projection conversion from state plane to utm
Kenn Gardels (CEDR-REGIS) gardels at ced.berkeley.edu
Tue Jan 25 14:13:25 EST 1994
We are trying to project a vector file from california state plane, zone iii,
to UTM.  The source location is defined as zone 403, which is a lambert
conformal conic projection (as defined in etc/projections).  v.proj returns
an error
	major axis, radius = 0, or not spec'ed
	cannot initializa pj
The first error comes from src/libes/proj/pj_init.c in routine pj_param, which
then produces the second line from get_proj.c.
Before I try and figure out the proj code, which can be a little dense, I'm
wondering if anyone else has had a similar problem, if you have any ideas
about how to fix this, or if I'm missing a configuration step.
Here is the source location's PROJ_INFO file:
proj: lcc
a: 0.63782064e+07
es: 0.6768657997291094e-02
x_0: 0.6096012192024384e+06
y_0: 0
lon_0: 120d30'w
lat_0: 36d30'n
lat_1: 38d26'n
lat_2: 37d4'n
Thanks,
-kenn
| Kenn Gardels                     Tel +01 (510) 642-9205                      |
| CEDR - 390 Wurster Hall          Fax +01 (510) 643-5571                      |
| University of California         Internet  gardels at ced.berkeley.edu          |
| Berkeley, CA  94720              Bitnet    gardels at UCBCED                    |
