range.c
    M raster/r.rescale.eq/get_stats.c
    M raster/r.rescale.eq/main.c
    M raster/r.rescale/get_range.c
    M raster/r.rescale/main.c
    M raster/r.ros/local_proto.h
    M raster/r.ros/main.c
    M raster/r.ros/spot_dist.c
    M raster/r.series.accumulate/main.c
    M raster/r.series.interp/main.c
    M raster/r.series/main.c
    M raster/r.sim/r.sim.sediment/main.c
    M raster/r.sim/r.sim.water/main.c
    M raster/r.sim/simlib/erod.c
    M raster/r.sim/simlib/hydro.c
    M raster/r.sim/simlib/input.c
    M raster/r.sim/simlib/observation_points.c
    M raster/r.sim/simlib/output.c
    M raster/r.sim/simlib/random.c
    M raster/r.sim/simlib/simlib.h
    M raster/r.sim/simlib/utils.c
    M raster/r.sim/simlib/waterglobs.h
    M raster/r.slope.aspect/main.c
    M raster/r.solute.transport/main.c
    M raster/r.spread/collect_ori.c
    M raster/r.spread/deleteHa.c
    M raster/r.spread/display.c
    M raster/r.spread/fixHa.c
    M raster/r.spread/get_minHa.c
    M raster/r.spread/insert2Ha.c
    M raster/r.spread/insertHa.c
    M raster/r.spread/main.c
    M raster/r.spread/pick_dist.c
    M raster/r.spread/pick_ignite.c
    M raster/r.spread/ram2out.c
    M raster/r.spread/replaceHa.c
    M raster/r.spread/select_linksB.c
    M raster/r.spread/spot.c
    M raster/r.spread/spread.c
    M raster/r.spreadpath/drawline.c
    M raster/r.spreadpath/insert.c
    M raster/r.spreadpath/main.c
    M raster/r.spreadpath/path_finder.c
    M raster/r.statistics/main.c
    M raster/r.statistics/method.h
    M raster/r.statistics/o_adev.c
    M raster/r.statistics/o_average.c
    M raster/r.statistics/o_divr.c
    M raster/r.statistics/o_kurt.c
    M raster/r.statistics/o_max.c
    M raster/r.statistics/o_median.c
    M raster/r.statistics/o_min.c
    M raster/r.statistics/o_mode.c
    M raster/r.statistics/o_sdev.c
    M raster/r.statistics/o_skew.c
    M raster/r.statistics/o_sum.c
    M raster/r.statistics/o_var.c
    M raster/r.statistics/read_stats.c
    M raster/r.statistics/run_cmd.c
    M raster/r.statistics/write_rec.c
    M raster/r.stats.quantile/main.c
    M raster/r.stats.zonal/main.c
    M raster/r.stats/cell_stats.c
    M raster/r.stats/main.c
    M raster/r.stats/raw_stats.c
    M raster/r.stats/stats.c
    M raster/r.stream.extract/bseg.c
    M raster/r.stream.extract/close.c
    M raster/r.stream.extract/cseg.c
    M raster/r.stream.extract/del_streams.c
    M raster/r.stream.extract/do_astar.c
    M raster/r.stream.extract/dseg.c
    M raster/r.stream.extract/init_search.c
    M raster/r.stream.extract/load.c
    M raster/r.stream.extract/local_proto.h
    M raster/r.stream.extract/main.c
    M raster/r.stream.extract/seg.c
    M raster/r.stream.extract/seg.h
    M raster/r.stream.extract/streams.c
    M raster/r.stream.extract/thin.c
    M raster/r.sun/local_proto.h
    M raster/r.sun/main.c
    M raster/r.sun/rsunlib.c
    M raster/r.sun/sunradstruct.h
    M raster/r.sunhours/main.c
    M raster/r.sunhours/solpos00.c
    M raster/r.sunhours/solpos00.h
    M raster/r.sunmask/g_solposition.c
    M raster/r.sunmask/global.h
    M raster/r.sunmask/main.c
    M raster/r.sunmask/solpos00.c
    M raster/r.sunmask/solpos00.h
    M raster/r.support.stats/check.c
    M raster/r.support.stats/histo.c
    M raster/r.support.stats/main.c
    M raster/r.support/check.c
    M raster/r.support/histo.c
    M raster/r.support/main.c
    M raster/r.surf.area/area.c
    M raster/r.surf.area/local_proto.h
    M raster/r.surf.area/main.c
    M raster/r.surf.contour/add_in.c
    M raster/r.surf.contour/addpts.c
    M raster/r.surf.contour/contour.h
    M raster/r.surf.contour/find_con.c
    M raster/r.surf.contour/flag_clr_all.c
    M raster/r.surf.contour/flag_create.c
    M raster/r.surf.contour/main.c
    M raster/r.surf.contour/read_cell.c
    M raster/r.surf.fractal/frac.h
    M raster/r.surf.fractal/main.c
    M raster/r.surf.fractal/process.c
    M raster/r.surf.fractal/spec_syn.c
    M raster/r.surf.fractal/write_rast.c
    M raster/r.surf.gauss/gaussurf.c
    M raster/r.surf.gauss/main.c
    M raster/r.surf.idw/dist.c
    M raster/r.surf.idw/ll.c
    M raster/r.surf.idw/main.c
    M raster/r.surf.idw/main.h
    M raster/r.surf.random/main.c
    M raster/r.surf.random/randsurf.c
    M raster/r.texture/h_measure.c
    M raster/r.texture/h_measure.h
    M raster/r.texture/main.c
    M raster/r.thin/io.c
    M raster/r.thin/main.c
    M raster/r.thin/thin_lines.c
    M raster/r.tile/main.c
    M raster/r.timestamp/main.c
    M raster/r.to.rast3/main.c
    M raster/r.to.rast3elev/main.c
    M raster/r.to.vect/areas.c
    M raster/r.to.vect/areas_io.c
    M raster/r.to.vect/global.h
    M raster/r.to.vect/lines.c
    M raster/r.to.vect/lines_io.c
    M raster/r.to.vect/main.c
    M raster/r.to.vect/points.c
    M raster/r.to.vect/set_error_handler.c
    M raster/r.to.vect/util.c
    M raster/r.topidx/file_io.c
    M raster/r.topidx/global.h
    M raster/r.topidx/main.c
    M raster/r.topidx/topidx.c
    M raster/r.topmodel/file_io.c
    M raster/r.topmodel/global.h
    M raster/r.topmodel/infiltration.c
    M raster/r.topmodel/main.c
    M raster/r.topmodel/topmodel.c
    M raster/r.transect/local_proto.h
    M raster/r.transect/main.c
    M raster/r.transect/parse_line.c
    M raster/r.univar/globals.h
    M raster/r.univar/r.univar_main.c
    M raster/r.univar/r3.univar_main.c
    M raster/r.univar/sort.c
    M raster/r.univar/stats.c
    M raster/r.uslek/main.c
    M raster/r.uslek/prct2tex.c
    M raster/r.uslek/tex2usle_k.c
    M raster/r.usler/elswaify85.c
    M raster/r.usler/foster81.c
    M raster/r.usler/main.c
    M raster/r.usler/morgan74.c
    M raster/r.usler/roose75.c
    M raster/r.viewshed/distribute.h
    M raster/r.viewshed/eventlist.h
    M raster/r.viewshed/grass.h
    M raster/r.viewshed/grid.h
    M raster/r.viewshed/rbbst.h
    M raster/r.viewshed/statusstructure.h
    M raster/r.viewshed/viewshed.h
    M raster/r.viewshed/visibility.h
    M raster/r.volume/centroids.c
    M raster/r.volume/local_proto.h
    M raster/r.volume/main.c
    M raster/r.walk/cost.h
    M raster/r.walk/flag.c
    M raster/r.walk/heap.c
    M raster/r.walk/main.c
    M raster/r.water.outlet/main.c
    M raster/r.water.outlet/over_cells.c
    M raster/r.water.outlet/ramseg.c
    M raster/r.water.outlet/ramseg.h
    M raster/r.watershed/front/main.c
    M raster/r.watershed/ram/Gwater.h
    M raster/r.watershed/ram/close_maps.c
    M raster/r.watershed/ram/close_maps2.c
    M raster/r.watershed/ram/def_basin.c
    M raster/r.watershed/ram/do_astar.c
    M raster/r.watershed/ram/do_cum.c
    M raster/r.watershed/ram/do_flatarea.c
    M raster/r.watershed/ram/find_pour.c
    M raster/r.watershed/ram/flag_clr_all.c
    M raster/r.watershed/ram/flag_create.c
    M raster/r.watershed/ram/haf_side.c
    M raster/r.watershed/ram/init_vars.c
    M raster/r.watershed/ram/main.c
    M raster/r.watershed/ram/no_stream.c
    M raster/r.watershed/ram/over_cells.c
    M raster/r.watershed/ram/ramseg.c
    M raster/r.watershed/ram/ramseg.h
    M raster/r.watershed/ram/sg_factor.c
    M raster/r.watershed/ram/slope_len.c
    M raster/r.watershed/ram/split_str.c
    M raster/r.watershed/ram/usage.c
    M raster/r.watershed/seg/Gwater.h
    M raster/r.watershed/seg/bseg_close.c
    M raster/r.watershed/seg/bseg_get.c
    M raster/r.watershed/seg/bseg_open.c
    M raster/r.watershed/seg/bseg_put.c
    M raster/r.watershed/seg/bseg_read.c
    M raster/r.watershed/seg/bseg_write.c
    M raster/r.watershed/seg/close_maps.c
    M raster/r.watershed/seg/close_maps2.c
    M raster/r.watershed/seg/cseg.h
    M raster/r.watershed/seg/cseg_close.c
    M raster/r.watershed/seg/cseg_get.c
    M raster/r.watershed/seg/cseg_open.c
    M raster/r.watershed/seg/cseg_put.c
    M raster/r.watershed/seg/cseg_read.c
    M raster/r.watershed/seg/cseg_write.c
    M raster/r.watershed/seg/def_basin.c
    M raster/r.watershed/seg/do_astar.c
    M raster/r.watershed/seg/do_astar.h
    M raster/r.watershed/seg/do_cum.c
    M raster/r.watershed/seg/dseg_close.c
    M raster/r.watershed/seg/dseg_get.c
    M raster/r.watershed/seg/dseg_open.c
    M raster/r.watershed/seg/dseg_put.c
    M raster/r.watershed/seg/dseg_read.c
    M raster/r.watershed/seg/dseg_write.c
    M raster/r.watershed/seg/find_pour.c
    M raster/r.watershed/seg/haf_side.c
    M raster/r.watershed/seg/init_vars.c
    M raster/r.watershed/seg/main.c
    M raster/r.watershed/seg/no_stream.c
    M raster/r.watershed/seg/over_cells.c
    M raster/r.watershed/seg/sg_factor.c
    M raster/r.watershed/seg/slope_len.c
    M raster/r.watershed/seg/split_str.c
    M raster/r.watershed/seg/sseg_get.c
    M raster/r.watershed/seg/sseg_open.c
    M raster/r.watershed/seg/sseg_put.c
    M raster/r.watershed/seg/usage.c
    M raster/r.watershed/shed/accum_down.c
    M raster/r.watershed/shed/basin_maps.c
    M raster/r.watershed/shed/com_line.c
    M raster/r.watershed/shed/file_in.c
    M raster/r.watershed/shed/free.c
    M raster/r.watershed/shed/insert_cat.c
    M raster/r.watershed/shed/intro.c
    M raster/r.watershed/shed/main.c
    M raster/r.watershed/shed/print.c
    M raster/r.watershed/shed/read.c
    M raster/r.watershed/shed/valid.c
    M raster/r.watershed/shed/watershed.h
    M raster/r.what.color/main.c
    M raster/r.what/main.c
    M raster3d/r3.cross.rast/main.c
    M raster3d/r3.flow/flowline.c
    M raster3d/r3.flow/flowline.h
    M raster3d/r3.flow/integrate.c
    M raster3d/r3.flow/integrate.h
    M raster3d/r3.flow/interpolate.c
    M raster3d/r3.flow/interpolate.h
    M raster3d/r3.flow/main.c
    M raster3d/r3.flow/r3flow_structs.h
    M raster3d/r3.flow/test_main.c
    M raster3d/r3.flow/voxel_traversal.c
    M raster3d/r3.flow/voxel_traversal.h
    M raster3d/r3.gradient/main.c
    M raster3d/r3.gradient/r3gradient_structs.h
    M raster3d/r3.gwflow/main.c
    M raster3d/r3.in.ascii/main.c
    M raster3d/r3.in.bin/main.c
    M raster3d/r3.in.lidar/filters.c
    M raster3d/r3.in.lidar/info.c
    M raster3d/r3.in.lidar/main.c
    M raster3d/r3.in.lidar/projection.h
    M raster3d/r3.in.lidar/string_list.c
    M raster3d/r3.in.v5d/binio.c
    M raster3d/r3.in.v5d/main.c
    M raster3d/r3.in.v5d/v5d.c
    M raster3d/r3.in.v5d/v5d.h
    M raster3d/r3.info/main.c
    M raster3d/r3.mask/main.c
    M raster3d/r3.mkdspf/calc_linefax.c
    M raster3d/r3.mkdspf/fill_cfax.c
    M raster3d/r3.mkdspf/iso_surface.c
    M raster3d/r3.mkdspf/local_proto.h
    M raster3d/r3.mkdspf/main.c
    M raster3d/r3.mkdspf/make_header.c
    M raster3d/r3.mkdspf/r3_data.c
    M raster3d/r3.mkdspf/r3_find.c
    M raster3d/r3.mkdspf/vizual.h
    M raster3d/r3.neighbors/main.c
    M raster3d/r3.null/main.c
    M raster3d/r3.out.ascii/main.c
    M raster3d/r3.out.bin/main.c
    M raster3d/r3.out.netcdf/main.c
    M raster3d/r3.out.v5d/binio.c
    M raster3d/r3.out.v5d/main.c
    M raster3d/r3.out.v5d/v5d.c
    M raster3d/r3.out.v5d/v5d.h
    M raster3d/r3.out.vtk/errorHandling.c
    M raster3d/r3.out.vtk/main.c
    M raster3d/r3.out.vtk/parameters.c
    M raster3d/r3.out.vtk/parameters.h
    M raster3d/r3.out.vtk/writeVTKData.c
    M raster3d/r3.out.vtk/writeVTKData.h
    M raster3d/r3.out.vtk/writeVTKHead.c
    M raster3d/r3.out.vtk/writeVTKHead.h
    M raster3d/r3.retile/main.c
    M raster3d/r3.showdspf/Ball.c
    M raster3d/r3.showdspf/BallAux.c
    M raster3d/r3.showdspf/BallMath.c
    M raster3d/r3.showdspf/cap_data.c
    M raster3d/r3.showdspf/do_color_ogl.c
    M raster3d/r3.showdspf/draw_cap_ogl.c
    M raster3d/r3.showdspf/draw_cappolys_ogl.c
    M raster3d/r3.showdspf/draw_polys_ogl.c
    M raster3d/r3.showdspf/get_color_ogl.c
    M raster3d/r3.showdspf/init_caps.c
    M raster3d/r3.showdspf/main_ogl.c
    M raster3d/r3.showdspf/new_init_graphics.c
    M raster3d/r3.showdspf/r3_data.c
    M raster3d/r3.showdspf/r3_find.c
    M raster3d/r3.showdspf/thresh_array.c
    M raster3d/r3.showdspf/togif.c
    M raster3d/r3.showdspf/togif.h
    M raster3d/r3.showdspf/vizual.h
    M raster3d/r3.showdspf/vizual2.h
    M raster3d/r3.stats/local_proto.h
    M raster3d/r3.stats/main.c
    M raster3d/r3.stats/support.c
    M raster3d/r3.support/check.c
    M raster3d/r3.support/main.c
    M raster3d/r3.timestamp/main.c
    M raster3d/r3.to.rast/main.c
    M temporal/t.connect/main.c
    M utils/g.echo.c
    M utils/timer/main.c
    M vector/v.buffer/geos.c
    M vector/v.buffer/local_proto.h
    M vector/v.buffer/main.c
    M vector/v.build.polylines/main.c
    M vector/v.build.polylines/walk.c
    M vector/v.build.polylines/walk.h
    M vector/v.build/main.c
    M vector/v.category/main.c
    M vector/v.class/main.c
    M vector/v.clean/main.c
    M vector/v.clean/proto.h
    M vector/v.clean/prune.c
    M vector/v.clean/rmdac.c
    M vector/v.clean/rmline.c
    M vector/v.clean/split.c
    M vector/v.clean/test/topocheck.c
    M vector/v.cluster/main.c
    M vector/v.colors.out/local_proto.h
    M vector/v.colors.out/main.c
    M vector/v.colors.out/make_colors.c
    M vector/v.colors.out/scan_cats.c
    M vector/v.colors/local_proto.h
    M vector/v.colors/main.c
    M vector/v.colors/make_colors.c
    M vector/v.colors/read_rgb.c
    M vector/v.colors/scan_attr.c
    M vector/v.colors/scan_cats.c
    M vector/v.colors/scan_z.c
    M vector/v.colors/write_rgb.c
    M vector/v.db.connect/main.c
    M vector/v.db.select/main.c
    M vector/v.decimate/copy_tab.c
    M vector/v.decimate/count_decimation.c
    M vector/v.decimate/count_decimation.h
    M vector/v.decimate/grid_decimation.c
    M vector/v.decimate/grid_decimation.h
    M vector/v.decimate/main.c
    M vector/v.delaunay/data_types.h
    M vector/v.delaunay/edge.c
    M vector/v.delaunay/edge.h
    M vector/v.delaunay/geom_primitives.h
    M vector/v.delaunay/geometry.c
    M vector/v.delaunay/geometry.h
    M vector/v.delaunay/in_out.c
    M vector/v.delaunay/in_out.h
    M vector/v.delaunay/main.c
    M vector/v.delaunay/memory.c
    M vector/v.distance/cmp.c
    M vector/v.distance/distance.c
    M vector/v.distance/local_proto.h
    M vector/v.distance/main.c
    M vector/v.distance/print.c
    M vector/v.drape/local_proto.h
    M vector/v.drape/main.c
    M vector/v.drape/sample.c
    M vector/v.edit/args.c
    M vector/v.edit/close.c
    M vector/v.edit/global.h
    M vector/v.edit/main.c
    M vector/v.edit/max_distance.c
    M vector/v.edit/proto.h
    M vector/v.edit/select.c
    M vector/v.edit/snap.c
    M vector/v.external.out/args.c
    M vector/v.external.out/format.c
    M vector/v.external.out/link.c
    M vector/v.external.out/list.c
    M vector/v.external.out/local_proto.h
    M vector/v.external.out/main.c
    M vector/v.external.out/status.c
    M vector/v.external/args.c
    M vector/v.external/dsn.c
    M vector/v.external/list.c
    M vector/v.external/local_proto.h
    M vector/v.external/main.c
    M vector/v.external/proj.c
    M vector/v.extract/copy_tab.c
    M vector/v.extract/extract.c
    M vector/v.extract/local_proto.h
    M vector/v.extract/main.c
    M vector/v.extrude/db.c
    M vector/v.extrude/extrude.c
    M vector/v.extrude/local_proto.h
    M vector/v.extrude/main.c
    M vector/v.generalize/displacement.c
    M vector/v.generalize/main.c
    M vector/v.generalize/matrix.c
    M vector/v.generalize/matrix.h
    M vector/v.generalize/misc.c
    M vector/v.generalize/misc.h
    M vector/v.generalize/network.c
    M vector/v.generalize/operators.h
    M vector/v.generalize/point.c
    M vector/v.generalize/point.h
    M vector/v.generalize/pq.c
    M vector/v.generalize/simplification.c
    M vector/v.generalize/smoothing.c
    M vector/v.hull/chull.c
    M vector/v.hull/hull.c
    M vector/v.hull/hull.h
    M vector/v.hull/main.c
    M vector/v.hull/read.c
    M vector/v.hull/write.c
    M vector/v.in.ascii/local_proto.h
    M vector/v.in.ascii/main.c
    M vector/v.in.ascii/points.c
    M vector/v.in.db/main.c
    M vector/v.in.dwg/entity.c
    M vector/v.in.dwg/global.h
    M vector/v.in.dwg/main.c
    M vector/v.in.dxf/add_3dface.c
    M vector/v.in.dxf/add_arc.c
    M vector/v.in.dxf/add_circle.c
    M vector/v.in.dxf/add_line.c
    M vector/v.in.dxf/add_lwpolyline.c
    M vector/v.in.dxf/add_point.c
    M vector/v.in.dxf/add_polyline.c
    M vector/v.in.dxf/add_text.c
    M vector/v.in.dxf/dxf_to_vect.c
    M vector/v.in.dxf/layer_list.c
    M vector/v.in.dxf/main.c
    M vector/v.in.dxf/make_arc.c
    M vector/v.in.dxf/read_dxf.c
    M vector/v.in.dxf/write_vect.c
    M vector/v.in.lidar/count_decimation.c
    M vector/v.in.lidar/count_decimation.h
    M vector/v.in.lidar/info.h
    M vector/v.in.lidar/lidar.c
    M vector/v.in.lidar/main.c
    M vector/v.in.lidar/projection.h
    M vector/v.in.lidar/vector_mask.c
    M vector/v.in.lidar/vector_mask.h
    M vector/v.in.pdal/lidar.c
    M vector/v.in.region/main.c
    M vector/v.info/level1.c
    M vector/v.info/local_proto.h
    M vector/v.info/main.c
    M vector/v.info/parse.c
    M vector/v.info/print.c
    M vector/v.kcv/main.c
    M vector/v.kernel/function.c
    M vector/v.kernel/global.h
    M vector/v.kernel/main.c
    M vector/v.label.sa/annealing.c
    M vector/v.label.sa/font.c
    M vector/v.label.sa/labels.c
    M vector/v.label.sa/labels.h
    M vector/v.label.sa/main.c
    M vector/v.label/main.c
    M vector/v.lidar.correction/correction.c
    M vector/v.lidar.correction/correction.h
    M vector/v.lidar.correction/main.c
    M vector/v.lidar.edgedetection/edgedetection.c
    M vector/v.lidar.edgedetection/edgedetection.h
    M vector/v.lidar.edgedetection/main.c
    M vector/v.lidar.growing/ConvexHull.c
    M vector/v.lidar.growing/growing.c
    M vector/v.lidar.growing/growing.h
    M vector/v.lidar.growing/main.c
    M vector/v.lrs/lib/lrs.c
    M vector/v.lrs/lib/lrs.h
    M vector/v.lrs/v.lrs.create/main.c
    M vector/v.lrs/v.lrs.label/main.c
    M vector/v.lrs/v.lrs.segment/main.c
    M vector/v.lrs/v.lrs.where/main.c
    M vector/v.net.alloc/alloc.c
    M vector/v.net.alloc/alloc.h
    M vector/v.net.alloc/main.c
    M vector/v.net.allpairs/main.c
    M vector/v.net.bridge/main.c
    M vector/v.net.centrality/main.c
    M vector/v.net.components/main.c
    M vector/v.net.connectivity/main.c
    M vector/v.net.distance/main.c
    M vector/v.net.flow/main.c
    M vector/v.net.iso/alloc.c
    M vector/v.net.iso/alloc.h
    M vector/v.net.iso/main.c
    M vector/v.net.path/main.c
    M vector/v.net.path/path.c
    M vector/v.net.salesman/main.c
    M vector/v.net.spanningtree/main.c
    M vector/v.net.steiner/main.c
    M vector/v.net.timetable/main.c
    M vector/v.net.visibility/data_structures.c
    M vector/v.net.visibility/geometry.c
    M vector/v.net.visibility/main.c
    M vector/v.net.visibility/proto.h
    M vector/v.net.visibility/rotation_tree.c
    M vector/v.net.visibility/visibility.c
    M vector/v.net.visibility/visibility.h
    M vector/v.net/arcs.c
    M vector/v.net/args.c
    M vector/v.net/connect.c
    M vector/v.net/main.c
    M vector/v.net/nodes.c
    M vector/v.net/proto.h
    M vector/v.net/report.c
    M vector/v.net/turntable.c
    M vector/v.normal/main.c
    M vector/v.normal/scancats.c
    M vector/v.out.ascii/args.c
    M vector/v.out.ascii/local_proto.h
    M vector/v.out.ascii/main.c
    M vector/v.out.dxf/main.c
    M vector/v.out.dxf/write_dxf.c
    M vector/v.out.lidar/main.c
    M vector/v.out.ogr/args.c
    M vector/v.out.ogr/attrb.c
    M vector/v.out.ogr/create.c
    M vector/v.out.ogr/dsn.c
    M vector/v.out.ogr/export_areas.c
    M vector/v.out.ogr/export_lines.c
    M vector/v.out.ogr/list.c
    M vector/v.out.ogr/local_proto.h
    M vector/v.out.ogr/main.c
    M vector/v.out.postgis/args.c
    M vector/v.out.postgis/create.c
    M vector/v.out.postgis/local_proto.h
    M vector/v.out.postgis/main.c
    M vector/v.out.postgis/table.c
    M vector/v.out.pov/main.c
    M vector/v.out.svg/main.c
    M vector/v.out.vtk/head.c
    M vector/v.out.vtk/local_proto.h
    M vector/v.out.vtk/main.c
    M vector/v.out.vtk/writeVTK.c
    M vector/v.out.vtk/writeVTK.h
    M vector/v.outlier/main.c
    M vector/v.outlier/outlier.c
    M vector/v.outlier/outlier.h
    M vector/v.overlay/area_area.c
    M vector/v.overlay/line_area.c
    M vector/v.overlay/local.h
    M vector/v.overlay/main.c
    M vector/v.overlay/util.c
    M vector/v.parallel/main.c
    M vector/v.patch/main.c
    M vector/v.perturb/fische.c
    M vector/v.perturb/main.c
    M vector/v.perturb/myrng.c
    M vector/v.perturb/normal00.c
    M vector/v.perturb/normalen.c
    M vector/v.perturb/normalrs.c
    M vector/v.perturb/normalsv.c
    M vector/v.perturb/zufall.c
    M vector/v.perturb/zufall.h
    M vector/v.perturb/zufalli.c
    M vector/v.perturb/zufallrs.c
    M vector/v.perturb/zufallsv.c
    M vector/v.profile/main.c
    M vector/v.profile/processors.c
    M vector/v.proj/main.c
    M vector/v.proj/setenv.c
    M vector/v.qcount/count.c
    M vector/v.qcount/findquads.c
    M vector/v.qcount/indices.c
    M vector/v.qcount/main.c
    M vector/v.qcount/quaddefs.h
    M vector/v.random/main.c
    M vector/v.reclass/main.c
    M vector/v.reclass/reclass.c
    M vector/v.reclass/rules.c
    M vector/v.rectify/cp.c
    M vector/v.rectify/crs.h
    M vector/v.rectify/crs3d.c
    M vector/v.rectify/env.c
    M vector/v.rectify/main.c
    M vector/v.rectify/orthorot.c
    M vector/v.rectify/target.c
    M vector/v.sample/main.c
    M vector/v.segment/main.c
    M vector/v.select/args.c
    M vector/v.select/copy_tabs.c
    M vector/v.select/geos.c
    M vector/v.select/main.c
    M vector/v.select/overlap.c
    M vector/v.select/proto.h
    M vector/v.select/select.c
    M vector/v.select/write.c
    M vector/v.split/main.c
    M vector/v.support/main.c
    M vector/v.surf.bspline/bspline.h
    M vector/v.surf.bspline/crosscorr.c
    M vector/v.surf.bspline/main.c
    M vector/v.surf.bspline/resamp.c
    M vector/v.surf.idw/main.c
    M vector/v.surf.rst/main.c
    M vector/v.timestamp/main.c
    M vector/v.to.3d/args.c
    M vector/v.to.3d/local_proto.h
    M vector/v.to.3d/main.c
    M vector/v.to.3d/trans2.c
    M vector/v.to.3d/trans3.c
    M vector/v.to.db/areas.c
    M vector/v.to.db/calc.c
    M vector/v.to.db/find.c
    M vector/v.to.db/global.h
    M vector/v.to.db/lines.c
    M vector/v.to.db/main.c
    M vector/v.to.db/parse.c
    M vector/v.to.db/query.c
    M vector/v.to.db/report.c
    M vector/v.to.db/units.c
    M vector/v.to.db/update.c
    M vector/v.to.points/local_proto.h
    M vector/v.to.points/main.c
    M vector/v.to.points/write.c
    M vector/v.to.rast/dense_line.c
    M vector/v.to.rast/do_areas.c
    M vector/v.to.rast/do_lines.c
    M vector/v.to.rast/local.h
    M vector/v.to.rast/main.c
    M vector/v.to.rast/raster.c
    M vector/v.to.rast/support.c
    M vector/v.to.rast/vect2rast.c
    M vector/v.to.rast3/main.c
    M vector/v.transform/main.c
    M vector/v.transform/trans_digit.c
    M vector/v.type/main.c
    M vector/v.univar/main.c
    M vector/v.vect.stats/main.c
    M vector/v.vol.rst/dataoct.c
    M vector/v.vol.rst/main.c
    M vector/v.vol.rst/oct.c
    M vector/v.vol.rst/oct.h
    M vector/v.vol.rst/user1.c
    M vector/v.vol.rst/user2.c
    M vector/v.vol.rst/user3.c
    M vector/v.vol.rst/user4.c
    M vector/v.vol.rst/userglobs.h
    M vector/v.vol.rst/vector.c
    M vector/v.voronoi/clean_topo.c
    M vector/v.voronoi/main.c
    M vector/v.voronoi/skeleton.c
    M vector/v.voronoi/sw_defs.h
    M vector/v.voronoi/sw_edgelist.c
    M vector/v.voronoi/sw_geometry.c
    M vector/v.voronoi/sw_heap.c
    M vector/v.voronoi/sw_main.c
    M vector/v.voronoi/sw_memory.c
    M vector/v.voronoi/sw_voronoi.c
    M vector/v.voronoi/vo_extend.c
    M vector/v.voronoi/vo_write.c
    M vector/v.what.rast/local_proto.h
    M vector/v.what.rast/main.c
    M vector/v.what.rast/search.c
    M vector/v.what.rast3/local_proto.h
    M vector/v.what.rast3/main.c
    M vector/v.what.rast3/search.c
    M vector/v.what/main.c
    M vector/v.what/what.c
    M vector/v.what/what.h
    M visualization/ximgview/color.c
    M visualization/ximgview/main.c
  Log Message:
  Indent most of C code (#2544)
Indents most of the C and C++ code except for what is reported by indent as issues.
