Vector fixes for RS6000
Michael Shapiro shapiro at zorro.cecer.army.mil
Tue Sep 1 18:31:28 EDT 1992
(1) You have the old version of v.to.rast. Get the newest from moon.
(2) There are vector library changes that you have to install first, then
recompile vector modules (d.vect, v.support, v.to.rast, etc).
|Hello,
|I just downloaded the grass fixes for v.digit and the entire grass source
|code. It took me about 6 hours to build it on our IBM RS/6000 320H (32 MB RAM
|64 MB swap space)  I was told that the fixes to the problems we have been
|experiencing were done, and on the moon.  Unfortunately, the problems we
|have been  having still exist!  Some examples of problems we have been having
|are detailed below.
|v.to.rast:
|	Loading vector information.
| REGION
|   north:  247136.74,   south:  244512.10
|   east: 2815605.90,   west: 2813538.99
|   rows: 80,   cols: 63,   total:    5040.00
|Size of tmpfile 5040
|Step 1: Calculating Areas...           ERROR: G_malloc: out of memory
|d.vect:
|	The display function only works if you have not run v.support.
|        If you run v.support you get an out of memory error.
|Does anyone have any vector program (v.*) working correctly on an RS/6000
|running AIX 3.2 (X11R4)?  If you do can I get a copy of your executables
|and or source files?
|Thanks!
|-Lee Thomas
Michael
