[GRASS-git] [OSGeo/grass] b5a70b: apply .clang-format (#2712)
Nicklas Larsson noreply at github.com
Thu Dec 22 03:40:03 PST 2022
  Branch: refs/heads/main
  Home:   https://github.com/OSGeo/grass
  Commit: b5a70ba2c4d3115656baa764ff51a31bd5a8db19
      https://github.com/OSGeo/grass/commit/b5a70ba2c4d3115656baa764ff51a31bd5a8db19
  Author: Nicklas Larsson <n_larsson at yahoo.com>
  Date:   2022-12-22 (Thu, 22 Dec 2022)
  Changed paths:
    M raster/r.basins.fill/local_proto.h
    M raster/r.basins.fill/main.c
    M raster/r.basins.fill/read_map.c
    M raster/r.buffer/distance.h
    M raster/r.buffer/execute.c
    M raster/r.buffer/find_dist.c
    M raster/r.buffer/init.c
    M raster/r.buffer/local_proto.h
    M raster/r.buffer/main.c
    M raster/r.buffer/parse_dist.c
    M raster/r.buffer/process_at.c
    M raster/r.buffer/process_left.c
    M raster/r.buffer/process_rite.c
    M raster/r.buffer/process_row.c
    M raster/r.buffer/read_map.c
    M raster/r.buffer/support.c
    M raster/r.buffer/write_map.c
    M raster/r.buildvrt/link.c
    M raster/r.buildvrt/main.c
    M raster/r.buildvrt/proto.h
    M raster/r.carve/enforce.h
    M raster/r.carve/enforce_ds.c
    M raster/r.carve/lobf.c
    M raster/r.carve/main.c
    M raster/r.carve/raster.c
    M raster/r.carve/support.c
    M raster/r.carve/vect.c
    M raster/r.category/cats.c
    M raster/r.category/local_proto.h
    M raster/r.category/main.c
    M raster/r.circle/main.c
    M raster/r.clump/clump.c
    M raster/r.clump/local_proto.h
    M raster/r.clump/main.c
    M raster/r.clump/minsize.c
    M raster/r.clump/rclist.c
    M raster/r.clump/rclist.h
    M raster/r.coin/coin.h
    M raster/r.coin/format.c
    M raster/r.coin/local_proto.h
    M raster/r.coin/main.c
    M raster/r.coin/make_coin.c
    M raster/r.coin/print_coin.c
    M raster/r.coin/print_hdr.c
    M raster/r.coin/prnt_entry.c
    M raster/r.coin/totals.c
    M raster/r.colors.out/raster3d_main.c
    M raster/r.colors.out/raster_main.c
    M raster/r.colors/edit_colors.c
    M raster/r.colors/local_proto.h
    M raster/r.colors/raster3d_main.c
    M raster/r.colors/raster_main.c
    M raster/r.colors/rules.c
    M raster/r.colors/stats.c
    M raster/r.composite/main.c
    M raster/r.compress/main.c
    M raster/r.contour/cont.c
    M raster/r.contour/local_proto.h
    M raster/r.contour/main.c
    M raster/r.cost/cost.h
    M raster/r.cost/flag.c
    M raster/r.cost/flag.h
    M raster/r.cost/heap.c
    M raster/r.cost/main.c
    M raster/r.cost/stash.h
    M raster/r.covar/main.c
    M raster/r.cross/cats.c
    M raster/r.cross/cross.c
    M raster/r.cross/glob.h
    M raster/r.cross/local_proto.h
    M raster/r.cross/main.c
    M raster/r.cross/renumber.c
    M raster/r.cross/store.c
    M raster/r.describe/describe.c
    M raster/r.describe/dumplist.c
    M raster/r.describe/local_proto.h
    M raster/r.describe/main.c
    M raster/r.describe/tree.c
    M raster/r.distance/defs.h
    M raster/r.distance/distance.c
    M raster/r.distance/edges.c
    M raster/r.distance/labels.c
    M raster/r.distance/main.c
    M raster/r.distance/parse.c
    M raster/r.distance/report.c
    M raster/r.drain/filldir.c
    M raster/r.drain/local.h
    M raster/r.drain/main.c
    M raster/r.drain/resolve.c
    M raster/r.drain/tinf.c
    M raster/r.drain/tinf.h
    M raster/r.external.out/main.c
    M raster/r.external/colors.c
    M raster/r.external/link.c
    M raster/r.external/list.c
    M raster/r.external/main.c
    M raster/r.external/proj.c
    M raster/r.external/proto.h
    M raster/r.external/window.c
    M raster/r.fill.dir/dopolys.c
    M raster/r.fill.dir/filldir.c
    M raster/r.fill.dir/main.c
    M raster/r.fill.dir/ppupdate.c
    M raster/r.fill.dir/resolve.c
    M raster/r.fill.dir/tinf.c
    M raster/r.fill.dir/tinf.h
    M raster/r.fill.dir/wtrshed.c
    M raster/r.fill.stats/cell_funcs.c
    M raster/r.fill.stats/cell_funcs.h
    M raster/r.fill.stats/main.c
    M raster/r.flow/aspect.c
    M raster/r.flow/aspect.h
    M raster/r.flow/io.c
    M raster/r.flow/main.c
    M raster/r.flow/mem.c
    M raster/r.flow/mem.h
    M raster/r.flow/precomp.c
    M raster/r.flow/r.flow.h
    M raster/r.geomorphon/geom.c
    M raster/r.geomorphon/local_proto.h
    M raster/r.geomorphon/main.c
    M raster/r.geomorphon/memory.c
    M raster/r.geomorphon/multires.c
    M raster/r.geomorphon/pattern.c
    M raster/r.geomorphon/profile.c
    M raster/r.grow.distance/main.c
    M raster/r.gwflow/main.c
    M raster/r.his/his.c
    M raster/r.his/main.c
    M raster/r.horizon/main.c
    M raster/r.in.ascii/gethead.c
    M raster/r.in.ascii/main.c
    M raster/r.in.bin/gmt_grd.h
    M raster/r.in.bin/main.c
    M raster/r.in.gdal/main.c
    M raster/r.in.gdal/proj.c
    M raster/r.in.gridatb/adjcellhd.c
    M raster/r.in.gridatb/check_ready.c
    M raster/r.in.gridatb/file_io.c
    M raster/r.in.gridatb/local_proto.h
    M raster/r.in.gridatb/main.c
    M raster/r.in.lidar/filters.c
    M raster/r.in.lidar/filters.h
    M raster/r.in.lidar/info.c
    M raster/r.in.lidar/local_proto.h
    M raster/r.in.lidar/main.c
    M raster/r.in.lidar/point_binning.c
    M raster/r.in.lidar/point_binning.h
    M raster/r.in.lidar/projection.c
    M raster/r.in.lidar/rast_segment.c
    M raster/r.in.lidar/rast_segment.h
    M raster/r.in.lidar/string_list.c
    M raster/r.in.lidar/support.c
    M raster/r.in.mat/main.c
    M raster/r.in.pdal/bin_update.c
    M raster/r.in.pdal/bin_update.h
    M raster/r.in.pdal/bin_write.c
    M raster/r.in.pdal/bin_write.h
    M raster/r.in.pdal/filters.c
    M raster/r.in.pdal/filters.h
    M raster/r.in.pdal/grasslidarfilter.cpp
    M raster/r.in.pdal/grasslidarfilter.h
    M raster/r.in.pdal/grassrasterwriter.h
    M raster/r.in.pdal/info.h
    M raster/r.in.pdal/lidar.c
    M raster/r.in.pdal/lidar.h
    M raster/r.in.pdal/main.cpp
    M raster/r.in.pdal/point_binning.c
    M raster/r.in.pdal/point_binning.h
    M raster/r.in.pdal/projection.c
    M raster/r.in.pdal/projection.h
    M raster/r.in.pdal/rast_segment.c
    M raster/r.in.pdal/rast_segment.h
    M raster/r.in.pdal/string_list.c
    M raster/r.in.pdal/string_list.h
    M raster/r.in.png/main.c
    M raster/r.in.poly/format.h
    M raster/r.in.poly/get_item.c
    M raster/r.in.poly/getformat.c
    M raster/r.in.poly/main.c
    M raster/r.in.poly/poly2rast.c
    M raster/r.in.poly/raster.c
    M raster/r.in.xyz/local_proto.h
    M raster/r.in.xyz/main.c
    M raster/r.in.xyz/support.c
    M raster/r.info/main.c
    M raster/r.info/reclas_txt.c
    M raster/r.kappa/kappa.h
    M raster/r.kappa/main.c
    M raster/r.lake/main.c
    M raster/r.latlong/main.c
    M raster/r.li/r.li.cwed/cellWeighted.h
    M raster/r.li/r.li.cwed/cwed.c
    M raster/r.li/r.li.cwed/utility.c
    M raster/r.li/r.li.cwed/utility.h
    M raster/r.li/r.li.daemon/GenericCell.c
    M raster/r.li/r.li.daemon/GenericCell.h
    M raster/r.li/r.li.daemon/avl.c
    M raster/r.li/r.li.daemon/avl.h
    M raster/r.li/r.li.daemon/avlDefs.h
    M raster/r.li/r.li.daemon/avlID.c
    M raster/r.li/r.li.daemon/avlID.h
    M raster/r.li/r.li.daemon/daemon.c
    M raster/r.li/r.li.daemon/daemon.h
    M raster/r.li/r.li.daemon/defs.h
    M raster/r.li/r.li.daemon/ipc.h
    M raster/r.li/r.li.daemon/list.c
    M raster/r.li/r.li.daemon/list.h
    M raster/r.li/r.li.daemon/worker.c
    M raster/r.li/r.li.dominance/dominance.c
    M raster/r.li/r.li.edgedensity/edgedensity.c
    M raster/r.li/r.li.mpa/mpa.c
    M raster/r.li/r.li.mps/mps.c
    M raster/r.li/r.li.padcv/padcv.c
    M raster/r.li/r.li.padrange/padrange.c
    M raster/r.li/r.li.padsd/padsd.c
    M raster/r.li/r.li.patchdensity/main.c
    M raster/r.li/r.li.patchnum/main.c
    M raster/r.li/r.li.pielou/pielou.c
    M raster/r.li/r.li.renyi/renyi.c
    M raster/r.li/r.li.richness/richness.c
    M raster/r.li/r.li.shannon/shannon.c
    M raster/r.li/r.li.shape/main.c
    M raster/r.li/r.li.simpson/simpson.c
    M raster/r.mapcalc/column_shift.c
    M raster/r.mapcalc/evaluate.c
    M raster/r.mapcalc/expression.c
    M raster/r.mapcalc/expression.h
    M raster/r.mapcalc/func_proto.h
    M raster/r.mapcalc/function.c
    M raster/r.mapcalc/globals.h
    M raster/r.mapcalc/globals2.h
    M raster/r.mapcalc/globals3.h
    M raster/r.mapcalc/main.c
    M raster/r.mapcalc/map.c
    M raster/r.mapcalc/map3.c
    M raster/r.mapcalc/mapcalc.h
    M raster/r.mapcalc/xarea.c
    M raster/r.mapcalc/xcoor.c
    M raster/r.mapcalc/xcoor3.c
    M raster/r.mapcalc/xres.c
    M raster/r.mapcalc/xres3.c
    M raster/r.mapcalc/xrowcol.c
    M raster/r.mfilter/apply.c
    M raster/r.mfilter/execute.c
    M raster/r.mfilter/filter.h
    M raster/r.mfilter/getfilt.c
    M raster/r.mfilter/getrow.c
    M raster/r.mfilter/main.c
    M raster/r.mfilter/perform.c
    M raster/r.mode/main.c
    M raster/r.mode/read_stats.c
    M raster/r.mode/write_rec.c
    M raster/r.neighbors/bufs.c
    M raster/r.neighbors/divr_cats.c
    M raster/r.neighbors/gather.c
    M raster/r.neighbors/local_proto.h
    M raster/r.neighbors/main.c
    M raster/r.neighbors/ncb.h
    M raster/r.neighbors/readweights.c
    M raster/r.null/main.c
    M raster/r.null/mask.c
    M raster/r.null/mask.h
    M raster/r.object.geometry/main.c
    M raster/r.out.ascii/formspecific.c
    M raster/r.out.ascii/main.c
    M raster/r.out.bin/gmt_grd.h
    M raster/r.out.bin/main.c
    M raster/r.out.gdal/attr.c
    M raster/r.out.gdal/export_band.c
    M raster/r.out.gdal/local_proto.h
    M raster/r.out.gdal/main.c
    M raster/r.out.gridatb/main.c
    M raster/r.out.mat/main.c
    M raster/r.out.mpeg/main.c
    M raster/r.out.mpeg/rom_proto.h
    M raster/r.out.mpeg/write.c
    M raster/r.out.png/main.c
    M raster/r.out.png/pngfunc.h
    M raster/r.out.pov/main.c
    M raster/r.out.ppm/main.c
    M raster/r.out.ppm3/main.c
    M raster/r.out.vrml/main.c
    M raster/r.out.vrml/put_grid.c
    M raster/r.out.vrml/put_view.c
    M raster/r.out.vrml/pv.h
    M raster/r.out.vrml/vrml.c
    M raster/r.out.vtk/globaldefs.h
    M raster/r.out.vtk/main.c
    M raster/r.out.vtk/parameters.c
    M raster/r.out.vtk/parameters.h
    M raster/r.out.vtk/writeascii.c
    M raster/r.out.vtk/writeascii.h
    M raster/r.param.scale/close_down.c
    M raster/r.param.scale/feature.c
    M raster/r.param.scale/find_normal.c
    M raster/r.param.scale/interface.c
    M raster/r.param.scale/main.c
    M raster/r.param.scale/nrutil.c
    M raster/r.param.scale/nrutil.h
    M raster/r.param.scale/open_files.c
    M raster/r.param.scale/param.c
    M raster/r.param.scale/param.h
    M raster/r.param.scale/process.c
    M raster/r.param.scale/write_cats.c
    M raster/r.param.scale/write_cols.c
    M raster/r.patch/do_patch.c
    M raster/r.patch/main.c
    M raster/r.patch/support.c
    M raster/r.path/local.h
    M raster/r.path/main.c
    M raster/r.path/pavlrc.c
    M raster/r.path/pavlrc.h
    M raster/r.profile/input.c
    M raster/r.profile/local_proto.h
    M raster/r.profile/main.c
    M raster/r.profile/read_rast.c
    M raster/r.proj/bilinear.c
    M raster/r.proj/bilinear_f.c
    M raster/r.proj/bordwalk.c
    M raster/r.proj/cubic.c
    M raster/r.proj/cubic_f.c
    M raster/r.proj/lanczos.c
    M raster/r.proj/main.c
    M raster/r.proj/nearest.c
    M raster/r.proj/r.proj.h
    M raster/r.proj/readcell.c
    M raster/r.quant/global.h
    M raster/r.quant/main.c
    M raster/r.quant/read_rules.c
    M raster/r.quantile/main.c
    M raster/r.random.cells/flag.c
    M raster/r.random.cells/flag.h
    M raster/r.random.cells/init.c
    M raster/r.random.cells/main.c
    M raster/r.random.cells/ransurf.h
    M raster/r.random.surface/cpfilter.c
    M raster/r.random.surface/decay.c
    M raster/r.random.surface/init.c
    M raster/r.random.surface/local_proto.h
    M raster/r.random.surface/main.c
    M raster/r.random.surface/makebigf.c
    M raster/r.random.surface/makepp.c
    M raster/r.random.surface/ransurf.h
    M raster/r.random.surface/save.c
    M raster/r.random.surface/zero.c
    M raster/r.random/count.c
    M raster/r.random/local_proto.h
    M raster/r.random/main.c
    M raster/r.random/random.c
    M raster/r.random/support.c
    M raster/r.reclass/add_rule.c
    M raster/r.reclass/input.c
    M raster/r.reclass/main.c
    M raster/r.reclass/parse.c
    M raster/r.reclass/reclass.c
    M raster/r.reclass/rule.h
    M raster/r.reclass/stats.c
    M raster/r.recode/main.c
    M raster/r.recode/read_rules.c
    M raster/r.recode/recode.c
    M raster/r.region/main.c
    M raster/r.regression.line/main.c
    M raster/r.regression.multi/main.c
    M raster/r.relief/main.c
    M raster/r.report/format.c
    M raster/r.report/global.h
    M raster/r.report/header.c
    M raster/r.report/main.c
    M raster/r.report/maskinfo.c
    M raster/r.report/parse.c
    M raster/r.report/prt_report.c
    M raster/r.report/prt_unit.c
    M raster/r.report/stats.c
    M raster/r.resamp.bspline/bspline.h
    M raster/r.resamp.bspline/crosscorr.c
    M raster/r.resamp.bspline/main.c
    M raster/r.resamp.bspline/resamp.c
    M raster/r.resamp.filter/main.c
    M raster/r.resamp.interp/main.c
    M raster/r.resamp.rst/main.c
    M raster/r.resamp.rst/surf.h
    M raster/r.resamp.stats/main.c
    M raster/r.resample/main.c
    M raster/r.rescale.eq/get_range.c
    M raster/r.rescale.eq/main.c
    M raster/r.rescale/get_range.c
    M raster/r.rescale/main.c
    M raster/r.ros/main.c
    M raster/r.ros/spot_dist.c
    M raster/r.series.accumulate/main.c
    M raster/r.series.interp/main.c
    M raster/r.series/main.c
    M raster/r.sim/r.sim.sediment/main.c
    M raster/r.sim/r.sim.water/main.c
    M raster/r.sim/simlib/erod.c
    M raster/r.sim/simlib/hydro.c
    M raster/r.sim/simlib/input.c
    M raster/r.sim/simlib/observation_points.c
    M raster/r.sim/simlib/output.c
    M raster/r.sim/simlib/random.c
    M raster/r.sim/simlib/simlib.h
    M raster/r.sim/simlib/waterglobs.h
    M raster/r.slope.aspect/main.c
    M raster/r.solute.transport/main.c
    M raster/r.spread/cell_ptrHa.h
    M raster/r.spread/cmd_line.h
    M raster/r.spread/collect_ori.c
    M raster/r.spread/costHa.h
    M raster/r.spread/deleteHa.c
    M raster/r.spread/display.c
    M raster/r.spread/fixHa.c
    M raster/r.spread/get_minHa.c
    M raster/r.spread/insert2Ha.c
    M raster/r.spread/insertHa.c
    M raster/r.spread/main.c
    M raster/r.spread/pick_dist.c
    M raster/r.spread/pick_ignite.c
    M raster/r.spread/ram2out.c
    M raster/r.spread/replaceHa.c
    M raster/r.spread/select_linksB.c
    M raster/r.spread/spot.c
    M raster/r.spread/spread.c
    M raster/r.spreadpath/drawline.c
    M raster/r.spreadpath/insert.c
    M raster/r.spreadpath/local_proto.h
    M raster/r.spreadpath/main.c
    M raster/r.spreadpath/path_finder.c
    M raster/r.spreadpath/point.h
    M raster/r.spreadpath/stash.h
    M raster/r.statistics/main.c
    M raster/r.statistics/method.h
    M raster/r.statistics/o_adev.c
    M raster/r.statistics/o_average.c
    M raster/r.statistics/o_divr.c
    M raster/r.statistics/o_kurt.c
    M raster/r.statistics/o_max.c
    M raster/r.statistics/o_median.c
    M raster/r.statistics/o_min.c
    M raster/r.statistics/o_mode.c
    M raster/r.statistics/o_sdev.c
    M raster/r.statistics/o_skew.c
    M raster/r.statistics/o_sum.c
    M raster/r.statistics/o_var.c
    M raster/r.statistics/read_stats.c
    M raster/r.statistics/run_cmd.c
    M raster/r.statistics/write_rec.c
    M raster/r.stats.quantile/main.c
    M raster/r.stats.zonal/main.c
    M raster/r.stats/cell_stats.c
    M raster/r.stats/main.c
    M raster/r.stats/raw_stats.c
    M raster/r.stats/stats.c
    M raster/r.stream.extract/bseg.c
    M raster/r.stream.extract/close.c
    M raster/r.stream.extract/cseg.c
    M raster/r.stream.extract/del_streams.c
    M raster/r.stream.extract/do_astar.c
    M raster/r.stream.extract/dseg.c
    M raster/r.stream.extract/flag.h
    M raster/r.stream.extract/init_search.c
    M raster/r.stream.extract/load.c
    M raster/r.stream.extract/local_proto.h
    M raster/r.stream.extract/main.c
    M raster/r.stream.extract/seg.c
    M raster/r.stream.extract/seg.h
    M raster/r.stream.extract/streams.c
    M raster/r.stream.extract/thin.c
    M raster/r.sun/local_proto.h
    M raster/r.sun/main.c
    M raster/r.sun/rsunglobals.h
    M raster/r.sun/rsunlib.c
    M raster/r.sun/sunradstruct.h
    M raster/r.sunhours/main.c
    M raster/r.sunhours/solpos00.c
    M raster/r.sunhours/solpos00.h
    M raster/r.sunmask/g_solposition.c
    M raster/r.sunmask/global.h
    M raster/r.sunmask/main.c
    M raster/r.sunmask/solpos00.c
    M raster/r.sunmask/solpos00.h
    M raster/r.support.stats/check.c
    M raster/r.support.stats/histo.c
    M raster/r.support.stats/local_proto.h
    M raster/r.support.stats/main.c
    M raster/r.support/check.c
    M raster/r.support/histo.c
    M raster/r.support/main.c
    M raster/r.surf.area/area.c
    M raster/r.surf.area/local_proto.h
    M raster/r.surf.area/main.c
    M raster/r.surf.contour/add_in.c
    M raster/r.surf.contour/addpts.c
    M raster/r.surf.contour/contour.h
    M raster/r.surf.contour/find_con.c
    M raster/r.surf.contour/flag.h
    M raster/r.surf.contour/flag_clr_all.c
    M raster/r.surf.contour/flag_create.c
    M raster/r.surf.contour/flag_destroy.c
    M raster/r.surf.contour/flag_get.c
    M raster/r.surf.contour/flag_set.c
    M raster/r.surf.contour/flag_unset.c
    M raster/r.surf.contour/main.c
    M raster/r.surf.contour/read_cell.c
    M raster/r.surf.fractal/frac.h
    M raster/r.surf.fractal/main.c
    M raster/r.surf.fractal/process.c
    M raster/r.surf.fractal/spec_syn.c
    M raster/r.surf.fractal/write_rast.c
    M raster/r.surf.gauss/gaussurf.c
    M raster/r.surf.gauss/main.c
    M raster/r.surf.idw/dist.c
    M raster/r.surf.idw/ll.c
    M raster/r.surf.idw/main.c
    M raster/r.surf.idw/main.h
    M raster/r.surf.idw/pi.h
    M raster/r.surf.random/main.c
    M raster/r.surf.random/randsurf.c
    M raster/r.terraflow/3scan.h
    M raster/r.terraflow/ccforest.cpp
    M raster/r.terraflow/ccforest.h
    M raster/r.terraflow/common.cpp
    M raster/r.terraflow/common.h
    M raster/r.terraflow/direction.cpp
    M raster/r.terraflow/direction.h
    M raster/r.terraflow/fill.cpp
    M raster/r.terraflow/fill.h
    M raster/r.terraflow/filldepr.cpp
    M raster/r.terraflow/filldepr.h
    M raster/r.terraflow/flow.cpp
    M raster/r.terraflow/flow.h
    M raster/r.terraflow/genericWindow.cpp
    M raster/r.terraflow/genericWindow.h
    M raster/r.terraflow/grass2str.h
    M raster/r.terraflow/grid.cpp
    M raster/r.terraflow/grid.h
    M raster/r.terraflow/main.cpp
    M raster/r.terraflow/main.h
    M raster/r.terraflow/nodata.cpp
    M raster/r.terraflow/nodata.h
    M raster/r.terraflow/option.h
    M raster/r.terraflow/plateau.cpp
    M raster/r.terraflow/plateau.h
    M raster/r.terraflow/sortutils.h
    M raster/r.terraflow/stats.cpp
    M raster/r.terraflow/stats.h
    M raster/r.terraflow/streamutils.h
    M raster/r.terraflow/sweep.cpp
    M raster/r.terraflow/sweep.h
    M raster/r.terraflow/types.cpp
    M raster/r.terraflow/types.h
    M raster/r.terraflow/unionFind.h
    M raster/r.terraflow/water.cpp
    M raster/r.terraflow/water.h
    M raster/r.terraflow/weightWindow.cpp
    M raster/r.terraflow/weightWindow.h
    M raster/r.texture/h_measure.c
    M raster/r.texture/h_measure.h
    M raster/r.texture/main.c
    M raster/r.thin/io.c
    M raster/r.thin/main.c
    M raster/r.thin/thin_lines.c
    M raster/r.tile/main.c
    M raster/r.timestamp/main.c
    M raster/r.to.rast3/main.c
    M raster/r.to.rast3elev/main.c
    M raster/r.to.vect/areas.c
    M raster/r.to.vect/areas_io.c
    M raster/r.to.vect/global.h
    M raster/r.to.vect/lines.c
    M raster/r.to.vect/lines_io.c
    M raster/r.to.vect/main.c
    M raster/r.to.vect/points.c
    M raster/r.to.vect/set_error_handler.c
    M raster/r.to.vect/util.c
    M raster/r.topidx/file_io.c
    M raster/r.topidx/global.h
    M raster/r.topidx/main.c
    M raster/r.topidx/topidx.c
    M raster/r.topmodel/file_io.c
    M raster/r.topmodel/global.h
    M raster/r.topmodel/infiltration.c
    M raster/r.topmodel/main.c
    M raster/r.topmodel/topmodel.c
    M raster/r.transect/main.c
    M raster/r.transect/parse_line.c
    M raster/r.univar/globals.h
    M raster/r.univar/r.univar_main.c
    M raster/r.univar/r3.univar_main.c
    M raster/r.univar/sort.c
    M raster/r.univar/stats.c
    M raster/r.uslek/main.c
    M raster/r.uslek/prct2tex.c
    M raster/r.uslek/tex2usle_k.c
    M raster/r.usler/elswaify85.c
    M raster/r.usler/foster81.c
    M raster/r.usler/main.c
    M raster/r.usler/morgan74.c
    M raster/r.usler/roose75.c
    M raster/r.viewshed/distribute.cpp
    M raster/r.viewshed/distribute.h
    M raster/r.viewshed/eventlist.cpp
    M raster/r.viewshed/eventlist.h
    M raster/r.viewshed/grass.cpp
    M raster/r.viewshed/grass.h
    M raster/r.viewshed/grid.cpp
    M raster/r.viewshed/grid.h
    M raster/r.viewshed/main.cpp
    M raster/r.viewshed/rbbst.cpp
    M raster/r.viewshed/rbbst.h
    M raster/r.viewshed/statusstructure.cpp
    M raster/r.viewshed/statusstructure.h
    M raster/r.viewshed/viewshed.cpp
    M raster/r.viewshed/viewshed.h
    M raster/r.viewshed/visibility.cpp
    M raster/r.viewshed/visibility.h
    M raster/r.volume/centroids.c
    M raster/r.volume/local_proto.h
    M raster/r.volume/main.c
    M raster/r.walk/cost.h
    M raster/r.walk/flag.c
    M raster/r.walk/flag.h
    M raster/r.walk/heap.c
    M raster/r.walk/main.c
    M raster/r.walk/stash.h
    M raster/r.water.outlet/main.c
    M raster/r.water.outlet/outletP.h
    M raster/r.water.outlet/over_cells.c
    M raster/r.water.outlet/ramseg.c
    M raster/r.water.outlet/ramseg.h
    M raster/r.watershed/front/main.c
    M raster/r.watershed/ram/Gwater.h
    M raster/r.watershed/ram/close_maps.c
    M raster/r.watershed/ram/close_maps2.c
    M raster/r.watershed/ram/def_basin.c
    M raster/r.watershed/ram/do_astar.c
    M raster/r.watershed/ram/do_astar.h
    M raster/r.watershed/ram/do_cum.c
    M raster/r.watershed/ram/do_flatarea.c
    M raster/r.watershed/ram/find_pour.c
    M raster/r.watershed/ram/flag.h
    M raster/r.watershed/ram/flag_clr_all.c
    M raster/r.watershed/ram/flag_create.c
    M raster/r.watershed/ram/flag_destroy.c
    M raster/r.watershed/ram/flag_get.c
    M raster/r.watershed/ram/flag_set.c
    M raster/r.watershed/ram/flag_unset.c
    M raster/r.watershed/ram/init_vars.c
    M raster/r.watershed/ram/main.c
    M raster/r.watershed/ram/no_stream.c
    M raster/r.watershed/ram/over_cells.c
    M raster/r.watershed/ram/ramseg.c
    M raster/r.watershed/ram/ramseg.h
    M raster/r.watershed/ram/sg_factor.c
    M raster/r.watershed/ram/split_str.c
    M raster/r.watershed/ram/usage.c
    M raster/r.watershed/seg/Gwater.h
    M raster/r.watershed/seg/bseg_close.c
    M raster/r.watershed/seg/bseg_get.c
    M raster/r.watershed/seg/bseg_open.c
    M raster/r.watershed/seg/bseg_put.c
    M raster/r.watershed/seg/bseg_read.c
    M raster/r.watershed/seg/bseg_write.c
    M raster/r.watershed/seg/close_maps.c
    M raster/r.watershed/seg/close_maps2.c
    M raster/r.watershed/seg/cseg.h
    M raster/r.watershed/seg/cseg_close.c
    M raster/r.watershed/seg/cseg_get.c
    M raster/r.watershed/seg/cseg_open.c
    M raster/r.watershed/seg/cseg_put.c
    M raster/r.watershed/seg/cseg_read.c
    M raster/r.watershed/seg/cseg_write.c
    M raster/r.watershed/seg/def_basin.c
    M raster/r.watershed/seg/do_astar.c
    M raster/r.watershed/seg/do_astar.h
    M raster/r.watershed/seg/do_cum.c
    M raster/r.watershed/seg/dseg_close.c
    M raster/r.watershed/seg/dseg_get.c
    M raster/r.watershed/seg/dseg_open.c
    M raster/r.watershed/seg/dseg_put.c
    M raster/r.watershed/seg/dseg_read.c
    M raster/r.watershed/seg/dseg_write.c
    M raster/r.watershed/seg/find_pour.c
    M raster/r.watershed/seg/flag.h
    M raster/r.watershed/seg/init_vars.c
    M raster/r.watershed/seg/main.c
    M raster/r.watershed/seg/no_stream.c
    M raster/r.watershed/seg/over_cells.c
    M raster/r.watershed/seg/sg_factor.c
    M raster/r.watershed/seg/split_str.c
    M raster/r.watershed/seg/sseg_close.c
    M raster/r.watershed/seg/sseg_get.c
    M raster/r.watershed/seg/sseg_open.c
    M raster/r.watershed/seg/sseg_put.c
    M raster/r.watershed/seg/usage.c
    M raster/r.watershed/shed/accum_down.c
    M raster/r.watershed/shed/basin_maps.c
    M raster/r.watershed/shed/com_line.c
    M raster/r.watershed/shed/file_in.c
    M raster/r.watershed/shed/free.c
    M raster/r.watershed/shed/insert_cat.c
    M raster/r.watershed/shed/intro.c
    M raster/r.watershed/shed/main.c
    M raster/r.watershed/shed/print.c
    M raster/r.watershed/shed/read.c
    M raster/r.watershed/shed/valid.c
    M raster/r.watershed/shed/watershed.h
    M raster/r.what.color/main.c
    M raster/r.what/main.c
  Log Message:
