X terminal and Grass
Hal Mueller hmueller at orca.tamu.edu
Tue May 5 13:27:20 EDT 1992
We're running a Tektronix XP29 (1280x1024) off a Sparc2 and sometimes
a 3/60.  It works well and looks pretty good, but is not as crisp as I'd
like for text applications.
We tested an older (early 1991) NCD terminal and rejected it because
the resolution wasn't high enough.  Since this time they've introduced
some new models, though.
All vendors we had contact with were willing to loan us a terminal for
tests.  You should try this.
Hal Mueller			If guns are outlawed, only the government
hmueller at orca.tamu.edu          will have guns.
