Planning of Image Processing
Yile Wang {regular} wangyi at malamute.msu.edu
Mon Apr 18 12:47:33 EDT 1994
In article <Pine.3.89.9404181756.A15663-0100000 at scanner.frw.uva.nl>, martijn at scanner.frw.uva.nl writes:
|> Hi Marek,
|> 	have a look at `Khoros', an image processing application builder
|> in the public domain ---> ftp.eece.unm.edu.
Khoros is a visual programming environment.
|> Martijn van Leusen
|> On Mon, 18 Apr 1994, Marek Hatala wrote:
|> > Hi folks,
|> > I am involved in building Planning Expert System for Image Analysis Processes.
|> > The system would be able to design the script containing image processing
|> > procedures which fulfill the given goal. The information about some related
|> > work in this field will be greatly appreciate. Thanks in advance.
|> > Regards, Marek
|> > Marek Hatala              (hatala at ccsun.tuke.sk)
|> > Dept. of Cybernetics and Artificial Intelligence
|> > Technical University,  Letna 9/B,  041 20 Kosice
|> > SLOVAKIA (Central Europe :-)   fax: +42 95 32748
