[GRASS-git] [OSGeo/grass] d2317a: t.rast.list: Add CSV, JSON, YAML outputs (#2258)
Vaclav Petras noreply at github.com
Thu Mar 31 12:09:53 PDT 2022
  Branch: refs/heads/main
  Home:   https://github.com/OSGeo/grass
  Commit: d2317a2bb6b62a1863590519e404b47f2b3b3d57
      https://github.com/OSGeo/grass/commit/d2317a2bb6b62a1863590519e404b47f2b3b3d57
  Author: Vaclav Petras <wenzeslaus at gmail.com>
  Date:   2022-03-31 (Thu, 31 Mar 2022)
  Changed paths:
    M python/grass/temporal/list_stds.py
    M temporal/t.rast.list/t.rast.list.html
    M temporal/t.rast.list/t.rast.list.py
    R temporal/t.rast.list/test.t.rast.list.sh
    A temporal/t.rast.list/tests/conftest.py
    A temporal/t.rast.list/tests/t_rast_list_test.py
    A temporal/t.rast.list/testsuite/test_t_rast_list.sh
  Log Message:
* This adds CSV, JSON, and YAML output and generalizes the other outputs.
* Method is now meant only for different data gathering methods, not for the output formatting. method=cols and method=comma are now obsolete.
* All formatting is available with all methods.
* Most code is shared between the two main branches of code (simple list versus delta/gran methods code).
* Columns can be now specified for any option (previously only for cols/list and partially for comma/line output).
* The change is backwards compatible both on module interface level and on Python API level.
* Activate and fix old bash test (-i by t.register is not accepted without start_time).
