v.in.arc
Richard O. Flamm r6f at mtqgrass.esd.ornl.gov
Tue May 19 13:15:20 EDT 1992
v.in.arc
 There is a bug in v.in.arc.  The text-label
file has 2 columns you need to be concerned about,
the attribute number and the attribute ID.  These are
columns 4 and 5 in the example (top 4 lines of text-label file) below:
 $RECNO           AREA    PERIMETER MABSOIL# MABSOIL-ID GSL-NAME
      1   -1.13958E+11  1786085.000     1        0
      2   2.861446E+09  413,939.875     2      298      NC092
      3   7.340246E+08  190,118.031     3      318      NC093
 If the number and ID values have greater than 3 digits, then
ARC-INFO inserts a comma (e.g., 1,005).  These commas have to
be removed for v.in.arc. to work.
Richard
