can't find site files...
Chris Skelly chris at mqatmos.cic.mq.edu.au
Wed Feb 26 12:48:31 EST 1992
Shapiro writes:
>There was a bug in the 4.0 release of s.surf.idw. It aprobably will work if you
>specify the site file on the command line instead of letting the program prompt
>you for a name. If you find this to be true then check for this line in main.c
>and see if they are the same:
>    parm.input->gisprompt  = "old,site_lists,sites" ;
>What you'll probably see is that "site_lists" is mispelled  in your version.
Indeed!  This has to be the quickest fix in history...or I'm just running
a long streak of good luck!
Only...For some reason, even typing in the site name wouldn't work (of
course the name was 13 characters I could have typed it wrong).
Anyway, all is right.
cheers,
chris
