Converting Arc 7.0.2 to Grass
Malcolm Williamson malcolm at cast.uark.edu
Thu Jan 26 12:06:07 EST 1995
> I am not able to get v.in.arc to recognize more than one column in
> the .txt file -- I can't understand what's wrong since it looks fine to
> a text editor.
> Has anyone successfully done this conversion and managed to keep attribute
> values intact?
> Neel Smith
> smith at hcacad.holycross.edu
Neel,
I'm not sure that I understand your question properly. I believe that v.in.arc
only allows you to select one column for the actual attribute; if you want
multiple attributes, you'll have to import the coverage into multiple GRASS
vector layers, specifying different attribute columns each time.
Support your local OGIS!! :)
Malcolm D. Williamson - GIS Specialist           E-mail: malcolm at cast.uark.edu
Center for Advanced Spatial Technologies      Telephone: (501) 575-6159
Ozark Rm. 12                                        Fax: (501) 575-5218
University of Arkansas
Fayetteville, AR 72701
