Calcomp digitizer
cas22 at newsstand.cit.cornell.edu cas22 at newsstand.cit.cornell.edu
Sat Nov 18 07:00:00 EST 1995
> This was sent to me, by Susan Huse, about a week ago, and it works fine
> for me, on a Sparc 10 with SunOS 4.1.something, with a Calcomp Drawing
> Board III.  You want to put this in the
> $GISBASE/etc/digitizers directory, and edit the $GISBASE/etc/digcap
> file accordingly.
> Tim.
> # Calcomp 9500 digitizer, ASCII format 6
> # Originally build and tested by
> #  Terry Baker and David Gerdes  USA-CERL  1992
> # Modified for use with Calcomp 2000 with ASCII emulation
> #  at DRW/DOP config is stored in set 3 (click config, restore 3, exit)
> #  Sue Huse, James Ganong, Kenn Gardels
Thanks Tim!  It worked for me too.  Turns out, SunOS4.1.1 = Solaris 1
which works out fine.
Jan.
