Compilation error for Solaris 2.3
James Darrell McCauley mccauley at ecn.purdue.edu
Thu Oct 13 06:46:16 EDT 1994
Grass package (grass at sun1.bham.ac.uk) writes on 5 Oct 94:
>Following the instructions in the grass4.1 installation manual, I managed
>as far as section 7.6, where the actual compilation starts. After a few
>minutes, my GISGEN script returns the following error message and halts:
>intr_char.c: In function `G_intr_char':
>intr_char.c:17: storage size of `buf' isn't known
>intr_char.c:19: `TIOCGETC' undeclared (first use this function)
>intr_char.c:19: (Each undeclared identifier is reported only once
>intr_char.c:19: for each function it appears in.)
>make: Fatal error: Command failed for target `OBJ.sun4/intr_char.o'
sounds like you don't have
USE_TERMIO          = -DUSE_TERMIO
in your CMD/head file. You also need:
TERMLIB             = -ltermlib
CURSES              = -lcurses $(TERMLIB)
>Martijn van Leusen
--Darrell
