Adding a site to a map - amongst other things
Casey Claiborne mskc at io.com
Fri Aug 25 08:00:00 EDT 1995
Hello -
        I had wanted to ask 2 questions.
1) How does one add a site to a map. I saw a directory called "sites" in the
        "spearfish" sample data. I wanted to add sites to the "global" sample
        data but this directory did not exist there. I have seen routines that
        allow one to display site -ex: d.sites, d.points, etc. but I have not
        located one that will allow you to add a site to a sitefile - or even t
o
        create a site file.
2) How can one overlay two or more rasters in the display window.-e.g. I
        have raster file 1 and raster file 2 and I would like to place
raster 2 on
        top of raster 1.
Thanks in advance
Casey
One must note the importance of setting reasonable and achievable goals for
                    "If you aim for nothing, you'll hit it every time"
                               -Theodore Roosevelt
