compiling xgrass under Irix5.2
Bill Brown brown at ginko.cecer.army.mil
Wed Oct 26 09:41:49 EDT 1994
Compile notes for IRIX 5.2
A few compile problems:
When running the setup script I got complaints about some libraries
not being found - just ignore them.  The script looks for certain
names and can't find them, but cc seems to know to look for the
shared version of the library.
To fix the i.points, i.ortho.photo, i.vpoints problem:
make the function "screen" in the files "mark.c" a non-static function.
(Just delete the keyword "static" where the function is defined)
These files need to get this fix:
src/imagery/i.points/mark.c
src.alpha/imagery/i.ortho.photo/photo.2image/mark.c
src.alpha/imagery/i.ortho.photo/photo.2target/mark.c
src.alpha/imagery/i.vpoints/mark.c
To compile xgrass, I needed to use these XCFLAGS:
XCFLAGS             = -D_NO_PROTO -DXM_1_1_BC -Umips
To compile v.digit, I needed to remove this dependancy from the Gmakefile:
menus.o: menus.i
Everything else compiled OK.
xdigit did not work correctly when run.  To fix I added this test in the
function init_graphics() in the file src/xgrass/xdigit/draw.c : (~line 76)
    if(XtIsRealized(canvas)){
	/* ...body of function... */
There also seems to be a problem in v.support - actually when v.support
calls v.build, get a core dump.  I haven't figured out why this is
happening, so I'm using the IRIX 4.0.5 executable of v.build.  I put this
on moon.cecer.army.mil as /grass/incoming/v.build.sgi
Get this binary & copy it to GISBASE/etc/v.build
I don't have any digitizers to set up, so didn't try that ( I do use
digitizer "none" ).   I also don't have any plotters.
This is the head file I used:
CC                  = cc
ARCH                = sgi5
GISBASE             = /GRASS.bin/4.1/sgi5
UNIX_BIN            = /usr/local/bin
DEFAULT_DATABASE    = /data/foghorn/4.0
DEFAULT_LOCATION    = spearfish
COMPILE_FLAGS       = -O -cckr
LDFLAGS             = -s
XLDFLAGS            = -lPW
XINCPATH            =
XMINCPATH           =
XLIBPATH            =
XTLIBPATH           = -L/usr/lib
XMLIBPATH           = -L/usr/lib
XLIB                = -lX11
XTLIB               = -lXt
XMLIB               = -lXm
XEXTRALIBS          = -lPW
TERMLIB             = -ltermlib
CURSES              = -lcurses $(TERMLIB)
MATHLIB             = -lm
#                   LIBRULE = ar ruv $@ $?
#                   LIBRULE = ar ruv $@ $?; ranlib $@
#                   LIBRULE = ar ruv $@ $?; ar ts $@
#                   LIBRULE = ar rc $@ `lorder $(OBJ) | tsort`
USE_TERMIO          = -DUSE_TERMIO
USE_MTIO            = -DUSE_MTIO
USE_FTIME           =
DIGITFLAGS          = -DUSE_SETREUID -DUSE_SETEUID -DUSE_SETPRIORITY
VECTLIBFLAGS        =
GETHOSTNAME         = -DGETHOSTNAME_OK
XDRLIB = -lsun
Bill Brown				e-mail: brown at zorro.cecer.army.mil
USACERL - ECS				phone:  (217) 352-6511 ext 7676
PO Box 9005
Champaign, IL  61826-9005
See our visualization demo at URL:
http://www.cecer.army.mil/grass/viz/VIZ.html
