[GRASS-git] [OSGeo/grass] 5546e0: apply .clang-format (#2714)
Nicklas Larsson noreply at github.com
Thu Dec 22 06:24:28 PST 2022
  Branch: refs/heads/main
  Home:   https://github.com/OSGeo/grass
  Commit: 5546e0172d7dad1e3ee248aec3fe00eeebbb3ab3
      https://github.com/OSGeo/grass/commit/5546e0172d7dad1e3ee248aec3fe00eeebbb3ab3
  Author: Nicklas Larsson <n_larsson at yahoo.com>
  Date:   2022-12-22 (Thu, 22 Dec 2022)
  Changed paths:
    M lib/arraystats/basic.c
    M lib/arraystats/class.c
    M lib/bitmap/bitmap.c
    M lib/bitmap/main.c
    M lib/bitmap/smain.c
    M lib/bitmap/sparse.c
    M lib/btree/create.c
    M lib/btree/find.c
    M lib/btree/free.c
    M lib/btree/next.c
    M lib/btree/rewind.c
    M lib/btree/test/try.c
    M lib/btree/update.c
    M lib/btree2/kdtree.c
    M lib/btree2/kdtree.h
    M lib/btree2/rbtree.c
    M lib/cairodriver/box.c
    M lib/cairodriver/cairodriver.h
    M lib/cairodriver/color.c
    M lib/cairodriver/draw.c
    M lib/cairodriver/draw_bitmap.c
    M lib/cairodriver/driver.c
    M lib/cairodriver/erase.c
    M lib/cairodriver/graph.c
    M lib/cairodriver/line_width.c
    M lib/cairodriver/raster.c
    M lib/cairodriver/read.c
    M lib/cairodriver/read_bmp.c
    M lib/cairodriver/read_ppm.c
    M lib/cairodriver/read_xid.c
    M lib/cairodriver/set_window.c
    M lib/cairodriver/text.c
    M lib/cairodriver/write.c
    M lib/cairodriver/write_bmp.c
    M lib/cairodriver/write_ppm.c
    M lib/cairodriver/write_xid.c
    M lib/calc/calc.c
    M lib/calc/check.c
    M lib/calc/function.c
    M lib/calc/xabs.c
    M lib/calc/xacos.c
    M lib/calc/xadd.c
    M lib/calc/xand.c
    M lib/calc/xand2.c
    M lib/calc/xasin.c
    M lib/calc/xatan.c
    M lib/calc/xbitand.c
    M lib/calc/xbitnot.c
    M lib/calc/xbitor.c
    M lib/calc/xbitxor.c
    M lib/calc/xceil.c
    M lib/calc/xcos.c
    M lib/calc/xdiv.c
    M lib/calc/xdouble.c
    M lib/calc/xeq.c
    M lib/calc/xeval.c
    M lib/calc/xexp.c
    M lib/calc/xfloat.c
    M lib/calc/xfloor.c
    M lib/calc/xge.c
    M lib/calc/xgraph.c
    M lib/calc/xgt.c
    M lib/calc/xif.c
    M lib/calc/xint.c
    M lib/calc/xisnull.c
    M lib/calc/xle.c
    M lib/calc/xlog.c
    M lib/calc/xlt.c
    M lib/calc/xmax.c
    M lib/calc/xmedian.c
    M lib/calc/xmin.c
    M lib/calc/xmod.c
    M lib/calc/xmode.c
    M lib/calc/xmul.c
    M lib/calc/xne.c
    M lib/calc/xneg.c
    M lib/calc/xnmax.c
    M lib/calc/xnmedian.c
    M lib/calc/xnmin.c
    M lib/calc/xnmode.c
    M lib/calc/xnot.c
    M lib/calc/xnull.c
    M lib/calc/xor.c
    M lib/calc/xor2.c
    M lib/calc/xpow.c
    M lib/calc/xrand.c
    M lib/calc/xround.c
    M lib/calc/xshiftl.c
    M lib/calc/xshiftr.c
    M lib/calc/xshiftru.c
    M lib/calc/xsin.c
    M lib/calc/xsqrt.c
    M lib/calc/xsub.c
    M lib/calc/xtan.c
    M lib/cdhc/andrsnde.c
    M lib/cdhc/andrsndn.c
    M lib/cdhc/as177.c
    M lib/cdhc/as181.c
    M lib/cdhc/as241.c
    M lib/cdhc/as66.c
    M lib/cdhc/chisqe.c
    M lib/cdhc/chisqn.c
    M lib/cdhc/cvmw2e.c
    M lib/cdhc/cvmw2n.c
    M lib/cdhc/dagstndn.c
    M lib/cdhc/dmax.c
    M lib/cdhc/dmaxe.c
    M lib/cdhc/durbins.c
    M lib/cdhc/extreme.c
    M lib/cdhc/geary.c
    M lib/cdhc/kotz.c
    M lib/cdhc/kse.c
    M lib/cdhc/ksn.c
    M lib/cdhc/kuiprsve.c
    M lib/cdhc/kuiprsvn.c
    M lib/cdhc/local_proto.h
    M lib/cdhc/normp.c
    M lib/cdhc/omnibus.c
    M lib/cdhc/royston.c
    M lib/cdhc/shapiro1.c
    M lib/cdhc/shapiro2.c
    M lib/cdhc/shapiroe.c
    M lib/cdhc/test.c
    M lib/cdhc/watsonue.c
    M lib/cdhc/watsonun.c
    M lib/cdhc/weisberg.c
    M lib/cdhc/xinormal.c
    M lib/cluster/c_assign.c
    M lib/cluster/c_begin.c
    M lib/cluster/c_exec.c
    M lib/cluster/c_execmem.c
    M lib/cluster/c_means.c
    M lib/cluster/c_point.c
    M lib/cluster/c_reassign.c
    M lib/cluster/c_reclass.c
    M lib/cluster/c_sep.c
    M lib/cluster/c_sum2.c
    M lib/datetime/change.c
    M lib/datetime/copy.c
    M lib/datetime/diff.c
    M lib/datetime/error.c
    M lib/datetime/format.c
    M lib/datetime/incr1.c
    M lib/datetime/incr2.c
    M lib/datetime/incr3.c
    M lib/datetime/local.c
    M lib/datetime/misc.c
    M lib/datetime/same.c
    M lib/datetime/scan.c
    M lib/datetime/sign.c
    M lib/datetime/type.c
    M lib/datetime/tz1.c
    M lib/datetime/tz2.c
    M lib/datetime/values.c
    M lib/db/dbmi_base/column.c
    M lib/db/dbmi_base/columnfmt.c
    M lib/db/dbmi_base/connect.c
    M lib/db/dbmi_base/cursor.c
    M lib/db/dbmi_base/datetime.c
    M lib/db/dbmi_base/dbmscap.c
    M lib/db/dbmi_base/dbstubs.h
    M lib/db/dbmi_base/default_name.c
    M lib/db/dbmi_base/dirent.c
    M lib/db/dbmi_base/error.c
    M lib/db/dbmi_base/handle.c
    M lib/db/dbmi_base/index.c
    M lib/db/dbmi_base/interval.c
    M lib/db/dbmi_base/legal_dbname.c
    M lib/db/dbmi_base/login.c
    M lib/db/dbmi_base/macros.h
    M lib/db/dbmi_base/string.c
    M lib/db/dbmi_base/strip.c
    M lib/db/dbmi_base/table.c
    M lib/db/dbmi_base/test/test_columns.c
    M lib/db/dbmi_base/test/test_dbmi_base_lib.h
    M lib/db/dbmi_base/test/test_main.c
    M lib/db/dbmi_base/test/test_table.c
    M lib/db/dbmi_base/token.c
    M lib/db/dbmi_base/value.c
    M lib/db/dbmi_base/valuefmt.c
    M lib/db/dbmi_base/xdr.c
    M lib/db/dbmi_base/xdrcolumn.c
    M lib/db/dbmi_base/xdrdatetime.c
    M lib/db/dbmi_base/xdrfloat.c
    M lib/db/dbmi_base/xdrhandle.c
    M lib/db/dbmi_base/xdrindex.c
    M lib/db/dbmi_base/xdrstring.c
    M lib/db/dbmi_base/xdrtable.c
    M lib/db/dbmi_base/xdrtoken.c
    M lib/db/dbmi_base/xdrvalue.c
    M lib/db/dbmi_base/zero.c
    M lib/db/dbmi_client/c_add_col.c
    M lib/db/dbmi_client/c_bindupdate.c
    M lib/db/dbmi_client/c_close_cur.c
    M lib/db/dbmi_client/c_closedb.c
    M lib/db/dbmi_client/c_create_idx.c
    M lib/db/dbmi_client/c_create_tab.c
    M lib/db/dbmi_client/c_createdb.c
    M lib/db/dbmi_client/c_delete.c
    M lib/db/dbmi_client/c_deletedb.c
    M lib/db/dbmi_client/c_desc_table.c
    M lib/db/dbmi_client/c_drop_col.c
    M lib/db/dbmi_client/c_drop_index.c
    M lib/db/dbmi_client/c_drop_tab.c
    M lib/db/dbmi_client/c_execute.c
    M lib/db/dbmi_client/c_fetch.c
    M lib/db/dbmi_client/c_finddb.c
    M lib/db/dbmi_client/c_insert.c
    M lib/db/dbmi_client/c_list_drivers.c
    M lib/db/dbmi_client/c_list_idx.c
    M lib/db/dbmi_client/c_list_tabs.c
    M lib/db/dbmi_client/c_listdb.c
    M lib/db/dbmi_client/c_opendb.c
    M lib/db/dbmi_client/c_openinsert.c
    M lib/db/dbmi_client/c_openselect.c
    M lib/db/dbmi_client/c_openupdate.c
    M lib/db/dbmi_client/c_priv.c
    M lib/db/dbmi_client/c_rows.c
    M lib/db/dbmi_client/c_update.c
    M lib/db/dbmi_client/c_version.c
    M lib/db/dbmi_client/column.c
    M lib/db/dbmi_client/copy_tab.c
    M lib/db/dbmi_client/db.c
    M lib/db/dbmi_client/delete_tab.c
    M lib/db/dbmi_client/handler.c
    M lib/db/dbmi_client/printtab.c
    M lib/db/dbmi_client/select.c
    M lib/db/dbmi_client/shutdown.c
    M lib/db/dbmi_client/start.c
    M lib/db/dbmi_client/table.c
    M lib/db/dbmi_driver/d_add_col.c
    M lib/db/dbmi_driver/d_bindupdate.c
    M lib/db/dbmi_driver/d_close_cur.c
    M lib/db/dbmi_driver/d_closedb.c
    M lib/db/dbmi_driver/d_create_idx.c
    M lib/db/dbmi_driver/d_create_tab.c
    M lib/db/dbmi_driver/d_createdb.c
    M lib/db/dbmi_driver/d_delete.c
    M lib/db/dbmi_driver/d_deletedb.c
    M lib/db/dbmi_driver/d_desc_table.c
    M lib/db/dbmi_driver/d_drop_col.c
    M lib/db/dbmi_driver/d_drop_index.c
    M lib/db/dbmi_driver/d_drop_tab.c
    M lib/db/dbmi_driver/d_error.c
    M lib/db/dbmi_driver/d_execute.c
    M lib/db/dbmi_driver/d_fetch.c
    M lib/db/dbmi_driver/d_finddb.c
    M lib/db/dbmi_driver/d_insert.c
    M lib/db/dbmi_driver/d_list_idx.c
    M lib/db/dbmi_driver/d_list_tabs.c
    M lib/db/dbmi_driver/d_listdb.c
    M lib/db/dbmi_driver/d_mkdir.c
    M lib/db/dbmi_driver/d_opendb.c
    M lib/db/dbmi_driver/d_openinsert.c
    M lib/db/dbmi_driver/d_openselect.c
    M lib/db/dbmi_driver/d_openupdate.c
    M lib/db/dbmi_driver/d_priv.c
    M lib/db/dbmi_driver/d_rows.c
    M lib/db/dbmi_driver/d_update.c
    M lib/db/dbmi_driver/d_version.c
    M lib/db/dbmi_driver/driver.c
    M lib/db/dbmi_driver/driver_state.c
    M lib/db/dbmi_driver/procs.h
    M lib/db/sqlp/alloc.c
    M lib/db/sqlp/print.c
    M lib/db/sqlp/sql.c
    M lib/db/sqlp/test/sqlptest.c
    M lib/db/stubs/add_col.c
    M lib/db/stubs/bindupdate.c
    M lib/db/stubs/close_cursor.c
    M lib/db/stubs/create_index.c
    M lib/db/stubs/create_table.c
    M lib/db/stubs/createdb.c
    M lib/db/stubs/delete.c
    M lib/db/stubs/deletedb.c
    M lib/db/stubs/desc_table.c
    M lib/db/stubs/drop_col.c
    M lib/db/stubs/drop_index.c
    M lib/db/stubs/drop_table.c
    M lib/db/stubs/execute.c
    M lib/db/stubs/fetch.c
    M lib/db/stubs/finddb.c
    M lib/db/stubs/insert.c
    M lib/db/stubs/list_index.c
    M lib/db/stubs/list_tables.c
    M lib/db/stubs/listdb.c
    M lib/db/stubs/open_insert.c
    M lib/db/stubs/open_select.c
    M lib/db/stubs/open_update.c
    M lib/db/stubs/opendb.c
    M lib/db/stubs/priv.c
    M lib/db/stubs/rows.c
    M lib/db/stubs/update.c
    M lib/display/clip.c
    M lib/display/clip.h
    M lib/display/cnversions.c
    M lib/display/draw2.c
    M lib/display/icon.c
    M lib/display/r_raster.c
    M lib/display/raster.c
    M lib/display/raster2.c
    M lib/display/setup.c
    M lib/display/symbol.c
    M lib/display/tran_colr.c
    M lib/display/window.c
    M lib/driver/box.c
    M lib/driver/color.c
    M lib/driver/draw.c
    M lib/driver/driver.h
    M lib/driver/driverlib.h
    M lib/driver/erase.c
    M lib/driver/font.c
    M lib/driver/font2.c
    M lib/driver/font_freetype.c
    M lib/driver/get_t_box.c
    M lib/driver/graph.c
    M lib/driver/init.c
    M lib/driver/line_width.c
    M lib/driver/move.c
    M lib/driver/parse_ftcap.c
    M lib/driver/path.c
    M lib/driver/path.h
    M lib/driver/raster.c
    M lib/driver/set_window.c
    M lib/driver/text.c
    M lib/driver/text2.c
    M lib/driver/text3.c
    M lib/dspf/cell_table.c
    M lib/dspf/cube_io.c
    M lib/dspf/dspf_header.c
    M lib/dspf/print_info.c
    M lib/dspf/struct_copy.c
    M lib/dspf/viz.h
    M lib/external/ccmath/ccmath.h
    M lib/external/ccmath/chouse.c
    M lib/external/ccmath/chousv.c
    M lib/external/ccmath/cmattr.c
    M lib/external/ccmath/cmcpy.c
    M lib/external/ccmath/cminv.c
    M lib/external/ccmath/cmmul.c
    M lib/external/ccmath/cmmult.c
    M lib/external/ccmath/cmprt.c
    M lib/external/ccmath/csolv.c
    M lib/external/ccmath/cvmul.c
    M lib/external/ccmath/hconj.c
    M lib/external/ccmath/heigval.c
    M lib/external/ccmath/heigvec.c
    M lib/external/ccmath/hevmax.c
    M lib/external/ccmath/hmgen.c
    M lib/external/ccmath/matprt.c
    M lib/external/ccmath/qrecvc.c
    M lib/external/ccmath/trncm.c
    M lib/external/ccmath/unitary.c
    M lib/external/ccmath/utrncm.c
    M lib/external/ccmath/utrnhm.c
    M lib/external/shapelib/dbfopen.c
    M lib/external/shapelib/safileio.c
    M lib/external/shapelib/shapefil.h
    M lib/external/shapelib/shpopen.c
    M lib/gis/G.h
    M lib/gis/adj_cellhd.c
    M lib/gis/alloc.c
    M lib/gis/aprintf.c
    M lib/gis/area.c
    M lib/gis/area_ellipse.c
    M lib/gis/area_poly1.c
    M lib/gis/area_sphere.c
    M lib/gis/ascii_chk.c
    M lib/gis/asprintf.c
    M lib/gis/basename.c
    M lib/gis/bres_line.c
    M lib/gis/clicker.c
    M lib/gis/cmprbzip.c
    M lib/gis/cmprlz4.c
    M lib/gis/cmprrle.c
    M lib/gis/cmprzlib.c
    M lib/gis/cmprzstd.c
    M lib/gis/color_rules.c
    M lib/gis/color_str.c
    M lib/gis/commas.c
    M lib/gis/compress.c
    M lib/gis/compress.h
    M lib/gis/copy_dir.c
    M lib/gis/copy_file.c
    M lib/gis/datum.c
    M lib/gis/debug.c
    M lib/gis/distance.c
    M lib/gis/done_msg.c
    M lib/gis/endian.c
    M lib/gis/env.c
    M lib/gis/error.c
    M lib/gis/file_name.c
    M lib/gis/find_etc.c
    M lib/gis/find_file.c
    M lib/gis/find_rast.c
    M lib/gis/geodesic.c
    M lib/gis/geodist.c
    M lib/gis/get_ellipse.c
    M lib/gis/get_projinfo.c
    M lib/gis/get_window.c
    M lib/gis/getl.c
    M lib/gis/gisbase.c
    M lib/gis/gisdbase.c
    M lib/gis/gisinit.c
    M lib/gis/handler.c
    M lib/gis/ilist.c
    M lib/gis/intersect.c
    M lib/gis/is.c
    M lib/gis/key_value1.c
    M lib/gis/key_value2.c
    M lib/gis/key_value3.c
    M lib/gis/key_value4.c
    M lib/gis/legal_name.c
    M lib/gis/line_dist.c
    M lib/gis/list.c
    M lib/gis/ll_format.c
    M lib/gis/ll_scan.c
    M lib/gis/locale.c
    M lib/gis/location.c
    M lib/gis/lrand48.c
    M lib/gis/ls.c
    M lib/gis/ls_filter.c
    M lib/gis/lz4.c
    M lib/gis/lz4.h
    M lib/gis/make_loc.c
    M lib/gis/make_mapset.c
    M lib/gis/mapcase.c
    M lib/gis/mapset.c
    M lib/gis/mapset_msc.c
    M lib/gis/mapset_nme.c
    M lib/gis/mkstemp.c
    M lib/gis/myname.c
    M lib/gis/named_colr.c
    M lib/gis/nme_in_mps.c
    M lib/gis/open.c
    M lib/gis/open_misc.c
    M lib/gis/parser.c
    M lib/gis/parser_dependencies.c
    M lib/gis/parser_help.c
    M lib/gis/parser_html.c
    M lib/gis/parser_interface.c
    M lib/gis/parser_json.c
    M lib/gis/parser_local_proto.h
    M lib/gis/parser_rest.c
    M lib/gis/parser_script.c
    M lib/gis/parser_standard_options.c
    M lib/gis/parser_wps.c
    M lib/gis/paths.c
    M lib/gis/percent.c
    M lib/gis/pi.h
    M lib/gis/plot.c
    M lib/gis/pole_in_poly.c
    M lib/gis/popen.c
    M lib/gis/proj3.c
    M lib/gis/put_window.c
    M lib/gis/putenv.c
    M lib/gis/radii.c
    M lib/gis/rd_cellhd.c
    M lib/gis/remove.c
    M lib/gis/rename.c
    M lib/gis/rhumbline.c
    M lib/gis/rotate.c
    M lib/gis/seek.c
    M lib/gis/short_way.c
    M lib/gis/sleep.c
    M lib/gis/snprintf.c
    M lib/gis/spawn.c
    M lib/gis/strings.c
    M lib/gis/tempfile.c
    M lib/gis/timestamp.c
    M lib/gis/token.c
    M lib/gis/units.c
    M lib/gis/user_config.c
    M lib/gis/verbose.c
    M lib/gis/view.c
    M lib/gis/win32_pipes.c
    M lib/gis/wind_2_box.c
    M lib/gis/wind_format.c
    M lib/gis/wind_in.c
    M lib/gis/wind_limits.c
    M lib/gis/wind_overlap.c
    M lib/gis/wind_scan.c
    M lib/gis/window_map.c
    M lib/gis/worker.c
    M lib/gis/wr_cellhd.c
    M lib/gis/writ_zeros.c
    M lib/gis/zone.c
    M lib/gmath/ATLAS_wrapper_blas_level_1.c
    M lib/gmath/blas_level_1.c
    M lib/gmath/blas_level_2.c
    M lib/gmath/blas_level_3.c
    M lib/gmath/brent.c
    M lib/gmath/ccmath_grass_wrapper.c
    M lib/gmath/dalloc.c
    M lib/gmath/del2g.c
    M lib/gmath/eigen_tools.c
    M lib/gmath/fft.c
    M lib/gmath/findzc.c
    M lib/gmath/gauss.c
    M lib/gmath/getg.c
    M lib/gmath/ialloc.c
    M lib/gmath/la.c
    M lib/gmath/lu.c
    M lib/gmath/max_pow2.c
    M lib/gmath/mult.c
    M lib/gmath/rand1.c
    M lib/gmath/solvers_classic_iter.c
    M lib/gmath/solvers_direct.c
    M lib/gmath/solvers_direct_cholesky_band.c
    M lib/gmath/solvers_krylov.c
    M lib/gmath/sparse_matrix.c
    M lib/gmath/symmetric_band_matrix.c
    M lib/gmath/test/bench_blas2.c
    M lib/gmath/test/bench_blas3.c
    M lib/gmath/test/bench_solver_direct.c
    M lib/gmath/test/bench_solver_krylov.c
    M lib/gmath/test/test_blas1.c
    M lib/gmath/test/test_blas2.c
    M lib/gmath/test/test_blas3.c
    M lib/gmath/test/test_ccmath_wrapper.c
    M lib/gmath/test/test_gmath_lib.h
    M lib/gmath/test/test_main.c
    M lib/gmath/test/test_matrix_conversion.c
    M lib/gmath/test/test_solvers.c
    M lib/gmath/test/test_tools.c
    M lib/gmath/test/test_tools_les.c
    M lib/gpde/N_gwflow.h
    M lib/gpde/N_heatflow.h
    M lib/gpde/N_pde.h
    M lib/gpde/N_solute_transport.h
    M lib/gpde/n_arrays.c
    M lib/gpde/n_arrays_calc.c
    M lib/gpde/n_arrays_io.c
    M lib/gpde/n_geom.c
    M lib/gpde/n_gradient.c
    M lib/gpde/n_gradient_calc.c
    M lib/gpde/n_gwflow.c
    M lib/gpde/n_heatflow.c
    M lib/gpde/n_les.c
    M lib/gpde/n_les_assemble.c
    M lib/gpde/n_parse_options.c
    M lib/gpde/n_solute_transport.c
    M lib/gpde/n_tools.c
    M lib/gpde/n_upwind.c
    M lib/gpde/test/test_arrays.c
    M lib/gpde/test/test_assemble.c
    M lib/gpde/test/test_geom.c
    M lib/gpde/test/test_gpde_lib.h
    M lib/gpde/test/test_gradient.c
    M lib/gpde/test/test_gwflow.c
    M lib/gpde/test/test_heat.c
    M lib/gpde/test/test_les.c
    M lib/gpde/test/test_main.c
    M lib/gpde/test/test_solute_transport.c
    M lib/gpde/test/test_tools.c
    M lib/htmldriver/box.c
    M lib/htmldriver/draw.c
    M lib/htmldriver/driver.c
    M lib/htmldriver/graph_clse.c
    M lib/htmldriver/graph_set.c
    M lib/htmldriver/htmlmap.h
    M lib/htmldriver/polygon.c
    M lib/htmldriver/text.c
    M lib/imagery/alloc.c
    M lib/imagery/eol.c
    M lib/imagery/find.c
    M lib/imagery/fopen.c
    M lib/imagery/georef.c
    M lib/imagery/georef_tps.c
    M lib/imagery/group.c
    M lib/imagery/iclass.c
    M lib/imagery/iclass_bands.c
    M lib/imagery/iclass_local_proto.h
    M lib/imagery/iclass_perimeter.c
    M lib/imagery/iclass_signatures.c
    M lib/imagery/iclass_statistics.c
    M lib/imagery/iscatt_core.c
    M lib/imagery/iscatt_structs.c
    M lib/imagery/list_gp.c
    M lib/imagery/list_subgp.c
    M lib/imagery/loc_info.c
    M lib/imagery/manage_signatures.c
    M lib/imagery/points.c
    M lib/imagery/ref.c
    M lib/imagery/sig.c
    M lib/imagery/sigset.c
    M lib/imagery/target.c
    M lib/imagery/title.c
    M lib/init/clean_temp.c
    M lib/init/lock.c
    M lib/init/run.c
    M lib/init/winlocale.c
    M lib/iostream/ami_stream.cpp
    M lib/iostream/mm.cpp
    M lib/iostream/mm_utils.cpp
    M lib/iostream/rtimer.cpp
    M lib/lidar/InterpSpline.c
    M lib/lidar/lidar.h
    M lib/lidar/raster.c
    M lib/lidar/zones.c
    M lib/linkm/dispose.c
    M lib/linkm/init.c
    M lib/linkm/new.c
    M lib/linkm/next.c
    M lib/linkm/test/linkm.c
    M lib/linkm/test/malloc.c
    M lib/linkm/test/speed.c
    M lib/linkm/test/speed2.c
    M lib/linkm/test/speed3.c
    M lib/linkm/test/try.c
    M lib/linkm/test/try2.c
    M lib/manage/add_elem.c
    M lib/manage/do_copy.c
    M lib/manage/do_list.c
    M lib/manage/do_rename.c
    M lib/manage/read_list.c
    M lib/manage/sighold.c
    M lib/nviz/change_view.c
    M lib/nviz/cplanes_obj.c
    M lib/nviz/draw.c
    M lib/nviz/exag.c
    M lib/nviz/lights.c
    M lib/nviz/map_obj.c
    M lib/nviz/nviz.c
    M lib/nviz/position.c
    M lib/nviz/render.c
    M lib/ogsf/gk.c
    M lib/ogsf/gk2.c
    M lib/ogsf/gp.c
    M lib/ogsf/gp2.c
    M lib/ogsf/gp3.c
    M lib/ogsf/gpd.c
    M lib/ogsf/gs.c
    M lib/ogsf/gs2.c
    M lib/ogsf/gs3.c
    M lib/ogsf/gs_bm.c
    M lib/ogsf/gs_norms.c
    M lib/ogsf/gs_query.c
    M lib/ogsf/gs_util.c
    M lib/ogsf/gsd_cplane.c
    M lib/ogsf/gsd_fonts.c
    M lib/ogsf/gsd_fringe.c
    M lib/ogsf/gsd_img_ppm.c
    M lib/ogsf/gsd_img_tif.c
    M lib/ogsf/gsd_label.c
    M lib/ogsf/gsd_legend.c
    M lib/ogsf/gsd_objs.c
    M lib/ogsf/gsd_prim.c
    M lib/ogsf/gsd_surf.c
    M lib/ogsf/gsd_views.c
    M lib/ogsf/gsd_wire.c
    M lib/ogsf/gsdiff.c
    M lib/ogsf/gsdrape.c
    M lib/ogsf/gsds.c
    M lib/ogsf/gsget.c
    M lib/ogsf/gsget.h
    M lib/ogsf/gsx.c
    M lib/ogsf/gv.c
    M lib/ogsf/gv2.c
    M lib/ogsf/gv3.c
    M lib/ogsf/gv_quick.c
    M lib/ogsf/gvd.c
    M lib/ogsf/gvl.c
    M lib/ogsf/gvl2.c
    M lib/ogsf/gvl3.c
    M lib/ogsf/gvl_calc.c
    M lib/ogsf/gvl_calc2.c
    M lib/ogsf/gvl_file.c
    M lib/ogsf/gvld.c
    M lib/ogsf/mc33_table.h
    M lib/ogsf/rgbpack.h
    M lib/ogsf/rowcol.h
    M lib/ogsf/trans.c
    M lib/pngdriver/box.c
    M lib/pngdriver/color.c
    M lib/pngdriver/color_table.c
    M lib/pngdriver/draw.c
    M lib/pngdriver/draw_bitmap.c
    M lib/pngdriver/draw_line.c
    M lib/pngdriver/driver.c
    M lib/pngdriver/erase.c
    M lib/pngdriver/graph_set.c
    M lib/pngdriver/line_width.c
    M lib/pngdriver/pngdriver.h
    M lib/pngdriver/point.c
    M lib/pngdriver/polygon.c
    M lib/pngdriver/raster.c
    M lib/pngdriver/read_png.c
    M lib/pngdriver/read_ppm.c
    M lib/pngdriver/write_png.c
    M lib/proj/convert.c
    M lib/proj/datum.c
    M lib/proj/do_proj.c
    M lib/proj/ellipse.c
    M lib/proj/get_proj.c
    M lib/proj/local_proto.h
    M lib/psdriver/box.c
    M lib/psdriver/color.c
    M lib/psdriver/draw.c
    M lib/psdriver/draw_bitmap.c
    M lib/psdriver/driver.c
    M lib/psdriver/graph_set.c
    M lib/psdriver/psdriver.h
    M lib/psdriver/raster.c
    M lib/psdriver/set_window.c
    M lib/raster/R.h
    M lib/raster/align_window.c
    M lib/raster/alloc_cell.c
    M lib/raster/auto_mask.c
    M lib/raster/cats.c
    M lib/raster/cell_stats.c
    M lib/raster/cell_title.c
    M lib/raster/cellstats_eq.c
    M lib/raster/close.c
    M lib/raster/color_compat.c
    M lib/raster/color_free.c
    M lib/raster/color_get.c
    M lib/raster/color_hist.c
    M lib/raster/color_insrt.c
    M lib/raster/color_look.c
    M lib/raster/color_org.c
    M lib/raster/color_out.c
    M lib/raster/color_rand.c
    M lib/raster/color_range.c
    M lib/raster/color_read.c
    M lib/raster/color_remove.c
    M lib/raster/color_rule.c
    M lib/raster/color_rule_get.c
    M lib/raster/color_rules.c
    M lib/raster/color_set.c
    M lib/raster/color_shift.c
    M lib/raster/color_write.c
    M lib/raster/color_xform.c
    M lib/raster/format.c
    M lib/raster/fpreclass.c
    M lib/raster/gdal.c
    M lib/raster/get_cellhd.c
    M lib/raster/get_row.c
    M lib/raster/get_row_colr.c
    M lib/raster/histo_eq.c
    M lib/raster/histogram.c
    M lib/raster/history.c
    M lib/raster/init.c
    M lib/raster/interp.c
    M lib/raster/null_val.c
    M lib/raster/open.c
    M lib/raster/put_row.c
    M lib/raster/put_title.c
    M lib/raster/quant.c
    M lib/raster/quant_io.c
    M lib/raster/quant_rw.c
    M lib/raster/range.c
    M lib/raster/rast_to_img_string.c
    M lib/raster/raster.c
    M lib/raster/raster_metadata.c
    M lib/raster/reclass.c
    M lib/raster/sample.c
    M lib/raster/set_window.c
    M lib/raster/vrt.c
    M lib/raster/window.c
    M lib/raster/window_map.c
    M lib/raster3d/alloc.c
    M lib/raster3d/cache.c
    M lib/raster3d/cache1.c
    M lib/raster3d/cachehash.c
    M lib/raster3d/cachehash.h
    M lib/raster3d/cats.c
    M lib/raster3d/changeprecision.c
    M lib/raster3d/changetype.c
    M lib/raster3d/close.c
    M lib/raster3d/color.c
    M lib/raster3d/defaults.c
    M lib/raster3d/doubleio.c
    M lib/raster3d/error.c
    M lib/raster3d/filecompare.c
    M lib/raster3d/filename.c
    M lib/raster3d/fpcompress.c
    M lib/raster3d/fpxdr.c
    M lib/raster3d/getblock.c
    M lib/raster3d/getvalue.c
    M lib/raster3d/gradient.c
    M lib/raster3d/header.c
    M lib/raster3d/headerinfo.c
    M lib/raster3d/history.c
    M lib/raster3d/index.c
    M lib/raster3d/keys.c
    M lib/raster3d/long.c
    M lib/raster3d/mask.c
    M lib/raster3d/maskfn.c
    M lib/raster3d/misc.c
    M lib/raster3d/null.c
    M lib/raster3d/open.c
    M lib/raster3d/open2.c
    M lib/raster3d/param.c
    M lib/raster3d/putvalue.c
    M lib/raster3d/range.c
    M lib/raster3d/raster3d_intern.h
    M lib/raster3d/region.c
    M lib/raster3d/resample.c
    M lib/raster3d/retile.c
    M lib/raster3d/rle.c
    M lib/raster3d/test/test_coordinate_transform.c
    M lib/raster3d/test/test_main.c
    M lib/raster3d/test/test_put_get_value.c
    M lib/raster3d/test/test_put_get_value_large_file.c
    M lib/raster3d/test/test_raster3d_lib.h
    M lib/raster3d/test/test_tools.c
    M lib/raster3d/tilealloc.c
    M lib/raster3d/tileio.c
    M lib/raster3d/tilemath.c
    M lib/raster3d/tilenull.c
    M lib/raster3d/tileread.c
    M lib/raster3d/tilewrite.c
    M lib/raster3d/volume.c
    M lib/raster3d/window.c
    M lib/raster3d/windowio.c
    M lib/raster3d/writeascii.c
    M lib/rowio/fileno.c
    M lib/rowio/forget.c
    M lib/rowio/get.c
    M lib/rowio/put.c
    M lib/rowio/release.c
    M lib/rowio/setup.c
    M lib/rst/data/dataquad.c
    M lib/rst/data/dataquad.h
    M lib/rst/interp_float/distance.c
    M lib/rst/interp_float/func2d.c
    M lib/rst/interp_float/init2d.c
    M lib/rst/interp_float/input2d.c
    M lib/rst/interp_float/interp2d.c
    M lib/rst/interp_float/interpf.h
    M lib/rst/interp_float/matrix.c
    M lib/rst/interp_float/minmax.c
    M lib/rst/interp_float/output2d.c
    M lib/rst/interp_float/point2d.c
    M lib/rst/interp_float/resout2d.c
    M lib/rst/interp_float/ressegm2d.c
    M lib/rst/interp_float/secpar2d.c
    M lib/rst/interp_float/segmen2d.c
    M lib/rst/interp_float/segmen2d_parallel.c
    M lib/rst/interp_float/vinput2d.c
    M lib/rst/interp_float/write2d.c
    M lib/rst/qtree/qtree.c
    M lib/rst/qtree/qtree.h
    M lib/segment/address.c
    M lib/segment/close.c
    M lib/segment/flush.c
    M lib/segment/format.c
    M lib/segment/get.c
    M lib/segment/get_row.c
    M lib/segment/init.c
    M lib/segment/local_proto.h
    M lib/segment/open.c
    M lib/segment/pagein.c
    M lib/segment/pageout.c
    M lib/segment/put.c
    M lib/segment/put_row.c
    M lib/segment/release.c
    M lib/segment/seek.c
    M lib/segment/setup.c
    M lib/stats/c_ave.c
    M lib/stats/c_count.c
    M lib/stats/c_divr.c
    M lib/stats/c_intr.c
    M lib/stats/c_kurt.c
    M lib/stats/c_max.c
    M lib/stats/c_maxx.c
    M lib/stats/c_median.c
    M lib/stats/c_min.c
    M lib/stats/c_minx.c
    M lib/stats/c_mode.c
    M lib/stats/c_percentile.c
    M lib/stats/c_range.c
    M lib/stats/c_reg.c
    M lib/stats/c_skew.c
    M lib/stats/c_stddev.c
    M lib/stats/c_sum.c
    M lib/stats/c_thresh.c
    M lib/stats/c_var.c
    M lib/stats/sort_cell.c
    M lib/symbol/read.c
    M lib/symbol/stroke.c
    M lib/temporal/lib/connect.c
    M lib/temporal/lib/default_name.c
    M lib/temporal/lib/map_list.c
    M lib/vector/Vlib/area.c
    M lib/vector/Vlib/area_pg.c
    M lib/vector/Vlib/array.c
    M lib/vector/Vlib/ascii.c
    M lib/vector/Vlib/box.c
    M lib/vector/Vlib/break_lines.c
    M lib/vector/Vlib/break_polygons.c
    M lib/vector/Vlib/bridges.c
    M lib/vector/Vlib/buffer.c
    M lib/vector/Vlib/buffer2.c
    M lib/vector/Vlib/build.c
    M lib/vector/Vlib/build_nat.c
    M lib/vector/Vlib/build_ogr.c
    M lib/vector/Vlib/build_pg.c
    M lib/vector/Vlib/build_sfa.c
    M lib/vector/Vlib/cats.c
    M lib/vector/Vlib/cindex.c
    M lib/vector/Vlib/clean_nodes.c
    M lib/vector/Vlib/close.c
    M lib/vector/Vlib/close_nat.c
    M lib/vector/Vlib/close_ogr.c
    M lib/vector/Vlib/close_pg.c
    M lib/vector/Vlib/color_read.c
    M lib/vector/Vlib/color_remove.c
    M lib/vector/Vlib/color_write.c
    M lib/vector/Vlib/constraint.c
    M lib/vector/Vlib/copy.c
    M lib/vector/Vlib/dangles.c
    M lib/vector/Vlib/dbcolumns.c
    M lib/vector/Vlib/dgraph.c
    M lib/vector/Vlib/dgraph.h
    M lib/vector/Vlib/e_intersect.c
    M lib/vector/Vlib/e_intersect.h
    M lib/vector/Vlib/field.c
    M lib/vector/Vlib/find.c
    M lib/vector/Vlib/geos.c
    M lib/vector/Vlib/geos_to_wktb.c
    M lib/vector/Vlib/graph.c
    M lib/vector/Vlib/handler.c
    M lib/vector/Vlib/header.c
    M lib/vector/Vlib/header_finfo.c
    M lib/vector/Vlib/hist.c
    M lib/vector/Vlib/init_head.c
    M lib/vector/Vlib/intersect.c
    M lib/vector/Vlib/intersect2.c
    M lib/vector/Vlib/legal_vname.c
    M lib/vector/Vlib/level.c
    M lib/vector/Vlib/level_two.c
    M lib/vector/Vlib/line.c
    M lib/vector/Vlib/list.c
    M lib/vector/Vlib/local_proto.h
    M lib/vector/Vlib/map.c
    M lib/vector/Vlib/merge_lines.c
    M lib/vector/Vlib/net_analyze.c
    M lib/vector/Vlib/net_build.c
    M lib/vector/Vlib/open.c
    M lib/vector/Vlib/open_nat.c
    M lib/vector/Vlib/open_ogr.c
    M lib/vector/Vlib/open_pg.c
    M lib/vector/Vlib/overlap.c
    M lib/vector/Vlib/overlay.c
    M lib/vector/Vlib/pg_local_proto.h
    M lib/vector/Vlib/poly.c
    M lib/vector/Vlib/read.c
    M lib/vector/Vlib/read_nat.c
    M lib/vector/Vlib/read_ogr.c
    M lib/vector/Vlib/read_pg.c
    M lib/vector/Vlib/read_sfa.c
    M lib/vector/Vlib/remove_areas.c
    M lib/vector/Vlib/remove_duplicates.c
    M lib/vector/Vlib/rewind.c
    M lib/vector/Vlib/rewind_nat.c
    M lib/vector/Vlib/rewind_ogr.c
    M lib/vector/Vlib/rewind_pg.c
    M lib/vector/Vlib/rtree_search.c
    M lib/vector/Vlib/select.c
    M lib/vector/Vlib/simple_features.c
    M lib/vector/Vlib/sindex.c
    M lib/vector/Vlib/snap.c
    M lib/vector/Vlib/tin.c
    M lib/vector/Vlib/window.c
    M lib/vector/Vlib/write.c
    M lib/vector/Vlib/write_nat.c
    M lib/vector/Vlib/write_ogr.c
    M lib/vector/Vlib/write_pg.c
    M lib/vector/Vlib/write_sfa.c
    M lib/vector/dglib/avl.c
    M lib/vector/dglib/avl.h
    M lib/vector/dglib/dgl.h
    M lib/vector/dglib/edgemgmt-template.c
    M lib/vector/dglib/examples/components.c
    M lib/vector/dglib/examples/cr_from_a.c
    M lib/vector/dglib/examples/cr_large_graph.c
    M lib/vector/dglib/examples/delnode.c
    M lib/vector/dglib/examples/minspan.c
    M lib/vector/dglib/examples/opt.c
    M lib/vector/dglib/examples/opt.h
    M lib/vector/dglib/examples/parse.c
    M lib/vector/dglib/examples/shortest_path.c
    M lib/vector/dglib/examples/span.c
    M lib/vector/dglib/examples/unflatten.c
    M lib/vector/dglib/examples/view.c
    M lib/vector/dglib/graph.c
    M lib/vector/dglib/graph.h
    M lib/vector/dglib/graph_v1.c
    M lib/vector/dglib/graph_v1.h
    M lib/vector/dglib/graph_v2.c
    M lib/vector/dglib/graph_v2.h
    M lib/vector/dglib/heap.c
    M lib/vector/dglib/heap.h
    M lib/vector/dglib/helpers.c
    M lib/vector/dglib/helpers.h
    M lib/vector/dglib/misc-template.c
    M lib/vector/dglib/nodemgmt-template.c
    M lib/vector/dglib/sp-template.c
    M lib/vector/dglib/span-template.c
    M lib/vector/dglib/tavl.c
    M lib/vector/dglib/tavl.h
    M lib/vector/dglib/tree.c
    M lib/vector/dglib/tree.h
    M lib/vector/dglib/type.h
    M lib/vector/dglib/v1-defs.h
    M lib/vector/dglib/v2-defs.h
    M lib/vector/diglib/allocation.c
    M lib/vector/diglib/angle.c
    M lib/vector/diglib/box.c
    M lib/vector/diglib/cindex.c
    M lib/vector/diglib/cindex_rw.c
    M lib/vector/diglib/file.c
    M lib/vector/diglib/frmt.c
    M lib/vector/diglib/head.c
    M lib/vector/diglib/inside.c
    M lib/vector/diglib/line_dist.c
    M lib/vector/diglib/linecros.c
    M lib/vector/diglib/list.c
    M lib/vector/diglib/plus.c
    M lib/vector/diglib/plus_area.c
    M lib/vector/diglib/plus_line.c
    M lib/vector/diglib/plus_node.c
    M lib/vector/diglib/plus_struct.c
    M lib/vector/diglib/poly.c
    M lib/vector/diglib/port_init.c
    M lib/vector/diglib/port_test.c
    M lib/vector/diglib/portable.c
    M lib/vector/diglib/prune.c
    M lib/vector/diglib/spindex.c
    M lib/vector/diglib/spindex_rw.c
    M lib/vector/diglib/struct_alloc.c
    M lib/vector/diglib/test.c
    M lib/vector/diglib/type.c
    M lib/vector/diglib/update.c
    M lib/vector/neta/articulation_point.c
    M lib/vector/neta/bridge.c
    M lib/vector/neta/centrality.c
    M lib/vector/neta/components.c
    M lib/vector/neta/flow.c
    M lib/vector/neta/path.c
    M lib/vector/neta/spanningtree.c
    M lib/vector/neta/timetables.c
    M lib/vector/neta/utils.c
    M lib/vector/rtree/card.c
    M lib/vector/rtree/card.h
    M lib/vector/rtree/docs/test.c
    M lib/vector/rtree/gammavol.c
    M lib/vector/rtree/index.c
    M lib/vector/rtree/index.h
    M lib/vector/rtree/indexf.c
    M lib/vector/rtree/indexm.c
    M lib/vector/rtree/io.c
    M lib/vector/rtree/node.c
    M lib/vector/rtree/rect.c
    M lib/vector/rtree/rtree.h
    M lib/vector/rtree/split.c
    M lib/vector/rtree/split.h
    M lib/vector/rtree/test_suite/test_basics.c
    M lib/vector/rtree/test_suite/test_main.c
    M lib/vector/rtree/test_suite/test_rtree_lib.h
    M lib/vector/vedit/break.c
    M lib/vector/vedit/cats.c
    M lib/vector/vedit/copy.c
    M lib/vector/vedit/delete.c
    M lib/vector/vedit/distance.c
    M lib/vector/vedit/extend.c
    M lib/vector/vedit/merge.c
    M lib/vector/vedit/move.c
    M lib/vector/vedit/render.c
    M lib/vector/vedit/select.c
    M lib/vector/vedit/snap.c
    M lib/vector/vedit/vertex.c
    M lib/vector/vedit/zbulk.c
  Log Message:
