awk help
Michael Shapiro shapiro at zorro.cecer.army.mil
Tue Aug 11 14:30:04 EDT 1992
Don't use awk to do this. Use pr:
	 pr -m -t -l1 -s' ' file1 file2
This will do what you want, except it adds one line at the end of its output
tht contains a single space. If you want to get rid of this last line
add a sed script to delete lines that have only a single space:
	 pr -m -t -l1 -s' ' x y | sed '/^ $/d'
|Could someone with with a greater knowledge of awk than  me  help
|me  out  with  a  short  script that will read two floating point
|numbers from two seperate files and write out a single file  with
|four values on each line ?
