[GRASS-git] [OSGeo/grass] 719672: v.db.select: Add column names and types to JSON (#...
Vaclav Petras noreply at github.com
Wed Jul 19 06:51:37 PDT 2023
  Branch: refs/heads/main
  Home:   https://github.com/OSGeo/grass
  Commit: 719672d726ace7f1917c58b965513b80d15887f0
      https://github.com/OSGeo/grass/commit/719672d726ace7f1917c58b965513b80d15887f0
  Author: Vaclav Petras <wenzeslaus at gmail.com>
  Date:   2023-07-19 (Wed, 19 Jul 2023)
  Changed paths:
    M vector/v.db.select/main.c
    M vector/v.db.select/testsuite/test_v_db_select.py
    M vector/v.db.select/testsuite/test_v_db_select_json_csv.py
    M vector/v.db.select/v.db.select.html
  Log Message:
  v.db.select: Add column names and types to JSON (#3090)
The JSON output now has column names and types under info/columns.
The example in documentation does not include the unclear note about booleans (a discussion for another place).
A command to reproduce the example output is now included.
Documentation and test of the new functionality are included.
