No subject
    Net.Noise owner
    news at max.cecer.army.mil
    Fri Mar 26 01:46:54 EST 1993
Newsgroups: info.grass.programmer
Path: zorro.cecer.army.mil!shapiro
From: shapiro at zorro.cecer.army.mil (Michael Shapiro)
Subject: Re: popen
Message-ID: <C4HHI3.Lw8 at news.cecer.army.mil>
Sender: news at news.cecer.army.mil (Net.Noise owner)
Organization: US Army Corps of Engineers Construction Engineering Research Labs
References: <01GW74LL9K6Q8Y5ZX0 at delphi.com>
Date: Fri, 26 Mar 1993 06:46:50 GMT
Lines: 30
In <01GW74LL9K6Q8Y5ZX0 at delphi.com> DOTSON at delphi.com writes:
>I have been having a good deal of success compiling GRASS 4.0 under
>Linux.  I did come across a problem that someone
>may be able to solve quickly before I tear into the code.
>A function "popen" is defined in ....../libes/gis.  This function is
>also part of the standard gcc library and since it is written
>in ANSII C came up as an error because of incompatable types.  What is
>the purpose of a custon "popen"?  Does it duplicate existing
>functionallity of the "built-in" version?
>I renamed the GRASS defined version "p_open" so that I counld continue
>the build.  Does every reference to "popen" refer to the GRASS defined
>version or do some refer to the built-in version?
>Thanks,
>Doug Dotson
>dotson at delphi.com
In early version of GRASS we had problem with the system supplied popen()
trying to have two popens() at the same time. So I rewrote it and
put it in the gis library. We have renamed it G_popen() in 4.1.
I think the system popen() has been long since fixed since then so
we/you could probably eliminate the popen() from the library and
things will work. But your solution effectively does this.
Michael Shapiro U.S. Army CERL
Environmental Division
